White Rabbit
Postovi: 5,578
[OpenSuse 13.1] USB muke
Imam jako čudan problem sa prepoznavanjem USB vanjskog diska na OpenSuse 13 stroju. Disk u pitanju je Seagate M3 USB 3.0 1TB (2 kom, 100% ispravni jer svugdje rade samo ne tu) i pretpostavljam da udev radi probleme ali nemogu skužit kako riješit stvar. Code:
# udevadm monitor --udev monitor will print the received events for: UDEV - the event which udev sends out after rule processing UDEV [83499.217409] remove /devices/pci0000:00/0000:00:14.0/usb4/4-6/4-6:1.0 (usb) UDEV [83499.217876] remove /devices/pci0000:00/0000:00:14.0/usb4/4-6 (usb) UDEV [83573.759521] add /devices/pci0000:00/0000:00:14.0/usb4/4-6 (usb) UDEV [83573.762405] add /devices/pci0000:00/0000:00:14.0/usb4/4-6/4-6:1.0 (usb) Code:
# lsusb Bus 001 Device 002: ID 8087:8008 Intel Corp. Bus 002 Device 002: ID 8087:8000 Intel Corp. Bus 004 Device 011: ID 0bc2:61b6 Seagate RSS LLC Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Code:
#ls -l /dev/disk/by-uuid/ total 0 lrwxrwxrwx 1 root root 9 Feb 20 10:52 054a3503-1bcc-4fde-9111-4f70e807f818 -> ../../md1 lrwxrwxrwx 1 root root 9 Feb 20 10:52 8024a2dc-7959-48a8-afd9-b04cee2cc2f7 -> ../../md2 lrwxrwxrwx 1 root root 9 Feb 20 10:52 97fbed61-5806-4546-8a4f-2c755b28757f -> ../../md0 |
Postovi: 61
Code:
dmesg | tail Code:
uname -a Code:
fdisk -l |
#3 | |
White Rabbit
Postovi: 5,578
Code:
fdisk -l Disk /dev/sda: 2000.4 GB, 2000398934016 bytes, 3907029168 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk label type: dos Disk identifier: 0x0008a36f Device Boot Start End Blocks Id System /dev/sda1 * 2048 209713151 104855552 fd Linux raid autodetect /dev/sda2 209713152 243271679 16779264 fd Linux raid autodetect /dev/sda3 243271680 3907028991 1831878656 f W95 Ext'd (LBA) /dev/sda5 243273728 3907008511 1831867392 fd Linux raid autodetect Disk /dev/sdb: 2000.4 GB, 2000398934016 bytes, 3907029168 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk label type: dos Disk identifier: 0x000ad8d8 Device Boot Start End Blocks Id System /dev/sdb1 * 2048 209713151 104855552 fd Linux raid autodetect /dev/sdb2 209713152 243271679 16779264 fd Linux raid autodetect /dev/sdb3 243271680 3907028991 1831878656 f W95 Ext'd (LBA) /dev/sdb5 243273728 3907008511 1831867392 fd Linux raid autodetect Disk /dev/md1: 17.2 GB, 17165189120 bytes, 33525760 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/md0: 107.4 GB, 107371954176 bytes, 209710848 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/md2: 1875.7 GB, 1875697991680 bytes, 3663472640 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Code:
uname -a Linux server 3.12.67-64-xen #1 SMP Fri Dec 9 15:56:17 UTC 2016 (35c7b99) x86_64 x86_64 x86_64 GNU/Linux Code:
dmesg |tail [121390.812506] [<ffffffff8000a89c>] show_stack+0x1c/0x50 [121390.812517] [<ffffffff80549514>] dump_stack+0x76/0xab [121390.812530] [<ffffffff80031cbf>] warn_slowpath_common+0x7f/0xb0 [121390.812539] [<ffffffff80031d37>] warn_slowpath_fmt+0x47/0x50 [121390.812575] [<ffffffffa02b3932>] hsw_disable_lcpll+0x4e2/0x600 [i915] [121390.812688] [<ffffffff8004c77b>] process_one_work+0x19b/0x4b0 [121390.812699] [<ffffffff8004d635>] worker_thread+0x115/0x420 [121390.812710] [<ffffffff80053bff>] kthread+0xaf/0xc0 [121390.812720] [<ffffffff805578a0>] ret_from_fork+0x60/0x90 [121390.812729] ---[ end trace 81fdb04802b18336 ]--- Code:
2018-02-21T20:37:08.266538+01:00 server kernel: [121510.812360] CPU: 0 PID: 23353 Comm: kworker/0:1 Tainted: G W 3.12.67-64-xen #1 2018-02-21T20:37:08.266541+01:00 server kernel: [121510.812364] Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./B85M, BIOS P2.10 12/06/2013 2018-02-21T20:37:08.266545+01:00 server kernel: [121510.812401] Workqueue: events hsw_enable_pc8_work [i915] 2018-02-21T20:37:08.266548+01:00 server kernel: [121510.812406] ffffffffa02fd7a0 ffffffff80549514 ffff880080e39db0 ffffffffa02fd7a0 2018-02-21T20:37:08.266551+01:00 server kernel: [121510.812413] 00000000000017fa ffffffff80031cbf ffff880003288000 ffff880080e39e00 2018-02-21T20:37:08.266554+01:00 server kernel: [121510.812419] 0000000000000001 ffff880002046c98 0000000000000001 ffffffff80031d37 2018-02-21T20:37:08.266557+01:00 server kernel: [121510.812426] Call Trace: 2018-02-21T20:37:08.266559+01:00 server kernel: [121510.812450] [<ffffffff80008ab4>] dump_trace+0x74/0x1a0 2018-02-21T20:37:08.266562+01:00 server kernel: [121510.812460] [<ffffffff80008c6f>] show_stack_log_lvl+0x8f/0x170 2018-02-21T20:37:08.266565+01:00 server kernel: [121510.812469] [<ffffffff8000a89c>] show_stack+0x1c/0x50 2018-02-21T20:37:08.266568+01:00 server kernel: [121510.812479] [<ffffffff80549514>] dump_stack+0x76/0xab 2018-02-21T20:37:08.266571+01:00 server kernel: [121510.812492] [<ffffffff80031cbf>] warn_slowpath_common+0x7f/0xb0 2018-02-21T20:37:08.266574+01:00 server kernel: [121510.812502] [<ffffffff80031d37>] warn_slowpath_fmt+0x47/0x50 2018-02-21T20:37:08.266577+01:00 server kernel: [121510.812538] [<ffffffffa02b3932>] hsw_disable_lcpll+0x4e2/0x600 [i915] 2018-02-21T20:37:08.266579+01:00 server kernel: [121510.812645] [<ffffffff8004c77b>] process_one_work+0x19b/0x4b0 2018-02-21T20:37:08.266582+01:00 server kernel: [121510.812656] [<ffffffff8004d635>] worker_thread+0x115/0x420 2018-02-21T20:37:08.266585+01:00 server kernel: [121510.812667] [<ffffffff80053bff>] kthread+0xaf/0xc0 2018-02-21T20:37:08.266588+01:00 server kernel: [121510.812676] [<ffffffff805578a0>] ret_from_fork+0x60/0x90 2018-02-21T20:37:08.266591+01:00 server kernel: [121510.812685] ---[ end trace 81fdb04802b18338 ]--- |
Postovi: 61
Ak je struja nestala nekaj na root disku je off, probaj livecd distru zavrtit [knoppix, salix, systemrescuecd] i Code:
umount /dev/sdaX && fsck /dev/sdaX |
Postovi: 61
USB-3.0 stick ako dela na istom (3.0) port-u vjerojatno nije HW problem nego FS korupcija, ak ti je root tree koruptiran najbolje napravit backup image i formatirat, Kernel 3.12.67 ti je obsolete plus kaj ima Taint, da je moj server; prvo format, novi root i kernel >>3.16.54 ili >>4.4.116 |
#7 | |
Postovi: 61
