Staro 23.10.2016., 13:16   #24721
vga killer
Treba kaj skurit??
vga killer's Avatar
Lokacija: Zgb
Postovi: 4,032
Baotić - velki servis na Laguni II 1.8 plus prednje kugle preko 12000 kuna
vga killer je online   Reply With Quote
Staro 23.10.2016., 13:40   #24722
ThePornstar
ThePornstar's Avatar
Postovi: 4,403
Haha, pa to nije ni 15k
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
Battery: 57 Wh internal
ROM: Android 9
Staro 23.10.2016., 14:33   #24723
adaksinjo
adaksinjo's Avatar
Datum registracije: Dec 2011
Lokacija: Virje
Postovi: 602
Staro 23.10.2016., 14:51   #24724
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Autor Blue_Fatal1ty Pregled postova
Ph2 je megane?
Yep. Sa lećama koje su vjerojatno veliki krivac za to.
Staro 23.10.2016., 14:51   #24725
Dottore
Dottore's Avatar
Postovi: 7,736
Bravo Adakinto!
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 23.10.2016., 14:59   #24726
Blue_Fatal1ty
Blue_Fatal1ty's Avatar
Lokacija: Čazma
Postovi: 1,728
Autor Vuco Pregled postova
Postoji šansa da su lece zmazane i daju se ocistit. No velika je vjerojatnost da su izgorile kao moje i onda ne s ijetle ama bas nista.
Rijesio sam to tako da sam dao ispolirat farove stavit druge lece i ugradit xenonke. Sad je mila majka.
https://www.dropbox.com/s/kbfpyn01za...39.41.jpg?dl=0
Staro 23.10.2016., 15:32   #24727
Vuco
Vuco's Avatar
Postovi: 9,505
Sve mi jasno, samo mi se neda biti u ilegali radi prokletih farova. Na leći mi se čini kao da ima prašine, ali gledam na drugim meganima, u 90% slučajeva je još i puno gora situacija - mliječni su.
Staro 23.10.2016., 16:32   #24728
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
Sa unutarnje strane lece izgori taj nekakav film i povratka nema.
Ti renaulti imaju taj problem jos od klija dvojke, i nevjerojatno je da to nisu jos rijesili.
Staro 23.10.2016., 16:41   #24729
lowrider
lowrider's Avatar
Lokacija: KR
Postovi: 1,176
Izgori reflektirajući sloj, posebno na francuzima kojima gore često žarulje jer su u overdriveu. Nedavno sam slagao jednom P208 termistor na žarulje kratkog svjetla, jer su pregorijevale tjedno. Napon na žarulji je bio 14v dok motor radi,inače je oko 13v na drugim autima
Staro 23.10.2016., 17:00   #24730
adaksinjo
adaksinjo's Avatar
Lokacija: Virje
Postovi: 602
elf ulje u metro-u na dobroj akciji: 5l 700STI polusintetike 100kn, 5l 900NF sintetike 150kn.
https://view.publitas.com/10729/2109...4fc4-at800.jpg
Staro 23.10.2016., 17:53   #24731
Romul
Romul's Avatar
Lokacija: Rijeka/Bratislava
Postovi: 222
Autor Gilbert5 Pregled postova
Svaka odluka ima prednosti i mane. Ali dati 103k kn za 208 pezo je negdje u rangu sa kupovinom 10 godina starog vw diesela s 200+km. Ludost
Sogi kupio bmw koji se "kao" ne kvari, 2006 320d, super je isao jedno vrijeme a sada 4 tjedna na popravku...a popravak ce ga izaci opasne novce.
Ako netko gleda kompakta novog za 90000kn, sigurno nije tip koji ce kupiti 10 godina star dizel za kurcenje.
Btw, vozio sam prije 10 dana bmw 525d 2006. Tromo, 9.2 u prosjeku. Tvrd uzasno...
Kolega, koji auto ti vozis ako ti je 525d trom??
Ako je taj 525d kojeg si ti vozio ispravan i u dobrom stanju onda se tesko moze kvalificirati kao trom auto
Ali opet dozvoljavam da ako si izasao iz 911 turba i sjeo za 525d pa u tom slucaju osjecaj moze biti kao da je trom
Inace taj auto je brzi od golfa VII 2.0 TDI za pola sekunde do 100-tke a nekako imam osjecaj da si vozio tog golfa da bi rekao da je raketa auto
Romul je offline   Reply With Quote
Staro 23.10.2016., 18:40   #24732
Vuco
Vuco's Avatar
Postovi: 9,505
Autor Gabre Pregled postova
Čitao sam o tome, no ne mogu naći nikako slike primjera, pa da potvrdim jel se to kod mene događa.
Ni po danu nije svijetlo neko bajno, ali da se vozit. Ali po noći + mokra cesta je valjda korisno samo drugima da vide da idem prema njima
Staro 23.10.2016., 18:58   #24733
webstartm
Sandy!!!
webstartm's Avatar
Postovi: 1,695
Sile nove šlape
Rainexpert 3, dot 4615
330kn sa montazon, balasiranjen i novin ventilima
175 70 r13
Pa ćemo da vidimo jel to ičemu
Staro 23.10.2016., 19:07   #24734
Gabre
Lika u mom srcu
Gabre's Avatar
Postovi: 9,887
To ti je milion posto.
Staro 23.10.2016., 19:09   #24735
Gilbert5
Agent 0
Gilbert5's Avatar
Lokacija: Kutina - ZG
Postovi: 4,312
Autor Romul Pregled postova
Auto je na 309000km, i to je moj subjektivan dojam.
Takav bmw mi je oduvjek bio san, i onda kad ga isprobas onda skuzis da nije to to. Da li je to zbog km i nije skroz ispravan, ili sam ja panj...ne mogu reci.
Vozio sam stari vw 2.0 pumpa dizna i nove cr, i subjektivno su puno zabavniji za voznju.
Staro 23.10.2016., 20:03   #24736
Gabre
Lika u mom srcu
Gabre's Avatar
Postovi: 9,887
Bmw 525d je lijena krava. To je auto od pun K kila i trom, lako sto on do 100 potegne ok, ali ta tezina se osjeti svugdje. Moj Audi ima 220ks pa sam siguran da je moj leon na cesti brzi i definitivno okretniji.
Staro 23.10.2016., 20:14   #24737
Juan
Juan's Avatar
Postovi: 338
Po čemu zaključuješ da je prvo polusintetsko a drugo sintetsko jer nijedno od ova dva ulja nije sintetsko.
Zadnji pogon nije toliko živahan u prvoj brzini, a i veliki auti ne daju takav dojam. Do nekidan sam imao 320d i kad bih sjeo u bilokoji tdi pd mislio bih da je raketa ali rame u rame nije ništa brži. Koliko god da su zabavne navale momenta kod pd motora toliko su ti motori i nezahvalni za zavojite uzbrdice/nizbrdice gdje bmw-a po zavojima ganjaš druga pod, treća pa nazad drugom kočiš, dok za tdi-a uvijek moraš tražit adekvatnu brzinu jer se dere u drugoj a u trećoj je preslab. Pritom ne govorim o osjećaju kako auto ide, nego o brzini koju vidiš na satu jer PD-a ubijaš ako ga pri 50 spustiš u drugu dok sam s 320d to radio pod normalno.
A to što je na 309 000 km nema veze jer je 99% dizelaša iz te godine i debelo iznad.
Juan je offline   Reply With Quote
Staro 23.10.2016., 20:18   #24738
MuroF
MuroF's Avatar
Lokacija: VŽ-okolica
Postovi: 118
Autor webstartm Pregled postova
Sile nove šlape
175 70 r13
je,super su,samo kaj su mi trajale tocno 2 ljeta,sad su već na 2mm cca.. auto 100 konja,nis posebno.
MuroF je offline   Reply With Quote
Staro 23.10.2016., 20:18   #24739
zgmmax
zgmmax's Avatar
Postovi: 1,683
netko je imao tu saraf u gumi?
Kak je to rijeseno?
Imam istu situaciju sada, ko zna kolko se vec vozim sa sarafom, a trebam do ljubljane.
Ostavit saraf nutra il ic kod vulkanizera ta to zakrpa?
Staro 23.10.2016., 20:20   #24740
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,614
ja sam imao, vulkanizer riješio, lupkalo je pa mi je smetalo
Staro 23.10.2016., 20:23   #24741
bertone
bertone's Avatar
Datum registracije: Mar 2010
Postovi: 2,068
Autor zgmmax Pregled postova
Kak je to rijeseno?
Možeš do Ljubljane i natrag samo stani svakih 20-30 km i malo ga dotegni ... ma zezam se, odi kod vulkanizera da zakrpa gumu jer ovako nije sigurno otići ni do placa a kamo li malo dalje
Staro 23.10.2016., 20:40   #24742
zgmmax
zgmmax's Avatar
Postovi: 1,683
Preporuka nekog vulkanizera i kolko to dodje?
Staro 23.10.2016., 20:41   #24743
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,614
80ak kn u tratinskoj
Staro 23.10.2016., 22:08   #24744
bertone
bertone's Avatar
Postovi: 2,068
Pneumatik na Samoborskoj... za cijenu ih cimni na mail: pneumatik.stenjevec@gmail.com
Staro 23.10.2016., 22:51   #24745
webstartm
Sandy!!!
webstartm's Avatar
Postovi: 1,695
Autor MuroF Pregled postova
Neprelazim puno kilometara pa ce trajat duze, računam bar 4 godine pa mijenjanje
Ali otac mi ih,ima on vozi 20k na godinu, dvi godine i adio, izlizane skroz
Nemam preporuku jer sam iz ST, ali meni je naplacivalo 40kn krpanje.
5 min posla doslovno
Staro 24.10.2016., 07:43   #24746
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,064
Zna li netko koja jačina žarulje ide u Golf V,da li 35 ili 55w ?
Koje biste žarulje preporucili,uzeo bi osram samo ne znam da li nightbreaker plus ili cool blue intense ili pak blue intense radi bjelkasto-plave boje ( zakonom dopušteno ) ?
Staro 24.10.2016., 10:24   #24747
Getriba94
Getriba94's Avatar
Datum registracije: Jun 2016
Postovi: 1,052
mislim da su 55
a preporuka je da ne bacas pare na preskupe osramice , probo sam vise zarulja i iznenadio sam se sa pevecovim (imitacija cool blue intense)
40kn par a svijetle ko lude bijelo , stavio sam ih i na skuter i auto svjetle bez beda mjesecima.
frend ima nightbreaker i kad stane pored mene njegove djeluju skroz žuto
https://www.abrakadabra.com/medias/0...Tg4OTllMThkNmM
Staro 24.10.2016., 10:52   #24748
Hrconja
Hrconja's Avatar
Postovi: 1,629
Autor Getriba94 Pregled postova
mislim da su 55
Ček ti si stavio xenon lampe umjesto običnih ? Ili je to nekakva imitacija xenon lampi. Može li se s time proći tehnički ?
Hrconja je offline   Reply With Quote
Staro 24.10.2016., 11:00   #24749
Getriba94
Getriba94's Avatar
Postovi: 1,052
Autor Hrconja Pregled postova
nisu xenon lampe , za xenon bi trebo balaste imat
ovo je samo zarulja sa plavim filterom koji pobjeli svjetlo
normalno prolaze tehnicki po zakonu
Staro 24.10.2016., 12:08   #24750
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,064
Lijepo izgleda i još je legalno,da li si siguran da neće far otopiti ?
Još ako ide 55w moglo bi to fino zagrijati far.
Mogu kupiti po dva komada za kratko i dugo ?
