Staro 19.03.2003., 23:21   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Novi Rivatuner 2.0 RC 12.3
Ima zanimljivih stvari:
Added low-level AGP controls (tested on all NVIDIA based boards and ATI R300 based boards). This module was added special to replace ATI SMARTGART, the component of 'the most stable drivers on the market' that never seems to work as supposed on our KT400 based system. This module will finally allow KT400 users to switch to AGP 4x mode if AGP 8x mode
causes any instability.
Added ATI RV280 and R350 graphics processors support.
Updated SoftR9x00 scripts for both Windows 9x/ME and Windows 2000/XP. Now the scripts are tested and certified for use with Catalyst 2.0 - 3.2 (both beta and release versions) and allow you to force RADEON 9800PRO PCI DeviceID as well as RADEON 9500 and RADEON 9700PRO PCI DeviceIDs.
Updated SoftFireGL scripts. Now the scripts are tested and certified for use with 1021 - 1030 FireGL drivers.
Možete ga naći tu:
http://www.guru3d.com/rivatuner/
