#181 | |
Postovi: 8,630
Exclusive: Is Intel’s Arctic Sound already dead? ![]() Citiraj:
#182 |
Postovi: 8,630
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX |
#183 |
Postovi: 8,630
Intel Ponte Vecchio GPU to be liquid cooled inside OAM form factor ![]() Citiraj:
#184 |
All-rounder
Datum registracije: Sep 2013
Postovi: 1,342
Taj tile sustav je fascinantan, ako stvarno bude radio i držao temperature i latencije pod kontrolom, bit će to revolucija. Neobično da su to išli plasirati u okviru ovako kompleksnog proizvoda, razumijem da im je to primarno područje (serveri), ali i izazovi su bitno veći (više dijelova i 600W!). |
#185 | |
Postovi: 8,630
Tiles je Intelov naziv za chiplet dizajn, a kaj se samog pakiranja (1 - 2) tiče, svakako moraju isporučiti Ponte Vecchio GPU, jer su ga uz Sapphire Rapids CPU obećali za Aurora superračunalo. Citiraj:
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 15.06.2021. u 15:26. |
#187 |
Postovi: 8,630
Da, jer je Intel itekako svjestan da sad već opasno zaostaju, posebice za nVidijom koja je glavni HPC/AI/ML izbor, a to je ono kaj Intel cilja s Ponte Vecchio GPU-om. Zato su i išli za toliko kompleksnom arhitekturom koja onda naposljetku spaja nekoliko različitih proizvodnih procesa, nekolicinu pločica (tiles/chiplet) koji pak pojedinačno imaju zasebne funkcije i namjene (Rambo cache, HBM2, Xe GPU, I/O link, EMIB, itd.). Bog-bogova, ako to 2022. sprovedu u djelo kak spada. ![]()
#188 | |
Datum registracije: Sep 2018
Postovi: 309
koliko od toga ima potencijala za nas smrtnike? |
#189 |
Postovi: 8,630
Možda trenutno nema za nas direktno, ali ako im ovo uspije, onda imaju jako dobru podlogu za dalje, pa mogu iste ili slične tehnologije u godinama koje dolaze složiti, tj. iskoristiti za desktop i mobilne modele. Isto kak je AMD odradil sa svojim chiplet dizajnom, Infinity fabric + cacheom i ostatkom popratne skalamerije, koji su im danas sastavni dijelovi CPU i GPU ponude. Intelu je ovo jako bitno, jer u slučaju da ne zajebu sve po spisku i opet odgode, onda imaju dokaz da stvarno mogu odraditi kaj pričaju i obećavaju.
#190 |
All-rounder
Postovi: 1,342
AMD je to definitivno bolje odigrao, išao korak po korak i stekao nužno iskustvo s minimalnim rizikom, a Intel kao i sa 10nm želi sve odjednom, pri čemu je potencijal za greške i odgađanja daleko veći. Kao TSMC koji node smanjuje postepeno. Intel nema izbora nego ići na kamikaze ![]() |
#191 |
Postovi: 8,630
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 21.06.2021. u 10:45. |
#193 |
Postovi: 8,630
#195 | |
Postovi: 8,630
Intel video cards get a brand name: Arc, starting with "Alchemist" in Q1 2022 ![]() Citiraj:
#196 |
...samo te gledam...
Postovi: 2,837
Neka samo i na produkcijskim primjercima bude takva brzina, ovakvih najava smo se nagledali već s njihovim grafičkim karticama. Sjećam se da su isto tako bile pompozne najave za Intel i740 AGP grafičku karticu, ono tipa gotovo najjača grafička kartica u trenutku izlaska, kad ono pucanj u prazno, osrednja grafička kartica. |
#197 |
Postovi: 8,630
Valjda bude nekaj od toga, Raja još uvijek nije dobil otkaz, tj. zapravo je i promoviran, pa možda na kraju ipak ispadne nešto iz dosadašnji najava. Problem je kaj prvo idu mobilne verzije, a desktop izdanja potencijalno izlaze u vrijeme kad stiže RDNA 3 i sljedeća GeForce generacija.
#198 |
Datum registracije: Aug 2020
Postovi: 900
Ako Radeon bude kaskao opet ćemo imati duopol. |
#199 |
Postovi: 8,630
Ko zna kaj bude na kraju, ali AMD već sad ima spremno GPU chiplet rješenje za CDNA 2 i RDNA 3, dok nVidia isto tak priprema svoju varijantu. Od Intela tek trebamo vidjeti što su zapravo složili u tri godine od prve Rajine Twitter najave. ![]()
#200 |
Datum registracije: Oct 2010
Lokacija: Sfera
Postovi: 408
Jos nikad nismo imali 3 natjecatelja grafičkih. Znači li to da će Nvidia preskočiti sljedeću godinu sa 4000 serijom? |
#201 |
..starija garda
Postovi: 3,281
S3 savage je bio posljednji mohikanac, ako ne racunamo 3dfx xD Ako budu tri igraca, makar u mainstreamu, svi cemo biti sretni, pogotovo kada krenu cijene dole xD
#202 |
Postovi: 2,837
Bio je i Matrox neko vrijeme u igri, ali su onda prestali s ulaganjem u nove grafičke čipove na način kako su to radili Nvidia i ATI jer jednostavno nisu mogli slijediti njihov korak. Intelu je interesantno imati vlastiti GPU koje dovoljno snažan da se odupre ostalim igračima, ako ništa drugo barem u mobilnom segmentu jer tu kaskaju barem generaciju-dvije za ostalima. |
#203 |
Postovi: 8,630
#205 |
Lokacija: Sfera
Postovi: 408
Zanima me kakve će biti performanse sa Real time raytracing i jel njihovo rješenje isto kao i Nvidijino/AMD-ovo? Ako će igre imati DLSS hoće li XeSS moći biti aktivan i tada? |
#206 |
All-rounder
Postovi: 1,342
Tome služe videi gore. Pošto su na različitim mjestima u piplieneu, teoretski se mogu upaliti oba, iako teško da će to itko dopustiti. TLDR, Intel obećava temporalni upscaling kao DLSS, samo bez potrebe za dodatnim hardverom ala tensor cores, s lakoćom implementacije kao FSR. Ono što je važno je da radi na svim grafičkim karticama, cross vendor. Obećavaju i open source s vremenom. Osobno mi se čini da je to puno obećanja da bi sva bila ispunjena u potpunosti, ali vidjet ćemo. FSR mi se zbog lakoće implementacije i dobrih rezultata čini kao favorit, barem dok Nvidia ne otvori DLSS za ostale kartice (a hoće prije ili kasnije ). |
#207 |
Postovi: 8,630
Da, hrpu toga su obećali i najavili, a kad vidim da ženska prilikom XeSS tech-demo materijala, prvo krene na Space tipku, tako da odpauzira unaprijed pripremljen video - pitanje je da li se pokazano uopće ikad odvrtjelo na konkretnom hardveru, odnosno da li Intel uopće ima svoje rješenje stvarno spremno ili je sve zapravo samo izrenderirano (na čijem već hardveru) u Unreal Engineu i onda dodatno filtritano (blur, sharpness, itd.), tako da se stvore side-by-side razlike. Nažalost, ne bi bilo ni prvi ni zadnji put da se nešto prikazuje onakvim kakvim bi htjeli da bude (1 - 2), mada realno nije blizu tome, ali OK - budemo pričekali finalni proizvod.
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x8TB WD Red Plus | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 20.08.2021. u 13:31. |
#208 |
Lokacija: Sfera
Postovi: 408
Izgleda odlično no morati će konkurirati RDNA 3 i RTX4000. |
#209 |
Postovi: 4,496
Konkurirati performansama? Ne, samo treba imati dobru cijenu, uloženo/dobiveno i ljudi će kupovati. Ne prodaje se samo najbrže, isto kao i kod CPU. Naravno da je kvalitetno i stabilno sa dobrim driverima i da nije grijalica, to se podrazumijeva. |
#210 |
Datum registracije: May 2003
Postovi: 1,116
Intel ARC Alchemist Desktop Graphics Cards To Compete With AMD RX 6700 XT & NVIDIA RTX 3070, Pricing Starts at $100 US & Up To $500 US Samo da nebude "Tresla se brda...." https://wccftech.com/intel-arc-alche...-up-to-500-us/
SS |
