Staro 26.03.2022., 12:20   #391
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,419
I još jedan hotfix:
Third Hotfix (33.1.0.319 deployed on 3/25/2022):
Resolves issue pairing Dual Shock 3, XBOX, and Switch controllers
Resolves bug where video colors would be displayed incorrect when HW acceleration is enabled
Fixes bug affecting streaming to twitch
Adds helpful notifications when connecting or formatting removable storage
Fixes bug where system would hang when access home screen after matching frame rate in Kodi
Fixes bug where surround upmixer would stop working after playing Dolby audio streams
Adds Plex support for latest Hauppauge WinTV-dualHD DVB-T tuner (EU only)
Fixes bug where AI upscaling could not be changed in Netflix app
Resolves issue where Documents UI cannot access external storage folders
Resolves issue where SD card notification would be displayed when launching apps
Resolves issue when capturing screenshots in GeForce NOW using NVIDIA Share
Resolves crash issue with Google Play Games on 2015/2017 SHIELDs.
Resolves localization issue with Canadian Language selection of energy start timers
Resolves audio issues when connecting headset to 2015 SHIELD Controller
Slobodno me dodajte na PSN
Disco je online   Reply With Quote
Staro 09.04.2022., 04:58   #392
LAcy
Pink Floyd fan
LAcy's Avatar
Lokacija: Santa Clara, CA
Postovi: 5,572
Iskočilo mi sinoć. A onako, nije losa ideja al' nije i da ce bas pomoci u moru streaming services.
https://www.theverge.com/2022/4/5/23...atibility-beta
Core i7-6700K LGA1151 Skylake
RTX 2080 TI 11GB GDDR6
Samsung 850 EVO M.2 1TB SSD
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 09.04.2022., 11:29   #393
Postovi: 10,340
Odem na streamable.com i pokrije mi sve te cross platform search potrebe.
Staro 12.04.2022., 18:58   #394
Postovi: 10,340
9.0.2 je vani:
https://www.nvidia.com/en-us/geforce...eleased-41222/
Zanimljivo, iako mi je oznaceno da svaki put skida full image, skinuo mi je 75MB inkrementalni update (bio sam na 9.0.1 bez hotfixeva).
Staro 13.04.2022., 05:54   #395
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,572
Evo dobio i ja (update), tako sam uzbudjit...
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 14.04.2022., 17:26   #396
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,419
Meni nije niš došlo tj uopće mi ne nudi update ni kada ga pokrenem, tako da je to onda ovaj hotfix 3 zapravo.
Staro 14.04.2022., 19:12   #397
Postovi: 10,340
Ne bi se kladio, vjerojatno ti samo jos nije stigao. Ekipa (Ameri) koja zeli Disney+ bi ih pojela da zaglave na hotfixu umjesto da ga pregaze certificiranim buildom.
Kad sam bio na hotfixevima na 9.0, uredno mi je na kraju dosao 9.0.1 i pregazio zadnji hotfix. Nisam ni siguran je li 9.0.1 donio ista novo naspram hotfixa prije njega.
U ovoj zadnjoj rundi nisam ulazio u hotfix program, bio sam zadovoljan s 9.0.1
Staro 15.04.2022., 06:33   #398
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,419
Autor xlr Pregled postova
Today we released SHIELD Experience Upgrade v9.0.2 (33.1.0.319)
Isto je, isti je ovaj build no, ili što god je to već.
Staro 16.04.2022., 11:17   #399
Postovi: 10,340
Idemooo:
https://i.imgur.com/C9Ht9Bi.jpeg
Dogodilo mi se nekoliko puta na 9.0.1 da se app koji pusta mjuzu freeza, ali muzika ide i pjesme se redaju i ne skuzis da je freezan dok ne uzmes daljinski u ruke. Dogadjalo se s Plex klijent appom (vuce muziku sa NAS Plex servera) i Deezerom (vuce muziku s neta).
A ovo na slici je kompletni raspad od jucer gdje prvi put vidim glitcheve (9.0.2).
Rjesenje u svim navedenim slucajevima je cupanje napajanja jer na nis drugo ne trza.
Staro 16.04.2022., 14:35   #400
Prezime
Datum registracije: Aug 2013
Postovi: 4,361
Al su uspjeli syebat taj fini box, svaka im cast.., ko da im Xiaomi radi softver
Staro 16.04.2022., 19:54   #401
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,572
Idemooo:
Jesi li zgooglao dal' jos netko ima takav problem? Ovo lici na hw issue...
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 16.04.2022., 22:24   #402
Postovi: 10,340
Nisam, ali budem. samo da skupim dovoljno logova pa da mogu izvući neki zaključak. Ako je hardverski issue, zanimljivo da se događa u dvije aplikacije koje efektivno najmanje vremena koristim.
Staro 16.04.2022., 22:49   #403
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,572
Malo sam bacio pogled i nisam vidio da se zale na takav problem.
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 19.04.2022., 18:31   #404
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,419
Ako niš drugo uvijek ti preostaje factory reset.
Izgleda kao da je grafa umrla.
Staro 19.04.2022., 19:12   #405
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,572
Mora da je majnao na njoj
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 19.04.2022., 19:29   #406
Postovi: 10,340
Nope, ni da stucne vise. Za vikend se vise/duze slusala mjuza (Plex, Deezer), a i igre sam zavrtio (Moonlight) - sve normalno.
Nisam napomenuo, box nije bio ni mlak na dodir kad se to desilo. I daljinski nije mogao pauzirati mjuzu. Znaci bas se nesto raspalo iznutra, nadam se samo softverski
Staro 19.04.2022., 19:31   #407
dadoremix
dadoremix's Avatar
Postovi: 4,752
Bas te voli factory reset
Staro 19.04.2022., 19:47   #408
Postovi: 10,340
Nope, not gonna happen. Radio sam ga s updateom sa closed bete 9.0 na sluzbeni 9.0, znaci nedavno.
Staro 19.04.2022., 20:45   #409
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,572
Barem jednom dnevno factory reset...
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 16.05.2022., 07:45   #410
Postovi: 10,340
Kada castate deezer ili yt music na shield tv, mozete li preko moba i google homea kontrolirati glasnocu shielda?
Probao preko volume tipki (cast volume) - ne reagira. Ako otvorim onaj cast menu (u principu google home app) i tamo diram volume, isto nista.
Ali uredno rade sve ostale kontrole za playback, skipanje, mute itd...
Jedino kada radi volume control je kada otvorim home app, pa odaberem shield, pa remote control i tamo imam isto tipke za volume.
Neki dan prodao chromecast audio puckove, znaci instant regret!
Staro 17.05.2022., 23:21   #411
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,572
Meni radi volume normalno kad castam na shield. Pritisnem volume na mobu i iskoci mi volume za cast... al' ne koristim deezer niti youtube music. Spotify to ima bolje rijeseno. Ako su mob i shield na istoj mrezi, starta app na shield i koristi neki svoj connect iako moze i chromecast ako app nije instalirana. Cak se kasnije mob moze maknuti sa iste mreze, remote za app connect jos uvijek radi. Ono izadjes van i mjenjas pjesme, volume doma
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 30.06.2022., 21:02   #412
Postovi: 10,340
Staro 30.06.2022., 21:32   #413
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,572
Uzbudjenju nikad kraja
[SHIELD Remote 2019] Adds option to only wake SHIELD with power button or NETFLIX button
Bolje nek dodaju da se moze Netflix button mapirati da starta nesto drugo, Plex recimo.
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 30.06.2022., 23:18   #414
Postovi: 10,340
Ako koristite USB DAC i izgubili ste volume slider kod pojacavanja/stisavanja zvuka, ne berite brigu. Odite u volume control postavke i ugasite CEC+USB fixed volume.
Ne kuzim zasto je to sad tako, te postavke su takve od pamtivijeka, ali eto nakon updatea sam izgubio volume slider i malo rovio po postavkama u nadi da cu skuziti sto se zbiva. Ne znam jel to sada bug ili feature
Staro 01.07.2022., 04:45   #415
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,572
Bugoviti feature
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 05.07.2022., 11:01   #416
sharkri
sharkri's Avatar
Postovi: 706
Pozdrav ekipica, kako riješiti ovaj problem sa kodi, ovo mi se događa kada zumiram sliku tako da nemam crnih crta gore i dolje na ekranu, takvih problema nisam imao na firesticku dok na nVidii imam.
Sig-5 redova normalne veličine max
Staro 05.07.2022., 11:17   #417
Postovi: 10,340
Same here, ali ne koristim toliki zoom pa nisam to ni primjetio dok nisi spomenuo. Ako zoomiram do ~1.2 onda je ok.
Staro 07.07.2022., 17:51   #418
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,722
Autor LAcy Pregled postova
Pa možeš to, moraš instalirati dodatan App, ja to napravio od prvog dana.
Nešto Button nešto se zove.
Ovo sa zoomom, jednostavno na Shield ne radi. Radi na nekom drugom playeru, ne sjećam se kojem, Emby brijem, ali Kodi je Kodi.
MMA
Staro 07.07.2022., 23:58   #419
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,297
Treba mu button mapper. Super radi na google chromecast with tv playeru.
Staro 08.07.2022., 00:37   #420
Postovi: 10,340
Button mapper je na 8.x radio ok, ako se ne varam, ali od Shield 9.x updejta app nije bio updejtan i ima bug kod remapiranja Netflix botuna. Barem je tako bilo dok sam ga koristio. Imao sam neke cudne probleme i prestao sam ga koristiti, ali sad se ne mogu sjetiti sto tocno me zaj*. Znam da se cesto kod reportanja bugova na Shield forumu savjetovalo "pokusaj ugasiti button remapper"...
https://www.nvidia.com/en-us/geforce...-known-issues/
"App Issues that require app developer to resolve:
Button mapper remap on Netflix button triggers Netflix button and the new button mapped"
Button remapper last updated 6.1.'22.
