Staro 11.04.2021., 23:42   #871
Gigi1
Postovi: 2,138
Kazali su njegovi uradci
Staro 12.04.2021., 00:32   #872
Odinarius
All-rounder
Datum registracije: Sep 2013
Postovi: 1,342
Nije nikad ponovio kvalitetu leaka koju je imao sa chipletima, to je istina, ali analize su mu uvijek bile zanimljive za slušati.
Staro 12.04.2021., 21:35   #873
Le0n
Groarrr
Le0n's Avatar
Postovi: 438
Moram pohvaliti Asrock...
Memorija f4-3600c16d-32gtznc (Hynix chipovi) nije na QVL listi i kako kužim po redditu dosta se X570 muči s dualrank memom. Pogotovo s ovom GSkill ljudi imaju hrpu problema. Manifestira se da ne radi na XMP postavkama. Kod mene je od deklariranih 3600 jedva je radila na 3200 i na šit latencijama (16/19/19/39)
Bios updatei su išli:
- Agesa 1.1.0.0 patch D. - 3200MHz
- Agesa 1.2.0.0 - 3566MHZ
- jučer stavim Agesa 1.2.0.1 Patch A i hop 3800MHz (IF 1900)
Staro 13.04.2021., 20:01   #874
Postovi: 8,658
AMD Ryzen 5000G APUs: OEM only for now, full release later this year
Today the Ryzen 5000G series comes out to play, again for pre-built systems, but AMD is this time making clear that it will also come to retail for regular systems and gaming systems. These new Ryzen 5000G APUs are built on TSMC’s 7nm process, and will feature eight Zen 3 cores with Vega 8 graphics. All CPUs will also have 24 lanes of PCIe 3.0 and support DDR4-3200. This means that AMD will deal with 8-core CCX designs with a unified L3 cache across all the cores within a CCX. While the Ryzen and EPYC processors offer 32 MB of L3 cache for eight cores, the Ryzen 5000G will have 16 MB of L3, but each core will access to the full 16 MB. The Ryzen 5000G series remains a monolithic design. AMD has confirmed that X570, B550, and A520 motherboards will support the new 5000G processors. X470 and B450 motherboards might also be supported, but that depends on the motherboard manufacturer. At this time, for anyone lucky enough to get one on the open market, special Beta BIOSes will be needed to enable full performance.
Izvor: AnandTech
Staro 07.05.2021., 16:01   #875
sharyn
sharyn's Avatar
Datum registracije: Jun 2010
Lokacija: grubišno polje
Postovi: 569
hellou
eto mene na 4. ryzenu u karijeri; uletio 5800x po odličnoj cijeni
radi bez problema, boosta do 5ghz single core; nisam još testirao jer iskreno još nisam pohvatao taj PBO2 kako radi točno. Moram proučiti BIOS i pronać odgovore na par pitanja.
PS: grije se ko krme ne znam jesu li svi takvi ali ovaj će mi otopit kučište iako je pod vodenim.
validacija (rejected, ne znam zašto)
HWINFO
Zadnje izmijenjeno od: sharyn. 07.05.2021. u 18:55. Razlog: očito sam nepismen I
sharyn je offline   Reply With Quote
Staro 07.05.2021., 17:01   #876
Autor sharyn Pregled postova
hellou
eto mene na 4. ryzenu u karijeri; uletio 3800x po odličnoj cijeni
HWINFO
3800X? Da nije 5800X
Staro 07.05.2021., 18:55   #877
sharyn
sharyn's Avatar
Postovi: 569
Autor Brko Pregled postova
ahahah ae taj je da
Staro 08.05.2021., 00:52   #878
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,772
hellou
HWINFO
Congrats
Meni je isto pisalo rejected prvi put kad je cpu boostao na 4.7Ghz all core. Nedugo nakon toga sam isao ponovno napraviti validaciju, tad je boostao na 4.675Ghz i naravno proslo je
Staro 13.05.2021., 19:40   #879
Postovi: 8,658
AMD Ryzen 5 5600H Review: Faster than 10th-gen Core i9, Waiting for Tiger Lake
Overall, the Ryzen 5 5600H is another impressive Ryzen Mobile 5000 processor. Like other models in the line-up that we’ve reviewed so far, the 5600H isn’t the same revolutionary step that AMD introduced a year ago, but it does present a solid iteration that brings better performance in most areas. Compared to its direct predecessor, the Ryzen 5 4600H, the 5600H is roughly 10 to 15 percent faster in multi-threaded workloads and over 20% faster in single-threaded tests, which is respectable for a mainstream laptop processor. We could spend more time in this conclusion breaking down how the 5600H competes against Intel’s current offerings, but we don't feel that's necessary considering Tiger Lake H45 processors are just around the corner. AMD looks well positioned for the battle though, considering the 5600H is competitive in gaming, and can outperform even Intel’s flagship Core i9-10980HK in some productivity workloads.
Izvor: TechSpot
Staro 13.05.2021., 22:54   #880
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,772
Staro 14.05.2021., 10:35   #881
sharyn
sharyn's Avatar
Postovi: 569
igrao se s CTR sinoć malo, ova verzija je odlična.
single thread kucka na 4.950 ghz
PS: neke matične ploče imaju bug s CTR da tokom dijagnostike procesor razguli na 90 stupnjeva, izlazi patch za par dana. navodno.
Staro 14.05.2021., 16:52   #882
Le0n
Groarrr
Le0n's Avatar
Postovi: 438
Ja ne kapiram. CTR mi uvijek daje niži rezultat u R20 benchmarku. Ne ulazim u to da je procesor sada optimiziran da manje troši sl. ali mi je čudno da mi uporno skor ide na lošije a svima ide na bolje.
CTR je u jednom momentu bacio 90c pa je stao a inače je bilo non stop 60-65c. Piše da je moj 5800X golden sample (a i s 2 CCDa je).
Staro 14.05.2021., 16:57   #883
sharyn
sharyn's Avatar
Postovi: 569
jer ti sam CTR ukrade malo skora od CB-a
Staro 14.05.2021., 21:55   #884
Odinarius
All-rounder
Postovi: 1,342
Jel možeš molim te mali tutorial i koje vrijednosti unijeti za 3600? Moj je izgleda šrot Bronze sample i ne dobivam ništa vrijedno spomena, ali možda ga ne guram dovoljno.
Staro 14.05.2021., 23:25   #885
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,772
***ClockTuner for Ryzen 2.1 RC5(ver.23) by 1usmus***
AMD Ryzen 5 5600X 6-Core Processor
ASUS ROG STRIX B550-F GAMING
BIOS ver. 2201 SMU ver. 56.50.00
TABLE ver. 3672325
DRAM speed 3600 MHz
05/14/2021 20:37:02
P1
FREQ CCX1# 4475MHz
VID# 1150mV
Usage trigger# 81%
OB CCX1# 1
OB CCX2# 1
P2
FREQ CCX1# 4600MHz
VID# 1250mV
Usage trigger# 58%
OB CCX1# 1
OB CCX2# 1
PX
FREQ HIGH# 4875MHz
FREQ MID# 4850MHz
FREQ LOW# 4775MHz
VID HIGH# 1375mV
VID MID# 1375mV
VID LOW# 1350mV
OB HIGH# 1
OB MID# 1
OB LOW# 1
Usage trigger# 24%
PX OB LIMIT# 75MHz
PPT limit reached! 23,6W
EDC limit reached! 56,9A
EDC limit reached! 53,8A
EDC limit reached! 44,7A
TDC limit reached! 3,5A
TDC limit reached! 4A
Phoenix ready!
Cinebench R20 started
Cinebench R20 finished with result: 4298
Voltage: 1.164 V PPT: 76 W Temperature: 53.6°
20:39:15: Test 1 started!
Basic statistics
CORE / CPPC / FREQUENCY / VID / POWER / TEMP / DEBUG
C01 129 F 294 V 1.279 W 1.14 T 35.77 L 0.95
C02 140 F 4478 V 1.279 W 8.34 T 47.56 L 1.19
C03 133 F 159 V 1.279 W 0.89 T 33.25 L 0.921
C04 125 F 687 V 1.279 W 1.52 T 36.86 L 0.978
C05 137 F 152 V 1.279 W 0.68 T 32.01 L 0.918
C06 140 F 4462 V 1.279 W 8.37 T 49.56 L 1.178
Vdroop: 0.87%
4675 - PASSED
4700 - PASSED
4725 - PASSED
4750 - PASSED
4775 - PASSED
4800 - PASSED
4825 - PASSED
4850 - PASSED
4875 - PASSED
20:39:43: Cinebench stopped!
PX HIGH sub-profile
CPU usage(min): 16.7%
CPU usage(avg): 18.59%
CPU usage(max): 26%
SAFE: 4875MHz
FAST: 4900MHz
20:39:44: Test 1 finished!
20:39:44: Test 2 started!
Basic statistics
C01 129 F 216 V 1.288 W 1.06 T 37.21 L 0.936
C02 140 F 4579 V 1.288 W 9.11 T 50.89 L 1.203
C03 133 F 1732 V 1.288 W 3.68 T 42.53 L 1.019
C04 125 F 456 V 1.288 W 1.23 T 38.88 L 0.964
C05 137 F 4110 V 1.288 W 7.77 T 49.59 L 1.17
C06 140 F 4621 V 1.288 W 10.04 T 54.12 L 1.195
Vdroop: 1.31%
4675 - PASSED
4700 - PASSED
4725 - PASSED
4750 - PASSED
4775 - PASSED
4800 - PASSED
4825 - PASSED
4850 - PASSED
20:40:11: Cinebench stopped!
PX MID sub-profile
CPU usage(min): 33.3%
CPU usage(avg): 34.5%
CPU usage(max): 39.8%
SAFE: 4850MHz
FAST: 4875MHz
Max CPU usage for PX MID: 41%
20:40:11: Test 2 finished!
20:40:11: Test 3 started!
Basic statistics
C01 129 F 1728 V 1.3 W 3.7 T 47.24 L 1.039
C02 140 F 4632 V 1.3 W 10.68 T 56.94 L 1.215
C03 133 F 4108 V 1.3 W 8.71 T 53.34 L 1.174
C04 125 F 502 V 1.3 W 1.53 T 43.42 L 0.963
C05 137 F 4594 V 1.3 W 9.28 T 54.57 L 1.204
C06 140 F 4634 V 1.3 W 10.93 T 58.96 L 1.2
Vdroop: 1.56%
4625 - PASSED
4650 - PASSED
4675 - PASSED
4700 - PASSED
4725 - PASSED
4750 - PASSED
4775 - PASSED
4800 - PASSED
20:40:39: Cinebench stopped!
PX LOW sub-profile
CPU usage(min): 50%
CPU usage(avg): 51.37%
CPU usage(max): 53.1%
SAFE: 4800MHz
FAST: 4825MHz
Max CPU usage for PX LOW: 58%
20:40:39: Test 3 finished!
20:40:39: Test 4 started!
Basic statistics
C01 129 F 4330 V 1.16 W 7.05 T 50.63 L 1.079
C02 140 F 4330 V 1.16 W 7.12 T 50.38 L 1.072
C03 133 F 4330 V 1.16 W 7.3 T 51.79 L 1.06
C04 125 F 4330 V 1.16 W 7.22 T 53.97 L 1.07
C05 137 F 4330 V 1.16 W 6.94 T 49.1 L 1.057
C06 140 F 4330 V 1.16 W 7.32 T 53 L 1.066
20:40:49: Stress test stopped.
Start VID 1250
Start FREQ CCX#1 4500
Vdroop: 1.68%
4525 - PASSED
4550 - PASSED
4575 - PASSED
4600 - PASSED
4625 - PASSED
P2 PROFILE
VID: 1250mV
CCX#1: 4625MHz
20:40:53: Stress test stopped.
20:40:53: Test 4 finished!
20:40:53: Test 5 started!
Basic statistics
C01 129 F 4333 V 1.162 W 7.05 T 50.88 L 1.08
C02 140 F 4333 V 1.162 W 7.21 T 50.54 L 1.072
C03 133 F 4333 V 1.162 W 7.28 T 51.84 L 1.062
C04 125 F 4333 V 1.162 W 7.38 T 54.04 L 1.072
C05 137 F 4333 V 1.162 W 7.05 T 49.55 L 1.058
C06 140 F 4333 V 1.162 W 7.37 T 53.54 L 1.068
Start VID 1150
Start FREQ CCX#1 4300
Vdroop: 1.65%
4325 - PASSED
4350 - PASSED
4375 - PASSED
4400 - PASSED
4425 - PASSED
4450 - PASSED
4475 - PASSED
P1 PROFILE
VID: 1150mV
CCX#1: 4475MHz
20:41:11: Stress test stopped.
Cinebench R20 finished with result: 4441
Voltage: 1.15 V PPT: 76.8 W Temperature: 56.1°
20:42:25: Test 5 finished!
CORES ORDER (from the best to the worst)
### CPPC VID FIT
1 С06 С05 С04
2 С02 С03 С06
3 С05 С06 С03
4 С03 С02 С01
5 С01 С04 С02
6 С04 С01 С05
AVX light mode
Cycle time: 60000 ms
Reference frequency: 4375MHz
Reference voltage: 1187 mV
Voltage step: 6 mV
Manual overclocking mode enabled
20:42:32: Saving temporary settings...
20:42:37: CCX1 (125): 4375 MHz, 1187 mV
20:42:37: Step# 1. Diagnostic VID: 1187 mV
20:42:37: Stress test 1 started...
20:43:11: Stress test stopped.
20:43:13: Stress test 2 started...
20:43:20: Thread# 5 fall down!
20:43:20: Stress test stopped.
20:43:22: Step# 2. Diagnostic VID: 1076 mV
DIAGNOSTIC RESULTS
CPU VID: 1076
CPU TEL: 1052
Max temperature: 54,04°
Energy efficient: 4,16
Your CPU is GOLDEN SAMPLE
Recomended values for overclocking (P1 profile):
Reference voltage: 1150 mV
Reference frequency: 4450 MHz
Recomended values for overclocking (P2 profile):
Reference voltage: 1300 mV
Reference frequency: 4700 MHz
Recomended values for undervolting:
Reference voltage: 1025 mV
Reference frequency: 4200 MHz
Phoenix deactivated!
Ja imam generalno bolje performanse sa PBO + CO, CTR mi daje nesto nize rezultate. Za potrosnju me boli ona stvar, grijanje nije nikakav problem - cpu ne prelazi 60 ni pod razno.
Navodno imam Golden sample no sa CTR profilima cpu uredno manje boosta a time su i skorovi u benChmarcima nesto manji. Za sad preskacem CTR ... PBO + CO
TABLE ver. 3672325
DRAM speed 3600 MHz
05/14/2021 20:37:02
P1
FREQ CCX1# 4475MHz
VID# 1150mV
Usage trigger# 81%
OB CCX1# 1
OB CCX2# 1
P2
FREQ CCX1# 4600MHz
VID# 1250mV
Usage trigger# 58%
OB CCX1# 1
OB CCX2# 1
PX
FREQ HIGH# 4875MHz
FREQ MID# 4850MHz
FREQ LOW# 4775MHz
VID HIGH# 1375mV
VID MID# 1375mV
VID LOW# 1350mV
OB HIGH# 1
OB MID# 1
OB LOW# 1
Usage trigger# 24%
PX OB LIMIT# 75MHz
Phoenix ready!
Basic statistics
Vdroop: 0.87%
4675 - PASSED
4700 - PASSED
4725 - PASSED
4750 - PASSED
4775 - PASSED
4800 - PASSED
4825 - PASSED
4850 - PASSED
4875 - PASSED
PX HIGH sub-profile
CPU usage(max): 26%
SAFE: 4875MHz
FAST: 4900MHz
Basic statistics
Vdroop: 1.31%
4675 - PASSED
4700 - PASSED
4725 - PASSED
4750 - PASSED
4775 - PASSED
4800 - PASSED
4825 - PASSED
4850 - PASSED
PX MID sub-profile
SAFE: 4850MHz
FAST: 4875MHz
Basic statistics
Vdroop: 1.56%
4625 - PASSED
4650 - PASSED
4675 - PASSED
4700 - PASSED
4725 - PASSED
4750 - PASSED
4775 - PASSED
4800 - PASSED
PX LOW sub-profile
CPU usage(min): 50%
SAFE: 4800MHz
FAST: 4825MHz
Basic statistics
Start VID 1250
Vdroop: 1.68%
4525 - PASSED
4550 - PASSED
4575 - PASSED
4600 - PASSED
4625 - PASSED
P2 PROFILE
VID: 1250mV
CCX#1: 4625MHz
Basic statistics
Start VID 1150
Vdroop: 1.65%
4325 - PASSED
4350 - PASSED
4375 - PASSED
4400 - PASSED
4425 - PASSED
4450 - PASSED
4475 - PASSED
P1 PROFILE
VID: 1150mV
CCX#1: 4475MHz
### CPPC VID FIT
1 С06 С05 С04
2 С02 С03 С06
3 С05 С06 С03
4 С03 С02 С01
5 С01 С04 С02
6 С04 С01 С05
AVX light mode
Voltage step: 6 mV
DIAGNOSTIC RESULTS
CPU VID: 1076
CPU TEL: 1052
Staro 15.05.2021., 09:39   #886
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,480
Pa u samom članku je kratki video tutorial:
A u članku piše što točno trebaš podesiti u BIOSu.
Probam ja ovog svog, moram samo BIOS poštelat
Slobodno me dodajte na PSN
Staro 15.05.2021., 11:05   #887
Nick7
Lokacija: Velika Gorica
Postovi: 1,541
Hmm....ja sam probao sa PBO kod sebe, i s tim ide na 4.2GHz, ali i napon odd na 1.35V.
Probao rucno unjeti multi 44 (4.4GHz), napon 1.25V u BIOSu, i radi k'o raketa, s tim da napon dodje max do 1.2V.
Hladnije nego s PBO, a brze
Sent from my Redmi K20 using Tapatalk
Staro 15.05.2021., 11:15   #888
Odinarius
All-rounder
Postovi: 1,342
AMD Ryzen 5 3600 6-Core Processor
GIGABYTE B550 AORUS ELITE
BIOS ver. F10 SMU ver. 46.64.00
TABLE ver. 2361603
DRAM speed 3200 MHz
05/15/2021 09:55:08
P1
FREQ CCX1# 0MHz
FREQ CCX2# 0MHz
VID# 1175mV
Usage trigger# 81%
OB CCX1# 1
OB CCX2# 1
P2
FREQ CCX1# 0MHz
FREQ CCX2# 0MHz
VID# 1275mV
Usage trigger# 58%
OB CCX1# 1
OB CCX2# 1
PX
FREQ HIGH# 0MHz
FREQ MID# 0MHz
FREQ LOW# 0MHz
VID HIGH# 1450mV
VID MID# 1425mV
VID LOW# 1400mV
OB HIGH# 1
OB MID# 1
OB LOW# 1
Usage trigger# 24%
PX OB LIMIT# 75MHz
Phoenix ready!
Cinebench R20 finished with result: 3600
Voltage: 1.38 V PPT: 62.6 W Temperature: 65.2°
09:57:21: Silicon FIT measurement started...
09:57:39: Silicon FIT measurement done!
09:57:39: Stress test stopped.
CCX COEFFICIENTS
CCX# 1 0 CPPC 127
CCX# 2 0 CPPC 116
### CPPC FIT
1 С03 С05
2 С02 С03
3 С01 С04
4 С05 С02
5 С04 С01
6 С06 С06
AVX light mode
Reference frequency: 4050MHz
Reference voltage: 1350 mV
Voltage step: 6 mV
9:57:42: Saving temporary settings...
9:57:47: CCX1 (127): 4050 MHz, 1350 mV
9:57:47: CCX2 (116): 4050 MHz, 1350 mV
9:57:47: Step# 1. Diagnostic VID: 1350 mV
9:57:47: Stress test 1 started...
9:58:22: Stress test stopped.
9:58:23: Stress test 2 started...
9:58:57: Stress test stopped.
9:58:58: Step# 2. Diagnostic VID: 1344 mV
9:58:58: Stress test 1 started...
9:59:32: Stress test stopped.
9:59:34: Stress test 2 started...
10:00:08: Stress test stopped.
10:00:09: Step# 3. Diagnostic VID: 1338 mV
10:00:09: Stress test 1 started...
10:00:43: Stress test stopped.
10:00:44: Stress test 2 started...
10:01:19: Stress test stopped.
10:01:20: Step# 4. Diagnostic VID: 1332 mV
10:01:20: Stress test 1 started...
10:01:54: Stress test stopped.
10:01:55: Stress test 2 started...
10:02:30: Stress test stopped.
10:02:31: Step# 5. Diagnostic VID: 1326 mV
10:02:31: Stress test 1 started...
10:03:05: Stress test stopped.
10:03:06: Stress test 2 started...
10:03:40: Stress test stopped.
10:03:41: Step# 6. Diagnostic VID: 1320 mV
10:03:42: Stress test 1 started...
10:04:16: Stress test stopped.
10:04:17: Stress test 2 started...
10:04:51: Stress test stopped.
10:04:52: Step# 7. Diagnostic VID: 1314 mV
10:04:52: Stress test 1 started...
10:05:27: Stress test stopped.
10:05:28: Stress test 2 started...
10:06:02: Stress test stopped.
10:06:03: Step# 8. Diagnostic VID: 1308 mV
10:06:03: Stress test 1 started...
10:06:38: Stress test stopped.
10:06:39: Stress test 2 started...
10:07:13: Stress test stopped.
10:07:14: Step# 9. Diagnostic VID: 1302 mV
10:07:14: Stress test 1 started...
10:07:48: Stress test stopped.
10:07:50: Stress test 2 started...
10:08:02: Thread# 3 fall down!
10:08:02: Stress test stopped.
10:08:04: Step# 10. Diagnostic VID: 1308 mV
DIAGNOSTIC RESULTS
CPU VID: 1308
CPU TEL: 1296
Max temperature: 56,4°
Energy efficient: 3,12
Your CPU is BRONZE SAMPLE
Reference voltage: 1250 mV
Reference frequency: 3850 MHz
Reference frequency: 4000 MHz
Reference voltage: 1175 mV
Reference frequency: 3700 MHz
4100 na 1.3 odmah izbacuje errore.
AVX Light mode
Cycle time: 360000 ms
Reference frequency: 4100 MHz
CCX delta: 25 MHz
Target voltage: 1300 mV
10:18:46: Saving temporary settings...
Step# 1
10:18:51: CCX1 (127): 4100 MHz, 1300 mV OC+
10:18:51: CCX2 (116): 4100 MHz, 1300 mV OC+
10:18:52: Stress test #1 started...
10:18:56: CPU Vdroop: 0,4 % temperature: 52,2°
10:18:56: CCX1 overclocking failure detected!
10:18:56: Thread# 3 fall down!
10:18:56: Stress test stopped.
Step# 2
10:18:59: CCX1 (127): 4075 MHz, 1300 mV OC=
10:18:59: CCX2 (116): 4100 MHz, 1300 mV OC=
10:19:00: Stress test #1 started...
10:19:04: CPU Vdroop: 0,5 % temperature: 51,9°
10:19:05: CCX1 overclocking failure detected!
10:19:05: Thread# 3 fall down!
10:19:05: Stress test stopped.
Tuningom dobijem 52 C20 boda za 10 stupnjeva više zagrijavanja, koja smijurija
Vidio sam i čitao tutoriale, ali čini se da naprosto imam krumpir. Preko Ryzen Mastera je još i držao taktove od 4300 u stressu, cinebench nema šanse (4050 all core sa i bez pbo).
Nakon što CTR dovrši dijagnostiku, smanji mu defaultnu reference frequency sa 4075 na 3850. Toliko je loš primjerak I jedna stvar koja me zbunjuje je što mi je Calculate profile stalno zasivljen. Mogu ih samo ručno unijeti.
TABLE ver. 2361603
DRAM speed 3200 MHz
05/15/2021 09:55:08
P1
FREQ CCX1# 0MHz
FREQ CCX2# 0MHz
VID# 1175mV
Usage trigger# 81%
OB CCX1# 1
OB CCX2# 1
P2
FREQ CCX1# 0MHz
FREQ CCX2# 0MHz
VID# 1275mV
Usage trigger# 58%
OB CCX1# 1
OB CCX2# 1
PX
FREQ HIGH# 0MHz
FREQ MID# 0MHz
FREQ LOW# 0MHz
VID HIGH# 1450mV
VID MID# 1425mV
VID LOW# 1400mV
OB HIGH# 1
OB MID# 1
OB LOW# 1
Usage trigger# 24%
PX OB LIMIT# 75MHz
Phoenix ready!
CCX COEFFICIENTS
CCX# 1 0 CPPC 127
CCX# 2 0 CPPC 116
### CPPC FIT
1 С03 С05
2 С02 С03
3 С01 С04
4 С05 С02
5 С04 С01
6 С06 С06
AVX light mode
Voltage step: 6 mV
DIAGNOSTIC RESULTS
CPU VID: 1308
CPU TEL: 1296
AVX Light mode
CCX delta: 25 MHz
Step# 1
Step# 2
Zadnje izmijenjeno od: Odinarius. 15.05.2021. u 11:39.
Staro 15.05.2021., 12:20   #889
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,480
Evo tu malo detaljniji tutorial. Ja jos vrtim svog, za svaki profil po cca 45min.
EDIT: Moj ima za dlaku bolje perf od tvoga tj mali visi clock. 100mhz po profilu.
Zadnje izmijenjeno od: Disco. 15.05.2021. u 12:27.
Staro 15.05.2021., 13:37   #890
Odinarius
All-rounder
Postovi: 1,342
Moj je po tablici rezultata vjerojatno najgori uopće s obzirom na voltažu.
https://docs.google.com/spreadsheets...#gid=403143418
Staro 15.05.2021., 15:23   #891
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,480
Evo mojih rezultata, normalno mi je all core clock oko 3,95, dok mi ga je ovo čudo mrvu povećalo, a smanjilo vcore. Ali zato mi je single core clock max bio 4,15 (sa nekim starijim biosom je išlo do 4,2), dok mi ga je CTR podesio na 4,35.
I sve 5, osim što kad uključim taj hibridni OC i aktiviram sva 3 profila, OCCT bude krcat greškama nakon cca 5min.
Ali evo par sličica:
Stock(PBO?):
CTR hybrid:
P1:
P2:
Svi profili sa PX-om:
1usmus spominje da to silovanje proca sa small FFT/Data u stvarnosti nećemo vidjeti nikad...ta tvrdnja vj drži vodu, isto tako veli da moramo i sami dodatno provjeriti stabilnost jer CTR nije svemoguć.
Caka je da CB prolazi bez frke, ali OCCT sa najjačim postavkama ne.
Inače, ovaj moj proc u OCCTu spušta takt na 3,85 kada je na defaultu, a CTR mu to neda sa ovim postavkama.
Pa eto, kome se da malo gubiti vrijeme.
EDIT: Nestabilno je i u CB, srušio se nakon 20ak min.
Dakle, nazad na automatiku.
Zadnje izmijenjeno od: Disco. 15.05.2021. u 16:00.
Staro 15.05.2021., 18:27   #892
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
Potpuno isto i kod mene sa dva 3600. Sve preko 4200 all core umiranje na small ftt. Na istoj ploči mozda je ona. Who knows.
Stavio sam sad all core 4.0@1.065 minus vdroop
Small FTT nakon 40min 58~60°C dok je na 4.2 nakon 10min preko 90° @1.3V
Automatski all core 3.9,single core burst na 4.15~4.2 dakle ništa spešl osim temperature
Staro 15.05.2021., 19:05   #893
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,772
Decki, NHF ali ovo je ipak zen3 tema
Staro 15.05.2021., 22:35   #894
sharyn
sharyn's Avatar
Postovi: 569
5800X
navodno gold sample, mada mislim da to ne znači ništa previše spektakularno.
na ovome je stabilan, još se treba poigrat malo sa generalnim clockom jer ima još lufta.
navodno će 1usmus izbacit nekakvi patch koji će poboljšat PX profil.
Zadnje izmijenjeno od: sharyn. 15.05.2021. u 22:36. Razlog: neće slika ostat u postu :(
Staro 15.05.2021., 22:46   #895
Dr. Strange
Datum registracije: Aug 2020
Postovi: 900
https://www.hardwaretimes.com/amd-ry...3-chip-supply/ 5900x najprodavaniji model, izgleda da ljudi pošto je ovo zadnja AM4 platforma uzimaju future proof modele da ne moraju kasnije mijenjat.
Staro 18.05.2021., 02:18   #896
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,281
Autor Dr. Strange Pregled postova
ma i cijena je best buy i drzat ce cijenu dugo, pa se nece puno gubiti prilikom prodaje , te uz to ne ocukujem da ce ga nesto tako brzo znacajno prestici po performansama ni konkurencija ne nudi nesto bitno, ni ti amd se sada ima sta zuriti izdati nasljednika, sto je opet pokazatelj da je "dobra" investicija
MojSkuter
Eladio je online   Reply With Quote
Staro 26.05.2021., 16:01   #897
ezav
ezav's Avatar
Postovi: 130
Ete i ja se pridruzil klubu ...
Za sada dosta bolje nego stari i7-2600 , mada to nije nis cudno realno.
Name:	Ezav komp.jpg‎
"What do humans know of our pain? We have sung songs of lament since before your ancestors crawled on their bellies from the sea."
- Farseer Eldrad Ulthran
ezav je offline   Reply With Quote
Staro 26.05.2021., 18:45   #898
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,772
Autor ezav Pregled postova
Congrats , definitivno vrijedan upgrade...
Staro 30.05.2021., 02:12   #899
Odinarius
All-rounder
Postovi: 1,342
Uletio 5800x
Ovaj reagira fantastično na tjunanje, po CTR 2.1 je Golden Sample. Dobio je 100mhz all core u odnosu na default, a temp pale za 15c. Namjestio ga je pinkicu manje od Sharyinovog, all core drži 4625mHz, single 4900. Skor u C23 nakon tjuniranja je MT 15825, ST 1619. Ja zadovoljan
Očekivano, s ovom grafičkom u igrama nema nikakvog pomaka, čeka se neki novi Radeon po pristojnoj cijeni.
Staro 30.05.2021., 09:37   #900
Mladenxy
Mladenxy's Avatar
Postovi: 4,511
Brutala od procesora.
