Staro 25.12.2005., 13:18   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Peticija za povratak CP-a
Naletio sam na techpowerup-u na ovo...
It's time to boycott purchases of ATi products until the old control panel is brought back. We want the option of the old control panel back.
I am an outraged customer of a Sapphire ATI Radeon 9500 Pro. The last set of drivers to support the old (good) control panel has disappeared in Catalyst drivers 5.12 and 5.13 and you are forced to use the CATALYST .net Control Panel. Bring back the old control panel.
Catalyst 5.11 drivers were the last to be bundled with the old control panel. At least with 5.11, there was an option between the old control panel and the new CATALYST .net control panel.
The new Catalyst Control Center, is
1. Slow
2. Memory hogging
3. Unresponsive
4. Crash prone
5. Requires the Microsoft .net Framework which is a 23.1MB download from microsoft
6. Takes longer to download than the old control panel.
7. Loads unneccary processes to your system (CLI.exe) which can't be disabled anywhere in the new Control Panel, no for reason at all CLI.exe is loaded twice.
8. Killing CLI.exe process, the new Control Panel does not load at all, no error message or anything.
9. CLI.exe required by the new Control Panel, This increases boot time, and memory usage while it is not in use.
Signing this petition is telling ATi to cut the crap and give us the old control panel back.
I was considering upgrading my graphics card, and ATi has forced my hand to go to Nvidia unless of course the old control back comes back.
Sincerely,
The Undersigned
Više:
http://www.petitiononline.com/ctrlpanl/petition.html
Staro 25.12.2005., 17:10   #2
pinsla
Caught Somewhere In Time
pinsla's Avatar
Datum registracije: Oct 2002
Lokacija: zg-vrbani, vž u srcu
Postovi: 1,860
ah nije da da sjajan ali nakon kaj sam ga koristio mjesec dva nije toliki problem
uostalom vjerojatno svi imaju još nekaj instalirano tipa att pa se već snađeš
pinsla je offline   Reply With Quote
Staro 25.12.2005., 17:25   #3
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Ja stvarno ne znam što je vama. CCC je zakon
Staro 25.12.2005., 17:33   #4
Vedran
Vedran's Avatar
Lokacija: Kutina
Postovi: 1,208
Originally posted by tor
CCC je zakon
Vedran je offline   Reply With Quote
Staro 25.12.2005., 18:11   #5
domy_os
domy_os's Avatar
Postovi: 18,831
I ja dižem ruku. Nema Control Panela, ATT ima neki bug s TV-outom, CCC je smeće,... Stvarno ne znaš šta ćeš.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 26.12.2005., 01:38   #6
sick_boy
sick_boy's Avatar
Postovi: 680
Pa, zašto ljudi ne koriste stari Control Panel s novim driverima? Ja na svom laptopu koristim CP iz 5.11 verzije, s driverima 5.13. I sve pet.
iBase MI980VF-4700EQ Motherboard
Intel Core I7-4700EQ (2.4-3.4Ghz, 4 cores, 8 threads)
16GB DDR3L RAM 1600 MHz
250 GB Samsung 860 Evo mSATA SSD
1TB Seagate Barracuda 7200 2.5" HDD
ATI RX550 4GB
Kolink Satellite mATX Cube Case
Delta Electronics GPS-350EB-200 A ATX 350W PSU
Acer 27" 1440p 75Hz Freesync IPS monitor
Cherry MX Board 1.0 keyboard, brown switches
LOGITECH G305 Lightspeed mouse
Arch Linux/Win 10
Lenovo Idepad 5 pro:
AMD Ryzen 7 6800HS
16GB DDR5 RAM 5600 MHz
1TB Micron nVme HDD
16" 2160x1600 16:10 IPS Display
Windows 11
Fujitsu Esprimo:
Intel(R) Core(TM)2 Duo CPU E7500
4GB DDR2 RAM
WDC WD1600AAJS-0 160GB
Seagate ST4000DM000 4TB
openmediavault 4.1.17
Philips 55PUS7373/12 55" 4K HDR VA Direct LED TV
Toshiba 50" QLED 4K Dolby Vision/Dolby Atmos TV
TCL 40ES560 40" FullHD TV
Pioneer BDP-160 BD player
Maxell SB-3000 soundbar
Onkyo TX-SV444 AV Receiver
Onkyo DX-7333 CD Player
Audio-Technica AT-LP2XGY gramofon
Mirage 290is bookshelf speakers
sick_boy je offline   Reply With Quote
Staro 26.12.2005., 13:19   #7
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,164
Je, to je sad tako. Ali dodje novi hradware sa novim mogucnostima, ili se nesto znacajnije promjeni u Catalyst driverima, doda se neka opcija... i ti tim opcijama nemas pristup sa starim CP... i prisiljen si koristit CCC, koji ti pozdere gomilu sistemskih resursa.
Nije to dobro. CCC je ogroman u usporedbi sa CP. IMHO, bolje bi bilo da tu razliku u velicini iskoriste za bolje specificne optimizacije u driverima.
I sad je nVidia pocela radit sve gore i gore drivere, jos samo fali da i ATi krene istim putem.. sta cu onda kupit sljedece? S3?
Staro 27.12.2005., 11:39   #8
Mailman
Mailman's Avatar
Postovi: 1,606
za mijenjanje opcija koristim ikonu u trayu tako da CCC uopće ne "palim"...
dva CLI-ja, tj. tri, mi u idleu zauzimaju 7MB, to im mogu oprostiti
a što se tiče podizanja Windowsa, nisam primijetio da se boot time povećao :confused:
edit: 3 CLI-ja max 15MB...
Zadnje izmijenjeno od: Mailman. 27.12.2005. u 12:34.
Mailman je offline   Reply With Quote
Staro 27.12.2005., 14:31   #9
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
Kad se sjetim vremena Apple ][ računala kad smo se pitali čemu služi 10MB hard disk (koji je koštao nekih 5000$) kad ga ionako nemaš s čim napuniti
