Staro 25.06.2019., 17:19   #3631
locks
Datum registracije: Mar 2010
Lokacija: Vukovar
Postovi: 3,596
HT mreža, računajući i bonbon ima problem s kašnjenjem push notifikacija. Prouči recimo temu bonbon.
Ma držim u pozadini gmail,viber i messenger i sad radi....
Staro 26.06.2019., 01:26   #3632
catroot
catroot's Avatar
Datum registracije: Apr 2009
Lokacija: I live in 43 05'04.11"N 17 57'36.71"E
Postovi: 881
Autor locks Pregled postova
Ja ih držim u pozadini isto bonbon mreža i preko wifi, pa opet ne dolaze notifikacije za whatsapp i viber, tek kad se otvore aplikacije. Jedino što nisam napravio reset to factory settings, radi se o huawei mate 10 lite.
Sent from my SM-A530F using Tapatalk
catroot je offline   Reply With Quote
Staro 26.06.2019., 16:41   #3633
zig
zig's Avatar
Datum registracije: Jan 2010
Postovi: 386
Mate 20 PRO dobio EMUI 9.1 (HiCare).
zig je offline   Reply With Quote
Staro 26.06.2019., 17:09   #3634
Facelessone
Facelessone's Avatar
Postovi: 4,203
Autor yaya Pregled postova
Ja sam skoro sve mobitele kupila od dilera al uvijek kupujem novo zapakirano i nisam nikad imala problema, uzgred Tijekom srpnja nadogradnju na EMUI 9.1 dobit će još 14 mobitela: P20, P20 Pro, Mate 10, Mate 10 Pro, Mate 10 Porsche Design, Mate 9, Mate 9 Pro, Y9 2019, Y6 2019, Y5 2019, Nova 3, Nova 3i, Nova 3e i Nova
Ipak malo više uređaja.
Huawei 9.1 Update – Eligible Devices
The following are the list of Huawei and Honor devices confirmed to get EMUI 9.1 update –
Huawei EMUI 9.1 Supported Devices
Huawei Mate 20
Huawei Mate 20 Pro
Huawei Mate 20 X
Huawei Mate 20 RS Porsche Design
Huawei Mate 20 Lite
Huawei Mate 10
Huawei Mate 10 Pro
Huawei Mate RS Porsche Design
Huawei Mate 9
Huawei Mate 9 Pro
Huawei Mate 9 Porsche Design
Huawei P20
Huawei P20 Pro
Huawei P10
Huawei P10 Plus
Huawei Nova 4
Huawei Nova 3
Huawei Nova 3i
Huawei Nova 2S
Huawei Nova 4e
Huawei Nova 3e
Huawei Enjoy 9 Plus
Huawei Enjoy 8 Plus
Huawei Enjoy Max
Huawei Enjoy 9S
Huawei Enjoy 7S
Huawei Enjoy 9e
Huawei MediaPad M5 10.1
Huawei MediaPad M5 8.4
Huawei MediaPad M5 8.0
Huawei MediaPad M5 Pro 10.8
Huawei MediaPad 5T 10.1
Honor EMUI 9.1 Supported Devices
Honor Play
Honor 10
Honor Play 8A
Honor View 10
Honor View 10 Lite
Honor Note 10
Honor 9
Honor V9
Honor 8X
Honor 9 Lite
Honor 8X Max
Honor 20i
Honor 9i
Honor 7X
Source
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 27.06.2019., 09:04   #3635
mlajo
mlajo's Avatar
Lokacija: Zemlja
Postovi: 156
U dilemi sam između Samsung S10e i Huawei P30 i Honor V20
kod ova dva Kineza velikim hendikepom bar za mene smatram kod P30 korištenje te njihove Nano kartice znači ostale odj. a Honor V20 ni nema utor za karticu.
Utor za MC držim jako bitnim u izboru mobitela .
E sad jeli to vrijedno kvalitete ova dva Kineza u odnosu na Zamzunga jer mi se čini da su Kinezi kvalitetniji.
Dali ova dva Kineza podržavaju OTG funkciju pa da preko adaptera ili kabela koristim drugu vrstu memorije.
Što napravit molim mišljenje HITNO je.
Mlajo
mlajo je offline   Reply With Quote
Staro 27.06.2019., 10:50   #3636
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,719
Ako ti je microSD bitan, sam si odgovorija na pitanje.
Uzmi S10e.
Staro 27.06.2019., 10:55   #3637
Xenon
Postovi: 1,542
dobil je i Smart P EMUI 9.1
Xenon je offline   Reply With Quote
Staro 27.06.2019., 10:55   #3638
Dottore
Dottore's Avatar
Postovi: 7,635
OTG podržava bez problema.
Отправлено через SM-G975F
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 27.06.2019., 12:19   #3639
Dottore
Dottore's Avatar
Postovi: 7,635
Huawei’s EMUI 9.1 is set to head to a further 49 devices soon
June
P20 Lite
Mate 20
Mate 20 Pro / Mate 20 RS Porsche Design
July
P20 / P20 Pro
nova 3 / 3i
P30 Lite
Mate 10 / 10 Pro / 10 RS Porsche Design
Mate 9 / Mate 9 Pro
Y9 2019
Y6 Pro 2019
Y5 2019
August
P10 / P10 Plus
source
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 28.06.2019., 04:31   #3640
baTman
Lokacija: asfsafsa
Postovi: 327
Mislim da su se neki zbunili kada su pisali o p20 pro, neki su mislili na p20 pro, a neki na mate 20 pro^^ Zato me cudi kako je izisao 9.1 za p20 pro kada nije. Provjerio na system-update i na hicare.
baTman je offline   Reply With Quote
Staro 28.06.2019., 09:31   #3641
Ivo_Strojnica
PRO
Postovi: 4,719
Autor zig Pregled postova
Koliko vidim, piše Mate 20 Pro.
Šta uopće donosi taj EMUI 9.1?
Staro 28.06.2019., 12:12   #3642
devaa
Datum registracije: Mar 2013
Postovi: 1,391
Staro 28.06.2019., 13:07   #3643
Neo-ST
Neo-ST's Avatar
Postovi: 8,320
Ma nemoguće 😂
____________
Sent from my mobile using Tapatalk
Staro 28.06.2019., 14:11   #3644
srale7
srale7's Avatar
Postovi: 5,772
Jebeno, dodjeljivati godisnju nagradu za nesto sredinom godine.
Mate30 ce biti bolji telefon od P30P, tako da zali boze ove ( i ovakvih) nagrada.
Staro 28.06.2019., 14:11   #3645
dean225
DD9512
dean225's Avatar
Postovi: 1,869
Očekivano. Ove godine bez konkurencije.
dean225 je offline   Reply With Quote
Staro 28.06.2019., 14:59   #3646
Eye of Truth
Eye of Truth's Avatar
Datum registracije: May 2019
Postovi: 58
Neka, samo da se unormali ovo oko zabrana i nek deru i dalje. Treba probudit malo Samsung i Apple.
Eye of Truth je offline   Reply With Quote
Staro 28.06.2019., 16:39   #3647
devaa
Postovi: 1,391
Autor srale7 Pregled postova
Zasto ? M30 po datumu izlaska ne moze "stici" zasluziti spomenutu titulu.
Staro 29.06.2019., 11:46   #3648
schetz
schetz's Avatar
Postovi: 1,570
Autor Eye of Truth Pregled postova
Riješiti će i ranije od očekivanog: https://www.androidauthority.com/bre...again-1004260/
schetz je offline   Reply With Quote
Staro 29.06.2019., 13:46   #3649
sasha2511
Mindfreak
sasha2511's Avatar
Datum registracije: Apr 2015
Postovi: 1,232
Autor schetz Pregled postova
bilo je za ocekivati.. prevelik je to biznis da bi se tek tako prekinulo sve..
Poslano sa mog BLA-L09 koristeći Tapatalk
sasha2511 je offline   Reply With Quote
Staro 29.06.2019., 13:54   #3650
Nismo li to odmah bili rekli?
Bitno da se mlatilo o Trumpu, Natou, HAARPu, Masonima, Trilaterali i sličnim stvarima u nedogled
Na kraju pojeo vuk magare. Sigurno bi to jako bilo dobro za biznis da su bannali Huawei for good. Moš mislit.
A saću vam ispričat jednu pričicu:
Jednom davno, dvedesetih godina, u Lijepoj Našoj događala se Pretvorba i bila jedna firma koja je imala 200tinjak zaposlenih. Kako se nije znalo ko pije ko plaća, frka je bila ko bude direktor te se našla dvojica "ljutitih" protivnika. Kako se nisu mogli dogovoriti, dali su zaposlenicima na izbor koga bi oni htjeli za dišu te rekli da za 3 tjedna bude glasanje u firmi.
A dok je trajala "kampanja" na bog-isus-mater jedan drugom, ljudi su naravno zagrizli i počeli međusobno se karinđat i klat koji je bolji za njih. U ta 3 tjedna, mnogi prijatelji postali su neprijatelji, mnogi neprijatelji postali su još veći neprijatelji.
Na dan izbora, jedan lik je pobjedio i obećao da zakapa ratnu sjekiru sa "poraženim" te ga imenuje, ni više ni manje nego svojim savjetnikom i ađutantom, a ljudi u nevjerici gledaju što se događa (u to vrijeme nije bilo onog Pikaču Suprised memea). Nedugo nakon izbora, išlo se gledati tko je to bio u "taboru" "poraženog" kandidata da im se uruče knjižice i zahvali na svim godinama provedenim u firmi prije i poslije Domovinskog rata. Oni koji su bili "sretni" da ne dobiju knjižicu, ti su bili krivi za sveku pizdariju koja se u firmi dogodila. A ovi koji su bili u "taboru" "pobjednika", dio je postao rukovodeći kadar, a dio "use as is" ali ponosit jer je njihov čovjek direktor.
Ono što se saznalo kasnije je da su oba kandidata tijekom "bratoubilačke kampanje" jedan drugom dolazili doma, klinci su si frendovi, išli na ručkove i večere i dogovarali strategije, dok su pred radnicima bili ono, Star Wars. Oni prijateljevali, a ljudi koji su si godinama bili dobri, odjednom su se popičkali oko 2 preplaćena kretena.
Poanta priče: kad se slonovi tuku, najebu trava i mravi.
Sad si povucite paralelu sa ovim Čajna vs US and A i vidite je li stvarno nekima bilo potrebno da dobiju ban i read only zbog pizdarija koje su pisali i oko čega su se sekirali. Hm?
Eto, sorry na podužem postu, izuzetno sam dobro raspoložen ovih dana (ne, nisam se počeo drogirat) pa laprdam do daske
Sent from my SM-G965F using Tapatalk
Staro 29.06.2019., 14:13   #3651
schetz
schetz's Avatar
Postovi: 1,570
Jašta .Doduše, s masonima nikad ne znaš :P
Veći je problem što bi tema opet mogla biti preplavljena političkim komentarima (u prozama Milana Kundere) . Da je ostao ban, mogli smo barem trkeljati o 60% bržem OSu
Staro 29.06.2019., 14:13   #3652
devaa
Postovi: 1,391
Ma brko ti si gospodin. 😁
Staro 29.06.2019., 14:16   #3653
Ma jasno. Isto kao i Apple i Samsung. S jedne strane rat oko patenata i uglova mobitela, s druge manje vidljive strane trgovina dijelova na veliko. A raja bi se ispikala nožovima za obranu svog branda i investicije
Da, jedino i meni žao što nećemo vidjeti taj 60% brži OS
Autor devaa Pregled postova
Staro 29.06.2019., 16:16   #3654
Ivo_Strojnica
PRO
Postovi: 4,719
Jebe se njemu, on je na moru.
Staro 29.06.2019., 20:57   #3655
devaa
Postovi: 1,391
Ja bio danas s curom na quadu. Brutalno iskustvo. 😁
Staro 29.06.2019., 21:19   #3656
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
Nisam to nikad radio na quadu :O
Staro 29.06.2019., 23:33   #3657
dadoremix
dadoremix's Avatar
Postovi: 4,692
i šta je huawei .. panika minula, trump je reko .. ajmo dalje po starome, nema sankcija na kraju
Staro 30.06.2019., 09:24   #3658
D/G
D/G's Avatar
Datum registracije: Feb 2010
Lokacija: Ploče
Postovi: 1,184
Pa morao je kad su ga njegovi ekonomisti napali jer bi imali veće gubitke nego korist radi njegove "politike" .
Ipak se nadam da će Huawei izdati svoj OS bez obzira što je Trump pojeo g.... i povukao se.
Staro 30.06.2019., 11:23   #3659
renc
Datum registracije: Feb 2019
Postovi: 455
Autor D/G Pregled postova
Pa jasno. Nikad nije bila namjera zabranit americkim kompanijama da ne zaradjuju na prodaji hardvera. Samo politicke igre. Medjutuva jos nije jasno kaj bu bilo sa softverajem...bar ne sluzbeno...
renc je offline   Reply With Quote
Staro 30.06.2019., 11:26   #3660
thunder11
thunder11's Avatar
Datum registracije: Dec 2013
Postovi: 1,697
