Staro 20.10.2022., 10:10   #511
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,079
Najlakse je spojiti lan kabel kliknuti na next na korak prije nego sto trazi msa i izvuci lan kabel. U roku 10 sekundi zatrazi lokalni account. Tako radim wins 11 home vec jedno vrijeme
Osim ak nemaš LAN kabel, ili port na laptopu, ili ak postoji još lakši način ko taj sa fejk accountom
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Staro 20.10.2022., 13:18   #512
Dottore
Dottore's Avatar
Postovi: 7,674
Ili ubacivanje u stick bootabilne windowse
Code:
write*AutoUnattend.xml*in boot.wim to enable local account on Windows 11 Home (11 only)
https://github.com/AveYo/MediaCreationTool.bat
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Dottore je online   Reply With Quote
Staro 21.10.2022., 23:33   #513
Mladenxy
Mladenxy's Avatar
Postovi: 4,389
https://www.xda-developers.com/micro...lean-up-files/
PC Manager
https://pcmanager.microsoft.com/
skinuo, funkcionira, niš posebno ali veseli
Staro 22.10.2022., 00:54   #514
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,455
zaš mi je ovakva stranica s linka https://i.imgur.com/6eVwKcl.png
edit: svejedno kliknuo i kad se instalira je normalno engleski
Staro 07.11.2022., 09:32   #515
vga killer
Treba kaj skurit??
vga killer's Avatar
Lokacija: Zgb
Postovi: 4,029
Never combine u taskbaru - jel ima ikakav način da se upali bez instaliranja 3rd party alata jer ću inace hitit laptop kroz prozor i dat otkaz
Staro 07.11.2022., 14:24   #516
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,079
Autor vga killer Pregled postova
Ne
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Staro 16.11.2022., 23:05   #517
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,079
Evo, navodno vraćaju Never combine opciju za taskbar u Win11:
https://twitter.com/thebookisclosed/...247490/photo/1
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Staro 17.11.2022., 13:14   #518
virty
Ronon Dex
virty's Avatar
Lokacija: DS9
Postovi: 1,625
Autor Mario92 Pregled postova
To mi najviše fali
virty je offline   Reply With Quote
Staro 18.11.2022., 03:37   #519
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,663
Meni najviše fale vremena kad se čovjek veselio a ne strepio od nove verzije MS Windowsa.
Staro 18.11.2022., 11:25   #520
Mladenxy
Mladenxy's Avatar
Postovi: 4,389
Koristim windowse od 95 verzije i po mojem iskustvu nikada nisu bili bolji nego sada, od same instalacije do stabilnosti i otpornosti na hrpe različitih instalacija/deinstalacija kroz godine. Nadograđena desetka puna "smeća" sa jedanaesticom koja radi vrhunski. Nikakvih problema sa nadogradnjama. Npr. tam gdje desetka nije kužila HDR sadržaj jedanaestica to skuži promptno i fercera ko atomski sat.
Staro 18.11.2022., 11:34   #521
Libertus
Libertus's Avatar
Datum registracije: Jul 2017
Lokacija: Ramura
Postovi: 2,815
Jučer prvi puta pokrenuo W11 na novom laptopu. Gubi BT vezu sa mišom svakih 10 sekundi, usporava bezveze na desktopu ničim izazvana, forsira hrpu neki MS aplikacija. Morao sam guglati kako maknuti chat iz taskbara itd... Uglavnom nije me oduševila na prvu.
Nego, postoji li način za narediti kada koristim laptop da je na nativnoj rezoluciji i 200% povećanja, a kada spojim na dock (mirror je ekran monitora i ovaj na docku) na kojem je fullhd monitor da koristi fullhd rezoluciju i 100% povećanje?
Kada na docku ostavim 200% katastrofa je veliko sve pa moram prebaciti na 100% da bude normalno. Ali čim odlučim dock, lap se prebaci na 2880x1800 (mislim) i onda su na 100% ikone super male.
Zadnje izmijenjeno od: Libertus. 18.11.2022. u 11:42.
Staro 18.11.2022., 11:57   #522
virty
Ronon Dex
virty's Avatar
Lokacija: DS9
Postovi: 1,625
Slazem se s tim da sam koristio kratko i Win 3.11. Meni su Win 10, a i Win 11 najbolji i najstabilniji Windowsi.
Poslano sa A52S 5G
Staro 18.11.2022., 15:04   #523
Postovi: 34,017
Danas mi je ruku dopao prastari laptop Toshiba Satellite (T4300, 4Gb SDDR2,...) sa W11H. Nije mi legao. Totalno je drugačiji od prethodnika pa sam se malo gubio po njemu dok sam našao što mi treba.
Laptop je serijski dolazio sa W7, ali je W11H neaktiviran. Rekao vlasnici neka si kupi ključ na netu.
Staro 18.11.2022., 16:00   #524
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,079
ili iskoristiš key od W7 da aktiviraš W11?
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Staro 18.11.2022., 16:09   #525
Postovi: 34,017
Mogu pokušati. Hvala.
EDIT: upalilo je.
btw, iako je laptop prastar i nema TPM, W11 su uredno instalirani i rade. Negdje u Setingsima (Security?) sam maknuo kvačicu sa opcije TMP check (ili slično) i radi normalno.
Zadnje izmijenjeno od: coconut. 19.11.2022. u 10:14.
Staro 21.11.2022., 08:22   #526
jollyb
4K FTW
jollyb's Avatar
Lokacija: Minken
Postovi: 1,046
Odlično. Predugo im je trebalo za ovo.
Još da vrate da mogu sysbar imati gore i bit ću prezadovoljan.
Odugovlačio sam upgrade desktop i surface 7 na win 11 i mogu reći da kad sam se priviknuo nakon 1-2 tjedna sam zažalio što to nisam. Napravio ranije.
Također se pridružujem pozitivnom iskustvu, za mene isto najbolji win os. Nema više strpljenja da backupovima kao prije. Čak i win 10 je bila dovoljno stabilna.
jollyb je offline   Reply With Quote
Staro 21.11.2022., 09:47   #527
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,663
Staro 21.11.2022., 21:19   #528
BinaryJesus
Datum registracije: Feb 2021
Lokacija: Sveti Petar
Postovi: 302
StartAllBack popravlja 99% sranja s Win 11 taskbarom i start menijem, vraća stare kontekst menije u explorer, Win 10 ili Win 7 UI u explorer i hrpu toga još.
Ima i 100 dana trial. Koristim ga od prvog dana od kad sam instalirao Win 11.
BinaryJesus je offline   Reply With Quote
Staro 30.11.2022., 12:48   #529
Black mustang
Postovi: 111
Pozdrav,
Ima li mozda tu foto ili video edior koji ima instalirane Windowse 11 i koristi Adobe paket ili DaVinci? Zanima me stabilnost i ima li jako puno bugova?
Naravno i vasa osobna iskustva svih koji imate Windowsw 11 .
Sljedeci tjedan slazem novi komp za foto i video editing...... prvotno sam planirao Instalirati Windowse 10 jer su stabilni i vec dugo vremena vani, ali me kolega uvjerava da 11 radi odlicno i da je malo brza i responsivnija od desetke ( opcenito bez obzira na konfiguraciju ). Kad ver radim clean install, reko da provjerim u kakvom su stanju Windowsi 11. Cini li se kao imalo brzi i responsivniji sustav ili su samo Windowsi 10 sa novim suceljem? Ima li trenutno puno bugova i rijesava li ih Microsoft brza sa novim updateovima ?
Hvala!
Black mustang je offline   Reply With Quote
Staro 30.11.2022., 15:16   #530
Taproot7
mag.math.
Taproot7's Avatar
Datum registracije: Dec 2021
Lokacija: Daruvar/Zagreb, Republika Hrvatska
Postovi: 363
w11 je u redu za koristenje sad od 22h2 updatea a adobe paket radi skroz zadovoljavajuce tojest nisam primjetio razliku naspram w10 a w11 sam dobio na novom laptopu i nisam radio downgrade a w11 su malo lijepsi za koristenje inace sve isto kao w10 tojest neces pogrijesiti sa w11 pogotovo ako ces koristiti zadnju generaciju intel procesora. bugova nema update-ovi idu normalno kao i na w10 kumulativne zakrpe mjesecno i ostali driver-i i zakrpe
Taproot7 je offline   Reply With Quote
Staro 04.12.2022., 16:28   #531
jollyb
4K FTW
jollyb's Avatar
Lokacija: Minken
Postovi: 1,046
Koje su vase preporuke za kupiti Win 10 ili 11 key?
Za novi laptop bih instalirao Win 10 pa updejtao na 11 ili direktno install 11. Ovisno sto je jeftinije / bolje.
Staro 04.12.2022., 18:57   #532
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,079
Bilo koji key od Win7 pa nadalje aktiviral bu Win11
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Staro 11.12.2022., 11:55   #533
Black mustang
Postovi: 111
Pozdrav svima,
Stavio sam isti post u hardverske probleme, ali reko da pitam i tu buduci da se radi o Windowsima 11.
Jel mozda netko imao slican slucaj ili ima neki savjet?
Prije nekoliko dana sam kupio komponente i slozio novi PC. Ovo mi je 6-7 PC koji sam slagao tako da imam iskustva.Ovo su komponente :
Intel 13700 K
Gigabyte z790 Aero G
Kingston DDR5 5200 Furry Beast 2x 32GB
Gigabyte 3070 OC
Samsung 990 PRO OS + 3x Samsung 980 M.2
Ironwolf HD 10T
Corsair 850e
Fractal Torrent Compact RGB
Slozio komp....sve je radilo. Instalirao Windowse 11 ( Kad sam radio instalaciju stavio sam samo glavni M.2 a sve ostale sam dodao nakon instalacije Windowsa ).Napravio sve BIOS updatove, update za SSD i instalirao sve osnovne drivere. Skinuo i instalirao sve updateove za Windows 11 za 22H2. Temperature normalne ( CPU oko 32 u Idle ).Inace, ovo je bilo drugi put da sam instalirao Windows 11 jer je prvi put bio neki cudni bug di je windows update stao sa instalacijom na 25% ( stajalo je tako 2-3 sata ) i kada sam isao restartat komp pisalo je svaki put da instalira update.
Ugl. Sa drugim clean instalom sve radilo normalno. Slozim i podesim cijeli komp, instaliram si programe za rad. Napravim restore point i kompletni backup cijelog OS diska. Komp radio cijeli dan. Navecer prije spavanja stavim komp u Sleep mode. Ujutro se probudim, ukljucim komp.....komp se non stop resetira ( restart loop ).
Ne reagira ako drzim power, reset, iskopcam ga iz struje. Cim ga ukljucim i stisnem power radi 2-3 sek mozda i onda se restarta ( znaci ne dode niti do biosa )...tako u nedogled.
Evo video :
https://youtu.be/hz1kknbtn5o
Napravio sam sljedece:
Clear Cmos
Iscupao jedan Ram pa probao obje kombinacije sa jednim Ramom
Provjerio sve kablove ( iako mi nema logike da nesto nije dobro spojeno ili se odspojilo ).
Iscupao graficku i spojio se direktno na maticnu.
Nema nikakve promjene ili rezultata.
Inace imam na maticnoj 4 lampice za dijagnostiku ( CPU,VRAM, VGA,BOOT )
Pise u manualu do maticne da ako postoji neki problem, da lampica ostaje svjetliti. Meni prvo napravi provjeru za CPU ( upali se i ugasi lapica za CPU )
, nakon toga se upali lampica za VRAM i tu se komp odmah restarta.
Ako netko ima neki savjet, bio bih zahvalan.
Staro 12.12.2022., 23:53   #534
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,691
pozz
kupio laptop bez os-a, pa sam uzeo preko neta i jedan od onih jeftinih ključeva za w10. Sve je uredno prošlo i aktiviralo se, ali je problem u tome da je latop imao neki glupi hw kvar i na reklamaciji je dobiven novi. I sad je fino taj ključ ostao vezan za taj laptop i ne želi mi se w10 aktivirati na novom laptopu s istim ključem.
Dal mogu zvati Microsoft info telefon i očekivati da prebace ključ na novi laptop ili se mogu pozdraviti s tih par eura?
Staro 13.12.2022., 00:17   #535
Revolver3844
Datum registracije: Apr 2017
Lokacija: SB
Postovi: 715
Autor Problem Pregled postova
pozz
Nemaš se ti na što pozvat.
Nemaš ni račun nit išta.
To je oem licenca.
Kupi drugi.
evo tu za 3.5 dolara
https://www.gamers-outlet.net/en/sof...rice&order=ASC
Revolver3844 je offline   Reply With Quote
Staro 13.12.2022., 07:01   #536
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,082
pozz
I da imas racun - ne. OEM Licenca se veze uz jedan komp i umire s tim kompom. Simple as that. Ako zelis prebacivat trebas Retail licencu.
Staro 13.12.2022., 09:42   #537
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,691
Autor Revolver3844 Pregled postova
To je oem licenca.
Kupi drugi.
kupio licencu sa linka.
Hvala!
Staro 25.12.2022., 20:58   #538
NoNic2
NoNic2's Avatar
Lokacija: zadar
Postovi: 103
Ja sam nakon nekih ~6god Win10 prešao na 11 i na moje iznanađenje super sam zadovoljan. Os izgleda jako lijepo i sve štima osim.... desni klik gdje se ne pokaže puni Contekst meni neko ova nekakva pojednostavljena verzija... uzaš!! Nadao sam se da će izači updejt koji daje opciju starog menija ali izgleda da ču morati napraviti registry edit.
NoNic2 je offline   Reply With Quote
Staro 26.12.2022., 12:43   #539
jucca
jucca's Avatar
Postovi: 1,696
Autor NoNic2 Pregled postova
https://www.startallback.com/
Sent from my SM-S908B using Tapatalk
Staro 26.12.2022., 13:30   #540
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,082
Imas u Folder Options opciju ili :
https://allthings.how/how-to-show-mo...file-explorer/
Easy
