|  10.03.2017., 02:44 | #4082 |
| Premium Datum registracije: Jul 2012 Lokacija: vk+
					Postovi: 14,584
|  12.03.2017., 13:46 | #4083 | |
| ..starija garda Datum registracije: Dec 2002 Lokacija: ZG
					Postovi: 3,280
				 | Citiraj:
				__________________ MojSkuter ---------------------------------PEACE Zadnje izmijenjeno od: Eladio. 12.03.2017. u 13:53. | |
|  12.03.2017., 15:18 | #4084 |
					Postovi: 14,584
				 | Dobro mislim da te za tako nešto mora pogoditi primjerak. Vidim lista se još popunjava IMO pravi šampioni su ovi sa 1.18v i 3.750 mhz na asus B350 prime, te 1.168v i 3692mhz na B350 tomahawkici   Čovječe to sipće struju, a rastura u MT performansama Ovaj što je praktično undervoltao (1.216v) i 3.5ghz na tomahawkici B350 mi djeluje kao nešto realno za svaki ili većinu primjeraka. Ne znam otkud sam ovdje linkao, ako treba nek se prebaci |
|  15.03.2017., 21:54 | #4086 |
					Postovi: 14,584
|  15.03.2017., 22:23 | #4087 | |
					Postovi: 3,280
				 | Citiraj: "AMD looks very strong with the current product roadmap and they have some really cool stuff coming out in the next few years."
				__________________ MojSkuter ---------------------------------PEACE | |
|  16.03.2017., 15:17 | #4088 |
| Premium Datum registracije: Dec 2007 Lokacija: Karlovac
					Postovi: 84
				 | R5 Stiže 11.4. - 4 modela, 3 sa coolerima, cijene su od 170 do 250 dolara: http://www.anandtech.com/show/11202/...n-5-april-11th |
|  18.03.2017., 09:00 | #4089 |
| Registered User Datum registracije: Dec 2016 Lokacija: Sat
					Postovi: 1,119
				 | AMD launching "X399" HEDT Zen platform 2H 2017 Public knowledge by now but AMD has a new HEDT platform coming out in a couple of months You'll see more of it at Computex I believe. It's a 16 core /32 Thread, quad channel behemoth. And it is insanely quick in the tests that Ryzen is already excelling at. So Cinebench, and all other related productivity programs. The gaming issues that were causing the Ryzen AM4 CPUs to behave erratically to say the least have been ironed out. It's akin to a newer revision on a newer platform. This should be competing with the Xeon and of course 6950X Intel offers for $1700~$1800USD, but at about $1,000 USD if not less for some Skews. Coming soon. CPSs are pretty big physically, about twice the size of surrent 6950X CPUs and a bit more perhaps. And if you were hoping for pins, nope it's strictly LGA! IT's NOT 8 channel, but Quad. |
|  24.03.2017., 19:39 | #4090 | |
					Postovi: 14,584
				 | Rumor: AMD X390 and X399 chipsets diagrams leaked? Citiraj:
|  25.03.2017., 16:13 | #4091 |
					Postovi: 14,584
|  25.03.2017., 16:32 | #4092 |
| Freelancer Datum registracije: Jan 2007 Lokacija: Bilje (Osijek)
					Postovi: 5,301
				 | To je to, sad samo nek izbace Dual/Quad socket modele i ploce po dobroj cijeni i bit ce frke u Intel taboru     .
				__________________ RS1 - MB: WS X299 Asus Sage, CPU: i7 9800X, RAM:128GB, GPUs: 3*RTX 3090 24GB RS2 - MB:Asus X99-E WS, CPU: i7 6850K, RAM:128GB, GPUs: 2*RTX 4090 24GB |
|  25.03.2017., 16:37 | #4093 | |
					Postovi: 3,280
				 | Citiraj:
|  25.03.2017., 18:05 | #4094 |
					Postovi: 14,584
				 | Promjenio je itekako, sad će izgleda napast i intelove HEDT i dual socket xeone. FX se cjenovno borio sa i3-icama i i5-icama, dvije potpuno različite stvari po pitanju performansi i financija X390 navodno 44 lejnsa, no uzet sve sa lopatom soli |
|  25.03.2017., 19:51 | #4095 |
| Overclocker Datum registracije: Nov 2016 Lokacija: Otiš'o sam, morao sam
					Postovi: 523
				 | Teško da će Intel gledati kako gubi kupce samo tako, pa dioničari će krenut na njih sa vilama, bakljama, bit će lomača itd |
|  26.03.2017., 14:51 | #4096 |
| Premium Datum registracije: Feb 2005 Lokacija: Zagreb
					Postovi: 2,138
				 | Problem intela sto ih je amd ulovio flat footed, previse su igrali na kartu da ce zen arhitektura biti fail, a ispalo je surotno. Intel koliko god jaca kompanija od amd trenutno bas i nema odgovor, vjerojatno ga ni sa sljedecom generacijom proceva nece imati.
				__________________  |
|  26.03.2017., 14:54 | #4097 | |
					Postovi: 1,119
				 | Citiraj:
 Poslano sa mog E6653 koristeći Tapatalk | |
|  26.03.2017., 15:23 | #4099 |
| Guest
				 | A 4/4 i 4/8 kao nije bilo dovoljno za kućnog korisnika? Intel je proračunat ko Sidorovich.   Daje taman koliko treba, ni promila viška, a bome ovima koji su furali i7, još od Nehalema, kroz sve ove godine nije ništa ni falilo. |
|  26.03.2017., 15:25 | #4100 |
					Postovi: 3,280
				 | Nisu znali, racunali su mozda da nece biti ni 40% povećanje ipc, problemi s taktovima iznad 3ghz o kojima se suskalo. Pa i proizvodjaci mbo su ostali paf. Kasne s isporukama, biosi itd. Amd je to dobro skrivao dok se intwl previse opustio. S druge strane sjecam se nvidiw koja svaki put ima rješenje na pokusaje amda .. Intel nije u problemima, ali jos malo i amd se vraca
|  26.03.2017., 15:35 | #4101 |
					Postovi: 14,584
				 | Ma znali su oni točno kakav je. Jednostavno su proračunati, moraju uzeti u obzir: - isplativost. Čak i da mogu napraviti bitno bolju arhitekturu (što je veoma dvojbeno), ne isplati im se u to utući milijarde kad će svejedno izgubiti marketshare jer će ovoga puta postojati konkurencija u svim segmentima. Naravno sa primjetno boljom arhitekturom bi izgubili manje marketsharea, ali vjerojatno gledaju uloženo/dobiveno - tehničke limitacije. Clockovi i ipc se ne mogu bitno povisiti već godinama, tako da su ta dva segmenta došla skoro do zida. Znači ostaje paralelizam (broj jezgri), mijenjanje cijena i feature-i (4K netflix  , optane ssd i sl.) |
|  26.03.2017., 15:38 | #4102 |
					Postovi: 3,280
				 | Mislim da tu nije problem lova. Pogotovo jer je imaju   nabacili bi sad oni hrpu milijardi da neko prodaje bolje gotovo rjesenje ne sumnjam. Sve u svemun amd je tu, intel ima svoju liniju koja nije nekonkurentna, dapce .. nego smo treba refresh naziva i cijena  i mirqju se malo trgnut  Ali bas me briga, jedva cekam siru najezdu ryzena u sve segmente
				__________________ MojSkuter ---------------------------------PEACE Zadnje izmijenjeno od: Eladio. 26.03.2017. u 15:45. |
|  26.03.2017., 16:14 | #4104 |
| Uptime 99.99% Datum registracije: Nov 2001 Lokacija: Zagreb
					Postovi: 2,619
				__________________ “Those who surrender freedom for security will not have, nor do they deserve, either one.” |
|  26.03.2017., 16:29 | #4106 |
					Postovi: 2,619
				 | Ne mogu, ali planovi su tu da se mijenjaju. Znaci mogu probati nesto izbaciti iduce godine ili 2019.
|  26.03.2017., 16:59 | #4107 |
					Postovi: 14,584
				 | Njih čak ne jebu tehnološke mogućnosti core arhitekture (skylake-x i kaby-x će biti brži od ryzena nedvojbeno), nego ih jebu cijene koje je amd nametnio. Em bi još trebali prepolovit cijene, tu još dijele marketshare sa još jednim konkurentom. Prodaja i profit padaju kako god okreneš, tu oni ništa ne mogu napraviti, o tome se radi. Ako x266 procesori opet budu duplo i trostruko skuplji, malo koga će zanimati to što su xy % brži. Na kraju krajeva izbacit će i amd nove zenove nagodinu |
|  26.03.2017., 18:07 | #4108 | |
					Postovi: 2,138
				 | Citiraj:
 Kuzis recimo moja stara dere bespucima interneta na prastarom monocore sempronu, to ne znaci da je to dovoljno za avakog kucnog korisnika. Ja sam jedan od tih koji prozvakuje staru i7 evo vec skoro 8god., i vjeruj mi da bi odavno bio na necem novijem da mi je bilo isplativo prelaziti. Mislim da jos nismo svjesni koliki bi zen mogao biti udarac intelu ako se ne trgnu dovoljno brzo i ne promjene nesto, evo sad citam da na novu x299 platformu stavljaju 4core proc...meni je to potpuno nerazumno.
				__________________  | |
|  26.03.2017., 20:03 | #4109 |
					Postovi: 14,584
				 | Ovo izgleda nije bilo linkano, mada uzeti clockove sa zrnom soli AMD's rumoured 180W 16-core Ryzen part will reportedly run at 3.1/3.6GHz U svakom slučaju gdje ima dima ima i vatre, vrlo vjerojatno postoji nekakav amd ekvivalent intelovim quad channel i 40 pci-e lanes procesorima. Ionako ne vidim smisao da nemaju ponudu i u tom segmentu ako već imaju 8c16t u mainstreamu + 32c64t x2 na serverskoj platformi. |
|  26.03.2017., 22:45 | #4110 |
					Postovi: 2,138
				 | Ma da boosta samo do 3.4GHz puna saka brade. I tih 16 jezgri je isto jedan od razloga da jos nismo svjesni u kakve bi potencijalne probleme intel mogao upasti, pa je tu i mobilno trziste, pa serversko sa naplesom. U principu je desktop trziste amdu 'najnepovoljnije' Tdp od 180W za onakve clockove uopce nije los
				__________________  Zadnje izmijenjeno od: Gigi1. 26.03.2017. u 22:59. |
