Staro 19.03.2021., 20:03   #4411
exzzy
exzzy's Avatar
Datum registracije: Aug 2014
Postovi: 843
Pa vec je to odavno u maloprodaji, anandtech je radio review sa procom kupljenim u dućanu.
Staro 19.03.2021., 20:18   #4412
Revolver3844
Datum registracije: Apr 2017
Lokacija: SB
Postovi: 715
10400f i 11400f su u 2-5% pretpostavljam ?
Šta je u glavama tih budala iz intela ?
Revolver3844 je offline   Reply With Quote
Staro 19.03.2021., 20:45   #4413
Postovi: 8,224
Zajebavaju se dok marketing hype mašina radi punom parom, a zapravo ne gledaju širu sliku (1 - 2), već se sad i s novim generalnim direktorom fokusiraju na pizdarije i podjebavanja (1 - 2) dojučerašnjih poprilično velikih i bitnih partnera.
In July 2019, Intel sold most of its modem business to Apple at a multi-billion dollar loss, as much as $4 billion per year on mobile research and development, while the mobile business lost an estimated $16 billion between 2011 and 2018.
Uredno se troše milijarde na akvizicije (1 - 2 - 3) koje se kasnije pokazuju kao upitne i dubiozne isplativosti, ali nema veze ...
Intel announced plans to buy Mobileye in March 2017 for a cool $15.3 billion. There it is. Mobileye was bought because Intel believed it was creating the technological foundation on which the future of autonomous driving would be built. Intel currently finds itself fighting battles on all fronts. With nVidia and AMD (and Xilinx) in datacenter and compute. With TSMC and Samsung in manufacturing. It has lost Apple as a CPU customer. Pat Gelsinger starts as CEO on Monday (Feb. 15), Intel’s third in four years. Meanwhile Mobileye continues to make promises and drain resources from Intel, all for less than a billion dollars of revenue in 2020, equating to just a little over 1 percent of total revenues of nearly $78 billion.
... dokle god Ryan Shrout i Raja Koduri slažu nove tehnologije i slajdove za iste, Intel nema brige, mada ih konkurencija (1 - 2 - 3) ostavlja u prašini.
Budemo vidjeli kaj budu najavili sljedeći tjedan, ali moglo bi biti na foru ...
Today, in the leaked HPE listing, we get to see some of the Xeon models Intel plans to launch. Starting from 32-core models, all the way to 40-core models, all SKUs above 28 cores are supposed to use dual die configuration to achieve high core counts. The limit of a single die is 28 cores. HPE listed a few models, with the highest-end one being the Intel Xeon Platinum XCC 8380 processor. It features 40 cores with 80 threads and a running frequency of 2.3 GHz. If you are wondering about TDP, it looks like the 10 nm SuperFin process is giving good results, as the CPU is rated only for 270 Watts of power.
... slijepljenih tehnoloških rješenja.
Zadnje izmijenjeno od: The Exiled. 19.03.2021. u 20:52.
Staro 19.03.2021., 23:07   #4414
Revolver3844
Lokacija: SB
Postovi: 715
To je veliki skup kretena na jednom mjestu.
Staro 20.03.2021., 18:14   #4415
Postovi: 8,224
Zato je već krenula Alder Lake ofenziva, dok im nova generacija službeno još nije ni lansirana.
First and foremost, Intel claims up to 20% single-thread performance uplift with its new Golden Cove core design. We are not sure if the baseline for this claim is Rocket Lake or Tiger Lake though. There is also a confirmation on DDR5 and DDR4 support, the platform will actually support both memory technologies at the same time. The new desktop CPUs will support up to dual-channel DDR5-4800 memory. The DDR4-capable motherboards will support up to 3200 MHz modules. We were told that high-end Z690 motherboards are to offer DDR5 support, whereas cheaper variants would rely on DDR4.
Potvrđeni hibridni DDR4/DDR5 IMC je svakak plus, a još ako AMD sa Zen 3+ (prema nagađanjima) omogući istu stvar, to je to.
Staro 20.03.2021., 18:40   #4416
Meni ovo sad počelo izgledat kao pred 10tak godina kad je nVidia svakim novim driverom napisala na svojoj stranici koliko % se dižu performanse u pojedinoj igri. Sjećam se da je netko izračunao da se u nekom Battlefieldom po toj matematici performance povećao za cca 320%
Tad ih je netko javno ismijao pa su prestali te postotke trpati.
Intel tj Ryan baca te postotke šapkom i kapom. Tak je i Raketlin trebal bit 10+% brži od Zen3 pa na kraju jbg.
Čemu to? Bacite van procesor pa nek bude koliko bude % bolji. Ovako unapred pisati gluposti generaciju za generacijom već postaje istovremeno i smiješno i žalosno za giganta i nekoć ozbiljnu firmu.
Staro 20.03.2021., 18:54   #4417
Postovi: 8,224
Moraju tak, da ostane dojam najboljih. Mada, recimo da je istina, jer u tom kontekstu onda s Alder Lakeom dolaze na kakvih 10% do možda 15% bolje od trenutnih Zen 3 modela, pod uvjetom da stvarno bude tak kak pričaju.
Hibridni IMC su pokupili s Tiger Lakea, tak da je taj dio OK. Jedini zajeb u svemu tome je Zen 3+ koji bude isto tak imal određeni IPC napredak u odnosu na Zen 3, pa dolazimo to onoga kaj smo pričali - Alder Lake (samo) u rangu Zen 3+.
Staro 21.03.2021., 22:59   #4418
Exy
Exy's Avatar
Lokacija: Zagreb, Črnomerec
Postovi: 2,513
Autor Revolver3844 Pregled postova
10400F ostaje best buy, ne znam kad smo zadnji put imali takav bang for buck za bijednih 1k kuna. 99% ljudi za gayming ne treba ništa više. 10700F je zanimljiv, ali je vrlo upitno da li su dvije jezgre vrijedne duplo više para.
Gledam na anandu test 11700K....pa to samo brutalan marketing može prodat, srećom za Intel tu su jaki
Staro 22.03.2021., 07:48   #4419
Mladenxy
Mladenxy's Avatar
Postovi: 4,336
Nisu "samo" dvije jezgre, memorija radi na većoj frekvenciji ako koristiš B460 ploču i core boost je veći za sve jezgre.
i7 10700F
4800 MHz (1 core)
4600 MHz (all cores)
i5 10400F
4300 MHz (1 core)
4000 MHz (all cores
https://www.cpu-world.com/Compare/65...i7-10700F.html
Zadnje izmijenjeno od: Mladenxy. 22.03.2021. u 07:57.
Staro 22.03.2021., 08:23   #4420
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,262
i7 10700F
4800 MHz (1 core)
i5 10400F
4300 MHz (1 core)
4000 MHz (all cores
To sve na kraju bude vj 5% ili manje razlike.
Slobodno me dodajte na PSN
Disco je online   Reply With Quote
Staro 22.03.2021., 11:29   #4421
Odinarius
All-rounder
Datum registracije: Sep 2013
Postovi: 1,319
S bilo kojom normalnom GPU, i razlika do Ryzena 5950X je 5% Treba kupovati pametno, proc koji nam treba, one onaj koji bi željeli
Staro 22.03.2021., 11:32   #4422
Postovi: 8,224
Današnji 10400(F) modeli su ono što su prije bili R5 1600(AF)/2600, R7 2700(X), R5 3600 i 8400, jer su svi u jednom trenu bili jako popularni u rangu od 1.000 kn do 1.200 kn po kojekakvim akcijama i sniženjima.
Staro 22.03.2021., 12:49   #4423
S time nek se tješe svi koji ne mogu pregristi i kupiti si ono što žele pa moraju kupovati "pametno i mudro" a oni koji mogu pregristi, ti kupuju "glupo i nepotrebno"
Kao što rekoh, svatko kupuje po svojim željama, potrebama i prohtjevima bez obaveze da se nekome opravdava ako za to ima sreCtva
Suma summarum - kupuj pametno sebi ali ne pametuj drugima
Staro 22.03.2021., 13:49   #4424
darkijas
darkijas's Avatar
Postovi: 1,806
Jel ce na tim novim intel procesorima barem igpu stogod napredovati.
darkijas je offline   Reply With Quote
Staro 22.03.2021., 14:00   #4425
Postovi: 8,224
Ništa posebno, mada se vodi kao Xe-LP rješenje, daleko je to od onih kakve ima Tiger Lake. Dobro bude za Quick Sync hardversku akceleraciju i za rezervu, ako primarni GPU krepa.
Tiger Lake has 96 Execution Units but of the new Xe-LP architecture. On top of that, there’s the new SuperFin transistor stack that promises to drive frequencies (and power windows) a lot higher, making Tiger Lake more scalable than before. Where Gen11 graphics saw frequencies up to 1100 MHz, the initial Xe-LP designs with Tiger Lake are at 1450 MHz. Intel has teased that future versions of Xe-LP (likely the discrete DG1 card) will go up to 1750-1800 MHz.
Staro 23.03.2021., 06:10   #4426
Mladenxy
Mladenxy's Avatar
Postovi: 4,336
https://www.youtube.com/watch?v=3n0_UcBxnpk
više troši, manje meda daje i još je skuplji
Staro 23.03.2021., 08:48   #4427
Postovi: 8,224
Koji lik, odmah u naslovu "Waste of sand", pa nek se Intel i JubiTo algoritam lijepo jebu. Core i9 bude sigurno bolje prošel sa istim brojem jezgri i cijenom od 600€.
Staro 23.03.2021., 15:44   #4428
Dr. Strange
Datum registracije: Aug 2020
Postovi: 892
Znači fail kao i sve od Intela u zadnje vrijeme...
Staro 23.03.2021., 17:33   #4429
Mladenxy
Mladenxy's Avatar
Postovi: 4,336
Autor Dr. Strange Pregled postova
Zašto su i5 10400F i i7 10700F fail, čak i verzije sa IGPU u današnje vrijeme? Imaju loš uloženo/dobiveno faktor, loše performanse ili nešto treće?
Staro 23.03.2021., 17:52   #4430
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Nevjerojatan launch
Znao sam da neće biti nešto mega, no uspjeli su i mene razočarati
Staro 23.03.2021., 18:15   #4431
Postovi: 8,224
Tu je počelo, a onda smo lagano komentirali da po svemu sudeći nemaju ništa konkretno. S moje strane da budu u najboljem slučaju u rangu Zen 3 modela, ali jebiga, nije prošlo.
Staro 23.03.2021., 18:21   #4432
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Zato će na i9 modelu imati tri različite tehnologije za boost (Turbo Boost 2.0, Turbo Boost Max 3.0 i Adaptive Boost), pa će biti i više FPS-ova u igrama . Za potrošnju se ionako ne pita pita kad je Intel u pitanju. Taj Adaptive Boost će po defaultu navodno biti ugašen, jer ipak bi bilo previše očekivati od svih ploča da mogu tjerati taj CPU na 5.1 GHz all-core boostu.
Staro 23.03.2021., 18:23   #4433
Mladenxy
Mladenxy's Avatar
Postovi: 4,336
Ja još uvijek ne mogu vjerovati da je to, TO. Sve čekam biti će neki AS iz rukava, barem jedan dostojan model Nevjerojatno da su izbacili novu seriju lošiju i skuplju od prošle.
Staro 23.03.2021., 18:24   #4434
Postovi: 8,224
Autor MadBoY Pregled postova
Da, Intelova verzija AMD Ryzen rješenja, ali čak i s tim ovo već lagano postaje tragikomično, pogotovo, jer već Alder Lake najavaljuju kao (opet) novog pobjednika u svemu.
Na stranu to da budu spajali velike i male jezgre i to bude naposljetku prezentirano kao isto, tj. ekvivalentno sadašnjim R9 16C/32T modelima, ako ne i bolje.
Nažalost, ali tak je, kad uporno sve baziraju na jedno-te-istoj pizdariji, dok se direktori i glavni inženjeri rotiraju ko na kolodvoru, a nofce umjesto na R&D troše na reklame i marketing u kojem svi ostali ispadaju lošiji.
Staro 23.03.2021., 18:31   #4435
Odinarius
All-rounder
Postovi: 1,319
5 godina nisu imali ništa novoga pa je najava 19% povećanja IPC-a, nakon Tiger Lakea na laptopima koji je to manje više i postigao, zvučala realno (znam da je Tiger Lake novija arhitektura, ali svejedno, to postoji na tržištu pa je normalno da se s tim uspoređuje). Kad ono... AMD kad kaže 19%, to i bude tu negdje, a kod Intela je "up to", odnosno valjda u jednoj aplikaciji i regresija u niz drugih...
Ono, kužim da muljaju kad istu arhitekturu vrte peti put pa nemaju što za pokazati, ali nadaš se da će s novom doći nešto opipljivo. Ima logike da najave budu realne, s TDP-om kao nedostatkom. Šipak. Sad im ništa ne vjerujem za Alder Lake dok ne vidim. Nije me previše briga za Intel, nego je konkurencija dobrodošla.
Staro 23.03.2021., 18:37   #4436
Postovi: 8,224
Tiger Lake je dobro ispal, tj. Intelu su takve mobilne arhitekture uvijek dobro prolazile, ali onda frajeri misle da je ovo još jedan Conroe, pa daj da složimo novi Core 2 Duo, ali ovaj put da sjebemo sve Ryzen modele, ali ništa od toga, dok na sva zvona najavljuju sve živo i neživo pod Suncem za kaj više od 10 godina nismo ni čuli, dok se 2017. nije pojavila konkurencija i onda odjednom i veliki Intel radi na svemu i naravno da je bolje od bilo kakve druge tehnologije ili tehnološkog rješenja općenito. Budemo vidjeli kaj bude od svih tih obećanja na kraju ispalo, ali da djeluje optimistično - ne, pogotovo kad iz godine u godinu pričaju bajke, a realnost ih uredno poklopi. Nažalost.
Staro 23.03.2021., 18:45   #4437
Manuel Calavera
Postovi: 14,584
Jedan fun fact - AMD je imao podjednak IPC napredak kao intel od negdje 25-30% od prve do zadnje bulldozer iteracije (kao intel od sandy do skylake jezgri).
Razlika je u tome što je AMD imao ogroman zaostatak u startu u vrijeme sandy-zembezi (prvi bulldozer), te se to nikako nije moglo nadoknaditi.
Hoću reći ako intel sad usere sa alder lakeom, a ovi nastave ovako sa 15-20% porasta po generaciji, bit će to teško stići, čak i ako im kasnije budu generacije imale dobre napretke
Staro 23.03.2021., 18:46   #4438
Odinarius
All-rounder
Postovi: 1,319
Slušam neki podcast sa Semiwiki i kaže tip da USA goverment ima 28 milijardi dolara u fondu za proizvodnju čipova i da bi dio toga mogao ići Intelu da se osigura proizvodnja čipova na američkom tlu. Odgovara drugi tip, ali nije problem u novcu, Intel ima i 10 i 20 i 30 milijardi dolara i već ih je spalio u R&D i tvornice, problem je u nečem sasvim drugom što se ne može riješiti novcem.
Staro 23.03.2021., 18:50   #4439
Postovi: 8,224
Da, slušal sam ih neki dan, jesi čul kaj su rekli za Intelov 7nm proces - "that ship has sailed" - i tu dolazimo do onoga kaj smo već raspravljali.
Taman da Intel sutra pređe na TSMC i bude 1:1 s AMD-u po pitanju procesa, bez nove arhitekture i dalje su u kurcu.
Ove im Alder Lake najave i dalje djeluju ko "seremo kvake, dok Ryan Shrout slaže prezentacije".
  • Zen vs. Bulldozer 52%+ IPC porast
  • Zen+ vs. Zen ~7%+ IPC porast
  • Zen 2 vs. Zen(+) ~10/15%+ IPC porast
  • Zen 3 vs. Zen 2 ~19%+ IPC porast
  • Zen 4 vs. Zen 3 ~25%+ IPC porast
Zadnje izmijenjeno od: The Exiled. 23.03.2021. u 18:58.
Staro 23.03.2021., 18:54   #4440
Mladenxy
Mladenxy's Avatar
Postovi: 4,336
Meni performanse nisu tragične, dapače. Cijene su tragične. Daj i5 11400f za 800 kn i i7 11700f za 1500 kn i da vidiš. Sve priče staju, kupuje se i fura u tačkama.
