Staro 21.12.2005., 20:55   #1
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
Catalyst 5.13
Evo preduhitrio sam jelca ovaj put evo novih drivera
https://support.ati.com/ics/support/...questionID=640
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 21.12.2005., 21:01   #2
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Staro 21.12.2005., 21:23   #3
Lihto
Lihto's Avatar
Postovi: 3,945
Jelc neradi ti link
iPhone XR 128gb
Staro 21.12.2005., 22:28   #4
Anthrax a.k.a. Priest
Postovi: 621
kakvi su? se isplati njih vise ili omege? ili neki treci modani?
Anthrax a.k.a. Priest je offline   Reply With Quote
Staro 21.12.2005., 22:35   #5
Lihto
Lihto's Avatar
Postovi: 3,945
na ih neću danas skidat nadam se da će domy pa eto sutra bi ih mogao istestirat pa javim,al evo čekam jelca da da prve dojmove
iPhone XR 128gb
Staro 21.12.2005., 23:28   #6
Mailman
Mailman's Avatar
Postovi: 1,606
Mailman je offline   Reply With Quote
Staro 22.12.2005., 12:45   #7
Torcida@1950
Torcida@1950's Avatar
Postovi: 107
ne znam zašto mi baca onu glupu obavijest catalyst control center not work properly,pa sam morao deinstalirati.Kako to riješiti jer sad nemam nikakav ati control display?
AMD64 3000+Venice@2.4Ghz 1.4v E6
DFI NF4 Ultra
2x512mb Twinmos 400mhz
ATI 3870HD 512mb
Hitachi 320mb
Hyper 435W
LG prža i sranje od monitora
OS Windows 7 Ultra
Torcida@1950 je offline   Reply With Quote
Staro 22.12.2005., 13:01   #8
Mailman
Mailman's Avatar
Postovi: 1,606
.Net framework 1.1 instalirati...
Staro 22.12.2005., 13:04   #9
nino
nino's Avatar
Postovi: 12,599
Ovo je tvoj problem "Caution: The Catalyst® Control Center requires that Microsoft's .NET Framework Version 1.1 be installed. Without .NET Version 1.1 installed the Catalyst® Control Center will not launch properly, and the user will see an error message as a result"
A ovdje ga imas za download
Staro 22.12.2005., 14:20   #10
sick_boy
sick_boy's Avatar
Postovi: 680
Jel' radi sa .Net framework-om 2.0? 5.12 nisu radili (nisu javljali nikakvu gresku, ali se CC zaglavljivao kad sam ga pokusao dozvati).
iBase MI980VF-4700EQ Motherboard
Intel Core I7-4700EQ (2.4-3.4Ghz, 4 cores, 8 threads)
16GB DDR3L RAM 1600 MHz
250 GB Samsung 860 Evo mSATA SSD
1TB Seagate Barracuda 7200 2.5" HDD
ATI RX550 4GB
Kolink Satellite mATX Cube Case
Delta Electronics GPS-350EB-200 A ATX 350W PSU
Acer 27" 1440p 75Hz Freesync IPS monitor
Cherry MX Board 1.0 keyboard, brown switches
LOGITECH G305 Lightspeed mouse
Arch Linux/Win 10
Lenovo Idepad 5 pro:
AMD Ryzen 7 6800HS
16GB DDR5 RAM 5600 MHz
1TB Micron nVme HDD
16" 2160x1600 16:10 IPS Display
Windows 11
Fujitsu Esprimo:
Intel(R) Core(TM)2 Duo CPU E7500
4GB DDR2 RAM
WDC WD1600AAJS-0 160GB
Seagate ST4000DM000 4TB
openmediavault 4.1.17
Philips 55PUS7373/12 55" 4K HDR VA Direct LED TV
Toshiba 50" QLED 4K Dolby Vision/Dolby Atmos TV
TCL 40ES560 40" FullHD TV
Pioneer BDP-160 BD player
Maxell SB-3000 soundbar
Onkyo TX-SV444 AV Receiver
Onkyo DX-7333 CD Player
Audio-Technica AT-LP2XGY gramofon
Mirage 290is bookshelf speakers
sick_boy je offline   Reply With Quote
Staro 22.12.2005., 14:24   #11
Jelc
Super Moderators
Postovi: 17,485
Nisam probao ni namjeravam
WDM-driveri+ATT je meni čisto dosta
Staro 22.12.2005., 14:32   #12
sick_boy
sick_boy's Avatar
Postovi: 680
Ma, i ja sam se rijesio tog cuda (koliko god optimizirali, ipak ta mastodonska aplikacija uspori sistem), pa koristim stari CP (ima sve sto mi treba - ATIja imam samo na laptopu).
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 22.12.2005., 15:43   #13
Jelc
Super Moderators
Postovi: 17,485
Sa 5.11 i net.2.0 je radilo ok, sa 5.12 sam morao kemijat da bi se uopće podigao...
ATT/Emulate CCC i bog te veseli
Ako ti baš treba CCC.
Kako ti uopće dela PowerPlay?
Znam da je jedno vrijeme bilo malo bugovito...
Staro 23.12.2005., 01:16   #14
domy_os
domy_os's Avatar
Postovi: 18,819
Kako forsirat TV-out na ATI Tray Tools? :confused:
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 23.12.2005., 01:29   #15
Jelc
Super Moderators
Postovi: 17,485
Pa imaš postavke za TV-out pod Display:confused:
Staro 23.12.2005., 01:29   #16
domy_os
domy_os's Avatar
Postovi: 18,819
Dakle, jel neko probo drivere? CoD 2 mi se ruši i baca artefakte...
Staro 23.12.2005., 01:40   #17
Jelc
Super Moderators
Postovi: 17,485
Ja sam ih stavio noćas-za sada sve igre rade ok.
Staro 23.12.2005., 03:03   #18
domy_os
domy_os's Avatar
Postovi: 18,819
Problem je bio u ATT-u, ne znam zašto. Sad skidam Control Panel.
Staro 23.12.2005., 06:01   #19
domy_os
domy_os's Avatar
Postovi: 18,819
Ima, al nema to što meni treba, a bilo je u dobrom starom Control Panelu.
Ne mogu imat obje stvari uključene, tj. ak upalim TV, ugasi se LCD i obrnuto. Probo sam nešt tweakat u vezi toga, al bez uspjeha.
Staro 23.12.2005., 11:45   #20
Jelc
Super Moderators
Postovi: 17,485
Tu su ti tweakovi za to, poigraj se malo, ja sad moram gibat-ako ne riješiš problem pogledat ću ja kad se vratim.
Staro 23.12.2005., 16:17   #21
vex
vex's Avatar
Datum registracije: Aug 2003
Lokacija: sl. brod
Postovi: 1,315
ja ih stavio, sve ok
Staro 23.12.2005., 16:24   #22
domy_os
domy_os's Avatar
Postovi: 18,819
I meni je sad sve OK osim tog TV-outa, nikako neće proradit.
Staro 23.12.2005., 19:19   #23
Hrconja
Hrconja's Avatar
Postovi: 1,614
ima li netko link za verziju sa control panelom?
kao i za verziju 5.12?
Hrconja je offline   Reply With Quote
Staro 23.12.2005., 21:19   #24
sick_boy
sick_boy's Avatar
Postovi: 680
Nema vise verzija s CP-om (ATI od verzije 5.12 ne ukljucuje Control Panel u drivere), ali mozes skinuti Control Panel 5.11 (koji, naravno, radi sa svim kasnijim driverima i, ustvari je zadnja verzija): ATI Control Panel
I onda skines samo drivere, bez Control Centra, eventualno WDM, ako trebas, i instaliras odvojeno.
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 23.12.2005., 22:21   #25
domy_os
domy_os's Avatar
Postovi: 18,819
Ja sam juče skinuo taj Control Panel i upario ga s driverima 5.13, al neke opcije mi nedostaju, CP ima staro sučelje, nije to to.
Staro 24.12.2005., 00:57   #26
domy_os
domy_os's Avatar
Postovi: 18,819
Čini se da je ovo s TV-outom neki bug U ATT-u, nisam jedini...
http://forums.guru3d.com/showthread.php?t=162791
Staro 24.12.2005., 01:43   #27
Lihto
Lihto's Avatar
Postovi: 3,945
A da to je smeće valjda će opet novi att
iPhone XR 128gb
Staro 26.12.2005., 01:41   #28
sick_boy
sick_boy's Avatar
Postovi: 680
Sto ti nedostaje? Mislim, nisam koristio ATIja prije (na desktopu imam nVidiju, a laptop sa ATIjem sam uzeo tek nedavno), pa ne znam.
BTW, sucelje je staro, ali sasvim funkcionalno (of course, nije za overclockiranje, ali meni to i netreba, jer nemam sto na laptopu overclockati).
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 26.12.2005., 15:10   #29
domy_os
domy_os's Avatar
Postovi: 18,819
Nije problem toliko u starom sučelju nego opet nema opcije za forsiranje TV-outa.
Staro 28.12.2005., 11:50   #30
vex
vex's Avatar
Lokacija: sl. brod
Postovi: 1,315
A što je sa Omegama ??
Da li je izašla verzija na bazi 5.13 ?? i ima li cp ili ???
I da li je itko benčao omegu vs. ati u 3dm ili tak nešt ??
