Staro 03.11.2017., 00:21   #3541
Lepac
Datum registracije: Apr 2014
Lokacija: Zg zupanija
Postovi: 107
Stronghold HD
Lepac je offline   Reply With Quote
Staro 03.11.2017., 08:21   #3542
SaleFFS
Varilnik
SaleFFS's Avatar
Postovi: 1,648
Iako to piše, vjeruj mi da toliko i gutne meni je EVGA PXOC pokazivala da guta 7.8GB VRAMa, a task manager da cici 12GB RAMa ali radila je kaj ti veliš lock na 60FPS bez trzaja
Ali zašto onda meni ne trzucka sa 4gb vrama i 8gb rama? Insane@60fps lock. Pratio sam ram usage u uvijek je bio na nekih cca 7gb.
Staro 03.11.2017., 08:38   #3543
emilblomsky
emilblomsky's Avatar
Lokacija: karlovac
Postovi: 2,111
Fear kolekciju.Extraction point mi je nekako najteži bio.Naravno,bez slowmoa!
Phil of the future!
Staro 03.11.2017., 08:49   #3544
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,589
Autor SaleFFS Pregled postova
Kao što smo pričali negdje to je samo alocirani ram. Kad bi imao 16gb ram može ti pisati u monitoring programima da uzima 10gb, a igra u stvarnosti vuče 7gb, evo na pr. BF1, kao jedna od najzahtjevnijih po tom pitanju
Battlefield 1 Memory Capacity - Is 8GB Enough?
The short answer: Yes. It's enough. Just barely.
Capacity is harder to test for a number of reasons. Memory isn't instantly saturated, so it's easier to test with something more heuristic -- like actually playing the game properly. We tried playing a 64-person multiplayer match for about 40 minutes while running logging utilities to track system memory consumption. Commit and working set memory were both logged, so we had an idea of requested and in-use memory by the application. Memory usage by BF1 goes up quickly, but never exceeds 6-7GB working set. We'd see commits upwards of 10GB, but again, that doesn't mean the memory is used -- it just means that BF1 and Windows agree that 10GB of 32GB available is not an unreasonable commit.
We also played with one stick of 8GB RAM (and separately two sticks of 4GB) for another 64-player match, just to see if any visible stutters or pop-in issues occurred. No, not really. We see pop-in issues, but it's all the same as what you normally see with Battlefield 1 -- nothing specific to memory. A single stick did show an FPS reduction resultant of the slower speed, but not because of the capacity. With 2x4GB sticks clocked at 2400MHz, we didn't run into issues with memory capacity being exceeded and causing artifacting, pop-in delays (beyond normal), or slowdowns. Heuristic testing suggests that 8GB of memory is enough for BF1.
Now, there's a caveat: The working set was approaching 7GB at times (typically closer to 6GB), so users who like to keep applications running in the background may benefit from more memory. Chrome, for example, can easily eat several gigabytes of memory just with a day's worth of tabs open. You'd want to close that to free-up volatile memory if playing BF1 with 8GB of RAM.
But as an application atop an OS, 8GB is sufficient.
Staro 04.11.2017., 16:17   #3545
bambi56x
bambi56x's Avatar
Postovi: 357
Zadnji fajt je trebao biti puno teži, završio sam igru na lvl 75, sa IX oružjem, i kao da igra to ne uzima u obzir, uopće nije bio problem kad sve umire s par metaka, abilitije da ne spominjem, sve je išlo u combo radius i combo power.
I nakon tog kraja nema nastavaka, šteta.
Završio Mass Effect Andromeda.
Unatoč svim problemima, mislim da je igra definitivno za preporuku, igrivost je fantazija, grafika isto, a i Ryderica mi je bolja od Shepardice.
102 sata za 100%.
bambi56x je offline   Reply With Quote
Staro 05.11.2017., 19:23   #3546
SaleFFS
Varilnik
SaleFFS's Avatar
Postovi: 1,648
Znači Andromeda je ok. Da li je to neki među nastavak ili?
Malo sam se zaželio dobrog starog Crysis-a. Bome dobro izgleda i nakon 10 godina
Staro 05.11.2017., 19:30   #3547
Da, Crysis i Crysis Warhead najbolje rade sa konfiguracijama koje su 4-5 godina novije od igre sjećam se da kad sam nabavio Crysis 2007. kad je izašla, komp mi je bio AMD Opteron 165 @ 3 GHz + nVidia 7900GS 256 MB. To ne da je štekalo, to su se čule suze iz računala
Par mjeseci kasnije je uletio C2D E6750 @ 3,6GHz + nVidia 8800GT 512MB. Tek tada je bilo igrivo na High
A prvi puta da sam na Enthusiast odigrao bez trzaja je bilo sa i7 2600K @ 4,5GHz + nVidia GTX 660Ti 2GB, u ljeto 2012
Stvarno je igra napravljena svjetski. Šteta što je taj serijal otišao u krivom smjeru.
Staro 05.11.2017., 19:39   #3548
SaleFFS
Varilnik
SaleFFS's Avatar
Postovi: 1,648
Tada kada je izašla baš sam frendu složio jednu konfu sa Q6600 i dvije 8800 GTX u sliju, ni tada nisi mogao to tjerati na max sve bez nekakvih trzanja
Staro 05.11.2017., 20:08   #3549
Manuel Calavera
Postovi: 14,589
Nema smisla praviti takve igre koje će se maxat za 5 god. To je nama sada fora, ali znaš kako ti je bilo onda
Staro 05.11.2017., 20:11   #3550
Postovi: 17,143
O čemu vi pričate?
Ja sam prije 2 godine složio skylake konfu, 16gb rama, i5 6600k na 4.0ghz ali nisam imao love za grafu pa sam ostavio HD6970 2gb. I krenem crysis, sve na high i pokrenem igru i ono, nije 100% fludina... Reko koji k
Ali ono što je čudno, ujak je laik za kompove, imao je u to vrijeme love i odlučio kupiti konfu za 6-7 tisuća kuna. Pričam o vremenu prije 3-4 godine. Imao je neki i5 (nemam pojma koji), 8gb rama i HD6850 i njemu je crysis radio solidno, što me iznenadilo. Meni je radio lošije s mojom skylake konfom, godinu dana kasnije.
Inače, igra se COD:WW2, meni igra ok, SP igram, 3 misije down, nekih sat i pol igre.
Igra se Dragon Age: Inquisition, nekih 5h imam.
I PUBG ofc, ali nešto manje zadnjih par dana, 2-3 meča dnevno.
Staro 05.11.2017., 22:27   #3551
bambi56x
bambi56x's Avatar
Postovi: 357
Po radnji, negdje između ME 2 i ME 3 rase Mliječne staze lansiraju 4 arke (ljudi, turianci, asari i salariani) i Nexus (svemirska postaja) prema Andromedi, i dok dođu prođe malo više od 600 godina. Znači isti svemir, druga galaksija, drugi likovi.
Staro 05.11.2017., 22:45   #3552
Spikeman
Lokacija: bi volio znat?
Postovi: 1,221
Wičer 3 (PS4), treci prelazak, vrh od igre, sto drugo rec
i dalje nemrem vjerovat da su ovako nes izvukli na konzoli koja se do nedavno mogla kupit za 1500kn, nova!
Sent from LG G2
Staro 05.11.2017., 22:49   #3553
Postovi: 17,143
3 puta prelaziš od početka ili ideš +?
Staro 05.11.2017., 22:50   #3554
Spikeman
Postovi: 1,221
od pocetka, iz nule
Sent from LG G2
Staro 05.11.2017., 23:16   #3555
Postovi: 17,143
Zašto ne igraš +? Sve je isto, samo teže puno.
Staro 05.11.2017., 23:19   #3556
Spikeman
Postovi: 1,221
Zbriso igru i save davnih dana
Sent from LG G2
Staro 06.11.2017., 19:03   #3557
Beetlejuice
Nisko letim, visoko padam
Beetlejuice's Avatar
Datum registracije: Mar 2010
Lokacija: RH
Postovi: 480
Far Cry 3 Blood Dragon. Relakairana makljaza...
Sent from my LG-H990 using Tapatalk
"You never know what is enough unless you know what is more than enough." - William Blake
Beetlejuice je offline   Reply With Quote
Staro 06.11.2017., 19:36   #3558
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
Half Life: Opposing Force
kakve igreee..
Staro 06.11.2017., 21:29   #3559
smirnoff
smirnoff's Avatar
Datum registracije: Dec 2009
Lokacija: nisam u ZG!!!!!!!!
Postovi: 1,207
jel igraš po noći sa slušalicama ??
u čekanju naslova koji me zanimaju (jako slabo izlaze FPSi normalne tematike a da nisu squad team taktike ili MPi) , po Xti put Far Cry 3...nikako me proć chili atmosfera tropskog otoka...
Staro 08.11.2017., 11:14   #3560
Postovi: 17,143
Dragon Age: Inquisition, 15h nekih imam, ali mislim da sam tek zagrebao površinu.
Daleko je od Witchera 3, ali nije toliko loša. Jedino što mogu reći, jede konfu žešće. Imam nekih 80-100 fps-a, sve na ultra 144hz, ali igra je 4 godine stara
Divim se ljudima koji su u ono vrijeme mogli igrati na ultra.
Priča za sada nije nešto preduboka, vjerojatno bude. Kontrole užasne, grafika odlična.
Sve u svemu, prolaz.
Nakon toga Wolfenstein serijal.
PUBG igram i dalje, nešto manje, svega meč-dva dnevno. 71h sam natukao.
Zadnje izmijenjeno od: Mommistake. 08.11.2017. u 11:20.
Staro 08.11.2017., 11:32   #3561
Manuel Calavera
Postovi: 14,589
Nije baš toliko, uskoro će ravno 3 godine napunit
Staro 08.11.2017., 14:40   #3562
Postovi: 17,143
Krivo izračunao
3 godine
Staro 08.11.2017., 15:08   #3563
rap_4_life
rap_4_life's Avatar
Postovi: 397
Dok cekam novu ekspanziju i dva 10day run-a za POE ubijem vrijeme na CS 1.6 ( fali mi zvuk ak ka zapuca), TF2 i Borderlands.
rap_4_life je offline   Reply With Quote
Staro 11.11.2017., 21:29   #3564
ddoxy
Lokacija: home
Postovi: 236
ddoxy je offline   Reply With Quote
Staro 13.11.2017., 10:26   #3565
SaleFFS
Varilnik
SaleFFS's Avatar
Postovi: 1,648
Završio Crysis jedinicu pa polako nastavljam Dirt Rally na elite. Tek sad vidim koliko je Crysis iz 2007 na normal daleko teži od današnjih fps-ova na normal.
Staro 13.11.2017., 10:28   #3566
BlackDwarf
BlackDwarf's Avatar
Lokacija: Novska
Postovi: 2,453
Diablo 3
Sent from my Lenovo A7020a40 using Tapatalk
Staro 13.11.2017., 11:28   #3567
Dottore
Dottore's Avatar
Postovi: 7,735
Autor Halos Pregled postova
kakve igreee..
Zakon priča.
Dosad sam igrao BF1 62 na 75 lvl u jedan dan. Rush shotgun
Sent from my SM-950U
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 13.11.2017., 12:53   #3568
rap_4_life
rap_4_life's Avatar
Postovi: 397
POE Turmoil 10day event, lagano levelanje, nisan igra POE više od godinu dana. Super je da je igra i dalje na visokom nivou.
Staro 15.11.2017., 18:17   #3569
Bodisson
Bodisson's Avatar
Datum registracije: Dec 2014
Postovi: 246
Ponovno krenuo Plants vs. Zombies. :-D
Bodisson je offline   Reply With Quote
Staro 16.11.2017., 00:51   #3570
emilblomsky
Lokacija: karlovac
Postovi: 2,111
[QUOTE=smirnoff;3123163]jel igraš po noći sa slušalicama ?[QUOTE]
Sorry,nisam vidio pitanje!
Ne,jer ih trenutno nemam.(Osim nekih za mob ).
Imao px100 ,pa sam ih prodao.Sad žalim.
Imam ok zvučnike,ali ih ne mogu odvrtiti po noći zbog ukućana.Tako da nije to to.
Inače,zavšio sve fearove,i bogami je i fear 3 nezgodan.Jesam se naginuo,ali večinom jer mi fali strpljivosti.
Sad idem far cryjove.2,3,4!
Phil of the future!
Zadnje izmijenjeno od: emilblomsky. 16.11.2017. u 08:37.
