Staro 01.09.2016., 14:12   #331
Moto001
Moto001's Avatar
Datum registracije: Sep 2014
Lokacija: Slavonija bajnaaaaa
Postovi: 237
Jer netko to već isprobo na RX karticama i ima li kakvog pomaka nabolje dakako jer ovi prošli i nisu baš najbolje sjeli.Pogotovo ako se koristi Trix(beta) dok neizađe nova verzija.
Moto001 je offline   Reply With Quote
Staro 01.09.2016., 14:21   #332
MikaHR
Postovi: 1,264
Probao deus ex, nema nikakve promjene.
Sve prošlo bez ikakvih problema, a Trixx....čekaj da izadje iz bete ;P
MikaHR je offline   Reply With Quote
Staro 08.09.2016., 13:04   #333
MikaHR
Postovi: 1,264
16.9.1.
http://support.amd.com/en-us/kb-arti...ase-Notes.aspx
  • Support for:
    • Deus Ex™: Mankind Divided (DirectX®12)
  • New AMD CrossFire profile added for DirectX® 11:
    • DOTA™2
Fixed Issues
    • A small number of 144Hz non-FreeSync enabled displays may exhibit flickering during gaming or on desktop.
    • FreeSync may stay enabled while on desktop causing flickering.
    • Grand Theft Auto V™ may experience an application hang after loading story mode.
    • DiRT™ Rally rain drops may flicker when using high or ultra in game settings.
    • DOOM™ may experience a hang on game exit in some limited AMD PowerXpress configurations.
    • Total War™: Warhammer may experience negative AMD CrossFire scaling on some Radeon RX 400 series configurations.
    • GPU utilization may remain high when idle after running SteamVR performance benchmark.
    • Pixel format options may be missing from Radeon Settings for some limited system configurations on Radeon RX 480 graphics.
    • Radeon Software may intermittently fail to install or hang on some AMD CrossFire configurations. If this happens users can reboot and re-install without issue as a workaround.
    • Some Radeon RX 400 series graphics products may experience high GPU usage when resuming from sleep.
Known Issues
    • A few game titles may fail to launch or crash if the AMD Gaming Evolved overlay is enabled. A temporary workaround is to disable the AMD Gaming Evolved "In Game Overlay".
    • Upgrading from a previous Radeon Software Crimson Edition version may cause user settings in Radeon Settings to reset to defaults.
    • OpenCL applications may run initially on integrated graphics if they are present. Make sure to set the application to the correct device you would like to use.
    • Radeon Settings information tab may report incorrect Open CL or Mantle versions.
    • Radeon Software installer may report driver uninstallation failed even when it was successful.
    • No Man's Sky™ some minor corruption may be experienced when standing close to solid structures inside of caves.
    • Mouse cursor corruption may be experienced very intermittently on the Radeon RX 480.
    • DOTA2™ may experience an application hang when using the Vulkan™ API and changing resolution or game/quality settings.
    • Ashes of the Singularity™ may experience an application crash with "crazy" in game settings and Multi-GPU enabled.
Staro 24.09.2016., 00:10   #334
MikaHR
Postovi: 1,264
16.9.2.
Fixed Issues
  • Overwatch™ may experience an application crash on some Radeon™ RX 480 configurations when using AMD Crossfire mode.
  • Vulkan™ information in the Radeon Settings software information tab may display an incorrect version.
  • Radeon WattMan may retain settings of an overclock after it has failed. If you have failed an overclock with a system hang or reboot.
  • Hitman™ may experience graphical corruption when the game is set to use DirectX®12 API and using zoom with weapons.
  • Total War™: Warhammer may experience minor graphical corruption in some map textures on AMD Radeon R9 380.
  • Flickering may be observed in Rise of the Tomb Raider™ on some AMD Crossfire configurations using the DirectX®11 API.
  • Changing settings in Dragon Age Inquisition™ with the Mantle API may result in an application crash or driver recovery.
  • DiRT™ Rally may experience flickering terrain in some races when the advanced blending option is enabled in the games settings page.
  • Display may exhibit a minor flicker on Radeon RX 480 when Freesync is enabled on a games launch or exit.
  • Shadows may experience rendering issues in DOTA2™ when using the Vulkan™ API.
  • Textures may experience holes or gaps in DOOM™ when using the OpenGL API and three display AMD Eyefinity configurations.
  • Need for Speed™ may experience flickering on some light sources in AMD Crossfire mode.
  • Performing a task switch with two cloned displays during full screen gaming may cause flickering on the extended display.
Staro 12.10.2016., 15:01   #335
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,589
http://wccftech.com/amd-gaming-evolv...ger-supported/
Aleluja, ne moram micat jednu kvačicu prilikom instalacije
Baš jučer gledam di je gayming evolved da ga otkačim
Staro 13.10.2016., 00:39   #336
Ag008
RESPECT MY AUTHORITAH
Ag008's Avatar
Postovi: 7,507
Ja je nisam koristio ali je bilo fora nekada pogledati komentar što preporučuju, koje postavke u igri i koje ja trenutno imam.
Btw stavio beta 16.10.1, sada s Updateom 1 Mafia 3 izgleda još gore
Staro 21.10.2016., 14:06   #337
Manuel Calavera
Postovi: 14,589
Staro 07.11.2016., 15:37   #338
intelduo
intelduo's Avatar
Postovi: 97
Meni se u 16.10.3. Crimsonu ruši Wattman aplikacija kad pokušam ući u nju. uspijem nakon više uzastopnih pokušaja. Ima li netko sličan problem? Imam 2x RX480 u CF.
intelduo je offline   Reply With Quote
Staro 07.11.2016., 17:51   #339
Manuel Calavera
Postovi: 14,589
Prodaj drugu
Staro 08.11.2016., 00:07   #340
klem
Postovi: 594
Hm, da li još netko ima sličan problem s novijim driverima od 16.7.3 za win 10. Naime, tu i tam si volim ubit slobodno vrijeme s Fallout New Vegas i ruši mi igru sa svim novijim driverima iza 16.7.3. Vidim na stranim forumima da i drugi imaju istih problema.. loadam save, baci error i moš se frigat. Ok... je da je igra stara i da je moja grafa Hd 7700 stara, al pokušavam skužit kaj se pohebalo u novijim catalystima. Malo mi žifce ispije kad nađem slobodnog vremena pa moram vraćat stare drivere . Mislim mogu i ostat na njima ali volim uvijek skinut nove i to mi onda opet žifce pije . Nikad problema imao nisam osim sa svojim žifcima
klem je offline   Reply With Quote
Staro 08.11.2016., 00:16   #341
Manuel Calavera
Postovi: 14,589
Thnx for the info. Baš sam mislio malo new vegasit nakon što pređem stalker cop (HD7850 2gb i win7).
Mada realno novi driveri dolaze za najnovije igre u tom mjesecu, mi nismo više ta publika. Možda baš probam sa novim driverima pa ti javim dal me jebe.
Staro 08.11.2016., 00:33   #342
klem
Postovi: 594
budem se ja još probao malo poigrati ovih dana i proguglat još po forumima da vidim da li postoji koje drugo rješenje osim rollback drivera. Ak nađem išta suvislo javim .
Staro 08.11.2016., 00:37   #343
Manuel Calavera
Postovi: 14,589
Ja ti imam 16.9.2 dugo već i nikakvih problema. Općenito nikad u životu nisam imao nekih problema s driverima. Mada možda je bitno napomenuti da nikad nisam igrao alfa, beta, day one, first week igre i sl. Čak ni prvi mjesec. Mada je moguće da sa nekim novim driverima pojebu nešto što smeta nekoj staroj igri, kao da oni to testiraju...
Staro 08.11.2016., 01:06   #344
klem
Postovi: 594
ma mislim nije sad neki problem zbog jedne igre, Ionak kasnim s igrama par godina i sad sam se tek dotaknuo New Vegasa a vani je već ohoho . U najgorem slučaju napravit ću roll back na stare drivere i bit će gore dok se New Vegas ne prođe...znači ovim tempom cca godinu dana još
Staro 08.11.2016., 20:44   #345
arrow
arrow's Avatar
Datum registracije: Nov 2014
Lokacija: Zd
Postovi: 609
jel imao tko problema na r9 3xx seriji sa novim 16.11.2 driverom?
ja danas instalirao te nakom 20min gejmanja dobio crveni zaslon i komp se iskljucio
vratio na 16.9.2 te radi bez problema
arrow je offline   Reply With Quote
Staro 29.11.2016., 15:31   #346
tuna3
Datum registracije: Mar 2009
Postovi: 474
Malo glupo pitanje ali kako najlakše updateam crimson na najnoviju verziju.
Win update mi još drži na starijoj verziji i ne mrda.
tuna3 je offline   Reply With Quote
Staro 29.11.2016., 15:34   #347
klem
Postovi: 594
Autor tuna3 Pregled postova
skineš s amdove stranice , ili napraviš update iz aplikacije
Staro 29.11.2016., 15:36   #348
tuna3
Postovi: 474
Autor klem Pregled postova
U tome i je problem, u aplikaciji ne vidim update. Ili je negdje sakriven. (WIN10)
Ako skidam sa stranice trebam prvo uninstall postojećih napravit?
Staro 29.11.2016., 15:58   #349
Manuel Calavera
Postovi: 14,589
Zadnji klik na desktop - radeon settings, donji lijevi čošak (new update) - check for updates (piše ti currently instaled te koji je new)
Staro 29.11.2016., 16:01   #350
tuna3
Postovi: 474
Meni je tamo preferences
Staro 29.11.2016., 16:03   #351
spitfire83
spava mi se
spitfire83's Avatar
Datum registracije: Nov 2013
Postovi: 329
Ma samo download sa amdove stranice i pokreni, nadograditi će se bez problema.
Ovi driveri šta skine win 10 iz nekog razloga nemaju update iz opcija, bar ga ja nisan nasa
spitfire83 je offline   Reply With Quote
Staro 29.11.2016., 16:08   #352
tuna3
Postovi: 474
Autor spitfire83 Pregled postova
E da, tako je i meni. Znači prvo uninstall pa novi sa weba. Tnx.
Staro 29.11.2016., 17:01   #353
Mr.Ex.President
Torrent freek
Mr.Ex.President's Avatar
Postovi: 3,949
Radije "pretuci" staru nego da je deinstaliraš, meni je ta deinstalacija napravila uvik više problema nego upgrade preko stare verzije
MBO: MSI B450 Gaming Plus
PSU: Corsair RM550X 550W
Periferija
LCD: HP ZR24w
Mouse: Logitech G400
Sound: Genius SP-HF1201A
Printer: HP LaserJet 1020
Scanner: HP ScanJet 4300
Headphones: Philips SHC 2000
MBO: Gigabyte GA-F2A85XM-HD3
HDD: WD Green 2TB [WD20EZRX]
PSU: Antec SU380
TV: Samsung 43E450 @HDMI
LINK
Mr.Ex.President je online   Reply With Quote
Staro 08.12.2016., 15:51   #354
Tex Willer
Tex Willer's Avatar
Postovi: 281
Radeon Software Crimson Edition ReLive
Origin: Dead_Body_cRo
Tex Willer je offline   Reply With Quote
Staro 08.12.2016., 18:52   #355
Badboy
Lokacija: Jastrebarsko
Postovi: 305
Meni bas instalirava....
Život je samo san na putu prema smrti!
Badboy je offline   Reply With Quote
Staro 08.12.2016., 19:21   #356
VandaL.pr!
VandaL.pr!'s Avatar
Lokacija: zaDAR
Postovi: 845
Nisam u toku, sto ima u tom ReLive - u?
EDIT, mogu li samo update ili da izbrisem sa sweeperom?
VandaL.pr! je online   Reply With Quote
Staro 08.12.2016., 19:47   #357
Manuel Calavera
Postovi: 14,589
Staro 09.12.2016., 01:15   #358
Manuel Calavera
Postovi: 14,589
Nisam još ništa pogledao ni isprobao, ali naslovi su bombastični
http://forum.pcekspert.com/showpost....postcount=3172
Staro 09.12.2016., 01:19   #359
buljaka
Datum registracije: Aug 2014
Postovi: 2,954
overwatch mi se srušio ,crveni ekran i restart... jebem sebe i nove drivere
Poslano sa mog SM-G930F
Staro 09.12.2016., 02:36   #360
dekky
dekky's Avatar
Lokacija: pula
Postovi: 637
Meni u bf4, jedno 4 puta se kod pokretanja igre osvježavao zaslon...ono crna slika pa igra, crna pa igra...i onda je radilo. Drugo nisam probavao...
