Staro 19.03.2019., 19:49   #1
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,542
Google Stadia
netko pratio keynote? još traje https://youtu.be/nUih5C5rOrA
neznam dal mi se sviđa, rano je za reć
Zadnje izmijenjeno od: mamutarka. 19.03.2019. u 20:36.
Staro 19.03.2019., 20:11   #2
RaWeN
RaWeN's Avatar
Datum registracije: Aug 2009
Postovi: 637
Zašto uopće guraju streaming igara kad je input lag nerješiv problem...
RaWeN je offline   Reply With Quote
Staro 19.03.2019., 20:14   #3
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,542
baš o tome ima
Staro 19.03.2019., 20:53   #4
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,542
Google's Stadia specs
Google has released the following data for Stadia. It's a curious mixture of data points, combining the kind of minutiae rarely released on some components along with notable omissions elsewhere, such as the amount of cores/threads available for developers on the CPU. Regardless, it paints a picture of a highly capable system, clearly more powerful than both the base and enhanced consoles of the moment.
Custom 2.7GHz hyper-threaded x86 CPU with AVX2 SIMD and 9.5MB L2+L3 cache
Custom AMD GPU with HBM2 memory and 56 compute units, capable of 10.7 teraflops
16GB of RAM with up to 484GB/s of performance
SSD cloud storage
According to Google, the Stadia is more powerful than the PlayStation 4 and Xbox One combined.
Staro 19.03.2019., 21:59   #5
SrKi
SrKi's Avatar
Postovi: 842
Zadnje što želim da se Google petlja u gaming. I ovako sve više manje nizbrdo ide.
SrKi je offline   Reply With Quote
Staro 19.03.2019., 22:21   #6
RaWeN
RaWeN's Avatar
Postovi: 637
baš o tome ima
Input lag je znači 166 ms, odnosno duplo veći nego na PC-u u 60 FPS-a. U prijevodu - neigrivo.
Staro 19.03.2019., 23:23   #7
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,542
možda neki SP ajde, ali MP, koji je danas većini najbitniji - teško
Staro 20.03.2019., 09:00   #8
Postovi: 17,143
A gledaj, ne bi predstavljali nešto za što nema riješenja.
Ajde da pustimo da vidimo prvo cijene pa da vidimo kako će raditi.
Nisu ništa rekli za brzine interneta, a i dalje je poznato da velika većina svijeta ima male brzine interneta.
Drugo, gamepad je užasan
Staro 20.03.2019., 15:11   #9
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,528
AMD zaradit od ovoga koji $ neka neka.
Aaaannndddd
Jok intel procesori
Zadnje izmijenjeno od: Tajl3r. 22.03.2019. u 20:41.
Staro 20.03.2019., 15:39   #10
gin.tonic
gin.tonic's Avatar
Postovi: 2,445
Kak je užasan kad je kopija PS4 Dualshock-a?
Malo i hands on:
https://www.theverge.com/circuitbrea...ds-on-gdc-2019
gin.tonic je offline   Reply With Quote
Staro 20.03.2019., 16:35   #11
Postovi: 17,143
A po čemu je kopija?
Usporedi slike Dualshocka i toga, vidjet ćeš da ima isto toliko sličnosti oblikom kao i s drugim gamepadovima.
Zadnje izmijenjeno od: Mommistake. 20.03.2019. u 16:47.
Staro 20.03.2019., 16:52   #12
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,542
izgleda ko DS4 bez touchpada, al dobro to je sad nebitno, svi kontroleri su više manje slični, ni netreba mijenjat nešto što valja
Staro 20.03.2019., 16:59   #13
Postovi: 17,143
A nije baš. Osim rasporeda tipki, estetski možda malo vuče na DS, ali usporedi poziciju gljiva, razmak između držaka itd. Možda samo na slici malo izgleda, nije baš kopija, baš sam gledao jučer live komentare ljudi, svi se žale na izgleda gamepada. Možemo reći onda da je kopija Logitecha isto, tako, ne? Tj. jedino nije kopija xboxa...
Staro 20.03.2019., 18:14   #14
nub
PREMIUM
nub's Avatar
Datum registracije: Dec 2014
Postovi: 2,165
Pusti brzinu neta, vjerojatno za to neće bit previsoki zahtjevi, ali lag će uvijek postojat osim ako stave server kod tebe u dvorištu...
Staro 20.03.2019., 18:22   #15
Postovi: 17,143
A gledaj, nije baš tako.
PS ima sličnu stvar, dosta ovisi o brzini neta. Lag nije strašan, igrivo je.
Staro 06.06.2019., 19:35   #16
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,542
Staro 07.06.2019., 15:50   #17
thunder11
thunder11's Avatar
Datum registracije: Dec 2013
Postovi: 1,699
Znači 4K streamanja igara proguta 1TB prometa u 65H
thunder11 je online   Reply With Quote
Staro 07.06.2019., 15:52   #18
Postovi: 17,143
For this year you’ll need to pay the Stadia Pro subscription of Ł8.99 per month for the 4K streaming subscription, but in 2020 Google will launch a Base subscription model that will be free to stream games in Full HD.
Odlična cijena.
S obzirom na cijene Netflixa, PS+ itd. ovo je sasvim prihvatljivo.
That means Stadia will support up to 4K resolution at 60fps at launch, and it has plans to hit 8K and 120fps in future, even if your device would normally struggle to run Pong.
Hmm.. Nekako mi je sve to nerealno.
I ono što me najviše muči, pre-order nije moguć u Hrvatskoj. Bojim se da će kao i Netflix, tek nakon nekog vremena doći k nama.
Staro 07.06.2019., 16:18   #19
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,542
ako će uopće, pogle recimo youtube premium - nema ga kod nas
Staro 07.06.2019., 16:19   #20
Postovi: 17,143
A jbg, account iz druge zemlje ili VPN, nema druge.
Staro 07.06.2019., 16:43   #21
ShebY
ShebY's Avatar
Lokacija: Velika / Osijek
Postovi: 1,442
Nije to vau cijena, nema igara u tome paketu uopće, igre se još moraju kupovati.
Staro 07.06.2019., 16:45   #22
Postovi: 17,143
Eh, to nisam znao
Mislio sam da je to to, platiš i igraš
Btw. špekulira se da bi RDR2 trebao biti na Stadia servisu, pa će se moći igrati i na PC-u.
Staro 09.06.2019., 18:28   #23
GreenLife
Čika Zeljeni
GreenLife's Avatar
Datum registracije: Sep 2013
Lokacija: Tannhausen (Aalen)
Postovi: 488
Ako ukomponiraju podršku Steam accounta, to će biti bomba. Ali opet - Hrvatska nije podržana, a VPN nikako nije rješenje (prevelik ping) .
Staro 09.06.2019., 19:45   #24
Postovi: 17,143
Kako misliš podršku steam accounta?
Staro 09.06.2019., 20:36   #25
GreenLife
Čika Zeljeni
GreenLife's Avatar
Postovi: 488
Npr. plaćaš mjesečno određenu cifru za Stadia (usluga i uređaj, jel) a igre povlačiš sa Steama. Jer ako ostane kako su pričali, opet bi trebao kupit igre koje već imam na Steamu.
Staro 09.06.2019., 20:52   #26
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,542
no shit, pa o tom se i radi
žele da njima plaćaš za igre, uslugu ti daju i đabe, samo kupuj igre
enivej nema nikakvog uređaja, to je servis
Staro 09.06.2019., 21:56   #27
sti
Lokacija: Lawl
Postovi: 1,380
Dead on arrival.
sti je online   Reply With Quote
Staro 09.06.2019., 22:18   #28
Postovi: 17,143
Autor sti Pregled postova
Dead on arrival.
Zašto?
Ja bi uzeo npr.
Ne trebas jaki pc, trebaš net i to je to.
Meni se iskreno sviđa i ima potencijala da promijeni svijet gaminga za uvijek.
Staro 09.06.2019., 22:20   #29
nickross
Budget gamer
Datum registracije: Nov 2017
Postovi: 909
1080p60fps dobiješ a ne potrošiš lipe na pc. Moći ćeš doslovno i na mobitelu i na bilokojem drlogu od pc-ja/laptopa koji može vrtiti youtube na 1080p60fps kroz chrome. I kroz stadiju kupuješ igre kao i inače. Di ćeš bolje. Samo me brine malo latencija
nickross je offline   Reply With Quote
Staro 09.06.2019., 22:32   #30
sti
Lokacija: Lawl
Postovi: 1,380
Zašto?
Ja bi uzeo npr.
Latencija Stadije plus input lag tvog hardvera - nitko neće kupovati gamerske monitore za streamanje igara, uglavnom će se vrtiti na low end monitorima, na 60 hz monitorima ćeš imati višestruko preskakanje frejmova - neigrivo.
