Staro 22.04.2020., 15:53   #4711
Blue Spirit
Blue Spirit's Avatar
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,228
nVIDIA RTX Voice works without RTX GPU
nVIDIA RTX Voice - radi i na GTX 1050 1060 1070 1070 Ti 1080 1080 Ti 1650 1660
Nvidija AI program koji eliminira pozadinski zvuk tipkovnice koji se cuje pri voice chatu ili strimingu (Discord, TS3, OBS , XSplit Broadcaster, Skype, i td. ...) više o tome imate tu
Imate gotov - unaprijed modan RTX voice ili možete ga sami po donjim uputama prepravit:
pre-modded NVIDIA RTX Voice v0.5.12.6 DL Link 379.6 MB:
The new nVIDIA RTX Voice works just fine without an RTX GPU and on windows 7 too, tested and working on a GTX 1080 and a Titan V, here's how to make it install...
After executing the installer and getting the message that stops it installing the installer files are extracted to C:\temp\NVRTXVoice
Open the file C:\temp\NVRTXVoice\NvAFX\RTXVoice.nvi with a text editor and remove the "constraints" section that looks like this:
HTML:
<constraints>
<property name="Feature.RTXVoice" level="silent" text="${{InstallBlockedMessage}}"/>
</constraints>
with that section deleted save the file and execute the installer here: C:\temp\NVRTXVoice\setup.exe
This software is absolutely unreal! Enjoy.
Edit: You may need to open the file as administrator to modify it.
Another edit: Seems to be working on all 10 and 16 series cards but 900 series results are mixed.
https://forums.guru3d.com/threads/nv...es-how.431781/
/connect 185.107.96.125:28990
server rcon: oldschool
Staro 23.04.2020., 15:23   #4712
tole_
Casual Racist
tole_'s Avatar
Lokacija: Sneed's feed and seed (formerly Chuck's)
Postovi: 422
Autor dada-as Pregled postova
E sad jel to dobro?
Normalno za kartice s lošim hlađenjem. Za 250W kartice treba i pošteni hladnjak, isto kao što za one od 120W treba nešto više od komadića aluminija. Možeš probati undervolt kako bi dobio niže temperature i nešto stabilniji clock ili barem tiši vent.
Why did the console peasant cross the road?
To render the buildings on the other side!
tole_ je offline   Reply With Quote
Staro 14.05.2020., 13:38   #4713
slavonac90
slavonac90's Avatar
Postovi: 1,537
Ljudi imam sljedeći problem, periodično mi se dogodi prilikom igranja crni ekran na sekundu i sve se vrati u normalu. Primjetio sam sam kada se igram navedeni problem i to možda jednom u 2 sata, nekad ne bude uopće. Grafa je nova Gtx 1650 super. Gledao po netu da treba uključiti "no scalling" ali nije mi pomoglo, probao reinstall drivera isto neuspješno. Samo da napomenem kako mi je grafa spojena na monitor preko DP-a, na TV-u nisam primjetio problem koji je na HDMI.
slavonac90 je offline   Reply With Quote
Staro 14.05.2020., 16:10   #4714
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,185
Autor slavonac90 Pregled postova
A ja mislio da se to događa samo na AMD Navi grafama...
Prvi put čujem za to kod nVidia-e. Da nije neki problem sa FreeSync/G-Sync?
Staro 14.05.2020., 16:30   #4715
slavonac90
slavonac90's Avatar
Postovi: 1,537
Ugašen je freesync, dešavalo mi se to i na drugim grafama(bilo nvidia ili ATi), ali sam već zaboravio na to jer sam preko pola godine bio na integruši i sada uzeo ovu 1650s, spojio na DP i opet se dešava. Nije ne znam šta , ali iritantno je kada bi sve trebalo bez problema raditi i desi se tilt Ne znam jel može do napajanja biti, iako bi ovaj forton hyper od 500w morao biti dovoljan za gtx 1650s koja jedva povuče 100w u full loadu.
Staro 14.05.2020., 16:34   #4716
Postovi: 8,655
Spoji karticu na neki (DVI?) izlaz koji nije DisplayPort, jer te to (vrlo vjerojatno) zajebava.
Staro 14.05.2020., 16:37   #4717
slavonac90
slavonac90's Avatar
Postovi: 1,537
To mi nije opcija nažalost, jer na monitoru preko DP-a mogu dobiti 4k u 60 hz8nativna reza) i preko HDMI 2 u koji je uštekan Ps 4 Zanima me postoji li neki način da se to riješi jer sve što sam probao ne radi,a vidim dosta po netu takvih problema, ali jako malo riješenih.
Staro 14.05.2020., 16:39   #4718
Postovi: 8,655
Velim ti, to je do DisplayPorta, nema veze kaj god da pokušaš, dokle god ne spojiš, pa makar samo za probu na nešto što nije DisplayPort. Nažalost.
Staro 14.05.2020., 16:42   #4719
slavonac90
slavonac90's Avatar
Postovi: 1,537
Onda ništa, probat ignorirat, možda s vremenom bude manje smetalo
Staro 14.05.2020., 17:50   #4720
GreenLife
Čika Zeljeni
GreenLife's Avatar
Datum registracije: Sep 2013
Lokacija: Tannhausen (Aalen)
Postovi: 497
Pretpostavljam da je konekcija direkt DP - DP bez ikakvog konvertera na kraju (tipa DP u HDMI).
Probaj s drugim kabelom. Imao sam sličan slučaj prije na GTX 970 - stvar je bila u kabelu.
Written on Note 10+
Staro 14.05.2020., 18:08   #4721
dragunovx
dragunovx's Avatar
Lokacija: OS
Postovi: 46
Po opisu sta se događa mogu ti reći da je meni bilo tako.
meni je uzrok bio pregrijavanje, pa svakako preporučujem da pratiš temperaturu kartice, npr. afterburnerom ili tako nečim.
poz.
Sent from my HMA-L29 using Tapatalk
dragunovx je offline   Reply With Quote
Staro 14.05.2020., 19:19   #4722
slavonac90
slavonac90's Avatar
Postovi: 1,537
Autor GreenLife Pregled postova
Written on Note 10+
Isprobano i ništa, isti problem imao i sa gtx 1660 Ti i rx 580,a evo sad i s ovom novom 1650s. Sumnjam nekako ili na napajanje ili matičnu jer jednostavno nema što drugo biti.
Autor dragunovx Pregled postova
poz.
Ma nije to, nejde grafa preko 65 celzija prilikom gaminga, nema fps dropova, sve radi kao podmazano osim što se na sekund izgubi slika i vrati. Svaki put mi nakon toga prikaže na monitoru oznaku DP kao da sam ga tek upalio, jednostavno kao da grafa i monitor izgube kontak u sekundi i poslije kao da se ništa nije dogodilo.
Staro 14.05.2020., 19:26   #4723
Postovi: 8,655
Nije ni matična, ni grafička, a bome ni napajanje. DisplayPort, ne kabel, već protokol + konektor kao takav i u određenim slučajevima imaš ovakvu (tvoju) situaciju. Isto se meni događa na službenom laptopu s Intel iGPU rješenjem i Dell U2417H monitorom kad je spojen DisplayPortom. Bilo koji drugi konektor je OK. I takvih primjera imaš more diljem Interneta i svi traže rješenje u hardverskim problemima, ali nažalost nije to na stvari. Zato sam ti napomenul da probaš spojiti samo za test, nešto što nije DisplayPort, jer se ovak vrtiš u krug.
Staro 14.05.2020., 20:09   #4724
slavonac90
slavonac90's Avatar
Postovi: 1,537
Mislim da na HDMI nisam imao problem na starim grafama, ali evo spojio sam pa vidim kako će se ponašati do sutra i na ovoj. Znači ako je do DP-a nema pomoći? Nije mi opcija da mi bude monitor na HDMI non stop jer imam 1 HDMi i 1 DP na grafi pa mi onda ne može i TV biti spojen.
Staro 14.05.2020., 20:15   #4725
Postovi: 8,655
Da, zajeb je, ako nemaš više izlaza na izbor i po tom pitanju nisam pametan, jer nije rješenje mijenjati karticu ili još gore monitor zbog blesavog DisplayPorta.
Staro 14.05.2020., 20:15   #4726
maXonja
bu
maXonja's Avatar
Datum registracije: Jan 2017
Lokacija: VŽ
Postovi: 2,631
DP na HDMI adapter? Možda bi to pomoglo iz nekog razloga, ono bubam
Jer ovo mi je malo blesavo da bi baš DP bio tako neispravan i da to radi
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 14.05.2020., 23:57   #4727
ThePornstar
ThePornstar's Avatar
Postovi: 4,403
O da, zna DP konekcija itekako zajebavati, baš na taj način kako je kolega opisao. Ako ništa, treba probati drugi DP kabel.
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
Battery: 57 Wh internal
ROM: Android 9
Staro 15.05.2020., 07:28   #4728
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,476
Slično ovome što se spominje sam se nagledao na poslu.
Ili slika zatitra ili se malo ugasi pa upali...sve preko DP-a.
Mjenjani kablovi, flashani BIOSi, updateani driveri od intelove integruše....niš ne pomaže.
Doduše, pomoglo je mijenjanje monitora tu i tamo (sve isti modeli monitora).
A koliko vidim sve novije grafe su samo DP i HDMI.
Slobodno me dodajte na PSN
Staro 15.05.2020., 08:10   #4729
zgmmax
zgmmax's Avatar
Postovi: 1,683
Kod mene u firmi isto većina nas ima problema sa DP.
Većinom svi imamo XPS-ove sa dockingom i svako malo se monitor (Dell monitori) ugasi na 1-2s.
Staro 15.05.2020., 09:13   #4730
Mladenxy
Mladenxy's Avatar
Postovi: 4,510
Monitor preko DP-a, TV preko HDMI-a sa iste grafe i nemam nikakvih problema. Na ekranima su različite rezolucije 2056x1080 i 4K te 75hz-a i 60hz/120 hza po potrebi i opet nema problema.
Staro 15.05.2020., 10:57   #4731
slavonac90
slavonac90's Avatar
Postovi: 1,537
Na HDMI od jučer nisam primjetio problem, ostavim još malo ali kontam da je to to. DP je faličan i hebat ga, probam još jedan kabl zamjenit jer će mi svakako biti komp i monitor preko DP-a spojeni, ako ne šljaka i treći kabl pravit se da ne vidim
Staro 15.05.2020., 11:26   #4732
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,476
A probaj i promjenit DP utor na grafi, ali iz iskustva neće pomoć.
Recimo kod nas u firmi se desi da od dva spojena monitora, zeza samo jedan, uvijek isti.
Ono, zamjenim im utore na matičnoj, i opet se isti monitor tako gasi.
A doma sam npr trenutno još uvijek na DVI.
DP sam preskočio jer mi je grafa post uporno bacala na TV (HDMI).
Staro 15.05.2020., 11:32   #4733
slavonac90
slavonac90's Avatar
Postovi: 1,537
Imam 1 DP i 1 HDMI 1 DVI (ali to nemam na monitoru) tako da nemam baš nekih opcija što se portova tiče. Koliko vidim da nema pomoći oko toga tako da ću jednostavno morati ignorirati. I tako sam primjetio samo prilikom gaminga to, u normalnom radu mislim da nisam...a ne igram se nešto puno na kompu u zadnje vrijeme tako da nije toliki problem, iako sam se nadao da se da riješit ali što je tu je.
Staro 15.05.2020., 14:23   #4734
kiki86
Tehničar
Datum registracije: Dec 2011
Postovi: 1,105
Autor Disco Pregled postova
e ovaj dio mene zanima, cura mi ima spojena 3 ekrana(2 monitora(vga i dp) i tv(hdmi)) na grafu, i post baca na monitor na vga kabel spojen, a volio bi da baca na ovaj koji je preko dp, cim uleti u windowse se tako prebaci na taj kao glavni. Ima nacina da se to negdje promjeni? iako neznam di, jer u windowsima je ok namjesteno, a u biosu bas i nema birat koji je monitor glavni Grafa je gtx 770 ako je bitno...
Staro 15.05.2020., 14:54   #4735
Postovi: 8,655
Ovisi i o proizvođaču kartice koji također može složiti da određeni video izlaz bude primarni, pa nema veze kaj sve je spojeno, prvo ide slika na taj izlaz.
Staro 15.05.2020., 19:50   #4736
maXonja
bu
maXonja's Avatar
Lokacija: VŽ
Postovi: 2,631
Ostavi ukopčan samo ekran sa kojeg hoćeš da ti POST-a i upali PC
Kad uđe u windowse uštekaj i ostalo
Nadalje bi trebalo stalno POST-at na tom ekranu kojeg si imao solo uštekanog kad je prvi puta dizao
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 13.06.2020., 20:21   #4737
dinos3
Dino Saur
dinos3's Avatar
Datum registracije: Jan 2012
Postovi: 941
Imam 2 pitanja pa da ne otvaram novu temu ovdje ću
1.
Kupio sam ASUS GTX 1070 Dual OC od kolege i u mom kompu ne radi. To jest radi sve dok ne instaliram drivere, nakon toga se komp samo restarta sam od sebe.
Probao sam reinstall windowsa jer sam prije imao grafu iz AMD tabora pa sam mislio da se nešto krši između starih drivera i ovih Nvidijinih (iako sam prije obrisao AMD drivere).
Sve u svemu dok je na onom Microsoft display basic driveru radi normalno i čim instaliram Nvidijin driver komp se restarta svaki put čim botooa windows (ili u roku 10 sekundi nakon boota windowsa) probao sam najnovije whql drivere i one stare s CDa.
Kod kolege grafa radila normalno, i ubacio sam ju u komp kod drugog kolege i njemu sve normalno radi.
Tako da ja mislim da je problem u mom napajanju, staro je oko 7 godina, iako su mi prošle komponente radile normalno s tim napajanjem (Fx 8350 i rx 570, i nakon njega ryzen 2600 i rx 570)
Rx 570 mi je zahtjevala 6 pin napajanje a ova gtx ima 6+2. Probao sam sve 6+2 konektore od napajanja koje imam i na svima se restarta cim digne windowse.
Može netko potvrdit da je napajanje u pitanju? Ili ako ima još neki prijedlog šta bi mogao probati?
2.
Također me zanima zašto svijetli ova bijela i crvena lampica na grafičkoj kod power utora? Je li to javlja neku grešku s njom? Te dvije lampice su svijetlile i kod mene i kod obojice kolega u kompu.
Skužio sam da ne radi jedan DisplayPort (probano i kod mene i kod kolege), na drugom DisplayPortu normalno daje signal.
Imam garanciju još pola godine, pa me zanima mogu li reklamirat grafičku? Jer jedan utor ne radi i to crveno vjerojatno signalizira neku grešku tako da bi možda mogla uskoro krenut pravit veće probleme.
A grafička je već prije 4 mjeseca bila na reklamaciji jer se gasila svakih 2 sata tijekom gejmanja, i problem je bio otklonjen (navodno su samo pastu promjenili) iako temp nije prelazila 80C.
SLIKA
Zadnje izmijenjeno od: dinos3. 13.06.2020. u 20:27.
dinos3 je offline   Reply With Quote
Staro 13.06.2020., 21:26   #4738
Iluzionist
Iluzionist's Avatar
Datum registracije: Apr 2019
Postovi: 420
Reklamiraj to, nemaš što dalje razbijati glavu sa njom.
Staro 13.06.2020., 21:50   #4739
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,581
Tko je mjenjao pastu ? tko smije skinuti naljepnicu s grafe da bi zamjenio pastu ?
Autor dinos3 Pregled postova
1.
2.
SLIKA
Staro 13.06.2020., 22:01   #4740
dinos3
Dino Saur
dinos3's Avatar
Postovi: 941
Autor xulos Pregled postova
U Instaru je kupljena grafa, tamo je i slana na reklamaciju. Oni su promjenili pastu i stavili novu identičnu naljepnicu preko ove stare koju su probušili kad su skidali hladnjak.
