Staro 12.09.2022., 12:44   #5581
Postovi: 8,767
Intel teases 6 GHz Raptor Lake at stock, 8 GHz overclocking World Record
We're here in Israel for Intel's Technology Tour 2022, where the company is sharing new information about its latest products, much of it under embargo until a later date. However, the company did share a slide touting that Raptor Lake is capable of operating at 6GHz at stock settings and that it has set a world overclocking record at 8GHz - obviously with liquid nitrogen. Intel also shared impressive performance projections for single- and multi-thread performance. Notably, the peak of 6GHz is 300 MHz faster than the 5.7GHz for AMD's Ryzen 7000 processors, but Intel hasn't announced which product will hit that peak speed. We also aren't sure if a 6GHz chip will arrive with the first wave of chips or be a special edition 'KS' model. Intel also claimed that Raptor Lake will have a 15% gain in single-threaded performance and a 41% gain in multi-threaded, as measured by SPECintrate_2017 and compared to Alder Lake, and an overall '40% performance scaling.' The Israel Development Center (IDC) has been the design engine behind a long line of Intel products spanning back to the 8088 that started it all back in 1979. That lineup spans until today, encompassing well-known names like Pentium MXX, Banias, Sandy Bridge, and many others.
Izvor: Tom's Hardware
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750
Staro 12.09.2022., 14:17   #5582
SlavoS
Datum registracije: May 2003
Postovi: 1,116
To če biti KS ili kW model ?
SS
SlavoS je offline   Reply With Quote
Staro 12.09.2022., 15:38   #5583
the_ghost
lar~
the_ghost's Avatar
Postovi: 1,559
takozvani bar 5kW Chiller Edition
Staro 12.09.2022., 18:09   #5584
jucca
jucca's Avatar
Postovi: 1,719
Autor MegaSkot Pregled postova
Adler lake jezgra pod novim imenom.
Igre za retardirane.
https://www.pcgamer.com/intels-13th-...-architecture/
Sent from my SM-S908B using Tapatalk
Staro 12.09.2022., 20:12   #5585
Postovi: 8,767
Intel confirms that Raptor Lake was not originally part of their CPU roadmap
At the company's Tech Tour press event, Intel confirmed that Raptor Lake was not originally part of the company's product roadmap, with its inception coming less than two years ago when Intel knew that there would be a long gap between Alder Lake and Meteor Lake. Intel's Meteor Lake processors will utilise more complex manufacturing techniques, being a multi-chiplet design that uses multiple lithography nodes and the company's Foveros Die Interconnect (FDI) technology. Originally, Intel planned to release Meteor Lake as a successor to Alder Lake, but when timelines for Meteor Lake stretched out, Intel decided to create Raptor Lake, a design that required minimal resources to create, but could deliver compelling performance gains over Alder Lake. Meteor Lake should have been Intel's 13th Generation series of Core processors, now 13th Gen is Raptor Lake.
With Raptor Lake, Intel has avoided leaving a gap in their product roadmap that their competitors could exploit. Using multiple design enhancements, Raptor Lake can deliver higher clock speeds and increased IPC while retaining core designs that are very similar to their Alder Lake counterparts. With Raptor Lake, Intel is delivering more than a standard CPU refresh, but less than we would expect from a full core redesign. In a sense, Raptor Lake is a highly polished version of Alder Lake, offering users more L2/L3 cache, additional E-cores to boost multi-threading performance, and higher core clock speeds to boost single-threaded and multi-threaded performance. Fundamentally, Raptor Lake is simply a refined version of Alder Lake, but that has not stopped Intel from delivering significant performance gains.
Izvor: OC3D
Staro 14.09.2022., 12:04   #5586
sfc_PsychQ
Retro hardware fan
sfc_PsychQ's Avatar
Datum registracije: Apr 2022
Postovi: 95
Evo malo leakanih benchova mid range-a:
https://wccftech.com/intel-core-i5-1...s-price-range/
sfc_PsychQ je offline   Reply With Quote
Staro 14.09.2022., 20:39   #5587
Postovi: 8,767
Između GoFundMeMyFAB epizoda i gašenja ili prodaje određenih divizija, situacija u Intelu IMHO sve više podsjeća na onu u AMD-u prije 15 godina, s tom razlikom da Intel nema šrot arhitekture i drže se svojih proizvodnih pogona.
Intel stock drops to 5-year low, dips by 46% year-over-year as chipmaker decides to sell Mobileye
Intel’s stock price has dropped to a 5-year low of $29, following an extended period of unrest across Wall Street. The chipmaker’s share price has plummeted by as much as 46% through the course of the last 12 months, going from $55 back in October last year to just $29 at the time of writing. The Blue stocks have essentially halved in value. To keep earnings in balance, Intel plans to spin off its Mobileye division, hoping to fetch as much as $30 billion for the same, twice as much as the $15 billion it cost to acquire it back in 2017. Gelsinger hopes to fund the chipmaker’s future expansions using the proceeds from this sale. The CHIPS Act was passed a short while back. Aimed at reinforcing the American chipmaking industry, Intel is expected to be one of the primary benefactors of the bill. Regardless, its share has fallen by 22% since the passing of the act.
Izvor: Hardware Times
Staro 19.09.2022., 20:06   #5588
Antony
Lokacija: Poreč
Postovi: 69
First review of retail Intel Core i9-13900K “Raptor Lake” CPU emerges
TLDR;
13900k compared to 12900k:
~12% higher ST / gaming performance
~ 42% higher MT performance at "unlimited mode"
Power usage have increased from 236w to 343w to reach performance numbers above (so 45% more power usage for 42% higher MT performance)
P-core IPC increase is basically nothing ~1-3%
E-core IPC increase is ~6%
Most of performance increase comes from higher clockspeeds
Antony je offline   Reply With Quote
Staro 19.09.2022., 20:12   #5589
Postovi: 8,767
Ovisno o modelu sad imaju 75% do 100% više manjih šparnih E-jezgri uz više taktove, zagrijavanje i potrošnju, ali na kraju se sve svodi na porast od kakvih 40% MT performansi.
Staro 19.09.2022., 20:49   #5590
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,919
jedan test sa oba na 5 ghz pa ćemo vidjet razliku mislim na 12900k i 13900k,i ostale.
hmhm,i ovu generaciju preskočit mislim na intel,uzet amd,čekat meteor lake,ako možda kupim rtx 3080 upogonit ću je sa i5 4670k.
Zadnje izmijenjeno od: demetrius. 19.09.2022. u 21:01.
Staro 19.09.2022., 20:56   #5591
Postovi: 8,767
IMHO takvi testovi budu samo dodatno potvrdili da je Raptor Lake osvježeni Alder Lake, te da konkrentog pomaka u arhitekturi nije bilo, pa su tu zato manje jezgre u duplo većem broju uz još više radne taktove, potrošnju i zagrijavanje.
E da, kaj su kupnje tiče, pa tebi je sad idealna prilika za neki Zen 3 ili Intel ekvivalent, da se ne patiš s Core i5-4670K + RTX 3080. Ne moraš uopće ovo novo gledati, jer i još aktualne generacije budu ti fini skok.
Zadnje izmijenjeno od: The Exiled. 19.09.2022. u 21:10.
Staro 20.09.2022., 13:33   #5592
robee
robee's Avatar
Lokacija: VinkovcI
Postovi: 954
Kakva je situacija 12500 vs 13500? Vidim da su i u njega natovarili hrpu jezgri? Radi li na taj nacin bolje sa win11? Ili ce i kod njega biti bolji samo mt?
Mbo b660 bi navodno trebale imati podrsku i za 13gen
robee je offline   Reply With Quote
Staro 20.09.2022., 13:53   #5593
Postovi: 8,767
Prepakirani Alder Lake tak da bude sigurno radilo s Windows 11 OS + B660 kombinacijom, a na temelju manjih jezgri budu i performanse išle gore gdje god je moguće.
The lower-end non-K offerings will be repurposed Alder Lake dies. The latter consists of the Core i3-13400, i5-13400, i5-13400, i5-13500, and the i5-13600.
Staro 20.09.2022., 14:10   #5594
robee
robee's Avatar
Lokacija: VinkovcI
Postovi: 954
Moguce i cijena bude isla malo na gore
I trebao bi imati malo bolju gpu?
Staro 20.09.2022., 17:50   #5595
Postovi: 8,767
I dalje bude to varijacija na Alder Lake UHD iGPU temu.
Staro 23.09.2022., 09:53   #5596
Odinarius
All-rounder
Datum registracije: Sep 2013
Postovi: 1,342
Izgleda da je zagustilo s parama... https://www.anandtech.com/show/17541...ith-brookfield
Staro 26.09.2022., 07:59   #5597
sfc_PsychQ
Retro hardware fan
sfc_PsychQ's Avatar
Postovi: 95
je, firmi koja radi 80 milijardi dolara godišnje je zagustilo
Evo malo rumora o ipc-u:https://hothardware.com/news/raptor-...s-ipc-compared
Staro 26.09.2022., 08:45   #5598
Postovi: 8,767
Autor sfc_PsychQ Pregled postova
Naravno, zato im sad već treći po redu dirketor ne zna na koji način da užica subvencije, dok su istoveremeno izgubili ~30% sveukupnog tržišta, a sve najave su samo na papiru, jer kasne sa apsolutno svime.
Osim toga ova vijest je ne samo stara već mjesec dana, nego potvrđena od strane Intela, obzirom da su oni bili izvor za tu informaciju, tak da Intel itekak treba vanjske financije.
Staro 26.09.2022., 10:03   #5599
sfc_PsychQ
Retro hardware fan
sfc_PsychQ's Avatar
Postovi: 95
Svatko ko ulaže 20 milijardi dolara treba vanjske financije, nece refinvestirati dobit i narušiti cash flow.
Izgubio tržišnog udjela je, ali je još puno jači:
https://www.cpubenchmark.net/market_share.html
O financijama da ne pričamo:
https://www.trefis.com/data/companies/AMD,.INTC/no-login-required/TfU13vlN/Intel-vs-AMD-How-Have-Revenues-Key-Operating-Metrics-Changed-Over-Recent-Years-#:~:text=Intel's%20revenues%20have%20grown%20from,by%20its%20computing%20%26%20graphics%20segment.
S time da:
Intel 2021 Revenue: $79 Billion
AMD 2021 Revenue: $16 Billion
Intel 2021 Profit: $19.9 Billion(samo od ove dobiti je mogao sam financirati novi fab ali bi narušio cash flow što nikome nije u interesu, posebno dok još uvijek možeš dobiti realtivno jeftino financiranje)
AMD 2021 Profit: $3.2 Billion
Intel Total Assets: $168 Billion
AMD Total Assets: $12 Billion
Intel x86 Desktop CPU Market Share: 84%
AMD x86 Desktop CPU Market Share: 16%
Intel x86 Laptop CPU Market Share: 78%
AMD x86 Laptop CPU Market Share: 22%
Intel x86 Server CPU Market Share: 89%
AMD x86 Server CPU Market Share: 11%
Intel has physical Fabs, AMD has none.
I onda uzmeš nvidiju i zbrojiš amd+intel i ona ih pojede par puta sama...
Ali ono nije topic o ekonomiji...
Sigurno komotnu situaciju koju je imao godinama iza jer je bio bez konkurencije neće imati, što je dobro za nas krajnje korisnike jer bi trebali imati bolji i brži hardver za manje love (vidimo da i to pada u vodu u vrijeme ovog divljanja).
Staro 26.09.2022., 10:12   #5600
Postovi: 8,767
Kaj stvarno, linkal si PassMark kao argument za Intelov tržišni udio? OK, ne moramo dalje ništa više pričati. Ne znam kaj se mora desiti da vas nekolicina BUG forum stručnjaka napokon skuži da u Intel preduzeće više ne cvate cveće.
Samo na prošloj stranici ima hrpa materijala da Intel iz kvartala u kvartal ide sve dublje i dublje, ali OK, lakše se pretvarati da je to sve dio jednog velikog plana, jer Intel ovo namjerno radi tak da dobe AMD i ostale na foru.
Prvo ismijavaš čovjeka, jer je linkal itekakvu činjenicu da Intel sve više ovisi o vanjskim financijama, a onda isto to potkrijepiš, "pa da svatko tko ulaže silne milijarde treba vanjske financije".
Znači Intel istovremeno ima toliko novaca da ne zna kud s njima, a opet žicaju uokolo pare, dok obećavaju brda i dolina, a kasne sa svim u svakom pogledu.
Zadnje izmijenjeno od: The Exiled. 26.09.2022. u 10:28.
Staro 26.09.2022., 10:29   #5601
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,747
@The Exiled
nemoj čovjeka omalovažavat samo zato što navodi podatke koji ne odgovaraj tvojoj slici stvari.
Jerbo bi mogao čovjek pomislit da tvoja slika stvari ne odgovara stvarnosti nego stvarnosti u tvojoj glavi.
Staro 26.09.2022., 10:42   #5602
Mladenxy
Mladenxy's Avatar
Postovi: 4,547
AMD CPU udio sigurno raste
https://www.statista.com/statistics/...-market-share/
Mislim to je logično i bez da gledaš statistike ako znaš koliko dobre procesore izbacuju zadnjih gona. Logično je da ih ljudi kupuju.
Također jasno je ko dan kako je Intel USA starteška kompanija na kojoj se bazira ekonomija, vojna indistrija i da će napraviti sve kako bi povratili neosvisnost o chipovima na vlastito tlo i ono koje kontroliraju ovako ili onako, čitaj prijateljske zemlje. Sigurno da će u tim okolnostima upumpavati novac koliko bude trebalo.
Staro 26.09.2022., 10:48   #5603
sfc_PsychQ
Retro hardware fan
sfc_PsychQ's Avatar
Postovi: 95
niko ne kaze da plivaju u novcu nego da je 20 milijardi dobiti jako lijepa dobit i ostvarena u godinu dana, za koju amd-u treba 5 godina....
ukoliko ideš u reinvestiraranje iznosa u visini dobiti, lakše ti je investirati iz fondova, kredita nego iz vlastitog cash flowa...
iz kojeg izvora hočeš market share?intel je trenutno 5 puta veća firma od amd-a, po revenue-u i net profitu, šta ti nije jasno?
Čovjeka nitko nije ismijavao...nego sam ukazao da to ispada da je intel u bankrotu..a ljudi ulažu 20 milijardi u novi fab...
Još te molim da mi objasniš ta brda i doline?
Staro 26.09.2022., 10:49   #5604
sfc_PsychQ
Retro hardware fan
sfc_PsychQ's Avatar
Postovi: 95
sa ovime se slažem u potpunosti
Staro 26.09.2022., 10:58   #5605
Postovi: 8,767
Autor kopija Pregled postova
@The Exiled
Ne znam čija je ovo stvarnost, ali sigurno nije moja konstrukcija, a njegov komentar je da Intelu to ne treba, jer oni imaju dovoljno novaca.
Intel this week introduced its new Semiconductor Co-Investment Program (SCIP) under which it will build new manufacturing facilities in collaboration with investment partners – a sharp departure from the company's traditional stance of wholly owning its logic fabs. As part of its SCIP initiative, Intel has already signed a deal with Brookfield Asset Management, which will provide Intel about $15 billion to build its fab new fab in Arizona in exchange for a 49% stake in the project. Furthermore, similar co-investment models are set to be used for other fabs in the future.
Staro 26.09.2022., 11:23   #5606
sfc_PsychQ
Retro hardware fan
sfc_PsychQ's Avatar
Postovi: 95
niko nije rekao, čitaj malo bolje..rečeno je bolje uzet novac od fondova i banaka dok je jeftin nego reinvestirati svoju dobit i narusiti cash flow.
bolje imas fab sa 2 vlasnika i djeliti kapacitet između...
nego dijeliti jedan kapacitet sa Appleom,MediaTekom,AMDom,Qualcommom,Broadcomom
Nvidiaom,Sonyem,Marvellom,STMicroelectronicsom,Analog Devicesom,Intelom....
Ako me kužiš šta hoću reći
Staro 26.09.2022., 11:39   #5607
Postovi: 8,767
Kužim da je Intel sad u istom loncu kao i ostali koji ovise o TSMC-u, a u godinama koje dolaze, možda čak i ostanu bez svojih FAB-ova.
Kad napokon voda dođe skroz do grla, pa po uzoru na šrot AMD, prvo iznajme (IDM 2.0 je već na tom putu), a onda i konkretno sve prodaju.
Ostaje pitanje koliko dugo bude i ovaj direktor pjeval borbene, prije nego ode, proda dionice i lijepo mahne svima.
Staro 26.09.2022., 11:42   #5608
sfc_PsychQ
Retro hardware fan
sfc_PsychQ's Avatar
Postovi: 95
Dok god je društvo profitabilno zašto bi mahao...jedino ako dioničari budu htjeli više i bolje...i odluče se na smjenu...
Staro 26.09.2022., 11:51   #5609
Postovi: 8,767
  • Intel Q2 earnings: Poor show expected, all eyes on outlook
  • Intel posts sizable miss on quarterly sales, slashes forecast
  • Intel lost half a billion dollars launching its underwhelming GPUs
  • Intel kills Optane Memory business entirely
  • Intel posts sharp drop in sales, issued muted outlook
  • Intel falls as it reports an unprofitable second quarter
  • Intel Q2 2022 earnings are a disaster as revenue and EPS miss by double-digit percent
Uz to dodamo 50+ milijardi od države za nove pogone i domaću proizvodnju i to je taj profitabilni Intel s novim direktorom na čelu vesele povorke.
Staro 26.09.2022., 11:58   #5610
sfc_PsychQ
Retro hardware fan
sfc_PsychQ's Avatar
Postovi: 95
https://www.intc.com/news-events/pre...ancial-results
Još uvijek 1,2 milijarde dolara dobiti za kvartal "samo"
