Staro 16.02.2006., 01:20   #1
Broken Arrow
The Man
Broken Arrow's Avatar
Lokacija: Novi Zagreb
Postovi: 1,252
Monitor se gasi
Ne razumijem počelo odjednom,nekad nakon što win ugase monitor ili ja "na gumb" kada ga oću upaliti (pomakom miša ili na gumb) on se upali i nakon sekunde ugasi, da proradi moram ga na gumb kojih 20-30 puta paliti gasiti da se sjeti ne ugasiti, a nekad radi normalno
U čem bi mogo biti problem, imam još garanciju i na monitor i na grafulju, tako da nije problem ali ne kužim...
Konfiguracija iz siga - prva...
thnx
"Everybody's at war with different things...I'm at war with my own heart sometimes"
Broken Arrow je offline   Reply With Quote
Staro 16.02.2006., 01:31   #2
zeus-horny
zeus-horny's Avatar
Lokacija: koprivnica
Postovi: 113
kupi sve novo
MBO:Epox 9npa3j
CPU :AMD 64,3000+
@2610MHz--290*9
RAM:2*512 G.E.I.L400
@480MHz--2,5-3-3-5
VGA:x1800xl 256mb@(570-1180mhz)
HDD:WD 120Gb 8mb
PSU :Tagan 430 easy con.
CASE:black delux with sensors(cpu,graf,itd.)
DVD-ROM :asus quickTrack ata100 16x
DVD/RW:asus 16x16
zeus-horny je offline   Reply With Quote
Staro 16.02.2006., 02:00   #3
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Probaj s nekim drugim monitorom, jel se tak blesira... Probaj promijenit drivere od grafe, mozda upali od prve... Stvarno neznam zakaj se tak blesire, mozda je stvarno u monitoru problem...
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 16.02.2006., 08:19   #4
terminator
Spermich Termich
terminator's Avatar
Lokacija: Zaprešić
Postovi: 885
pa kolko je star monitor?
kak je to odjednom počelo? probaj mijenjat drivere, probaj drugi monitor prikopčat.
ak niš drugo, imaš garanciju
terminator je offline   Reply With Quote
