Staro 24.02.2022., 15:45   #1771
Postovi: 34,120
Počeli su curiti podaci o P7. Po tim podacima, biti će manji i tanji, ali će imati veću bateriju. Kamere ostaju iste.
https://www.carhp.com/news/exclusive...era-dimensions
Staro 08.03.2022., 12:33   #1772
ThePornstar
ThePornstar's Avatar
Postovi: 4,403
Jučerašnji update za P4a je prolongirao vrijeme otključavanja na nekih sekundu i pol do dvije. Bravo Google!
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
Battery: 57 Wh internal
ROM: Android 9
Staro 08.03.2022., 13:11   #1773
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,809
Hahahaha kako mi je drago da sam se rijesio tog smeca…
Programer
Staro 08.03.2022., 13:53   #1774
kreatinko
kreatinko's Avatar
Datum registracije: Sep 2012
Postovi: 193
Autor Bubba Pregled postova
Meni sve radi kako treba nakon updatea sinoć.... aliiiiiiii od updatea na Android 12 mi baterija ne traje tako dugo, posebno sam skužio da se troši brzo kad je u standbyu :/
kreatinko je online   Reply With Quote
Staro 08.03.2022., 15:02   #1775
Dottore
Dottore's Avatar
Postovi: 7,735
P4 XL dobio march update i nadograđen SP2A.220305.012.
Отправлено через Pixel
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Dottore je online   Reply With Quote
Staro 08.03.2022., 15:16   #1776
ThePornstar
Postovi: 4,403
Autor kreatinko Pregled postova
P4a? Probaj isključiti AOD pa ćeš vidjeti u čemu je problem.
Nije lepo smejati se tuđoj nesreći
Jesi na Ajfonu?
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
ROM: Android 9
Staro 08.03.2022., 15:19   #1777
kreatinko
kreatinko's Avatar
Postovi: 193
[QUOTE=ThePornstar;3587966]P4a? Probaj isključiti AOD pa ćeš vidjeti u čemu je problem.
Imaš pravo, kad je AOD isključen treba mu 1-2s da se otključa :/ da, u pitanju je P4a
Staro 08.03.2022., 15:26   #1778
ThePornstar
Postovi: 4,403
Čak me ni to toliko ne ubija koliko novi, svijetliji ton sive ispod prikaza aktivnih aplikacija u pozadini.
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
ROM: Android 9
Staro 09.03.2022., 00:11   #1779
Dottore
Dottore's Avatar
Postovi: 7,735
Moj instantno otključava sa ili bez AOD. Uključen je face.
Edit. Nakon updatea izađe i update app.
Napokon Camera app dobio Locked Folder.
Za sada bez problema i još nisam naišao bug.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 26.03.2022., 22:54   #1780
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,922
Pixel 6, update za treci misec sjebe vibraciju.
Zaista valja pricekati nekoliko tjedana, poludija bi da sam ovo instalira, pa da mi vibra ne radi.
Staro 28.03.2022., 14:03   #1781
Ivo_Strojnica
PRO
Postovi: 4,922
Ekipa pitanje:
Pixel 6: sjedim u autu, na bluetoothu spojen auto i sat sa podrškom za pozive.
Zovem nekoga preko auto konzole, a on mi poziv na mobitel preusmjerava.
Kako složiti prioritizaciju bluetootha?
Kad mi je spojen auto, da pozivi idu na auto, a ukoliko nije spojen, onda ide na uređaj prioritetom ispod auta, primjerice taj sat ili slušalice?
Staro 29.03.2022., 07:43   #1782
Postovi: 34,120
Kad kažeš 'auto' misliš na auto kao vozilo ili Android Auto funkciju?
OP7T i S9/20 čim ih spojim na BT, sve mi ide preko njih - mjuza, pozivi, čak i audio od navigacije.
Savjet: riješi se tog poluproizvoda. Gori je od Kineza. Nikako s njime na zelenu granu, a svaki update ti shebe nešto novo.
Staro 29.03.2022., 11:04   #1783
Ivo_Strojnica
PRO
Postovi: 4,922
Jedino mi Huawei ima opciju da, zadnji Bluetooth na koji se spoji, da je glavni za sve.
Šta mi je jako logično zapravo.
Ako sam sija u auto i spoija se na radio bluetoothom (ne android auto), onda očekujem da sve ide preko tog bluetootha osim ako ja ne želim drukčije.
Iskreno, čekam da izađe neki pošteni custom ROM, uzet ću kod i to presložiti, ne da mi se sve sam slagati od nule, a kupovina novog mobitela mi se uopće sad neda.
Najgore od svega mi je naći lipu maskicu i zaštitu za ekran
Staro 29.03.2022., 12:06   #1784
Postovi: 34,120
Ja si uvijek uzmem Spigena. Maske nisu lijepe, ali obavljaju svoju funkciju.
Stakla? Bolja od ovih ćeš teško naći.
https://www.spigen.com/collections/p...40237826834479
https://www.whitestonedome.com/colle...film-protector
Staro 29.03.2022., 12:36   #1785
Ivo_Strojnica
PRO
Postovi: 4,922
krivo si me shvatija, imam ja sve složeno na pixelu, lijepo i funkcionalno.
Upravo zato ne želim opet novi mobitel
Staro 29.03.2022., 12:56   #1786
glazZ
glazZ's Avatar
Datum registracije: Jul 2010
Lokacija: Pakrac
Postovi: 359
Autor coconut Pregled postova
Uzimas bas sa spigena? Kako to dostavljaju, koliko je dostava za hr?
Poslano sa mog 2107113SG koristeći Tapatalk
glazZ je offline   Reply With Quote
Staro 29.03.2022., 14:01   #1787
Dottore
Dottore's Avatar
Postovi: 7,735
Spigen je dostupan, ovisi koji model. Nekada za Pixele nemaju.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 29.03.2022., 15:30   #1788
Postovi: 34,120
Spigena kupujem kod ovih. Koliko sam vidio, nemaju za Pixela, ali sigurno se može naručiti.
Staro 05.04.2022., 12:07   #1789
ThePornstar
Postovi: 4,403
Novi security update i novi improvementsi - otključavanje je ostalo isto. Oduševljen sam.
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
ROM: Android 9
Staro 05.04.2022., 14:45   #1790
brodjo
Playmaker
brodjo's Avatar
Lokacija: Osijek/Wien
Postovi: 1,670
Stvarno da su tolko mogli usrat taj fingerprint na Pixel 6
Čim je neka blaga kiša i imam 2 kapljice na ekranu, nema šanse da se otključa. Ne sjećam se koji je prvi ikad mobitel imao fingerprint, al hebo me pas ako i taj nije radio bolje
brodjo je offline   Reply With Quote
Staro 05.04.2022., 15:42   #1791
d0X
Kostolomac
d0X's Avatar
Postovi: 1,578
Autor brodjo Pregled postova
Mislim da je to do optičkog in-display fp-a općenito. Stariji (kapacitivni?) su bili brži i precizniji.
PSN Steam
Staro 05.04.2022., 15:55   #1792
Matta
El Mattador
Matta's Avatar
Lokacija: <->
Postovi: 1,955
Ako je netko koristio Oneplus 8 Pro i sada Pixel 6 / 6 Pro, ima li razlike kod brzine/točnosti fingerprint readera ?
Prezadovoljan sam sa brzinom otključavanja na Op 8 Pro. Ne mogu zamisliti da Pixel otključava lošije. Čisto me zanima da li je to subjektivno da je loš FP reader ili je baš loš. No, tko nije koristio Nokiu 9 Pureview ne zna šta je loš FP reader. Za čupati kosu kako je spor/netočan bio. Na kraju sam ga izgasio i koristio PIN.
A to da neće raditi kako treba ako je vlažan prst / ekran - ništa čudno, no to mi nije problem.
Matta je offline   Reply With Quote
Staro 05.04.2022., 15:57   #1793
sti
Lokacija: Lawl
Postovi: 1,381
Da, na mom prethodnom Huawei P20 Pro je kapacitivni i baš leti u odnosu na Pixel 6 Pro. Da bar omoguće face unlock sa prednjom kamerom, makar i da korisnik preuzme povećani sigurnosni rizik, ionako se svaka bitna aplikacija može zaključiti otiskom prsta.
Staro 05.04.2022., 19:50   #1794
Mr.Ex.President
Torrent freek
Mr.Ex.President's Avatar
Postovi: 3,953
Imho usrali su ga čim su ga sa zadnjeg dijela kućišta prebacili na ekran... Jer kako bi god uzeo mob i kojom god rukom, na tom zadnjem dijelu bi mi se prirodno našao jedan od 3-4 prsta koja sam stavio u Security. I nikad problema.
Na ekranu, em ne mogu otključat uopće jednom rukom ako sam mobitel uhvatio čudno jer mi je prenisko uglavnom, em kad je mokro također ne ide baš, otključa, ali ne iz prve
MBO: MSI B450 Gaming Plus
PSU: Corsair RM550X 550W
Periferija
LCD: HP ZR24w
Mouse: Logitech G400
Sound: Genius SP-HF1201A
Printer: HP LaserJet 1020
Scanner: HP ScanJet 4300
Headphones: Philips SHC 2000
MBO: Gigabyte GA-F2A85XM-HD3
HDD: WD Green 2TB [WD20EZRX]
PSU: Antec SU380
TV: Samsung 43E450 @HDMI
LINK
Staro 05.04.2022., 19:56   #1795
d0X
Kostolomac
d0X's Avatar
Postovi: 1,578
Ali imaš fora animacijice otključavanja itd., koga briga za funkcionalnost
PSN Steam
Staro 05.04.2022., 21:18   #1796
Matta
El Mattador
Matta's Avatar
Lokacija: <->
Postovi: 1,955
Evo izgleda da je ona izreka istinita: sto ljudi - sto ćudi.
Meni je fingerprint na leđima čudan totalno i izbjegavao sam mobitele sa istim.
OP 8 Pro sa integriranim optičkim (dakle, inferiornijim) čitačem radi savršeno i smještaj je odličan, s obzirom da mobitel u jednom danu (od 06:30h do 23:30h), bez pretjerivanja, otključam bar 200 puta, i to koristeći isključivo jednu ruku za držanje i otključavanje. Svaki slijedeći mob obavezno mora imati integrirani čitač otiska.
Što se tiče mokrih ruku - koliko vremena vi imate mokre ruke ili mokar ekran moba pa da je toliki problem ? Meni je posao takav da dnevno perem ruke vjerovatno više puta nego većina ovdje. Obriši i otključavaj. Ako nema ručnik onda zdravoseljačka tradicionalna opcija - od hlače.
Staro 06.04.2022., 00:16   #1797
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,310
Ekipa pitanje:
Koji sat, huawei?
Ako je, onda ti je problem u huawei health aplikaciji.
Mene je to isto izludjivalo u autu pa je jedino pomogao povratak na neku zadnju verziju na play storeu, u prijevodu nemoj instalirat zadnju verziju koju ti sama h.health aplikacija nudi.
Zadnje izmijenjeno od: Cuky. 06.04.2022. u 00:39.
Staro 06.04.2022., 13:54   #1798
Ivo_Strojnica
PRO
Postovi: 4,922
lipo ću ja disableati aplikaciju, pa ćemo viditi oće li se to i dalje pojavljivati.
javim večeras kako radi.
Staro 06.04.2022., 17:23   #1799
Ivo_Strojnica
PRO
Postovi: 4,922
Update: force close Huawei Health i radi sve normalno! Hvala!!!
Staro 06.04.2022., 22:27   #1800
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,310
Nema na cemu.
Al ono, ne vjerujem da to nisu mogli bolje slozit. Mene je to izludjivalo, mislio sam da je u mob problem. Kad na kraju sat.
