Povratak   PC Ekspert Forum > Računala > Storage > Mediji
Staro 18.02.2023., 13:32   #1021
banjodido
banjodido's Avatar
Lokacija: Agram
Postovi: 142
Ima kakva akcija za neki USB3 stick, 32-64 GB? Za prebacivanje datoteka 500 MB do nekih 1GB? Ne mora biti ultrabrz ali da bude pouzdan.
Sent from my KB2003 using Tapatalk
"Life is not a journey to the grave with the intention of arriving safely in one pretty and well preserved piece, but to skid across the line broadside, thoroughly used up, worn out, leaking oil, shouting GERONIMO!"
banjodido je offline   Reply With Quote
Staro 19.02.2023., 13:29   #1022
Dottore
Dottore's Avatar
Postovi: 7,736
Pregledaj prethodne postove i naći češ što te zanima.
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 02.03.2023., 15:27   #1023
imaticx
Default
imaticx's Avatar
Lokacija: Požega
Postovi: 1,520
Trebam neki usb otporan na udarce (bio bi na kljucevima), da nije neki prevelik i da se moze lako otkvaciti kad ga moram par puta dnevno spojiti na komp. Imao sam nekog malog zeljeznog samsunga, ali je trajao ni mjesec dana. Prije je bio onaj Voyager, stvarno je bio ok
Staro 02.03.2023., 18:20   #1024
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,737
Jel te ovaj Samsung iznevjerio?
It works through it all with a waterproofą, shock-proof˛, temperature-proofł, magnet-proof⁴, and X-ray-proof⁵
Staro 02.03.2023., 18:44   #1025
imaticx
Default
imaticx's Avatar
Lokacija: Požega
Postovi: 1,520
Autor kopija Pregled postova
Da, bas taj Nije ni ispadao ni nista, normalno koristenje, jednostavno prestao raditi
Staro 03.03.2023., 21:25   #1026
Dottore
Dottore's Avatar
Postovi: 7,736
Autor imaticx Pregled postova
Jesi li reklamirao ako ima garanciju?
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 04.03.2023., 07:33   #1027
imaticx
Default
imaticx's Avatar
Lokacija: Požega
Postovi: 1,520
Autor Dottore Pregled postova
Jesam, ali nisu imali isti takav, pa sam uzeo Sandisk Ultra mislim, ali on je prevelik za kljuceve. Znaci i dalje je preporuka taj samsung? Probati opet?
Staro 04.03.2023., 18:05   #1028
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,737
Ako ti brzina nije prioritet, uzmi neki minijaturni model.
Mislim da je taj Samsung dobar uređaj, brz, ima dobru disipaciju topline pa ne pati od throttlanja ko te minijature.
Imam ih dva i nikakvih problema.
Staro 02.04.2023., 10:28   #1029
Postovi: 34,131
Da podijelim svoja iskustva sa Kingston DT Micro 128Gb stickom. Nezadovoljan sam. Dok imaš jednu sesiju prebacivanaj podataka na njega, još je ok. Ako dodaš još jednu sesiju, uspori se do pakla. Ne daj Bože da staviš istovremeno više sesija.
Staro 02.04.2023., 10:44   #1030
Dottore
Dottore's Avatar
Postovi: 7,736
Autor coconut Pregled postova
Možeš li nabaciti test? Imam takav pa usporedi rezultate gore.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 06.04.2023., 15:25   #1031
theo
theo's Avatar
Datum registracije: Dec 2012
Postovi: 69
Kupio sam na akciji u Sancta Domenici Sandisk Ultra Luxe 128 Gb za 100kn, brzina mu je stabilnih 36-40 Mb/s nakon pocetnih 70 mb/s, grije se, al nista pretjerano. Metalan je i mali. Preporuka ako ne trebate ultra brzine.
theo je offline   Reply With Quote
Staro 06.04.2023., 15:28   #1032
dakky
Uptime freak
dakky's Avatar
Lokacija: Ri, Cro
Postovi: 2,968
Stavi kopirati vise od 10 GB pa onda vidi brzinu. Pusti sinteticke testove.
Kad se napuni buffer, onda brzina padne, tako je na svim jeftikanerima.
Staro 06.04.2023., 15:57   #1033
theo
theo's Avatar
Postovi: 69
Stavio sam kopirati Premiere projekt od 80Gb.
Prvo je 70 kad buffer nije pun, dalje je 36-40. Ali, evo sad nakon 50-ak Gb prijenosa je palo na 24 Mb/s, a i topliji je nego prije, throttla.
Meni je to oke za te pare, vidio sam horor priče da ti jeftini znaju biti i 10 Mb/s kad se zagriju, al ovo mi je zadovoljavajuće. Nisam znao što kupiti u tom cjenovnom rangu pa eto možda nekom pomogne.
Staro 06.04.2023., 15:58   #1034
dakky
Uptime freak
dakky's Avatar
Lokacija: Ri, Cro
Postovi: 2,968
Je, super, za te novce možda se i ja zaletim po jednog. Odlična cijena i brzina. Meni je i 24 MB/s sasvim OK, dok god ne ide što kažeš na 10...
Staro 06.04.2023., 19:42   #1035
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,614
ja sam jučer uzeo ovaj u sancti https://www.sancta-domenica.hr/usb-s...56be3-apc.html
bio je 40ak€, sa nekim kodom koji više nije aktivan
kopirao sam 196gb u komadu, vruć je ful ali ispod 180 nije pao
Zadnje izmijenjeno od: mamutarka. 06.04.2023. u 21:01.
Staro 06.04.2023., 21:28   #1036
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,737
Svaka im čast, fino su ga apgrejdali, moj 32GB Bar (prijašnja generacija) ide do najviše 25MBs i ostane tamo. Ajd barem ne pada, tješim se.
Read je 200, instalirao mi je windowse u pet minuta.
Uglavnom, veliko i aluminijsko mora biti, inače throttlanje ne gine.
Staro 06.04.2023., 21:32   #1037
Dottore
Dottore's Avatar
Postovi: 7,736
Odlično. Cijena je kao pristupačna.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 25.04.2023., 17:21   #1038
nepalac
Datum registracije: Feb 2022
Lokacija: EU
Postovi: 868
Kupovao neke stvari na amazonu pa uzeo usput i njihov amazon basics usb stick 128GB:
https://www.amazon.de/dp/B0B6148YKN?...t_details&th=1
Ovo su brzine:
Čini mi se ok za tih 12 eura.
Staro 25.04.2023., 20:03   #1039
Romano.Cule
Outer Space
Romano.Cule's Avatar
Lokacija: Vinkovci
Postovi: 852
Ovo je kralj USB stickova - Adata elite ue800.
https://www.memoryc.com/42316-512gb-...ash-drive.html
1GB read/write. Za one s plićim djepom tu su i verzije sa 128 i 256 GB
Staro 25.04.2023., 20:29   #1040
nepalac
Lokacija: EU
Postovi: 868
To je nonsens.
Za 25 eura kupiš Kingston NV2 500GB i staviš ga u nvme kućište od 17-18 eura.
I za cca 45 eura imaš isto 1GB read/write.
Ajd, jedino što je stick koji cm manjih dimenzija i ne treba ti kabel, pa je praktičniji.
Staro 25.04.2023., 20:35   #1041
Romano.Cule
Outer Space
Lokacija: Vinkovci
Postovi: 852
Po tvojoj logici nema vise ni smisla kupovati USB stickove. A mozda ni nema. Ja sam uzeo taj adata u800 i radi ko sisa.
Staro 25.04.2023., 20:44   #1042
nepalac
Lokacija: EU
Postovi: 868
Pa za 70 eura najbolje da ne radi dobro
I još ne znam jel ide kakva poštarina na to...
Ali uglavnom, kad su veći kapaciteti u pitanju (već od 250GB) po meni je bolje ići na nvme ssd u kućište, ssd-ovi su sad jako jeftini.
Ja sam si napravio par komada, na njih trpam backup i sve i svašta...
Brzine max, kućišta su stvarno mala, čak mi i spajanje kabelom više paše jer nekad nema mjesta za te široke i debele stickove...
I uvijek možeš po potrebi šaltat te ssd-ove u PC, laptop, druga kućišta itd...
Staro 25.04.2023., 22:22   #1043
dadoremix
dadoremix's Avatar
Postovi: 4,780
i imas usb A .. moj komp relativno nov, al mislim da imam 1 usb 1 na matični .. i šta sad ..
a hub mi usb 3.0 .. al nema C model ..
dadoremix je online   Reply With Quote
Staro 26.04.2023., 10:08   #1044
Night
Lokacija: Dbk
Postovi: 1,335
Autor Romano.Cule Pregled postova
Izgleda mi kao USB kućište sa uključenim m.2 NVME diskom, a i brzine su takve.
Staro 28.06.2023., 17:23   #1045
Postovi: 10,426
SLC stickovi, kupuje to jos itko? Htio bi par komada, pa me zanima je li Aliekspres i dalje jedino mjesto gdje ih se moze uzeti za neke ne prevelike pare?
Staro 29.06.2023., 10:16   #1046
medo
#erase startup-config
medo's Avatar
Postovi: 3,733
Imao sam par njih za backup konfe i logova na bare metalu na mjestima koja su često offline. Skupo i sporo. Rade.
Staro 28.08.2023., 09:52   #1047
tomasini_
tomasini_'s Avatar
Lokacija: Usa
Postovi: 1,164
može li mi netko preporučiti dual usb stick (128 ili 256 gb) - dakle stick koji ima usb c i usb a izlaz? namjena bi bila za dj-ing tako da je poželjno da je malo brži. zasad sam pronašao ovaj sandisk, jel to sporo?
divovski kompjuteri
tomasini_ je offline   Reply With Quote
Staro 21.12.2023., 17:20   #1048
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,737
2TB za 100 baksi, nije samo cijena čudo već, vjerovali ili ne, nije s Aliexpressa.
Staro 21.12.2023., 18:57   #1049
Dottore
Dottore's Avatar
Postovi: 7,736
Koliko vidim, bit će problema sa temperaturom. Kao i Kingston.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 21.12.2023., 19:16   #1050
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,737
Cjepidlako.
Do sada smo imali samo aliexpress lažnjake po takvoj cijeni, to je poanta.
