Staro 14.01.2021., 19:54   #9451
locks
Datum registracije: Mar 2010
Lokacija: Vukovar
Postovi: 3,682
Nema više micro SD, izbacili 45W punjenje, S21 i S21+ samo 8GB RAM, i dalje sporo bežično punjenje, a sumnjiv mi je i ovaj varijabilni refresh rate
Staro 14.01.2021., 19:58   #9452
Dottore
Dottore's Avatar
Postovi: 7,734
Jesu li izašle službene specifikacije? Odgledao sam event sa kašnjenjem. Pretpostavljam da S21Ultra ide microsd?
Отправлено через SM-G975F
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 14.01.2021., 20:03   #9453
gin.tonic
gin.tonic's Avatar
Postovi: 2,446
Autor Dottore Pregled postova
Yes and Yes
gin.tonic je offline   Reply With Quote
Staro 14.01.2021., 20:04   #9454
gin.tonic
gin.tonic's Avatar
Postovi: 2,446
Autor locks Pregled postova
Nema ni slušalica ako sam dobro shvatio
Staro 14.01.2021., 20:08   #9455
locks
Lokacija: Vukovar
Postovi: 3,682
Autor gin.tonic Pregled postova
I 1,1x optički zoom na S21/S21+
Staro 14.01.2021., 23:47   #9456
GreenLife
Čika Zeljeni
GreenLife's Avatar
Datum registracije: Sep 2013
Lokacija: Tannhausen (Aalen)
Postovi: 497
Yes and Yes
Netočno za memoriju - no more microSD cards in S line-upu, samo:
128GB - 12GB RAM
256GB - 12GB RAM
512GB - 16GB RAM
Staro 15.01.2021., 00:38   #9457
Dottore
Dottore's Avatar
Postovi: 7,734
Autor GreenLife Pregled postova
128GB - 12GB RAM
256GB - 12GB RAM
512GB - 16GB RAM
Yup!
Kažu da je jeftiniji 100€ u odnosu na aktualni S20.
Staro 15.01.2021., 08:47   #9458
Postovi: 34,120
Navodno samo EU modeli neće imati sd utor.
Staro 15.01.2021., 09:34   #9459
Libertus
Libertus's Avatar
Datum registracije: Jul 2017
Lokacija: Ramura
Postovi: 2,850
Sada otvorio na Anandtech članak o S21 seriji, i tip plače i plače kako su usrali 21 seriju (sve osim 21 ultra) zato što je ekran FHD+ (1080p+) umjesto 1440p+.
Jel mi netko može objasniti zašto on plače jer ja ne razumijem?
Jesmo li postali toliko razmaženi da nam na mobitelu od 6" treba veća rezolucija nego na monitoru od 24"? Da li se uopće okom vidi razlika između te dvije rezolucije na mobitelu od 6"?
Osobno kada sam gledao specifikaciju S21, veselila me FHD+ rezolucija, jer se nadam da će s tim ekranom, većom baterijom i novim Exynos chipsetom uspjeti dobiti veću autonomiju bez ikakvih gubitaka za korisnika.
Staro 15.01.2021., 09:44   #9460
Postovi: 34,120
Naravno da se razlika ne vidi. Neš' ti problema
Staro 15.01.2021., 09:56   #9461
Rista
Rista's Avatar
Lokacija: Ri
Postovi: 1,924
Veca rezolucija nije potrebna ali kad su ih prethodnici imali, razumijem zasto "place". Znaci nemojmo unaprijediti top model nego okljastrimo ostale. Nazalost smanjenje rezolucije generalno ne donosi osjetno vecu autonomiju kako bi se ocekivalo.
To sto top model ima sve sto bi trebao mi nis ne znaci kad je cigla.
Staro 15.01.2021., 10:56   #9462
m4dm4n
Does youer dewg byte?
m4dm4n's Avatar
Postovi: 1,960
Da dolijem ulje na vatru, nijedan mobitel nakon s7 nije dostigao njegov pixel density. 😁
A sve se nešto grebem, stvarno je vrijeme za prelazak sa s7 na novije, i ne znam dal da zemem s20 i s21 običan. Zapravo su me samo sa sd karticom sad zeznuli, iako bih uzeo 256GB model.
Staro 15.01.2021., 10:59   #9463
p3r02d3r0
p3r02d3r0's Avatar
Postovi: 522
Planiram uzet novi mob. Trenutno imam A8 iz 2018.
Uglavnom, gledam ubost S10+ ili S20+ na nekoj akciji. Valjda će ih bit početkom ove godine.
Nisam siguran jedino isplati li se dat više para za S20+.
Inače, jebe mi se za 5G. Ne gejmam na mobu.
Ako je netko od vas koristio S10+ i prešao na S20+, ima li neke ogromne razlike?
Hvala
p3r02d3r0 je offline   Reply With Quote
Staro 15.01.2021., 11:04   #9464
Postovi: 10,409
Autor Rista Pregled postova
Nazalost, ovo je istina. Barem na mom Note9 SD. Znao bi mjesec dana biti na 1080p i 1440p bez osjetne razlike.
Takodjer, ne vidim razliku ni u prikazu osim ako se zabuljim idem fakat traziti i usporedjivati ostrinu izmedju dva moda. Sve dok nema te direktne usporedbe, razlike se izgube i to sto vidis ti je sasvim normalno.
Nisam primjetio ni da mob ista brze radi s obzirom da gura manju rezoluciju.
Osobno mislim da 98% ljudi nece biti razocarano 1080p panelom jer 1) gustoca piksela je i dalje dovoljno velika (veca nego na monitorima) i 2) imas 1080p u nativnoj rezoluciji i to mora biti ljepse naspram recimo mog slucaja 1080p na 1440p panelu.
Placu vjerojatno techyji i jutuberi koji lizu specs sheetove
Ja vise placem za punjacem, jbga, uvijek je dobro imati neki brick viska. Ne nuzno za mob, nego i za druge uredjaje koji se pune na 5V, a ima ih i ne dolaze svi sa punjacima.
Staro 15.01.2021., 11:59   #9465
Dottore
Dottore's Avatar
Postovi: 7,734
Autor p3r02d3r0 Pregled postova
Hvala
Ne isplati se preći na S20+. To je moj subjektivni dojam što se tiče korištenja. Prilično razočaran sa autonomijom bez obzira na sjeban rastrošan Exynos 990 i veći kapacitet baterije.
S20+ je dobar kad miruje u stand by. Kad diraš i krene kraća autonomija bez 2 punjenja do ponoći.
U biti cijela S20 serija i Note 20 prilično lošiji. Vratio sam na ponovno S10+ za stalno.
Note 20 ultra (koristio barem 2 mj) minimalno 30% korištenja i nikako da izdrži do ponoći bez dodatnog punjenja. Kad ih maksimalno koristiš i traži barem 3 punjenja - stekao dojam kao stari Samsung S6.
Edit.
Na S10+ jučer sletio update na Android 11 - one ui 3.0. Nešto je bržk
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 15.01.2021., 12:04   #9466
p3r02d3r0
p3r02d3r0's Avatar
Postovi: 522
Edit.
Super, puno hvala na odgovoru.
Još jedno pitanje. Vidim da su u opticaju dvije verzije S10+. Jedna sa 128 GB pohrane i 8 GB RAM i druga sa 1 TB pohrane i 12 GB RAM.
Gledao sam malo recenzije, i uglavnom kažu da nema neke ogromne razlike u RAM-ima. ALI. Većina tih videa je iz razdoblja kada se S10+ tek pojavio na tržištu.
Hoće li biti neke osjetne promjene danas?
Staro 15.01.2021., 12:18   #9467
Postovi: 10,409
Ako ti kazem da je i 6GB previse s obzirom da ne gejmas (a ja k tome igram igre i ne gasim appove), hoce li ti to pomoci shvatiti danasnji presjek mobilnog marketinga kada vise nemaju sta pumpati pa dodaju gige u ram?
8 giga je bilo dobro onda, a bit ce i sutra. Od toga ce ti 3-4 gige konstantno biti prazne, garantiram ti to. Meni je ram u prosjeku popunjen 4GB od 6. Imam dosta appova u "never kill, never sleep" listi.
Staro 15.01.2021., 12:44   #9468
p3r02d3r0
p3r02d3r0's Avatar
Postovi: 522
Autor xlr Pregled postova
Eh Nekoć sam dosta pratio te čipsetove i tehnikalije. Više nemam baš živaca za to
Još samo nešto. Pročitao sam da se Samsung obvezao na tri godine značajnih ažuriranja i četiri (?) godine security ažuriranja za nove uređaje.
Vrijedi li to i za S10 seriju?
Hvala
Staro 15.01.2021., 12:47   #9469
Dottore
Dottore's Avatar
Postovi: 7,734
Vrijedi, za sada u pripremi je one ui 3.1 za S10 .
Kako je izašao S21 sa ui 3.1 i polako će krenuti od S20 na niže.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 15.01.2021., 13:14   #9470
p3r02d3r0
p3r02d3r0's Avatar
Postovi: 522
Super, puno hvala svima na odgovorima. S10+ it is!
Staro 16.01.2021., 06:35   #9471
GreenLife
Čika Zeljeni
GreenLife's Avatar
Postovi: 497
Što se tiče same memorije uređaja - imam na Noteu 10+ 256GB , od toga 47% mjesta slobodno.
Istina - skidam slike i videa bar jedanput u dva mjeseca na komp + cloud, tako da ako zatrebam neku sliku, imam na cloudu za podjelit.
I da stavim memorijsku, vjerujem da opet ne bi puno toga držao na mobu.
256GB je meni sweet spot, a sad kako kome.
Staro 16.01.2021., 14:04   #9472
Postovi: 10,409
Pa dosta je to zauzetog prostora
Meni je 128 recimo i previse (70GB free). Sve imam u oblacima lol. Imam i karticu od 64GB, ali svega 2GB zauzeto (mirror backup interne memorije, neke arhive appova, wallpaper, custom melodije... Sve forsiram na internu. Slike i videa s vremena na vrijeme pocistim jer mi ne trebaju na mobu, drzim se clouda.
Otkad sam prestao nositi flac-ove sa sobom i backup moba/memorije preko smbsynca i i foldersynca poceo prebacivati na "wannabe nas" (shield koji glumi home server), realno mi ni sd kartica vise ne treba u tom lancu backupova.
Staro 16.01.2021., 17:27   #9473
p3r02d3r0
p3r02d3r0's Avatar
Postovi: 522
Nvm, nisam vidio podforum za iskustva o trgovinama. Sori na spamu
Zadnje izmijenjeno od: p3r02d3r0. 16.01.2021. u 19:41.
Staro 16.01.2021., 20:27   #9474
tbogovi1
tbogovi1's Avatar
Datum registracije: Mar 2011
Lokacija: Sl.Brod
Postovi: 248
Pozz... Trebo bih za starog mobitel, od samsunga s10 što je žena imala prešli na huawei i hvala bogu da jesmo izgubio sam totalnu orjentaciju sa samsungom 😂
Dali bolje kupiti a21s ili a30? Nije on neki hardcore mobilni lik bitno da ima, sad vec 4 godine ima a5 al ubio ga čovjek
Poslano sa mog VOG-L29 koristeći Tapatalk
tbogovi1 je offline   Reply With Quote
Staro 17.01.2021., 15:42   #9475
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Autor m4dm4n Pregled postova
Da dolijem ulje na vatru, nijedan mobitel nakon s7 nije dostigao njegov pixel density. ��
Ja sam se sa S7 prebacio na S20+ prosle godine u petom mjesecu i mogu ti reci da je odluka bila vise nego dobra. Taman je doslo vrijeme za nadogradnju i razmisljao sam o tome ali nisam mogao prevagnuti isplati li se ili ne i onda mi je otisla baterija na S7. Odnosno, trajnost baterije se smanjila drasticno, rekao bih na minimalno 50% i tu sam prelomio.
Bila neka akcija na OTTO-u kao staro za novo i dao sam S7 prilikom kupovine S20 i dobio 150€ rabat. Jedini uvjet je bio da je mob funkcionalan i da nije razbijen zaslon.
Mogu ti preporuciti da slobodno napravis prijelaz.
All you have is your fire and the place you need to reach.
Don't you ever tame your demons, always keep them on a leash.
Alph4Dawg je offline   Reply With Quote
Staro 17.01.2021., 15:46   #9476
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,920
Ne znam kako vama, ali meni ovaj s21 ultra predobar.
Apsolutno sve tip top.
Osim velicine.
Staro 17.01.2021., 18:29   #9477
Mar
Suit up!
Mar's Avatar
Postovi: 5,986
To ti je kao i cura: bogata, zgodna, pametna, humoristična, voli sve što i ti ali ima hangar u kojem se tvoj Woody osjeća kao da voziš romobil po autoputu.
- Barney Stinson
Staro 17.01.2021., 18:46   #9478
James Dean
Datum registracije: Dec 2020
Postovi: 361
Koji god uzmeš nakon tog A8 bite će senzacionalni napredak.
Staro 17.01.2021., 18:53   #9479
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,770
Osim velicine.
Potpis, da je bar malo manji i laksi
Svejedno, kamere me privlace najvise - uz ostale ficure ofkors. Mislim da bi mogao na jesen-zimu uzet S21U (ciljam popuste), do tad ce sadasnji s10 biti preko 2 i po godine star, taman za penziju
Autor Mar Pregled postova
Staro 17.01.2021., 20:22   #9480
King of 4
Lokacija: na zapadu
Postovi: 150
Nije stvar ko plače.
Stvar je da dobivaš manje za više ili isto novaca i da se ide u kontra smjeru, a trebalo bi biti suprotno.
S ovom serijom su prešli na plastiku, makli su SD utor, smanjili rezu, maknuli punjač, slušalice, i 3.5mm utor.
Pa ko tu koga pravi majmunima.
Ako ovo nikoga ne smeta onda nije ni čudo da rade što hoće.
King of 4 je offline   Reply With Quote
