Staro 19.07.2019., 16:52   #661
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,544
FC5, tomb raider, FC6 (valjda ima bench ko i FC5?), čmark, heaven, Superposition.
Staro 19.07.2019., 17:20   #662
Autor Gabre Pregled postova
Da ja upitam,
Aj neki popis benchova da odvrtim prije nego stavim novi comho, danas valjda proc stize.... Ali nema rama jos...
Pa da napravim neki spredsit
Moš i ovo replicirat
http://forum.pcekspert.com/showthread.php?p=3319380
Sent from my SM-G965F using Tapatalk
Staro 19.07.2019., 19:59   #663
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
e bas budem kad stignem
bas da vidimo koliko je nadmocan 3700X naspram 4790k
Staro 19.07.2019., 21:30   #664
Gabre
Lika u mom srcu
Gabre's Avatar
Postovi: 9,887
Staro 19.07.2019., 21:36   #665
Postovi: 8,655
After Effects CPU Roundup
Overall, the new AMD Ryzen CPUs perform neck-in-neck with the Intel 9th Gen CPUs in traditional After Effects workflows. The Intel 9900K continues to hold the performance crown by a slim margin (especially for RAM Preview performance), but AMD has a slight lead at the Ryzen 5 and 7 price-points. If you use multithread plugins or scripts like BG Renderer Max or RenderGarden, however, Intel take a pretty significant lead over AMD at the top-end, but it continues to very close at the mid/low-end. In the real world, the extra performance during RAM Preview with the Intel Core i9 9900K will likely be noticeable, but if you are looking for a CPU at a slightly lower price point, it is going to be really hard to tell the difference between a system with an Intel 9th Gen CPU and one with an AMD Ryzen 3rd generation CPU. Because of this, many users are going to want to consider other factors beyond just price and performance. While there are many more factors that go into your choice of platform, here are a few other considerations to keep in mind.
Photoshop CPU Roundup
Overall, the new AMD Ryzen CPUs are a great choice for a Photoshop workstation. There may not be much of a reason to go with the more expensive Ryzen 9 3900X over the Ryzen 7 3800X, but the Ryzen 5 and Ryzen 7 CPUs should be slightly faster than the similarly prices Intel equivalents. However, the performance advantage over Intel is really only a handful of percent which is going to be almost impossible to notice in the real world. While the AMD CPUs are slightly faster or more affordable than Intel, oddly enough that may not be enough of a reason to go with team red (AMD) over team blue (Intel) for everyone. There are many more factors that go into your choice of platform than just benchmark performance - especially when the results are as close as these are. Many consumers may make the choice based simply on which company they want to support (which is a perfectly valid reason), there are a few other considerations to keep in mind.
Izvor: Puget Systems
Staro 19.07.2019., 22:16   #666
BusMaster
BusMaster's Avatar
Datum registracije: Apr 2017
Postovi: 343
Unhappy
Staro 20.07.2019., 01:35   #667
Čitam naa UK i DE forumima, totalna nestašica 3rd Gen Ryzen procesora. Grabe se doslovno svi, od R5 3600 do R9 3900X. 3700X su planuli odmah, a onda je bilo daj šta daš. Fino
Staro 20.07.2019., 02:31   #668
Exy
Exy's Avatar
Lokacija: Zagreb, Črnomerec
Postovi: 2,710
Evo i mene sa par benchmarka, po Brkinom modelu
Blender
Cinebench 15
CPU-Z
Uredno boosta na 4,2, sve je na defaultu. Kasnije sam mislio malo probati overclock i tako, iako mislim da nema smisla.
Win 1903, Ryzen performance plan, zadnji BIOS za ploču (AGESA 1.0.0.1)
Igre nema smisla da benchmarkam, možda kad zamijenim slabašni 1060
Staro 20.07.2019., 04:57   #669
Gabre
Lika u mom srcu
Gabre's Avatar
Postovi: 9,887
pokupio 3700X... sad jos ram i proc za flesanje... 57 faking dolara me trazili za flesanje, PEDESET i SEDAM
reko jeste vi normalni, pa kupim proc za te novce
Staro 20.07.2019., 09:27   #670
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,475
Autor Exy Pregled postova
Blender
Cinebench 15
CPU-Z
A di su rezultati starog kompa? U tome je bit
Slobodno me dodajte na PSN
Disco je online   Reply With Quote
Staro 20.07.2019., 11:30   #671
BusMaster
BusMaster's Avatar
Postovi: 343
Blender
Cinebench 15
CPU-Z
__________________________________________________________
Evo gledam ovaj tvoj post dva puta i čudim se..., 4,2 Giga na 1.088V,
jesi to ubo neki super golden-sample primjerak. Kolika ti je temp. na toj frekvenciji, jesi probao napraviti neki stres test da vidiš jeli stabilno?
Staro 20.07.2019., 11:45   #672
warlock25
warlock25's Avatar
Postovi: 2,327
Ima bug ziher sa cpu-z kao i ja jer ne ocitava voltazu ocito tocno.Meni je voltaza 0.68v u loadu.LOL.Ili ima super,uber,dijamantni primjerak proca drito iz ladice od Lise Su.
Staro 20.07.2019., 11:59   #673
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,281
Autor BusMaster Pregled postova
.. kako kaže warlock prije će biti neko krivo očitanje..
S obzirom da je sve default, boosta vcore sigurno na 1,45V+
Exy, ne vidim SS jer na mobitelu je teško razvući, ali interesiraju me temperature, koliko se grije?
MojSkuter
Staro 20.07.2019., 12:10   #674
Exy
Exy's Avatar
Postovi: 2,710
Autor Disco Pregled postova
U pravu si To je zamka u koju se često padne kad se radi ovakav upgrade, recimo gledaš koliko je 3600 brži od 2600 a u kanti imaš starudiju iz 2011. od koje je duplo brži Nažalost, nisam radio bencheve na starom.
@BusMaster i @warlock25
Kako da ne dečki
To CPU-Z samo tako pokazuje, u single ga bez problema boosta na 1.4V.
Nisam pretjerano testirao stabilnost, samo sam izvrtio intel burn stress 20 puta i aida64 onaj stability test. Mislim da nema razloga bit nestabilan na defaultu. Voltaža je na auto, cool n quiet je enablan.
Temperature idu do 72-73 u stres testu na sve jezgre, kučište je uvijek otvoreno.
Izvrtio sam i onaj noob bench - https://www.userbenchmark.com/UserRun/18566875
P.S. ako hoćete konkretno da neki test izvrtim pa pratim temperature, recite
Staro 20.07.2019., 12:18   #675
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,281
Zamka su općenito benchevi, jer u ovom slučaju ja osjetim u običnom browseru napredak, ali i općenito, da sve radi nekako responzivnije i bolje..
To sam više puta već spomenuo, to nisam osjetio ni približno kada sam prelazio s 1600 na 2600
MojSkuter
Staro 20.07.2019., 12:38   #676
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,589
Eladio to je očito placebo efekt, jer ne možeš osjetit razliku u browseru između iole relevantnijih cpu, a kamoli između dva moderna sa gro jezgri. Barem nebi trebao ako je sve u redu sa prijašnjim sistemom (odnosno instalacijom OS-a)
Staro 20.07.2019., 12:41   #677
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,475
Kako da ne dečki
Ajde pliz probaj i RAM na 3200 C16 pa javi, navodno ide bez problema.
EDIT@ Manuel: meni se sve uspori kad prvi put palim waterfox (sa 20+tabova) i kad ih refresham više do 5-6....
Staro 20.07.2019., 12:52   #678
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,281
..ja osjetim mozda jer vrtim hrpuuu tabova (krive navike ili ne baš me briga) i to često YouTube/flash što nije lagano kao forum..
..ali kao što osjetiš u gejmingu highrefresh monitor, te fine stvari osjetis i kad stavis bolji proc u komp. E sad, probaj češće mijenjati šta da ti kažem
Netko ne osjeti razliku izmedju 100 i 110ks konja u autu, a netko osjeti. I ne voze svi samo u 6.oj, 100km/h bez da preticu ili saltaju.. nije sve placebo kvragu
Ps da se nasalim, kada zena otvori 24h web, stutter samo takav i izgubim zivot u warfaceu lol . Nije ni web ono što je nekad bio
Pps..usudit cu se pa cu nagađati da je "gamecache" u igri.
Sjecam se dana kada si imao duron i athlon, ili celeron i pentium. Da ne spominjem xeone khm Cesto skoro isti proc, istog takta, ali malo vise cachea u procu, i odmah ljepse radi. Mozda/vjerojatno/sigurno sam falio, ali osjećaj je tu negdje
MojSkuter
Zadnje izmijenjeno od: Eladio. 20.07.2019. u 13:28.
Staro 20.07.2019., 13:49   #679
Manuel Calavera
Postovi: 14,589
Jbga to ti može biti i do neta. Pogotovo ako na tebe utječe u multiplayeru što netko drugi surfa
Staro 20.07.2019., 13:54   #680
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,281
Exy
Ako dobro vidim, u blenderu ti drzi niskih 3360 all core? Nastavno na taj niski takt, ako budes OCao (pogotovo all core iz biosa, mozda bolje pbo-autoOC jer ti ljepo boosta proc) pripazi na temp, jer spominjao si 72-73°C stock
Usporedi rezultate, jer kod ovih novih ryzena cesto dobijes malo ili nista, a temp skacu dosta
Ps
Manuel , naravno da je i do neta, zato npr sada igram tek.kad svi legnu spavati, ali načelno net je fixni, zica jos uvjek ista. Nije samo browser, index match probaj u excelici od nekoliko desetaka tisuca redaka. Ma na sta god kliknem. Proc je varijabla. Oscjecaj ili placebo, tesko izmjeriti ali moras probati . Neću vise jer nema smisla toliko pričati o nečemu nemjerljivom ili teško mjerljivom. Vec sam se upecao na highrefresh teme tako, i to ode unedogled
MojSkuter
Zadnje izmijenjeno od: Eladio. 20.07.2019. u 14:20.
Staro 20.07.2019., 14:18   #681
Michel
Michel's Avatar
Lokacija: Dubrovnik
Postovi: 1,288
Ima li netko da mi može reći, kakva je sada situacija sa Insurgency Sandstorm, što se tiće performansi.
Meni je na 4670k ( blagi oc ) i 1080 gtx
išla 85 fps pa naviše s ogromnim lag spike-ovima svako nekoliko.
Sve je bilo u jednoj sceni kao da klizi u drugoj zastajkivanja a jako mi se igra.
( Doduše već sam kupio matičnu i odlučio upgradati na 3xxx seriju. )
S3 Trio 64 , Voodoo 2 , Kyro 3d , GeForce MX 440 SE , Radeon 9000Pro , 6600 GT , 9600 GT , 260GTX , 560GTX , 760GTX, 1060 GTX, 1080 GTX, 3080 RTX
Michel je offline   Reply With Quote
Staro 20.07.2019., 14:41   #682
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,475
Kad se već spominju i temperature.
Koji bi bio neki best buy cooler za 3600 (da boosta kako treba)?
Frezzer 34? F34 Dual (ima li taj dual uopće smisla?)? Nešto treće za 200-300kn?
Zadnje izmijenjeno od: Disco. 20.07.2019. u 14:50.
Staro 20.07.2019., 15:08   #683
Thermalright "Buco" ARO-M14O. Izuzetan cooler. 400 kn.
Staro 20.07.2019., 15:18   #684
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,281
Best buy je stock cooler i deinstall monitoring aplikacija.. khm ..Em je top down, em je dobra cijena lol
Ali, slažem se s brkom, ovi noviji ryzeni za nas koji koji volimo da ti sve bude po PSu .. treba preskočiti ove od 200kn (ili racunati na kompromise) i staviti odmah nekog bucmastijeg
Tko ima budget ploču mozda odmah staviti i vent na VRMe ili odmah kupiti neku topdown mrcinu. Ne zbog potrošnje proca, nego brijem dio temp s proca ce dodatno grijati VRMe pa zato
MojSkuter
Staro 20.07.2019., 15:32   #685
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,475
E da, bitna mi je tisina u idleu, kad igram ili kad drobi handbrake neka se razmase, ali dok surfam i slicno ocu da je stealth.
Staro 20.07.2019., 15:32   #686
Dakle "Buco" ne treba ti nikakav extra bracket budući je to Ryzen only cooler.
Sent from S7 Presidency Phone
Staro 20.07.2019., 16:14   #687
Manuel Calavera
Postovi: 14,589
Autor Michel Pregled postova
Jedino što sam vidio da ju je testirao je Hardware unboxed u R9 3900x vs i9 9900K usporedbi i egal su tj. 0% razlike...
E sad ako igra dalje ima nekih problema to ne znam tj. nije do procesora (gpu, sama igra ili serveri)...
Koliko vidim cpu usage je velik tj. nema tu ni blizu neke velike gpu iskorištenosti:
https://www.reddit.com/r/insurgency/...tlenecking_my/
https://steamcommunity.com/app/58132...3798902423487/
No pretpostavljam da 6c12t nebi bio problem. Dalje je na igri...
Staro 20.07.2019., 16:22   #688
Dottore
Dottore's Avatar
Postovi: 7,734
Podsjeća me na Macho. Staviš malo niže vent i već puše po vrm-u
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Dottore je online   Reply With Quote
Staro 20.07.2019., 16:37   #689
Michel
Michel's Avatar
Lokacija: Dubrovnik
Postovi: 1,288
E hvala, ti odlično !
Staro 20.07.2019., 17:04   #690
Autor Dottore Pregled postova
To i je Macho samo je isključivo za AM4 socket i ima Ryzen natpis na gornjoj ploči koja je u Ryzen bojama (orange ili grey)
