Povratak   PC Ekspert Forum > Računala > Kriptovalute
Staro 26.12.2022., 22:02   #31
Neo-ST
Neo-ST's Avatar
Postovi: 8,715
Staro 26.12.2022., 22:18   #32
Postovi: 8,653
Da, firma se na ovaj način cigani skoro deset godina, a sad kaj je sve izašlo na vidjelo, zajedno s osobnim (korisničkim) podacima, kombinacija LastPass nesposobnosti i hakiranog materijala, bude prouzročila popriličnu štetu.
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750
Staro 26.12.2022., 23:34   #33
Dottore
Dottore's Avatar
Postovi: 7,733
E sad pravo pitanje što će biti sa podacima ako korisnik samovoljno obriše svoj account?
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 26.12.2022., 23:48   #34
medo
#erase startup-config
medo's Avatar
Postovi: 3,733
KeePass + Yubikey OTP master pass ftw
Staro 26.12.2022., 23:49   #35
Postovi: 8,653
Autor Dottore Pregled postova
Ovak to obično ide, u ovom slučaju LastPass ...
flags the database that the user has deleted their account but not actually delete the account until ...
... tak da ko zna koliko dugo se podaci zapravo drže u tom stanju, tj. da li ih ikada uopće obrišu, najvjerojatnije ne, jer većina toga je danas bazirana na preprodaji korisničkih podataka.
Obzirom da su LastPass podaci kompletno pokradeni, oni koji su ih pokupili, neovisno o korisničkom brisanju LastPass profila i dalje imaju sve, samo malo starijeg datuma.
Staro 27.12.2022., 00:00   #36
Dottore
Dottore's Avatar
Postovi: 7,733
U biti dalje zadržavaju podatke od izbrisanog korisnika.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 27.12.2022., 12:06   #37
dada-as
Bot Maker
dada-as's Avatar
Postovi: 2,741
neznam kak je ovo zavrsilo u topicu kriptovalute. Mislim kuzim ako se igramo s kriptovalutama, ali svatko tko drzi svotu do koje mu je stalo ne koristi ovakve aplikacije.
Lastpass sam koristio kada sam kupio share services, pa smo onda se svi preko tog last passworda prijavljivali u to, to je jedina svrha ovoga.
Od spomenutih sam koristio RoboForm ali prije kakvih 20 godina, ubrzo sam zakljucio cisto logicki, gdje se to nalaze moji paswordi, a nisam u ono doba imao nista bitno.
Phishaju me svaki dan vec 30 godina, i svaki put kad vidim da je nesto zanimljivo pogledam. I misljenja sam bio da su ljudi koji nagrabuse na phishing sami krivi, vecinom jesu, ali ima toliko sofisticiranih phishinga da je stvarno da ako nisi 100% skoncentriran nagrabusis.
Sada ce ovi sigurno to radit i bit ce svasta, a lastpass kao kompanija mora za ovo odgovarat tako da ode u stecaj i ljudi koji su osteceni dobe odstetu, pa onda sljedecoj kompaniji koja bude nudila ovakve usluge ne padne na pamet da im se ovo dogodi. NO vjerujem da je negdje u terms of use s malim slovima napisano da oni nisu za nista odgovorni tak da...
Staro 27.12.2022., 12:44   #38
Postovi: 8,653
Taman da svima isplate ne znam koje cifre kao odštetu, a neće, to i dalje ne mijenja činjenicu da su korisnički podaci u opticaju kod tko zna kakvih sve mušterija.
Koliko je velikih kripto muljaža bilo samo ove godine, pa na kraju najviše ispaštaju oni koji su vjerovali u "projekt" i da su njihovi nofci na sigurnom kod neke online mjenačnice.
LastPass je samo još jedan u nizu primjera vremena u kojem živimo, a podaci koji se spremaju u nečiji cloud/vault, pogotovo na ovaj način kak je to LastPass radil, su sve samo ne sigurni.
Staro 27.12.2022., 13:44   #39
Feyd
hungry, for a little more
Feyd's Avatar
Postovi: 246
Ovo je mail koji sam ja dobio kada sam obrisao račun 2021. Znam da odvjetnici mogu svašta izvrnuti, ali ovdje piše da su obrisali.
Feyd je offline   Reply With Quote
Staro 27.12.2022., 14:46   #40
Postovi: 8,653
Da, moguće da je (tvoj) profil stvarno kompletno obrisan, tj. da ovo nije samo generički mail koji šalju, ali obzirom kaj sve ih je snašlo - nažalost ništa nije sigurno.
