Lokacija: koprivnica
Postovi: 113
Kaj je bolje imat :confused: :confused:
MBO:Epox 9npa3j CPU :AMD 64,3000+ @2610MHz--290*9 RAM:2*512 G.E.I.L400 @480MHz--2,5-3-3-5 VGA:x1800xl 256mb@(570-1180mhz) HDD:WD 120Gb 8mb PSU :Tagan 430 easy con. CASE:black delux with sensors(cpu,graf,itd.) DVD-ROM :asus quickTrack ata100 16x DVD/RW:asus 16x16 |
Postovi: 18,960
2 x 1 GB CR 1T ne šljaka kod 4 x 512 MB
bycod
Lokacija: Zagreb / Dubrava
Postovi: 6,699
2 x 1gb
Junior Member
Datum registracije: May 2003
Postovi: 3,205
jel ove nove ploče oće radit u dual chanellu ak imas 1 pločicu od 1GB i dvije od 512? Nforce 2 je samo tak i radio
__________________ |
Postovi: 9,069
kako su dechki i rekli, 2x1gb svakako, bolje ce raditi, a i da ne govorimo da cesh za godinu dana mochi ubosti josh dva takva pa sve skupa 4gb.... ![]() @bruno zg probao sam jedan stick od 1gb i 2x256, ne rade u DC-u, tutto completo na single channel.
___________ Just atha x |
Junior Member
Postovi: 3,205
MIlsim da bi moralo bit 1 GB i 2x512..... ili 1x512 i 2x256...Ista kolicina rama po kanalu
#9 | |
Postovi: 12,433
Pa mem kontroler je u procu a ne na ploči! jedino neki ali ponavljam neki FX57 mogu držat 4 dvostrana keksa na 1T 2x1GB je bolje od 4x512MB ![]()
#10 | |
Strichek Moderator
Postovi: 9,347
žmnpp |
#11 | |
Postovi: 910
![]() Ja sam se samo osvrnuo na 1T post,ne na izbor 2 x 1GB ili 4 x 512 MB Naravno da je stvar i do proca ali: "To DFI's credit, many of the features of their new RDX200 board seem to be geared toward an understanding of what it will take to succeed with their new ATI chipset motherboard. Crossfire dual-video is on the board, but the emphasis is on performance and features. DFI lavished all the adjustments and tweak options of their nForce4 board on the RDX200 and then went even further. Oscar Wu found out how to make 4DS DIMMs run at 1T Command Rate and launched that solution with this board. He also claims that he has a working CAS 1.5 on the ATI motherboard, and the options for CAS 1.0 and 1.5 are available in the BIOS. Memory voltage extends to 4.0V, so any memory is supported, but this is done without special jumpers or a heat-producing work-around." http://anandtech.com/mb/showdoc.aspx?i=2572 |
The Dark Side of Moon
Postovi: 3,945
bolje je 2x1gb
#13 | |
Postovi: 12,433
![]() EDIT nisam ''sredio post'' zbog informacije koja (da odmah kažem nema veze s ovim) nego ovo nije niti mjesto niti vrijema a ponajmanje mi se da sad s tobom tu navlačit ![]()
''Of all the things I've lost I miss my mind the most'' Mark Twain Zadnje izmijenjeno od: Wolverine. 07.02.2006. u 00:52. |
#16 | |
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
U praksi to baš i ne radi kako su si oni zamislili. |
