Staro 17.04.2023., 20:23   #151
Postovi: 8,655
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750
Staro 29.07.2023., 14:26   #152
Postovi: 8,655
AMD brings HIP SDK to Windows, supporting Consumer and Pro GPUs
AMD announced that it has released the HIP SDK for Windows intending to democratize GPU computing. You no longer must choose between Team CUDA or Team HIP, as the HIP SDK will help developers make CUDA applications run on AMD hardware. Notably, this new SDK will run on a select number of consumer Radeon GPUs. There has always been a significant divide between developers that work with GPU-accelerated applications. Some prefer nVidia's proprietary CUDA API, while others opt for the open-source HIP API. The HIP SDK, part of AMD's ROCm platform, wants to bridge that gap, allowing developers to convert CUDA applications into C++ code that will work on nVidia and AMD graphics cards. ROCm targets HPC and AI applications, whereas HIP is for typical desktop applications.
AMD asserts that porting a CUDA application to HIP SDK isn't challenging since CUDA and HIP are based on C++. Furthermore, the HIP SDK provides tools to help developers speed up the process, such as the HIPIFY toolset that will convert CUDA code into portable HIP C++. The HIP SDK doesn't work miracles, such as optimizing code. That's still a manual task that you have to do by yourself. The HIP SDK works on 32-bit and 64-bit Windows operating systems, including Windows 10 (22H2), Windows 11 (22H2), and Windows Server 2022. According to AMD, the list of compatible graphics cards extends from workstation-grade to mobile gaming. AMD even brags about APUs being on the list. Of course, support also depends on the developer. The chipmaker cites an example of Blender HIP embracing AMD Radeon graphics cards going back to the Vega days.
AMD is still updating the compatibility list, but only ten Radeon graphics cards, between RDNA 3 and RDNA 2, are officially supported thus far. The Radeon Pro W7900, W7800, and W6800 hail from the Radeon Pro lineup. On the consumer end, the Radeon RX 7900 XTX, RX 7900 XT, RX 7600, RX 6950 XT, RX 6900 XT, RX 6800 XT, and RX 6800 support the HIP SDK. Offering HIP SDK on Windows is a milestone for AMD. Nonetheless, the chipmaker will continue to make HIP SDK better by adding new features in the future and making an effort to deliver updates on par with AMD Software: Pro Edition graphics driver.
Izvor: Tom's Hardware
Staro 04.10.2023., 16:50   #153
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,476
Slobodno me dodajte na PSN
Disco je online   Reply With Quote
Staro 08.04.2024., 23:19   #154
DragonSlayer
DragonSlayer's Avatar
Datum registracije: Nov 2012
Postovi: 724
Ola ljudi, nez dal da otvaram temu na softveru pa bu prvo ovdje pitao ak ima neki quick & easy fix, ugl 7900 XTX se kreša svake 2 minute neovisno. Probao reseat, RAMe shuffle napravit, mounting pressure na procu je dobar, sve stoji, ali "Display driver amduw23g stopped responding and has successfully recovered." ide svaki dan sada, od nez, prekjuče ja mislim.
Ugl, probao sam sve verzije drivera do 23.7.1 i sve isto. Heaven bench kao neki test pokrenem, i to može vrtit ali samo nasumično prdne.
Pitao sam kolege u ADMu i kažu jedno 30-40 dana da se servisira. Nekak mi treba komp za, well, skoro sve što radim pa mi je onda opcija jedino kupit zamjensku dok čekam, ali onda šta ću s njom?
Ugl, trebaju mi ideje.
Za modove, ak treba u novu temu samo pucajte.
https://forum.pcekspert.com/faq.php
DragonSlayer je offline   Reply With Quote
Staro 09.04.2024., 00:37   #155
Mladenxy
Mladenxy's Avatar
Postovi: 4,510
Stavi zadnji bios na ploču, instaliraj windowse na novo, probaj grafu u drugom konpu itd
Staro 09.04.2024., 00:43   #156
d0X
Kostolomac
d0X's Avatar
Postovi: 1,577
Baci pogled ovdje, pa probaj zbrisat Afterburner ako ga koristiš i/ili instalirati samo drivere, a ne cijeli Adrenaline paket.
PSN Steam
Staro 09.04.2024., 06:19   #157
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,476
I koristi obavezno DDU.
Staro 09.04.2024., 09:43   #158
DragonSlayer
Postovi: 724
All done, ne koristim Afterburner, uvijek je išao DDU, ide danas BIOS, pa Windows, pa onda ak ne radi ide ADMu na servis i kupujem neki kurac privremeno i guess. Mogu probat stavit u komp od cure al nez oće grafa stat xd
Staro 09.04.2024., 09:58   #159
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,545
a mozes uzet nekog fosila od 20-30e na njusci tek tolko da mozes radit na kompu. ono tipa gtx760 nadalje. da si u Ri bi ti ponudio da dodes po gtx 660 na posudbu...
edit:
ak imas vremena, praznu particiju/disk ja bi apsolutno pokusao novu inst OS-a prije servisa.
ak nemas part/disk viska, napravi image sa TI pa ga lako restoras, pod uvjetom da ti je OS drive normalne/prihvatljive velicine...
Staro 09.04.2024., 10:18   #160
DragonSlayer
Postovi: 724
Yep, realno mogu svježe OS reinstalirat in-place jer sad windowsi imaju tu opciju čini se (Settings > Update & Security > Recovery > Reset this PC), ali alternativno samo stavim na ovaj mali stari 120 GB SSD od prije boga isusa.
Sjetio sam se da, iako ventovi i jedan display output ne rade služit će me RX 580 još neko vrijeme u najgorem slučaju. Vidit ću jel ovo što napravilo, ako ne ide BIOS, pa win, pa onda u curin komp jer čini se da može do 395mm grafa stat što bi trebalo bit oke... ugl ima za sada par stvari koje mogu probat. Ako nebu radile, e onda će bit zabavno.
Hvala puno, budem updateo tu i tamo kako ide u slučaju da se nekome drugome pojave problemi.
Staro 12.04.2024., 21:41   #161
DragonSlayer
Postovi: 724
Evo ljudi, tjedan debugiranja i uspio sam riješiti koliko toliko ali me sad zanima - pošto mi je rješenje bilo maknut adrenalin i bit na starijoj verziji drivera + bios update, kak mogu kreirati custom rezoluciju bez adrenalina?
igram stretched, pa ovak na 16:9 ekranu ne radi.
Staro 12.04.2024., 22:41   #162
d0X
Kostolomac
d0X's Avatar
Postovi: 1,577
Probaj CRU.
PSN Steam
Staro 06.09.2024., 15:00   #163
Brzi Picek
Brzi Picek's Avatar
Datum registracije: Nov 2011
Lokacija: Ri,De,Čk,Zg itd
Postovi: 500
Adrenalin mi skače i diže tlak na max.
svako malo me izbaci iz igre na desktop ili sam iskoči preko igre.
Pregledao sam što sve napraviti da to eliminiram, ali ni reinstalacije ni sva isključivanja ko d mene ne prolaze na dotičnoj kanti koju imam s grafom.
obrisao DDU par puta, ali problem se stalno javlja.
Dal ima koji način da se instalira samo drivere bez tih kojekakvih adrenalinskih fora ?
ono doslovno usred igre on me izbaci na desktop, dok se nanovo pokrene ikona za igru ode tenk, brod, zec...
Brzi Picek
Brzi Picek je offline   Reply With Quote
Staro 06.09.2024., 15:14   #164
d0X
Kostolomac
d0X's Avatar
Postovi: 1,577
Koliko se sjećam, noviji driveri imaju "Driver only" opciju. Ili instaliraj preko Device Managera.
Na istoj grafičkoj igram CS2, WoW, Ghost of Tsushima, Cyberpunk 2077 bez nekih problema. Probaj možda spustiti Power Limit za 5 ili 10%, pa vidi. Možda imaš neku tvornički nasviranu 7800XT, pa nije stabilna na stock postavkama u svim igrama.
PSN Steam
Staro 06.09.2024., 15:18   #165
Brzi Picek
Brzi Picek's Avatar
Postovi: 500
Autor d0X Pregled postova
Upravo sam to otkrio i instalirao samo drivere, nadam se da više neće biti problema THX
Brzi Picek
Staro 06.09.2024., 15:37   #166
bambi56x
bambi56x's Avatar
Postovi: 357
Pa dok instaliraš imaš za odabrat (nakon onog dijela di kao skenira šta imaš od opreme na kompu) full, minimal, driver only. Driver only je to što ti hoćeš.
bambi56x je offline   Reply With Quote
Staro 06.09.2024., 18:14   #167
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,476
Koje su to govnarije, ako sam dobro shvatio, tebe Adrenalin dio drivera (ono fensi usporeno sučelje koje svi hvale naspram nV winXP sučelja) ti stalno iskače i zezne ti igru?
Koji vrag, pa što se ne može nešto ako ne u samim driverima tj adrenalin meniju isključit kroz win i notifikacije? Jednostavno mu zabraniš notifikacije i bok, to bi trebalo raditi...valjda.
IMHO sa driver only, nema štelanja i biranja ničeg od dodatnih fićra.
Čudi me da nema neki čistač kao za nV drivere gdje se može izbaciti telemetrija, glupost zvana experience i još dosta bloata.
Zadnje izmijenjeno od: Disco. 06.09.2024. u 18:36.
Staro 06.09.2024., 18:17   #168
Postovi: 8,655
Sve se to može i za sve postoje opcije koje ostaju zapamćene prilikom svake nadogradnje, samo jebiga, Next-Next-Finish.
Autor Disco Pregled postova
Čudi me da nema neki čistač kao za nV drivere gdje se može izbaciti telemtrija, glupost zvana experience i još dosta bloata.
ATIc Install Tool kao rješenje, samo jebiga, Next-Next-Finish.
Staro 06.09.2024., 21:17   #169
Brzi Picek
Brzi Picek's Avatar
Postovi: 500
Da upravo to , uz sve isključivanja i koječega upravo to mi je radilo .
Za sada "only driver" jedino što radi d amogu igrati bez prekida
Brzi Picek
Staro 06.09.2024., 21:57   #170
bambi56x
bambi56x's Avatar
Postovi: 357
Događa se to već godinama da neke (nekad) Radeonke prave probleme kad je to instalirano, ali kad je samo driver onda bude sve uredu. Još iz doba CCC-a prije adrenalina, pa i sad.
Staro 06.09.2024., 22:06   #171
geronimo_2
geronimo_2's Avatar
Postovi: 4,545
Mani ovo prvi glas. Imao Vega 56 sad rx6800. Nisam imao takve probleme. Ne koristim "clean" driver na amd gpu. Nisam ni znao da se moze počistiti ko i nvidia bloat.
Staro 06.09.2024., 22:15   #172
bambi56x
bambi56x's Avatar
Postovi: 357
Prije je bilo češće, znalo bi ljudima izbacivat da se driver uspješno oporavio od krešanja ili take neke fore, pa ljudi misle vid kak je ovo korisno i dobro, a bez toga nije bilo tih problema.
A zna se i samo rušit, ili windows baci ono da je program neresponzivan i slični problemi. Ne svima naravno, ne na svakoj verziji drivera. Meni recimo na windowsima s igpu+RX6800 (monitor je na igpu uštekan uvijek), s nekim verzijama adrenalina, su se rušile igre, ili ne bi prebacivalo renderiranje na 6800, maknem adrenalin, sve radi.
Staro 06.09.2024., 22:56   #173
geronimo_2
geronimo_2's Avatar
Postovi: 4,545
Hm, meni baci ponekad ono da su se resetirale postavke ali kad se igram sa oc/uv. Afaik nikad na default postavkama.
Staro 07.09.2024., 09:48   #174
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,476
Autor bambi56x Pregled postova
E to izbacivanje i oporavljanje...to je bilo često u catalystu (winXp), toga se bome sjećam...9700,X800,HD4xxx. Imao sam i ja đir Radeona, nije da nisam.
I koristio sam Omega-u, šteta da danas nema tako nečeg, modani driveri koji su X puta stabilniji od Ati/AMD-ovih.
Staro 07.09.2024., 10:45   #175
Mladenxy
Mladenxy's Avatar
Postovi: 4,510
Meni niš ne izbacuje, svaki mjesec nadogradim drivere. Radi sve ko podmazano.
Staro 07.09.2024., 13:28   #176
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,476
Mladene, da li ti npr kada prođeš kraj čovjeka koji mijenja probušenu gumu...onako usput dovikneš ''moja se nije probušila!''?
Staro 07.09.2024., 13:43   #177
Mladenxy
Mladenxy's Avatar
Postovi: 4,510
Pa sigurno mu ne kažem i meni se probušila 1998. ko tebi dok si još imao ATI u prošlom stoljeću.
Staro 07.09.2024., 13:56   #178
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,476
Touche. Ali sjetio me kolega na te učestale CTD, onda sam se sjetio Omege i da su ti driveri radili puno bolje.
Staro 08.09.2024., 13:09   #179
d0X
Kostolomac
d0X's Avatar
Postovi: 1,577
Jedini "problem" u trenutnim 24.8.1 driverima je da iz nekog razloga nasumično digne prozor od Adrenalinovog kontrolnog panela. To u 24.7.1 nije radio. Ostalo je najčešće skill issue.
PSN Steam
Staro 08.09.2024., 13:31   #180
maXonja
bu
maXonja's Avatar
Datum registracije: Jan 2017
Lokacija: VŽ
Postovi: 2,631
Pa to kolegu i muči
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
