Staro 11.03.2021., 21:37   #1021
domy_os
domy_os's Avatar
Postovi: 18,960
Pa zar nemaš weekly crontab task za TRIM? Imao sam ga na Mintu, imam ga i sad na Fedori. Ili mislimo na nešto drugo?
EDIT: Zapravo nije crontab nego systemd timer...
Code:
[domy@Domy-NB etc]$ systemctl status fstrim.timer
● fstrim.timer - Discard unused blocks once a week
     Loaded: loaded (/usr/lib/systemd/system/fstrim.timer; enabled; vendor preset: enabled)
     Active: active (waiting) since Tue 2021-03-02 17:46:58 CET; 1 weeks 2 days ago
    Trigger: Mon 2021-03-15 01:07:20 CET; 3 days left
   Triggers: ● fstrim.service
       Docs: man:fstrim
ožu 02 17:46:58 Domy-NB systemd[1]: Started Discard unused blocks once a week.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Zadnje izmijenjeno od: domy_os. 11.03.2021. u 21:48.
Staro 11.03.2021., 21:53   #1022
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,890
oooo, ja to nemam.
Molio bih skriptu, barba
Staro 11.03.2021., 22:26   #1023
domy_os
domy_os's Avatar
Postovi: 18,960
oooo, ja to nemam.
Koju?
Staro 12.03.2021., 00:01   #1024
c-shadow
c-shadow's Avatar
Postovi: 3,529
Autor domy_os Pregled postova
Code:
       Docs: man:fstrim
Imam, ali iz nekog razloga se to pokretalo i na svakom bootu što ja nisam znao. A nisam niti očekivao da traje tako dugo.
EDIT:
I dalje jubuntu pokreće trim na svakom bootu.
Ovo je isti komp, s Crucial MX, samo to nije problem jer traje 10s, a ne 10 min kao sa starom Adatom. Kako je stroj upaljen 24/7 ne zamaram se time ali dobro je znati
Code:
uptime
 07:01:33 up 34 days, 17:09,  2 users,  load average: 0,72, 0,87, 0,75
 systemd-analyze blame
          11.503s fstrim.service
          3.138s NetworkManager-wait-online.service
          2.222s sendmail.service
          1.257s nfs-server.service
           696ms media-multimedia-swapfile.swap
           674ms dev-sda1.device
           465ms udisks2.service
           435ms vboxdrv.service
           374ms plymouth-quit-wait.service
Systemd timer uredno radi:
Code:
journalctl -u fstrim
-- Logs begin at Wed 2018-10-24 17:53:32 CEST, end at Fri 2021-03-12 07:00:01 CET. --
velj 01 00:00:01 witch64 systemd[1]: Starting Discard unused blocks...
velj 01 00:00:10 witch64 fstrim[17846]: /: 16,2 GiB (17413054464 bytes) trimmed
velj 01 00:00:10 witch64 systemd[1]: Started Discard unused blocks.
-- Reboot --
velj 08 00:00:01 witch64 systemd[1]: Starting Discard unused blocks...
velj 08 00:00:31 witch64 fstrim[3896]: /: 385 GiB (413389037568 bytes) trimmed
velj 08 00:00:31 witch64 systemd[1]: Started Discard unused blocks.
velj 15 00:00:01 witch64 systemd[1]: Starting Discard unused blocks...
velj 15 00:00:11 witch64 fstrim[12679]: /: 18,5 GiB (19819356160 bytes) trimmed
velj 15 00:00:11 witch64 systemd[1]: Started Discard unused blocks.
velj 22 00:00:01 witch64 systemd[1]: Starting Discard unused blocks...
velj 22 00:00:08 witch64 fstrim[2467]: /: 13,4 GiB (14421602304 bytes) trimmed
velj 22 00:00:08 witch64 systemd[1]: Started Discard unused blocks.
ožu 01 00:00:01 witch64 systemd[1]: Starting Discard unused blocks...
ožu 01 00:00:12 witch64 fstrim[19984]: /: 18,4 GiB (19718438912 bytes) trimmed
ožu 01 00:00:12 witch64 systemd[1]: Started Discard unused blocks.
ožu 08 00:00:01 witch64 systemd[1]: Starting Discard unused blocks...
ožu 08 00:00:13 witch64 fstrim[11994]: /: 23,9 GiB (25658396672 bytes) trimmed
ožu 08 00:00:13 witch64 systemd[1]: Started Discard unused blocks.
Dokumentirano, ali nisam izguglao neko rješenje. Naravno uvijek se može isključiti ono govno od systemd i staviti fstrim u klasični cron.
https://askubuntu.com/questions/1165...high-boot-time
https://forums.linuxmint.com/viewtopic.php?t=289947
Zadnje izmijenjeno od: c-shadow. 12.03.2021. u 08:04.
Staro 12.03.2021., 10:11   #1025
Nick7
Lokacija: Velika Gorica
Postovi: 1,537
Blentavo pitanje - zasto rucno pokretati fstrim kad se moze dodati 'discard' opcija u fstabu, pa odma automatski radi, ala Winblows?
Staro 12.03.2021., 10:45   #1026
c-shadow
c-shadow's Avatar
Postovi: 3,529
Preporuka linux distribucija je da se radi jednom tjedno, a ne online discard. Zato po defaultu neke od njih to i imaju tako riješeno. Zašto je tako - google is your friend
Staro 12.03.2021., 17:53   #1027
domy_os
domy_os's Avatar
Postovi: 18,960
Da, tako je i meni, doslovno isti logovi, 10-15 s treba mom SSD-u od 2 TB da odradi trim.
Autor Nick7 Pregled postova
Nije preporučljivo dodavati discard, a ni ovo nije baš ručno jer je sve skriptirano i radi automatski u bootu i svakih tjedan dana. Windowsi isto rade optimizaciju jednom tjedno, ako se ne varam. Otvori defragmenter pa provjeri, više od toga nisam istraživao...
Ma da, ali mislim da ovim malo naprednijim sustavima tipa BTRFS/XFS/ZFS niti ne treba discard jer se sam FS brine o tome.
Staro 12.03.2021., 19:33   #1028
Ivo_Strojnica
PRO
Postovi: 4,890
btrfs ima svoje mehanizme čišćenja, koje isto moraš ručno pokretati ili napraviti jobove.
Staro 12.03.2021., 19:45   #1029
domy_os
domy_os's Avatar
Postovi: 18,960
Nisam istraživao toliko, ali vidim da se s vremena na vrijeme uključe BTRFS transaction i cleaner procesi, valjda je to to. Nisam ništa ručno radio, tako je po defaultu.
Staro 12.03.2021., 22:54   #1030
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,427
Discard je zastarjela opcija - nije ju preporucljivo vise imati u fstabu bas iz razloga sto vecina distri po defaultu imaju ukljuceni cronjob za fstrim. Sto se opcija na FS-ovima tice - kod svih sljaka fstrim.
Staro 13.03.2021., 14:04   #1031
Nick7
Postovi: 1,537
Jedini razlog za izbjegnuti discard opciju su performanse, jer discard uspori brisanje na disku.
No, Windowsi recimo odmah rade i discard.
Nego.. bas malo procitao, i eto.. prije je discard bio problem jer je bio non-queued command, kasnije je queued. Samim time vise nema neke bas penalizacije da se koristi discard i u fstabu, dok je na starim SSD-ovima to mogao biti jako veliki penalty kod brisanja (u rangu 50x i vise sporije).
Inace, ovo za Windowse sam siguran - najbolji test je kad kreiram iSCSI disk, nesto pobrisem na Windowsu i vidim da se disk usage smanji na Linuxu gdje se image nalazi.
Staro 16.03.2021., 16:41   #1032
rodriguez
rodriguez's Avatar
Postovi: 2,067
Izbrisoa sam Wine kompletno sa Minta.
Ali kada upišem u search wine, nudi mi install wine ovaj paket, install wine onaj paket makar ništa nije instalirano. Kako da maknem i to kompletno, te wine pakete u u searchu?
Thinkpad T430 running
Staro 16.03.2021., 16:52   #1033
Postovi: 8,574
Mislim da ti to automatski povlači iz službenih repozitorija, pa se pojavljuje, mada zapravo nije na tvojem računalu.
Slično imaju i ostale distribucije. Ili kroz Synaptic odabereš Completely Remove za Wine, ako ga još uvijek drži.
Zadnje izmijenjeno od: The Exiled. 16.03.2021. u 16:58.
Staro 16.03.2021., 17:04   #1034
rodriguez
rodriguez's Avatar
Postovi: 2,067
izbrisao i kroz synaptic
A ništa, ostavit cu kako je.
Staro 16.03.2021., 17:06   #1035
Postovi: 8,574
Onda još eventualno možeš okinuti apt autoremove naredbu, pa nek počisti kojekakve ostatke.
Zadnje izmijenjeno od: The Exiled. 16.03.2021. u 17:12.
Staro 16.03.2021., 20:44   #1036
rodriguez
rodriguez's Avatar
Postovi: 2,067
TY, ali ništa se nije dogodilo, izbrisao sam kroz synaptic complete remove. Nema veze
Staro 16.03.2021., 21:07   #1037
Dottore
Dottore's Avatar
Postovi: 7,712
Na W530 vrtim Pop os distru. Ne znam kako, ali šljaka podmazano unatoč 24gb ram i 512gb Sandisk ssd. Sve radi "automaČki" i full stabilno.
Secure boot je oduvijek isključen u biosu i nakon updatea firmwarea od Lenova ostaje dalje isključeno. Nije ni imao problema sa wifi modulom.
Отправлено через iPhone
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 16.03.2021., 21:45   #1038
domy_os
domy_os's Avatar
Postovi: 18,960
Desni klik na logo > Configure > Menu tab > Open the menu editor i tu obriši što ti smeta u izborniku. Prije toga možeš napraviti export konfiguracije u slučaju da nešto zbrljaš.
Staro 17.03.2021., 00:11   #1039
Ivo_Strojnica
PRO
Postovi: 4,890
Autor Dottore Pregled postova
Da, Pop OS je fini distro, definitivno medju boljima po meni.
Staro 18.03.2021., 07:59   #1040
rodriguez
rodriguez's Avatar
Postovi: 2,067
Vrtim Mint i odlican mi je, citam po netu da se nakon nekog vremena uspori? Dal je to istina?
A volio bi probat i ovaj Pop_OS
Staro 18.03.2021., 08:05   #1041
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,427
Sve je to isto sranje drugo pakovanje na zdravoseljackom
P.S.- apt remove wine*
Staro 18.03.2021., 10:16   #1042
Ivo_Strojnica
PRO
Postovi: 4,890
To su ti sve varijacije na istu temu.
Koliko ga održavaš, toliko će brzo raditi.
Kod linuxa je dobro što zaista možeš raditi tuning i održavanje, za razliku od Windowsa, iako, osobno, meni Fedora nije ništa usporila, a bome je koristim svakodnevno već mjesecima.
Staro 18.03.2021., 10:43   #1043
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
Ovaj tjedan distro hopping na dva prijenosnika. jedan c2d, drugi i5-8320u. Na zalost napustio sam Manjaro na c2d zbog nvidia g210m, na i5 zbog toga sto ima drugaciju namijenu i treba mi nesto stabilniji citaj pouzdaniji os. Na kraju je na oba zavrsio Linux Mint Cinnamon. Radi besprijekorno, sve je hassle free i najjednostavnije i najbrze sam dosao do istih stvari naspram drugih distri. Nekada davno dok sam ga vozio je bilo usporavanja vremenom. Vidjet cemo sada kako ce se ponasati. i3wm je na i5. Obozavam taj wm.
Zadnje izmijenjeno od: Mihael. 18.03.2021. u 15:20.
Staro 18.03.2021., 11:38   #1044
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,296
Ja stavio na x230 mxlinux 19.3 (xfce).
Zasad super dojmovi, vecina postavki ide preko gui-ja, za pocetnike odlicno.
Dosad sam vrtio lubuntu 16.04 sa lxde-om, ali obzirom da je lxde napusten potrazio sam nesto novo. Xfce mi je uvijek vise odgovarao od kde i gnomea.
Staro 18.03.2021., 12:48   #1045
bertone
bertone's Avatar
Datum registracije: Mar 2010
Postovi: 2,064
LM 20.1 Cinnamon koristim na X230 s time da sam prije par godina napravio frišku instalaciju 19.1, potom napravio upgrade na 19.3 pa potom upgrade na 20.0, pa ponovno upgrade na 20.1 i tako će ostati dok ne dođe 20.3 (nisam praznovjeran ali sam imao loša iskustva sa verzijama xx.2).
Usporavanje ili probleme za ovih par godina nisam imao.
PS. Ovako izgleda zadnjih par mjeseci radi posla jer su me počeli već umarati sa pričama (iako ih nisam ništa pitao) kako je Linux bez veze i kako su penđeri jedini pravi OS za posao.
Staro 18.03.2021., 13:23   #1046
Postovi: 23,641
Tema je super, dobro da nema (glupih) pitanja kako sad XP, di je W10 ??
Staro 18.03.2021., 13:28   #1047
bertone
bertone's Avatar
Postovi: 2,064
Ima, ali onda kažem da je to W10 sa XP skinom i to je prihvatljivo pa ne pitaju dalje.
Da ne misliš da se zaje**** , prije xy vremena smo dobili nove kompove sa MS (ne Microsoft nego baš MS šrotex periferijom u vidu miša i tipkovnice po 35 kn) i kako je tipkovnica koma donesem od doma IBM model M i nakon par dana mi šef vidi tipkovnicu i mrtav ozbiljan kaže da je moram maknuti jer sa ne fiminim hardverom mogu zaraziti PC
Staro 18.03.2021., 13:48   #1048
Postovi: 23,641
Blago budalama, njihovo je kraljevstvo nebesko. Nevjerojatno kako takvi (skoro u pravilu) postanu nekakvi šefovi ...
Staro 18.03.2021., 14:16   #1049
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
svakakve neugodnosi sam dozivljavao zbog toga sto sam imao linux na sluzbenom i sto nisam u AD-u.
Onda sam stavio MacOS da svi odj. lagano
Staro 18.03.2021., 15:07   #1050
c-shadow
c-shadow's Avatar
Postovi: 3,529
Autor Cuky Pregled postova
Na xfce mi oduvijek nedostajalo pretraživanje datoteka iz file managera (thunar), kao što to ima recimo stari gnome ili nemo.
Onaj njihov dodatni poluproizvod programček (zaboravio kako se zove) ne računam
