#3032 | |
Uptime freak
Lokacija: Ri, Cro
Postovi: 2,968
Dakle... po meni... imaš dvije opcije... platiti i kupiti polovno non-LHR ILI platiti i kupiti novo, ali LHR. U oba slučaja ćeš platiti puno. (za 120 MH ti trebaju 3x 3060Ti LHR, pa računaj koliko je to para i da li se isplati) |
#3035 |
Sir Paški
Postovi: 356
Nisam 3070 (non LHR) vidio ispod 1000 eura polovne ali da, barem nemas problema sa zagrijavanjem memorije kao na 3080. 3060ti (non LHR) su jos rijede. Sad je baza ova rx6600xt, tri takve i imas 90+ mh/s sa potrosnjom svake 60ak w ako sam dobro shvatio. Zadnje izmijenjeno od: Daedalus. 17.08.2021. u 08:04. |
#3036 |
Datum registracije: Dec 2020
Lokacija: Visegrad, BiH
Postovi: 212
Narode.. sta bi moglo da me zeza... 5700 xt na win rade super.. kada pokusam na hiveos nece ni naopako... ili ih ne pokrene nikako ili pocnu pomalo kopati tipa 16-20mhs i onda ispadnu.. u vecini slucajeva dobijam Aug 13 17:47:30 RX_5700xt kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring sdma0 timeout, signaled seq=2, emitted seq=3 Aug 13 17:47:30 RX_5700xt kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process pid 0 thread pid 0 Aug 13 17:47:30 RX_5700xt kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring sdma0 timeout, signaled seq=2, emitted seq=3 Aug 13 17:47:30 RX_5700xt kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process pid 0 thread pid 0 Aug 13 17:47:30 RX_5700xt kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring sdma1 timeout, signaled seq=1, emitted seq=2 Aug 13 17:47:30 RX_5700xt kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process pid 0 thread pid 0 Aug 13 17:47:31 RX_5700xt kernel: amdgpu 0000:03:00.0: amdgpu: failed to read reg:ec48 Aug 13 17:47:33 RX_5700xt kernel: amdgpu 0000:07:00.0: amdgpu: Msg issuing pre-check failed and SMU may be not in the right state! Aug 13 17:47:33 RX_5700xt kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring sdma1 timeout, signaled seq=1, emitted seq=2 Aug 13 17:47:33 RX_5700xt kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process pid 0 thread pid 0 Aug 13 17:37:38 RX_5700xt kernel: amdgpu 0000:03:00.0: amdgpu: message: TransferTableSmu2Dram (18) param: 0x00000006 is timeout (no response) Aug 13 17:37:42 RX_5700xt kernel: amdgpu 0000:03:00.0: amdgpu: Msg issuing pre-check failed and SMU may be not in the right state! probao sam dugi hiveos jer sam prvo na to posumnjao.. pa mjenao minere.. drajvere nisam podizao jer mislim da uz hiveos zadnji dodju zadnji i drajveri.... |
#3037 |
Datum registracije: Aug 2014
Postovi: 844
#3042 |
Uptime freak
Lokacija: Ri, Cro
Postovi: 2,968
#3043 | |
Datum registracije: Feb 2012
Lokacija: into the void
Postovi: 345
https://m.aliexpress.com/wholesale/p...f=auto_suggest Poslano sa mog POCO F1 koristeći Tapatalk |
#3044 |
Datum registracije: Aug 2016
Lokacija: osijek
Postovi: 43
Imam ja jednu viska sa 7 slotova u kompletu sa cpu i ram. Intel Core i7-6700K GIGABYTE Z170X-GamingG1 Corsair CMK16GX4M2B3000C15 2x8GB |
#3045 | |
MiningMod
Postovi: 8,715
https://www.nabava.net/search.php?q=Z490p&cod=&cdo= OOB sa 6 grafi |
#3047 |
Lokacija: Zagreb - Brinje
Postovi: 870
https://www.index.hr/mobile/clanak.a...sti&id=2298541 Beogradu poginula policajka: Ubio je strujni udar dok je rudarila kriptovalutu |
#3048 |
Datum registracije: Oct 2017
Lokacija: nigdje
Postovi: 475
SAMOANA: Nije u šoldima sve Nadmudrivanje sa budalom je kao hrvanje sa svinjom u blatu ..... nakon nekog vremena skužiš da svinja uživa |
#3050 | |
Lokacija: Bestovje,Sv.Nedelja
Postovi: 2,855
Nije,ipak nemam toliko i sigurno nebi dao da me snimaju u gaćama i tak ... BTW: Nemam AL frameove :-) i sve je na visini .... ![]() |
#3051 |
Lokacija: nigdje
Postovi: 475
onaj filmic je scena iz serije "12 reci" 1 epizoda @ Nbdy32 i kakva je situacija s temperaturama po ovim vrucinama posto je tavan? ili je potkrovlje pa ima prozore i vrata jer vidim svjetlo iza ledja...
SAMOANA: Nije u šoldima sve Nadmudrivanje sa budalom je kao hrvanje sa svinjom u blatu ..... nakon nekog vremena skužiš da svinja uživa Zadnje izmijenjeno od: livada2. 21.08.2021. u 13:44. |
#3053 | |
Lokacija: nigdje
Postovi: 475
pa tak se zove 12 reci https://www.imdb.com/title/tt13444828/ i to im je bio pocetak posle kupuju tek pravu opremu ![]()
#3054 |
Postovi: 2,855
Ovo je slikano negdje u proljeće, imam prozore na krovu i sa svake strane pa je lijepi propuh ... Temp, pa ne prelaze 60-tak stupnjeva, osim onih koje su reparirane ventovima ili kombinacijama,a to su 2 od 50-tak komada ... |
#3055 | |
tiki
Postovi: 2,793
