Staro 02.05.2020., 11:11   #6031
Old.machine
Old.machine's Avatar
Datum registracije: Feb 2016
Lokacija: ______
Postovi: 1,461
Naišao na ovaj giveaway, po komentarima kažu je odličan, pa eto kome treba neka uzme:
G-Stomper Studio 109kn 0kn
Reddit info
Info for G-Stomper Studio:
Current price (USD): Free was $12.99
Developer: planet-h.com
Rating: 4.7/5
Installs: 10,000+
Last updated: January 7, 2020
Contains IAPs: No
Contains Ads: No
Permissions: Read/Modify Storage, Record Audio, Location Access
Short description:
G-Stomper Studio is a Music Production Tool, highly optimized for doing Electronic Live Performances in Studio Quality. It's a feature packed, Step Sequencer based Drum Machine/Groovebox, a Sampler, a Virtual Analog Performance Synthesizer (VA-Beast), a polyphonic + a monophonic Step Sequencer for melodies, a Track Grid Sequencer for Beats, a Piano Keyboard, 24 Drum Pads, an Effect Rack, a Master Section, a Line Mixer and a Live Pattern/Song Arranger. Wherever you are, take your mobile device and start straight away creating your own music.
Old.machine je offline   Reply With Quote
Staro 07.05.2020., 20:28   #6032
bg_4_l
Postovi: 542
Kolege forumaši u potrazi za news aplikacijom (ima ih pregršt, znam). Ukratko ova nudi vijesti samo iz respektabilnih izvora (iako je to danas relativan pojam) za što koristi machine learning, a uz to ML uči sto vam je zanimljivo kako bi vijesti bile sto relevantnije.
Iza ovog stoje domaći devovi pa ako imate volje podržite dečke. Postoji i iOS aplikacija za ljubitelje Apple .
https://play.google.com/store/apps/d....quicknews.app
bg_4_l je offline   Reply With Quote
Staro 14.05.2020., 16:12   #6033
C128
Postovi: 212
Help
Ima li netko iskustva s mHPB-ovom aplikacijom. Kako ne koristim Google Play, do sada sam normalno pronašao na internetu APK skinuo ga i sve je radilo.
Od danas vezija 2.2.0. više ne radi, a APK verzije 2.3.0 ne mogu instalirati na mobitel. Najnoviju verziju 2.3.1. ne mogu nigdje pronaći na webu. Služba za korisnike se pravi blesava i kaže da se nova verzija mora instalirati s Google Play-a, te da nije moguća instalacija APK datoteke?!
Ako ima tko kakav prijedlog za rješenje problema bio bi zahvalan.
C128 je offline   Reply With Quote
Staro 22.05.2020., 19:53   #6034
SympForTheDevil
SympForTheDevil's Avatar
Datum registracije: Sep 2019
Postovi: 636
Swiftkey is Swiftkey no more?
Staro 22.05.2020., 19:58   #6035
LAcy
Pink Floyd fan
LAcy's Avatar
Lokacija: Santa Clara, CA
Postovi: 5,569
Autor C128 Pregled postova
Help
Prvo zasto ne koristis google play? Koristiti e-banking app skinutu sa interneta nije bas pametno. Mogao bi ostati bez novaca na racunu a onda se mozes zalit upravi vodovoda.
Drugo, netko ti moze povuci app sa svog mobitela i dati. Al' i dalje za takve ozbiljne app, treba koristiti official source.
Core i7-6700K LGA1151 Skylake
RTX 2080 TI 11GB GDDR6
Samsung 850 EVO M.2 1TB SSD
MacBook M1 Pro
MacBook Air M2
Moto Edge
LAcy je online   Reply With Quote
Staro 23.05.2020., 08:58   #6036
Postovi: 34,094
Možda čovjek koristi Huawei pa mu GP nije dostupan.
Staro 23.05.2020., 11:55   #6037
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,569
Tim gore
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 25.05.2020., 18:37   #6038
mrga
all you need is freeware
mrga's Avatar
Lokacija: Stolica
Postovi: 897
Zna netko kakvu aplikaciju za upravljanje mobitelom skeniranja dokumenata na printeru, ali sa spremanjem na šerani folder na kompu?
Dakle, nešto kao NAPS2 - mobitelom pokrenem skeniranje, pisač odradi sken i sve se spremi na šerani folder na kompu.
Našao sam Mopria scan, ali nema mogućnost spremanja na šerani folder, samo mobitel.
Ovo je potpis.
mrga je offline   Reply With Quote
Staro 26.05.2020., 04:27   #6039
Postovi: 34,094
Proizvođači printera obično imaju svoju aplikaciju s kojom možeš mobitelom raditi svašta na uređaju. Baci oko na GP da li postoji takva aplikacija za tvoj printer.
Staro 26.05.2020., 17:30   #6040
Ivan0705
Postovi: 17
Poz!
Da li netko zna pouzdano da li je na Samsungu Galaxi A51 zadano tvornički instalirana APK Android Auto...jer je bilo nekih napisa, da će se to napraviti na mobitelima koji imaju Android 10.
Hvala na info!
L.P.
Ivan0705 je offline   Reply With Quote
Staro 27.05.2020., 13:19   #6041
mrga
mrga's Avatar
Lokacija: Stolica
Postovi: 897
Autor coconut Pregled postova
Ima, ali sprema direktno na device.
Da, mogu prebaciti na komp, ali mi nekako nije jasno da u moru svih živih i neživih aplikacija ne postoji nijedna koja bi skenove spremala na share.
Općenito postoji manjak scan aplikacija, 99% ih zapravo radi scan putem kamere smartphonea, a ne da upravlja skenerom na pisaču.
Ovo je potpis.
Staro 30.05.2020., 12:27   #6042
Morpheous
Morpheous's Avatar
Postovi: 1,144
Imam jedno početničko pitanje u vezi kupovine android aplikacija na playstoreu. Valjda sam pogodio temu.
Naime, nikad nisam kupovao preko playstorea i kako koristim dvije SIM kartice u mobitelu od kojih mi je jedna tu reda radi (povijesni razlozi) te imam nešto novaca na računu na toj kartici koju jedva da koristim, odlučio sam probati kupiti nešto sa playstorea da malo podržim proizvođače čije aplikacije koristim već godinama i vidjeti da li mogu s nje skinuti novce umjesto da dajem podatke o kreditnoj kartici. Ta druga kartica je tomato na bonove, a primarna SIM kartica mi je A1 na pretplatu. Prilikom kupnje jedne aplikacije nisam dobio mogunost odabira s kojeg računa će mi se naplatiti - svejedno sam je kupio i vidio da mi je novac skinut s glavne pretplatničke kartice. Da li je možda razlog tome što mi je primarni A1 broj vezan za gmail account, a ne ovaj od Tomato računa ili postoji neki drugi način da kod sljedeće kupovine odaberem s koje će mi se točno kartice google naplatiti?
Morpheous je offline   Reply With Quote
Staro 30.05.2020., 13:12   #6043
acmevagabundo
Datum registracije: Jul 2015
Postovi: 323
U play storeu imaš dodaj način plaćanja. Jesi probao dodati drugu karticu kao način plaćanja?
Poslano sa mog SM-N975F koristeći Tapatalk
acmevagabundo je offline   Reply With Quote
Staro 30.05.2020., 15:50   #6044
Morpheous
Morpheous's Avatar
Postovi: 1,144
Autor acmevagabundo Pregled postova
Bok, jedino sto imam kao opciju je You can add purchases directly to your A1/Tomato bill. I ne nudi mi tocno odredenu karticu, pa me zato zanimalo na koji nacin je google odabrao A1 za naplatu umjesto Tomato racuna. Jedino sto mi ima smisla je sto mi je A1 broj unesen na google account od prije, ali mislio sam da je to samo za npr verifikaciju maila isl. Mozda vrijedi i za naplatu google play usluga?
Staro 30.05.2020., 16:22   #6045
acmevagabundo
Postovi: 323
Iskreno ne znam. I meni je oznaka A1 / Tomato, ali u trenutku kada sam dodavao način plaćanja imao sam samo Tomato karticu u mobitelu i sa nje su skinuta sredstva. Tomato na bonove radi, tu nemaš problema.
Jedino što mi pada na pamet da probaš zamijeniti telefon u google računu. Ili ako skida sredstva sa sim1, da probaš zamijeniti sim kartice. Već sam zaboravio, ali nekako mi u glavi da sam dobio sms verifikaciju na broj kada sam htio dodati plaćanje sa Tomato računa. Ali u stvari ne znam, nagađam.
Staro 30.05.2020., 17:34   #6046
Morpheous
Morpheous's Avatar
Postovi: 1,144
Mislim da cu sljedeci put napraviti disable na primarnoj kartici, a brojeve sam zamijenio na google racunu pa cu vidjeti kako ce funkcionirati.
Staro 02.06.2020., 22:25   #6047
baTman
Lokacija: asfsafsa
Postovi: 327
Jeli ima neka karta za skinut da je mogu koristiti offline za lokaciju?
baTman je offline   Reply With Quote
Staro 02.06.2020., 22:27   #6048
Sony1
Sony1's Avatar
Lokacija: Slavonija
Postovi: 294
Trazim aplikaciju za offline youtube tj. da moze raditi u pozadini. Tnx!
Poslano sa mog HD1903 koristeći Tapatalk
Sony1 je offline   Reply With Quote
Staro 02.06.2020., 22:30   #6049
Max_Damage
Max_Damage's Avatar
Lokacija: Krapinske Toplice
Postovi: 959
Vanced
Max_Damage je offline   Reply With Quote
Staro 02.06.2020., 22:59   #6050
Libertus
Libertus's Avatar
Datum registracije: Jul 2017
Lokacija: Ramura
Postovi: 2,845
Autor baTman Pregled postova
Google Maps ima mogućnost da skineš dio karte offline. Ljudi su preporučavali Here maps i onda imaš plaćene tipa Genius maps.
Staro 02.06.2020., 23:14   #6051
Morpheous
Morpheous's Avatar
Postovi: 1,144
Autor Libertus Pregled postova
Here je sasvim u redu. Skines mapu za cijelu drzavu i miran si. Meni je ok i Maps.me, ali Here koristim 90% vremena.
Staro 02.06.2020., 23:50   #6052
domy_os
domy_os's Avatar
Postovi: 18,960
Jedino što HERE prečesto vodi na kaldrmu iako je ista isključena tako da treba biti oprezan i pogledati rutu u još nekoj aplikaciji.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 03.06.2020., 07:02   #6053
Postovi: 34,094
Svako malo imaš solidne popuste na Sygic navigaciju. Ako ti se ne kupuje, imaš je 'sređenu' na raznim GPS forumima.
Staro 11.06.2020., 18:41   #6054
Bodisson
Bodisson's Avatar
Datum registracije: Dec 2014
Postovi: 246
Call blocker
Ekipa, isprike...
Ili nisam dobro tražio, ili se još nisam probudio.
Dakle, ima frendica mob na kojem nema whitelist/blacklist brojeva.
Nekakav Vivax Fly, Android 7
Trazimo free call blocker bez ili s minimumom reklama.
Koji radi.
Sve sto sam vidio na Google Play ima previse invazivne reklame.
Ili zeli biti default dialer.
I da, Google is my friend, a tamo su stvari jos gore...
Zadnje izmijenjeno od: Bodisson. 11.06.2020. u 19:01.
Bodisson je offline   Reply With Quote
Staro 12.06.2020., 05:50   #6055
Postovi: 34,094
Nek si kupi noviji mob pa joj neće trebati nikakav app za to. Vivaxa je ionako pregazilo vrijeme.
Staro 16.06.2020., 21:56   #6056
Wannabes
Wannabes's Avatar
Datum registracije: Apr 2011
Lokacija: Sk
Postovi: 193
Vidim Timely su developeri ostavili da umre, pa sad tražim zamjenu za njega jer mi na novom mobu više ne radi kak treba. Ne može se ugasit alarm bez da se mobitel otključa itd...
Šta koristite, kojom aplikacijom ste zamijenili Timely ?
Wannabes je offline   Reply With Quote
Staro 09.07.2020., 15:57   #6057
Mr.Ex.President
Torrent freek
Mr.Ex.President's Avatar
Postovi: 3,949
Pošto ne mogu nać nijednu normalnu galeriju (meni normalnu, da se ogradim odma) da ima uredan cloud sync servis, onda mi treba nekakav sync alat koji će jednostavno uzet 10 foldera sa mobitela i syncat iste na gooogle drive. Od opcija mi treba samo da to radi kad je mobitel na WIFI i Charging, ali pretpostavljam da je to toliko banalno da imaju svi.
Vidim toga ima hrpa, većina se nešto sitno i naplaćuje, ima li ko kakva iskustava?
MBO: MSI B450 Gaming Plus
PSU: Corsair RM550X 550W
Periferija
LCD: HP ZR24w
Mouse: Logitech G400
Sound: Genius SP-HF1201A
Printer: HP LaserJet 1020
Scanner: HP ScanJet 4300
Headphones: Philips SHC 2000
MBO: Gigabyte GA-F2A85XM-HD3
HDD: WD Green 2TB [WD20EZRX]
PSU: Antec SU380
TV: Samsung 43E450 @HDMI
LINK
Staro 09.07.2020., 16:00   #6058
prileee
laser
prileee's Avatar
Postovi: 2,356
Sta fali google photos?
Staro 09.07.2020., 20:32   #6059
perich
I hate mondays..........
perich's Avatar
Datum registracije: Nov 2002
Lokacija: Zagreb - Zaprešić
Postovi: 1,542
Ima li app (bez roota) koji bi po aplikaciji mogao blokirati mobilni internet,vam ostaviti wifi?
Na mobu od klinke bi htio blokirati mobilni net za YouTube i slične aplikacije a ostaviti WhatsApp i Chrome itd, ali da YT uredno radi preko WiFi.
Sent from my SM-G973F using Tapatalk
perich je offline   Reply With Quote
Staro 09.07.2020., 21:14   #6060
domy_os
domy_os's Avatar
Postovi: 18,960
Autor perich Pregled postova
Pa što nije firewall danas integriran u svaki telefon?
