Staro 26.01.2021., 19:52   #121
Postovi: 8,281
Autor Exomaniac Pregled postova
Šta je sad TSMC 6nm? Jel to kao poboljšani 7nm samo na EUV litografiji?
Točno to, poboljšani 7nm proces, koji istovremeno nudi veću gustoću tranzistora uz određene EUV prednosti nad orginalnim 7nm izdanjem.
Zadnje izmijenjeno od: The Exiled. 26.01.2021. u 20:00.
Staro 26.01.2021., 20:03   #122
lobo64
lobo64's Avatar
Postovi: 1,346
Evo kako će neke desktop varijante izgledati:
ID:	23325   Click image for larger version
Staro 26.01.2021., 20:08   #123
Postovi: 8,281
Lijepo oni vrte GPU priču, ali na kraja dana složili su mobilni iGPU na PCI-E 4.0: 128-bit + LPDDR4X@10 nm SuperFin.
Staro 26.01.2021., 21:02   #124
Exomaniac
Datum registracije: Mar 2016
Postovi: 767
Autor lobo64 Pregled postova
Ovoliki hladnjak i kartica za 30 vata TDP
Netko očito u dizajn timu ima komplekse oko veličine
Staro 27.01.2021., 21:06   #125
Postovi: 8,281
Š.O.K._i_V.J.E.V.E.R.I.C.A.
Intel's discrete desktop GPU is not compatible with AMD and older Intel PCs The Iris Xe discrete add-in card will be paired with 9th gen (Coffee Lake-S) and 10th gen (Comet Lake-S) Intel® Core™ desktop processors and Intel(R) B460, H410, B365, and H310C chipset-based motherboards and sold as part of pre-built systems. These discrete cards based on the DG1 GPU were designed for use by system integrators on their systems. These motherboards require a special BIOS that supports Intel Iris Xe, so the cards won’t be compatible with other systems.
Izvor: Legit Reviews
Staro 27.01.2021., 21:11   #126
Lewis
Freelancer
Lewis's Avatar
Lokacija: Bilje (Osijek)
Postovi: 5,292
Uuu to ce se onda prodavat ko alva sad kad svi predju na Ryzene
Lewis je online   Reply With Quote
Staro 27.01.2021., 21:19   #127
Postovi: 8,281
Ma ionak je sam GPU smiješan u usporedbi s Ampere i RDNA-om, ali bar je OK za normalan rad, multimediju, nezahtjevne igre i tome slično. Likovi jedno pričaju, a potezi su im ni vrit ni mimo.
Staro 28.01.2021., 08:00   #128
Sinac
...samo te gledam...
Sinac's Avatar
Postovi: 2,826
Xe GPU mi izgleda odličan za iGPU primjenu, pogotovo za multimedia centre i notebooke gdje je bitna solidna brzina i istodobno mala potrošnja, hladan rad a time i tišina. Kao add-in kartica stvarno ne vidim da bi se mogla probiti na tržište, pogotovo što ima boljih rješenja s pasivnim hlađenjem prisutnih na tržištu. Ali OK, novi je proizvod, dajmo Intelu vremena da vidimo što će uopće skuhati s tim proizvodom.
Staro 28.01.2021., 16:57   #129
Chuby
Chuby's Avatar
Datum registracije: Feb 2004
Postovi: 1,304
Ovo je takav promasaj da je grdo za gledat
Chuby je offline   Reply With Quote
Staro 30.01.2021., 15:53   #130
Postovi: 8,281
Intel DG1 including Intel Iris Xe MAX Graphics in exclusive teardown and with massive driver problems in benchmarks
To be fair, we have to preface this with the fact that this is a test sample only. However, now a few months have passed, driver after driver have been added and the overall situation has not improved. Only the rudimentary functions work, but the DisplayPorts and HDMI of the DG1 are still completely unusable. The performance is located at about the same level as an NVIDIA GT 1030, which could well be real, but unfortunately isn’t really verifiable. Intel had ever shown games in progress at the time, but one could almost doubt that given the current situation and the actual state. Why Intel distributes complete systems that you can never get running over the year, that can only be answered by Intel itself. The fact is that probably everyone involved in the test gave up at some point, exasperated. What is the DG 1 supposed to be good for and stand for in the end? For the office, a current iGP or a complete APU from AMD does it better and with much less effort.
Izvor: Igor's Lab
Staro 30.01.2021., 17:16   #131
BusMaster
BusMaster's Avatar
Datum registracije: Apr 2017
Postovi: 343
Intel DG1 GPU Teardown, Failed Benchmarks, and Why It Won't Work on Most Systems
Link: https://www.tomshardware.com/news/in...led-benchmarks
Citat iz članka: The DG1 features 8GB of LPDDR4 memory with a 2,133 MHz clock speed. The memory is reportedly connected to a 128-bit memory interface and supports PCIe 4.0, although it's limited to x8 speeds.
Ako su na ovo potrošili hrpu para, toliko pompe, najave i ostalih sranja.. onda bolje da odma potjeraju tog Raju. Što je tim likovima u glavi, za koji je ovo tržišni segment namijenjeno?
Staro 30.01.2021., 18:15   #132
Postovi: 8,281
Najbolje od svega je to kaj se sad s dolaskom novog direktora u Intelu ponovno ponavlja ista priča zbog koje je majstor Raja napustil AMD - većina resursa se prebacuje na Alder Lake i nadolazeće tehnologije i proizvodne procese, s tom razlikom da Intel kao AMD u ono vrijeme nema problema s bacanjem novaca, niti Raja može reći da su mu ruke vezane i tome slične bajke za javnost, ali čak ni oni ne žele ulagati u nešto kaj očito ne bude takvim kakvim se najavljuje i prikazuje. Kaj točno su napravili s tim GPU-om, pa da je tak loša izvedba za OEM desktop - ostaje misterij, jer ovo je isti mobilni čip kakav koriste za cijelu paletu prijenosnih proizvoda. Trenutno imam kod sebe ThinkPad koji dolazi s novom Tiger Lake + Iris Xe iGPU kombinacijom i stvar funkcionira besprijekorno. Pitanje je vremena kad se Raji sugerira da je možda bolje da potraži neki drugi (zeleniji) pašnjak.
Staro 30.01.2021., 19:01   #133
Odinarius
All-rounder
Datum registracije: Sep 2013
Postovi: 1,327
Što se nije pisalo da je DG1 napravljen prije Raje, da je u DG2 nešto njegovog inputa i da je tek DG3 baš njegova arhitektura?
DG1 nema tržišnu ulogu, zato i nije na tržištu. Ako je samo 20% jači os integruše, jasno je da je to samo test, da se naivni narod iskoristi kao beta testeri za drivere i slično. Ne bi sudio Intel prema ovome... Na DG2 se moraju pokazati.
Staro 30.01.2021., 19:08   #134
Postovi: 8,281
Ista stvar se pričala za Radeon GCN, Polaris i Navi, ovisno o tome kak je bilo zgodno za Raju, tak da nikad nije on kriv, a u slučaju da sve ispadne po planu i programu, onda je zaslužan do neba. Mislim tak svejedno, ali taj isti čip uredno radi bez greške u prijenosnicima, tak da su ga fino sjebali za desktop copy-paste metodom. I opet, nek bude testni primjerak, ali OEM ekipa čeka taj GPU, pa budu nekaj svakak morali smisliti. Kaj se općenito konkretnih Intelovih GPU rješenja tiče - ne držimo dah, pa ako ispadne OK - super, u suprotnome - jebiga Raja ni ovaj put nije prošlo.
Staro 30.01.2021., 19:11   #135
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Da, DG1 je kao nešto bilo "za developere" (valjda da se uče borit s njom ), neka beta-test generacija. DG2 bi trebala biti prava stvar.
Staro 30.01.2021., 19:35   #136
Postovi: 8,281
Lijepo piše u linkanom članku par postova prije, DG1 je već godinu dana dostupan developerima, a na ovom PCI-E desktop izdanju ne rade ni video izlazi kak spada, kamoli ostalo.
Staro 30.01.2021., 20:15   #137
Odinarius
All-rounder
Postovi: 1,327
Možda je to samo jedan chiplet koji će jednog dana spojiti u nešto više? I nekakve takve glasine sam vidio.
Stvarno me ne zabrinjava proizvod koji nam nije ni namijenjen. Kad dođu jače kartice, onda ćemo suditi, i cijene i performanse i kompatibilnost. Neće to još generaciju-dvije biti upotrebljivo, ali mislim da ovaj put Intel igra dugu igru. Slušao sam Broken Silicon s onim tipom za memorije i objasnio je dugu igru koju Intel igra s Optaneom, koliko su subvencionirali prodaju da bi došli do zamjene za RAM u serverima s njim. Mislim da nešto slično rade i ovdje, izbacuju loš proizvod kako bi za koju godinu imali nešto vrlo konkurentno u datacenterima.
Ili ne, možda samo imaju loš proizvod i Raja naklapa gluposti kao i obično
Staro 30.01.2021., 20:21   #138
Postovi: 8,281
Imaju i multi-chiplet rješenje, tj. isti mobilni iGPU na PCB-u, ali za servere. Lako za ovaj OEM PCI-E komad tehnike, ali ne djuluje obečavajuće, obzirom da im na tome počivaju i jači modeli.
Budemo vidjeli, ali ništ čudno da Raja napusti i ovo radno mjesto s hrpom primjedbi na voCtvo.
Staro 30.01.2021., 20:59   #139
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Kad nitko ne želi proizvod onda to Intel "subvencionira". To su isto radili i s Atom procesorima za tablete, prodavali su ih za "-$50" tj. Intel je "subvencionirao" svaki tablet s $50, samo da proizvođači ugrade Atom procesor. Nakon što su skupili 7 milijardi dolara gubitka na tome, shvatili su da to ipak nema smisla .
I ove DG1 kartice koje su namijenjene samo OEM tržištu će Intel vjerojatno davati besplatno ili čak "subvencionirati".
Staro 31.01.2021., 13:15   #140
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,585
Autor MadBoY Pregled postova
Bingo!
Zato i neće raditi na AMD platformi.
Potez očajnika.
Staro 10.02.2021., 13:37   #141
Postovi: 8,281
Intel’s Raja Koduri confirms that Xe HPG has gone through a new 3DMark Mesh Shader Feature Test
Staro 10.02.2021., 17:59   #142
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,291
Raja je definitivno u krivom odjelu, taj je stvoren za neki gerila marketing.
Poslušao sam taj video jutros...da veli da navodno imaju jako opaku datacenter grafu.
Slobodno me dodajte na PSN
Staro 10.02.2021., 18:08   #143
Postovi: 8,281
Da, zato sam namjerno stavil Raju uz ovaj video, jer jedno proturječi drugome, a ovaj i dalje lupa po Twitteru ko Maks po diviziji.
Staro 26.02.2021., 20:08   #144
exzzy
exzzy's Avatar
Datum registracije: Aug 2014
Postovi: 843
Vidim da je prošlo ispod radara pa da stavim specifikacije kartica
https://videocardz.com/newz/specific...-family-emerge
Staro 26.02.2021., 20:20   #145
Postovi: 8,281
Ma nije prošlo nezapaženo, ali danas su izašli novi Architects i Of Mice and Men, tak da Rajine pizdarije nemaju efekta.
Dobro bude ukoliko išta od ovog uopće izbace na tržište, a kamoli da budu konkurentni, mada prije će Raja spakirati kofere.
Staro 01.03.2021., 09:29   #146
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,585
Ak budu dolazile sa "Intel Xe inside" naljepnicom za zaljepit na kučište, uzimam samo zbog toga, bude se fino sljubila sa "Intel Xeon inside".
Staro 01.03.2021., 20:58   #147
b1tterman
Takozvani influenser
b1tterman's Avatar
Lokacija: Dublin
Postovi: 649
Raja propo ko grčka. Nakon solidnih Radeona napravi mobilni gpu za desktop...
b1tterman je offline   Reply With Quote
Staro 01.03.2021., 21:18   #148
Manuel Calavera
Postovi: 14,584
Vidjet ćemo. Prvi mačići se u vodu bacaju, no ako ova DG2 ne bude iole konkurentna onda imaju/imamo problem
Staro 01.03.2021., 21:25   #149
exzzy
exzzy's Avatar
Postovi: 843
Nebitno, ak oni mogu tog dovoljno natiskat prodat ce se.
Staro 01.03.2021., 21:35   #150
Postovi: 8,281
Ovo je sad već četvrta godina da Raja radi u firmi kojoj nofci i popratni ljuCki resursi nisu problem, a izuzev mobilnog Xe rješenja i razno-raznih varijacija na temu, ništa konkretno nisu pokazali, dok uredno najavljuju brda i doline od kojih budu i Radeon i nVidia skidali hlače i gaće, samo da ne moraju u borbu protiv Intelovih GPU rješenja. Nadalje, Raja je u isto vrijeme, tj. četiri godine provedenih u AMD-u na čelu RTG-a ipak nekog vraga i izbacil u prodaju, ma kakvi god se ti proizvodi u tom trenutku činili, ali bili su funkcionalni i sasvim solidni. Naravno, naposljetku je ispalo da frajer voli biti u centru pažnje i prikupljati kojekakve zasluge, kao da je sve sam stvoril iz nule i genije kakav je, ali AMD je napustil podvitoga repa, jer eto Lisa Su u tom trenutnku nije više htjela da Twitter hvalisavac i hype meštar troši ionak na knap resurse na svoje GPU fantazije.
I veli Raja, dobro, idem ja u Intel, jer AMD je šrot firma i Baba mi ne da, da se igram s najnovijim tehnologijama, jer eto - to netko treba i platiti. I tu dolazimo do šok i vjeverica trenutka u kojem prije koji tjedan novi Intel CEO stupa na scenu i pazi(te) sad - Raja opet, kao i u AMD-u sluša jezikove juhe da njegove GPU drangulije nikud ne vode, pa novi CEO opet, baš kao i Lisa Su, preusmjerava nofce i ljude na bitnije projekte, a fala Bogu Intel ima itekakvog posla ispred sebe. Pričal sam na početku ove teme da će Raja u najboljem slučaju odigrati RTG foru i Intel će na temelju toga imati neki HPC GPU proizvod uz pokoje mobilno GPU rješenje i sad stvarno tak ispada, jer HPC GPU moraju imati za jedino superračunalo koje su obećali opremiti i koje je već par puta odgođeno radi Intelovih planova i programa, tj. nedostatka istih. Prvom prilikom kad to isporuče, to je to. Raja, fala i doviđenja.
Uz sve rečeno, posljednih dana kruže glasine da je Rajina GPU divizija mrtvo slovo na papiru, te da ljudi masovno odlaze, neki ponovno u AMD otkud su došli nakon kaj ih je Raja vrboval u Intel.
