Staro 22.06.2016., 05:19   #541
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,589
AMD RX 480 Already Available For Preorder, To Be In-Stock In Large Quantities At Launch Thanks To “Strong” Supply
AMD Radeon RX 480 Graphics Card Thermal Tests Leaked – 72C Maximum Temperature, Overclocking Capability Hinted
AMD RX 480 Overclocking Tool, Power & Noise Leaked In Chinese Stream – Embargo May Get Cut Short To June 24
The streamer measured the card’s power draw at idle, which was 14W. Gaming power draw was not measured during the stream. However, we’ve already discussed the card’s gaming power draw in our exclusive report which went out a few days ago. While gaming the card hovers around ~100, which is substantially less than the advertised TDP of 150W. In fact, because the card is equipped with a single six pin PCIe connector, 150W would be the card’s maximum power rather than what would be typically seen under a gaming load.
Staro 22.06.2016., 15:28   #542
Thundercool
Plebium
Thundercool's Avatar
Lokacija: Sisak
Postovi: 156
Joj sta mi rade, nalozio sam se na ovu kartu kao budala na treci kredit😁. A cak nisam niti siguran hocu li je moci iskoristiti na ovom stroju. Jao Radovane crni Radovane.......
Thundercool je offline   Reply With Quote
Staro 22.06.2016., 15:56   #543
ivosimec
Datum registracije: Jul 2014
Lokacija: Pojatno
Postovi: 613
promjeni cpu
ivosimec je offline   Reply With Quote
Staro 22.06.2016., 16:43   #544
Manuel Calavera
Postovi: 14,589
Ma nek puste recenzije 24.6. ionako sve leaka na sve strane. Ionako je to bolje nego pustit recenzije istoga dana kad dolaze u prodaju. Dobiju 5 dana marketinga
Staro 22.06.2016., 18:48   #545
windfucker
Nebitno, jer ionako će sve planuti k'o šibice.
Jedino ako ispliva kakav megapropust, u što čisto sumnjam...
Ukratko, mislim da oni itekako pametno igraju ovaj put i da ništa od viđenoga nije slučajno... Leak my a$$ kada su milijarde u igri
Staro 22.06.2016., 18:54   #546
Manuel Calavera
Postovi: 14,589
Kako nije lekano kad osim recenzenata i kojekakvi shopovi/uvoznici, kao vendori imaju grafe tjednima
Staro 22.06.2016., 18:58   #547
windfucker
Pa to i kažem
"Leak"= uz blagoslov i dobro promišljen tajming koliko čega od informacija i točno kada
Staro 22.06.2016., 19:02   #548
Manuel Calavera
Postovi: 14,589
Mislim da AMD, nvidia itd. ne mogu to baš toliko kontrolirati. Jednostavno im previše ljudi ima pristup, a nisu to baš toliko ozbiljne stvari (kao vojne tajne), nego komadi hardvera na kojima će ljudi igrati igre tako da ono... Tj. nema tu one neke prave represije kojom bi to spriječili. I kad leaka uvjek ima rezerva "dali je čru"
Staro 22.06.2016., 19:21   #549
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,062
Nije da je toliki Bn Phenom II X6,ekipa redovno uparuje FX 6300 sa R9 380/380x i opet se dobro slazu u vecini igara,a FX 6300 nije bogzna sto bolji naspram Phenom II X6
Pricekaj RX 480,trebala bi biti do 2K cim se smire cijene malo ili R9 380X,no njoj ce cijena pasti dobrano pa je takoder neisplativa kupnja.
Staro 22.06.2016., 19:28   #550
windfucker
@Manuel: A dobro sad... Nitko od nas ne može znati 100%, no s obzirom na ono što je izvjesno (lova u igri i napokon winner u AMD-ovome rukavu), sve što "curne van" mislim da je (najmanje) uz prešutno odobravanje... Uglavnom, sve u službi marketinga koji i bez onih 5 dana itekako radi svoj posao
Staro 22.06.2016., 19:49   #551
Manuel Calavera
Postovi: 14,589
Izgleda da je većina curenja iz xfx-a. Ma ionako se otprilike zna kakva je. Otvorena pitanja su kakav je stock cooler i kakvi su aftermarket modeli
Staro 22.06.2016., 19:54   #552
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,727
Navodno su im driveri u komi, nije ni čudo da odugovlače:
http://videocardz.com/61340/amd-rade...-rumors-part-4
Staro 22.06.2016., 20:03   #553
MikaHR
Postovi: 1,264
Pa svi "leakovi" su na starim drajverima.
a ono, daj ti reci kinezima da ne leakaju ;P
MikaHR je offline   Reply With Quote
Staro 23.06.2016., 02:52   #554
MikaHR
Postovi: 1,264
Staro 23.06.2016., 09:16   #555
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,580
Staro 23.06.2016., 09:51   #556
Mladenxy
Mladenxy's Avatar
Postovi: 4,479
Joj kad se to začepi prašinom . Aj vadi ju van, odšarafi poklopac da bi očistio, pa vračaj sve nazad. Pitanje je gubiš li garanciju skidanjem poklopca. Super kartica za super cijenu ali ne sviđa mi se ovaj dio oko čišćenja. Trenutna XFX me jako razmazila po tom pitanju.
Staro 23.06.2016., 09:59   #557
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,580
Sta se zacepi? Izvadis grafu, drzis rukom vent i od venta prema van ispuhujes kompresorom i izadje sve. . A i ti na xfxu mozes skinut ventove i sto onda? Opet finove sa kulera moras ispuhat kompresorom da se rijesis naslaga fine prasine.
Staro 23.06.2016., 10:02   #558
Mladenxy
Mladenxy's Avatar
Postovi: 4,479
Ma kakv kompresor, penzla za 10 kn na deset godina i očistiš ju ko iz tvornice u roku od par minuta. Ali OK, ako netko ima kompresor onda mu nije problem ovakav hladnjak, ali nemaju svi kompresor. Rekao bih da ga nema skoro nitko Komprimirani zrak u onim malim sprej bocama su smješno loši za takva čišćenja...
I kak misliš kaj se začepi? Imao sam referentnu 3850 i jako dobro znam kaj se začepi i kako to onda radi.To mi je bila zadnja referentna.
Staro 23.06.2016., 10:11   #559
scarzz
scarzz's Avatar
Lokacija: Stuttgart/Rijeka
Postovi: 414
Heatsink je vrhunski
scarzz je offline   Reply With Quote
Staro 23.06.2016., 10:18   #560
Sam Fischer
Džabe si krečio!
Sam Fischer's Avatar
Postovi: 5,191
Autor scarzz Pregled postova
Bit će da mu netreba bolji xD
Ali nekako ne ulijeva povjerenje, vidit ćemo što će board partneri ponuditi
Staro 23.06.2016., 10:20   #561
goc_mails
low_rider
goc_mails's Avatar
Postovi: 487
Bas komentiram s kolegom...netko se popiknuo na kutiju punu starih stock coolera od athlona i reko taman za nove grafulje
A bu bu....
goc_mails je online   Reply With Quote
Staro 23.06.2016., 10:30   #562
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,580
Pa tko jos penzlom cisti graficku ? Kakva penzla. I imas kompresor. uzmes komp i odes na benzinsku, nije valjda da je i to problem.
Staro 23.06.2016., 10:32   #563
Mladenxy
Mladenxy's Avatar
Postovi: 4,479
Kad si zadnji puta bio na benzinskoj? Kod mene u gradu sve su automatizirane i rade samo kad staviš mlaznicu na ventil kotača. Zašto ne bi čistio penzlom kada je to najjednostavnije, najefikasnije i najjeftinije čišćenje? Zašto bi kupovina kompresora bila nužna za nešto tako jednostavno ako se malo pogleda dostupni hardver?
Staro 23.06.2016., 10:42   #564
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,416
+1, sve automatski.
A ako je penzla isto sto i pinel, e onda i ja tako sve cistim, fino rastavim, dobro ''ocetkam'' i usisem sa usisivacem
EDIT:
Penzla=Pinel
Slobodno me dodajte na PSN
Staro 23.06.2016., 10:48   #565
scarzz
scarzz's Avatar
Postovi: 414
Staro 23.06.2016., 10:50   #566
Nick7
Lokacija: Velika Gorica
Postovi: 1,537
Komprimirani zrak u bocicama je zakon.
Izvrsno ispuse svu prasinu.
Nick7 je online   Reply With Quote
Staro 23.06.2016., 11:14   #567
Mladenxy
Mladenxy's Avatar
Postovi: 4,479
Prvo ne namjeravam plaćati za zrak a drugo penzla/kist/pinel to napravi bolje. Tu je i onaj kondezat koji se stvori kada pušeš iz te boce a čepove prašine buš ispuho, ono moš si mislit. Jedino ako to koristiš svaki tjedan .
ali tko voli samo naprijed, ja znam da u moj komp takvi hladnjaci više nikada.
Staro 23.06.2016., 11:19   #568
Nick7
Postovi: 1,537
Ja koristim mozda jednom godisnje, kad je fini sloj prasine preko hladnjaka CPU-a, a na grafi bas i nema puno prasine cak nakon godinu dana. No sve super ispuse, i nikad imao problema da sto ostalo.
E, da.. ja koristio ovaj: http://www.chipoteka.hr/artikl/18872...k-malkem-400ml
Staro 23.06.2016., 11:41   #569
Brlja
Postovi: 874
Nadrukam kompresor na 10 bara. Ima da rupe buši na matičnoj. Samo kondenzatori lete na sve strane.
Brlja je offline   Reply With Quote
Staro 23.06.2016., 11:44   #570
scarzz
scarzz's Avatar
Postovi: 414
Bar frend nije **ebo cooler od cpua i 1 od kucista sa kompresorom )
Treba ih drzat fiksirane ili ode leziste ...
