Staro 30.10.2005., 14:21   #1
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
Kolika vam je temperatura?
Evo ovako...zamislio sam da tu svi procitate u everestu kolke su vam temperature u idle i load.... pa da se uspoređujemo i pomognemo onima kojima su temp previsoke...
evo trenutno u idle / load:
Maticna ploca:22C / 22-24C
Cpu:32C / 40-45C
Gpu:42C / 49-53C
Hard disk:25C / 27-29C
Ove najvise temeperature u loadu su nakon recimo 5 sati igranja Call of dutya sa svim detaljima.... aj sad vi pisite dalje svoje i sta mislite o ovim mojim temperaturama
AMD Phenom 9850be 2,5ghz@2,9ghz@OCZ Vendetta 2 700rpm
DFI Lan Party JR 790GX-M2RS
OCZ Blade 2x2Gb ddrII@1066mhz@1.8v
Gigabyte HD4850 1GB Multi Core @passive
Auzentech Meridian@Opamp LM4562NA
2xWestern Digital 6400aaks@RAID 1 + Seagate S-ATA 160gb@XXX
Tagan 480W Supersilent
Thermaltake V1000+ black with side window
Logitech MX500
DELL 2007FP
AMD Athlon 3000+(venice e3) stock
Abit AV8
Kingmax Superram 2x256ddr433 FHAS stock
Gainward 7600GT GS 256mb
Seagate Barracuda 80gb P-ata
Denon AVR-3805 black finish @DIY 3.5mm > 2RCA(Neutrik RCA plugs)
Focal Jmlab Chorus S 726s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S CC700s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S SW700 classic finish@Bandridge Profigold Subwoofer Cable
Review Chorus S serije
Review Denon AVR-3805
micek_kc je offline   Reply With Quote
Staro 30.10.2005., 14:26   #2
domy_os
domy_os's Avatar
Postovi: 19,028
Evo i mojih u idleu s tim da je u sobi pakao.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 30.10.2005., 14:38   #3
maxxp
maxxp's Avatar
Postovi: 323
moje u idleu:MBO 24C
CPU 38C
GPU 36C
maxxp je offline   Reply With Quote
Staro 30.10.2005., 14:48   #4
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
zast ti je na ploci takva temp? meni nikad nejde preko 27C
Logitech MX500
DELL 2007FP
Abit AV8
Staro 30.10.2005., 15:01   #5
domy_os
domy_os's Avatar
Postovi: 19,028
Zato što je senzor kod vrućeg SB-a i još topli zrak s diskova ide prema njemu.
Staro 30.10.2005., 15:19   #6
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
fakat...nisam se toga sjetil...
Logitech MX500
DELL 2007FP
Abit AV8
Staro 30.10.2005., 15:20   #7
nicko
Postovi: 4,190
matična 30st
procesor 27st
disk 29st
grafička 37st
nb 39st
nicko je offline   Reply With Quote
Staro 30.10.2005., 15:27   #8
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
kako si postigao ovih 27C ? meni je recimo 24 dok upalim komp al to se ne racuna...realna temp je nakon jedno ono da komp radi 30 min al da nista ne radis...
Logitech MX500
DELL 2007FP
Abit AV8
Staro 30.10.2005., 15:43   #9
MRKONJA
M.U.P.
MRKONJA's Avatar
Datum registracije: Sep 2004
Postovi: 2,277
Abit AX8 VIA k8t890//Venice 3000@2250//1x1gb PQI//POV 7600gs silent//Seagate 7200.10 250gb(16mb//sata)//Hitachi 7k160 120gb@mobile kučište//Seagate 7200.7 200gb
//Samsung SH-w163A//Seasonic S-12 380w//Sharkoon silvation
MRKONJA je offline   Reply With Quote
Staro 30.10.2005., 16:06   #10
nicko
Postovi: 4,190
to mi je sve u idlu, sa c'n'q i freezerom...
zadnji ventovi od 8cm rade na 5V, a bočni i prednji od 12cm rade na 7V...
Staro 30.10.2005., 16:08   #11
Dudek
Dudek's Avatar
Datum registracije: May 2005
Postovi: 369
Dudek je offline   Reply With Quote
Staro 30.10.2005., 17:35   #12
xmikex
Lokacija: split
Postovi: 58
svi bi uz svoj post trebali napisat i temeraturu zraka u blizini kucista jer je to vrlo bitno jer nije isto jel ga netko drzi na balkonu na 15°c ili mu je sprcen ispod stola na 30°c
temp zraka=21°c.....znaci ako cemo svi uzet nekih 20°c za referentne onda mi oduzmete jos 1°c
idle
cpu:29
mbo:31
load(15min spuper pi)
cpu:31
mbo:32
xmikex je offline   Reply With Quote
Staro 30.10.2005., 17:50   #13
domy_os
domy_os's Avatar
Postovi: 19,028
Kod mene je temperatura okoline 25-26°C.
Staro 30.10.2005., 19:19   #14
Gemmy
smeghead
Gemmy's Avatar
Postovi: 3,194
Staro 30.10.2005., 20:00   #15
Mr.Ex.President
Torrent freek
Mr.Ex.President's Avatar
Postovi: 3,953
Konfa iz siga na 100% CPU-a
MBO: 28
CPU: 41
VGA: 30
HDD: 24
U sobi je 24
MBO: MSI B450 Gaming Plus
PSU: Corsair RM550X 550W
Periferija
LCD: HP ZR24w
Mouse: Logitech G400
Sound: Genius SP-HF1201A
Printer: HP LaserJet 1020
Scanner: HP ScanJet 4300
Headphones: Philips SHC 2000
MBO: Gigabyte GA-F2A85XM-HD3
HDD: WD Green 2TB [WD20EZRX]
PSU: Antec SU380
TV: Samsung 43E450 @HDMI
LINK
Mr.Ex.President je online   Reply With Quote
Staro 30.10.2005., 20:28   #16
MRKONJA
M.U.P.
MRKONJA's Avatar
Postovi: 2,277
Onda ti hard nije na 24
Kako bi Trek rekao ako je nešto na sobnoj temperaturi znaći da se ne grije a to je nemoguće
Staro 30.10.2005., 20:47   #17
Mr.Ex.President
Torrent freek
Postovi: 3,953
Šta kolutaš očima odma
U Everestu piše da je na 24, e sad možda krivo mjeri, al nije puno poviše jer u njega direktno puše 120 mm
Periferija
LCD: HP ZR24w
PSU: Antec SU380
LINK
Staro 30.10.2005., 21:22   #18
Jablan
Jablan's Avatar
Datum registracije: Jul 2004
Postovi: 756
Temperatura u prostoriji je 25°C, sa tim da mi jebena klima puše ravno na komp
Idle
MBO: 29
CPU: 30
HDD: 39
Load
MBO: 30
CPU: 45
HDD: 42
Jablan je offline   Reply With Quote
Staro 30.10.2005., 21:24   #19
Wolverine
Wolverine's Avatar
Postovi: 12,433
Evo load temp dok radi Prime
Everest mi puca iste temp ko i Smartguardian
GPU 35/50
HDD 35/40
Mark Twain
Intel Core i7 2760QM
2x 8GB DDR3
Intel HD3000
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Zadnje izmijenjeno od: Wolverine. 30.10.2005. u 22:02.
Staro 30.10.2005., 21:54   #20
Crash009
Crash009's Avatar
Lokacija: Orahovica
Postovi: 7,363
IDLE
NB: 32c
CPU:35c
HDD: 28c
LOAD
NB: 37c
CPU: 46c
HDD 33c
Staro 30.10.2005., 22:08   #21
Tao2
Tao2's Avatar
Postovi: 319
IDLE
DFI LP ut-sli-D
Amd64 3000+ Venice E6 @ 2800mhz 1,45v + vodeno
...max oc 3009.17 mhz @ kamikaza screen
Leadtek px6600td @ 350/660
Hardovlje & Maxtorovi sata 80 i pata 40 + Hitachi 160
Mema / neka
Tao2 je offline   Reply With Quote
Staro 30.10.2005., 22:27   #22
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
a sta je onda sa vodenim hlađenjem?:confused: isto je recimo tako ak imas 8 ventova u kompu i prozor od sobe otvoren + stropni ventilator.....razmisljaj malo
ovo je odmah nakon paljenja kompa... [img=http://img327.imageshack.us/img327/7209/nakonpaljenja0yq.th.jpg]
a ovo je idle nakon 30min....
[img=http://img364.imageshack.us/img364/698/idlenakon30min6ur.th.jpg]
poslije budem stavio sliku na loadu...
Logitech MX500
DELL 2007FP
Abit AV8
Staro 30.10.2005., 22:44   #23
xmikex
Lokacija: split
Postovi: 58
brate kolika je tebi temperatura u sobi?10°c?
dok san ja hladia zalmanom na fullu pri sobnoj od ok 24 bi mi idle bia oko 37-38...sa otvorenim kucistem!
Staro 30.10.2005., 22:55   #24
MRKONJA
M.U.P.
MRKONJA's Avatar
Postovi: 2,277
A ti imaš vodeno na hardu:clap:
Govorim o konkretnom slučaju i hoću reči da temperatura komponente nemože biti jednaka sobnoj nikako
8 ventova u kompu:confused:
Koja je to buka
Staro 30.10.2005., 22:58   #25
Tao2
Tao2's Avatar
Postovi: 319
Ma uvijek dođe do te polemike na temu temperature.
A sve zato jer ljudi ne napišu u kakvim uvjetima sve skupa radi.
Jel komp stoji ispod stola, na stolu, otvoren, zatvoren, pritvoren,
temp sobna.
Vodeno?? pa kako je riješeno to?
Pasta?
Kako koji bios čita, itd....
Uglavnom milion stvari utiču na krajnji rezultat.
Možeš samo postat sliku, a ako čemo bit iskreni pa dodat i to kako je neko došao do krajnjeg rezultata to bi bilo to.
EDIT: ja sam recimo za ovu priliku prije slikanja upalio drugi vent
na kileru koji mi u pravilu radi samo po ljeti.
A sobna je trenutno 17
DFI LP ut-sli-D
Mema / neka
Staro 30.10.2005., 22:59   #26
Trek
Trek's Avatar
Postovi: 1,313
svi vi ikojima su diskov ispod sobne temperature (ako nisu haladnjeni vodom) niste puno pazili kad ste ucili fiziku drugog razred - termodinamiku... Predmet nemoze biti hladniji od svoje okoline ako otpusta toplinu sto disk radi. A da je hladniji od okolone onda bi okolina grijala njega kod ne poprimi JEDNAKU temperaturu okolini. Sobna temperatura je opci naziv za tempearturu okoline.
sto se tice mojih temp, svi koji su bili kod mene znaju da mi je kuciste gotovo necujno (cuje se porkleti seagate 7 al on je sad ugasen vecinu vremena )
ovo je idle sa ugasenim papstom 18dB na sonic toweru, NB cooler citat kao upuh a otraga je spojen na ispuhu papst na 700 rpm
full load, straznji fan jos puse na 750 rpm, OTES1 citat kao cpu (spojio sam na otes jer taj port abitica gasi kad je ispod "control temp") tamo je spojen papst 18dB koj je na 700 rpm jos uvijek necujan postaje cujan oko 900...
Sobna temp je 22*C
Biti lud ima prednosti koje razumiju samo ludjaci
FKT meber jednog dana high priest...
Trek je offline   Reply With Quote
Staro 30.10.2005., 23:14   #27
xmikex
Lokacija: split
Postovi: 58
@Tao 2 a ti imas pelt???...ili u tvom kompu ne vride zakoni fizike....okolina 17°c CPU 15°c??????
Staro 30.10.2005., 23:26   #28
Tao2
Tao2's Avatar
Postovi: 319
Nemam pelt.
Voda mi je trenutno hladnija od sobne temperature.
Kiler je veliki bakreni od nekakvog starog auta grijača kabine.
Smješten je u zasebno kućište skupa sa pumpom.
I može se reći da mi vodeno spada u oldtimere home made svoje vrsti. Radio sam ga prije 3/4 godine i još radi a ne bih ga mijenjao za ništa.
Blok je isto ručni rad.
Inače kiler hlade dva venta po ljeti. Jedan od 120 mm usis na 5v
a drugi na 12 isti takav upuhuje na full al samo kad idem u extremni clock za potrebe testiranja.
Sada sam, a spomenuo sam to uključio sve snage a u cilju da uslikam i postam ovu sliku gore.
A ponavljam, sobna mi je trenutno 17.
Mogu još otvorit prozor al to bi bilo fakat blesavo.
@KOVA
Ne vjerujem da se sjećaš sa teme vodenog još iz starog 2crowdeda prije par godina.
Riječ je bila o mojoj potopnoj EDEN pumpi.
Ne znam dal je za vjerovat, al još uvijek radi.
DFI LP ut-sli-D
Mema / neka
Zadnje izmijenjeno od: Tao2. 30.10.2005. u 23:50.
Staro 30.10.2005., 23:51   #29
xmikex
Lokacija: split
Postovi: 58
@Tao2 pa sta ima veze da ga hladis vodom-i voda se mora s necim hladit!-odnosno hladi se zrakom preko kilera....nije da sumnjam u tebe nego u tvoj bios ili software ili senzor koji ti pogresno ocitavaju temperaturu!...izmjeri temp zraka i vode istim termometrom pa se sam uvjeri...
a za ovo sto je nekima ista temp diska i okoline-to je nemoguce!...ali je moguce da je ta razlika jako mala ako se sami diskovi malo griju i dobro ga hladite pa je vasa temp okoline 27.0°c ,a disk 27.8°c sta naravno everest i ostala ekipa ne cita nego napise 27 i to je to-također senzori imaju odstupanja od +/-0.5°c-neki viseneki manje....
Staro 31.10.2005., 00:46   #30
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
evo upravo sam mjerio temperaturu u sobi... 14C....inace nemam grijanje u sobi pa si vi mislite....u zimi u sobi sjedim u jakni ...onak jednostavno mi se neda placati 1500kn svaki mjesec za grijanje... pa vam evo kak je moguce da mi je temperatura tak mala...po zimi mi proc zna biti na 20-25C
Logitech MX500
DELL 2007FP
Abit AV8
