Staro 10.08.2014., 23:01   #2011
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,529
Detected CPU: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz [GenuineIntel], F6/M10/S7, 3294.00 mhz, 23-clk 'rdtsc'
* CPU features: RDTSC, MMX, SSE, SSE2, SSE3, MONITOR/MWAIT, SSSE3, SSE4.1, SSE4.2
* CPU threads: 4
Initializing File System...
using fs-ltx fsgame.ltx
FS: 50244 files cached 29 archives, 10495Kb memory used.
Init FileSystem 1.674300 sec
'xrCore' build 3967, Dec 14 2009
EH: 3CAABCFCFF6F3A810019C6A72180F166
-----loading c:\program files (x86)\bitcomposer games\s.t.a.l.k.e.r. - call of pripyat\gamedata\configs\system.ltx
Initializing Engine...
Starting INPUT device...
Loading DLL: xrRender_R2.dll
Loading DLL: xrRender_R3.dll
refCount:m_pAdapter 1
Loading DLL: xrRender_R4.dll
command line
Executing config-script "user.ltx"...
[c:\users\public\documents\s.t.a.l.k.e.r. - call of pripyat\user.ltx] successfully loaded.
Loading DLL: xrRender_R1.dll
Loading DLL: xrGame.dll
! Player name in registry is empty! (InstallUserName)
* [win32]: free[3966228 K], reserved[90724 K], committed[137288 K]
* [ D3D ]: textures[0 K]
* [x-ray]: crt heap[16402 K], process heap[4490 K], game lua[0 K], render[0 K]
* [x-ray]: economy: strings[7586 K], smem[0 K]
SOUND: OpenAL: enumerate devices...
SOUND: OpenAL: EnumerationExtension Present
dir[0]=C:\Program Files (x86)\bitComposer Games\S.T.A.L.K.E.R. - Call of Pripyat\bin\
dir[1]=C:\Program Files (x86)\bitComposer Games\S.T.A.L.K.E.R. - Call of Pripyat\
dir[2]=C:\Program Files (x86)\bitComposer Games\S.T.A.L.K.E.R. - Call of Pripyat\bin\
dir[3]=C:\Windows\system32\
CleanDeviceSpecifierList
CleanDeviceSpecifierList Generic Hardware
devices Generic Hardware
SOUND: OpenAL: system default SndDevice name is Generic Hardware
SOUND: OpenAL: default SndDevice name set to Generic Software
SOUND: OpenAL: All available devices:
1. Generic Software, Spec Version 1.1 (default) eax[0] efx[no] xram[no]
2. Generic Software, Spec Version 1.1 (default) eax[0] efx[no] xram[no]
Executing config-script "c:\program files (x86)\bitcomposer games\s.t.a.l.k.e.r. - call of pripyat\gamedata\configs\default_controls.ltx"...
[c:\program files (x86)\bitcomposer games\s.t.a.l.k.e.r. - call of pripyat\gamedata\configs\default_controls.ltx] successfully loaded.
Executing config-script "c:\program files (x86)\bitcomposer games\s.t.a.l.k.e.r. - call of pripyat\gamedata\configs\rspec_default.ltx"...
[c:\program files (x86)\bitcomposer games\s.t.a.l.k.e.r. - call of pripyat\gamedata\configs\rspec_default.ltx] successfully loaded.
~ Invalid syntax in call to 'r2_aa_break'
~ Valid arguments: vector3 in range [0.000000e+000,0.000000e+000,0.000000e+000]-[1.000000e+000,1.000000e+000,1.000000e+000]
~ Invalid syntax in call to 'r2_aa_weight'
~ Invalid syntax in call to 'sv_adm_menu_ban_time'
~ Valid arguments: ui_mp_am_10_minutes/ui_mp_am_30_minutes/ui_mp_am_1_hour/ui_mp_am_6_hours/ui_mp_am_1_day/ui_mp_am_1_week/ui_mp_am_1_month/ui_mp_am_3_monthes/ui_mp_am_forever
SOUND: Selected device is Generic Software
* sound: EAX 2.0 extension: absent
* sound: EAX 2.0 deferred: absent
* sound : cache: 65537 kb, 4856 lines, 13820 bpl
Starting RENDER device...
* GPU [vendor:1002]-[device:679A]: AMD Radeon HD 7900 Series
* GPU driver: 8.17.10.1299
* CREATE: DeviceREF: 1
* Vertex Processor: PURE HARDWARE
* Texture memory: 4072 M
* DDI-level: 9.0
* GPU shading: vs(fffe0300/3.0/30), ps(ffff0300/3.0/30)
* GPU vertex cache: unrecognized, 16
* NVAPI is missing.
* Starting rendering as 2-GPU.
* DVB created: 1536K
* DIB created: 512K
FATAL ERROR
[error]Expression : file_handle_internal(file_name, *buffer_size, file_handle)
[error]Function : FileDownload
[error]File : D:\prog_repository\sources\trunk\xrCore\FS.cpp
[error]Line : 169
[error]Description : can't open file :
[error]Arguments : c:\program files (x86)\bitcomposer games\s.t.a.l.k.e.r. - call of pripyat\gamedata\textures\item\item_?4.thm
stack trace:
Eto proba sam opet taj 1.07 pa i 1.05 i također mi kreša kao i prije kad san proba sva tri i zakljucija postat 1.02 koji je igriv...(1.07 kreš od maloprije)
* CPU threads: 4
command line
* DDI-level: 9.0
* NVAPI is missing.
* DIB created: 512K
FATAL ERROR
[error]Line : 169
stack trace:
Staro 11.08.2014., 03:51   #2012
Bakica47
Bakica47's Avatar
Datum registracije: Nov 2012
Postovi: 249
FATAL ERROR
[error]Line : 169
Taj kreš (ustvari ne možeš ni u igru) sam rješio. Povezan je sa teksturom eksploziva C4. Ako želiš, samo mi daj neki link, mogu ti poslati ispravak. Ja sam jučer odigrao cijeli mod, ustvari napravio sam si kombinaciju sva 3 patcha, ali samo u vezi oružja i tekstura. Mod mi je bio strašno zanimljiv, ali nažalost nema freeplaya. Zadataka dosta i zanimljivih, mape stare ali izmjenjene (na bolje). Npr. ispod bara ima vjerojatno oko 1000 kvadrata - hodnici, prostorije, da sam se u jednom trenutku i izgubio. Dva zanimliva laba, nova frakcija Spektrum. Što se prijevoda tiče (dosta sam već preveo na hrvatski) ako se i uzme eng text dosta toga će biti na ruskom, jer 10-20% nije u folderu text nego razbacano po mnogim skriptama. Da ne zaboravim, cijelu igru sam odigrao na high postavkama uz dinamičko osvjetljenje DX11 bez ijednog kreša, smrzavanja i sl.
Sjetio sam se Jumbo maila. Mogu poslati preko njega. Ako želiš pošalji u privatnoj poruci email adresu.
Zadnje izmijenjeno od: Bakica47. 11.08.2014. u 04:04. Razlog: dopuna
Bakica47 je offline   Reply With Quote
Staro 30.09.2014., 10:27   #2013
kasper_sky
Drive. vruummm,shatatataa
kasper_sky's Avatar
Lokacija: 1.Rijeka-2.VG-3.Zg
Postovi: 779
malo da dignem temu iz mrtvih
uhvatio nešto vremena instaliro nove win i ssd pokreno stalkera sa misery modom i igra leti i ne ruši se.
btw ako tko igra misery pošto sam tek počeo zanima me čime se najviše isplati bavit u startu da se love malo nabere. jer sve je skupo a love nigdje
i dali kad kupim opremu za kuhanje pečenje mesa od mutanata dali se kasnije makne radijacija ili ostane kad je meso pečeno?
živili
kasper_sky je offline   Reply With Quote
Staro 12.12.2014., 15:47   #2014
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,062
Sa moba pisem pa mi problem copy/paste teksta,uglavnom radi se crowfunding za STALKER Apocalypse,spiritualni nastavak STALKER serijala
http://www.pcgamer.com/areal-devs-ar...er-apocalypse/
EDIT : sad koliko vidim to je rip-off originalnog S.T.A.L.K.E.R-s samo pod imenom STALKER da ne bude tuzbi oko plagijata tako da u biti igra pravljena od ljudi iz bivseg GSC game world studija samo pod drugim imenom...
Zadnje izmijenjeno od: blava. 12.12.2014. u 16:46.
Staro 12.12.2014., 17:13   #2015
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Lokacija: 00001
Postovi: 2,529
lol pa to su oni isti likovi sta su na Areal pokupili lovu scameri nista vise od toga.
Staro 14.12.2014., 02:27   #2016
exzzy
exzzy's Avatar
Datum registracije: Aug 2014
Postovi: 844
imate stalkere na bundlestarsu na akciji ako vas zanima
exzzy je online   Reply With Quote
Staro 21.12.2014., 21:41   #2017
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Lokacija: 00001
Postovi: 2,529
http://www.gamesindustry.biz/article...roud-ukrainian
GSC ziv ozivio ?? ma neman pojma vise ,ali svida mi se ovo dolje receno o FTP i dobnoj granici na koju su se amo reci fokusirani sa mogucima nadolazecima projektima .
Staro 22.02.2015., 13:45   #2018
Nakon 2 godine, skinuo sam CoP sa Steama, stavio Complete i krenuo... fakat se je lijepo vratiti u Zonu Čisto da vidim jel sam zahrđao... malo jesam, ali nema veze. No, još uvijek znam di se što nalazi
Staro 22.02.2015., 14:48   #2019
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,062
I ja taman krenio nakon pauze od 5-6 mjeseci Misery sa najnovijim updateovima.
Btw.zna li netko di se nalaze saveovi od Miseryja ? Imam otprije sacuvano pa bi nastavio di sam stao,a ne mogu naci ni u Public Documents,svugdje sam trazio u Users folderu.
I kako se rijesiti stutteringa,igra ide fluidno na +60 FPS,ali stuttering i lag svakih 5 sekundi ubija volju za igranjem...
Staro 23.02.2015., 01:01   #2020
Bakica47
Bakica47's Avatar
Postovi: 249
[QUOTE=blava;2740215]
Ako nije preko steama sejvanje COP-a je uvijek u c:Users\Public\Documents\S.T.A.L.K.E.R. - Call of Pripyat\savedgames Preko steama ne znam gdje je jer nisam nikad tako igrao. Da nisi izbrisao kompletan COP i nanovo instalirao pa ti je sve izbrisano?
Staro 23.02.2015., 15:06   #2021
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,062
Nasao sam ih,bili su na primarnoj particiji pod misery,prebacio prijasnje i super radi,ali opet crasha kad hocu prihvatiti zadatak novi od znanstvenika u bunkeru
I zastajkuje svakih 5 sekundi i to na 3-4 sekunde,neigrivo jednostavno.
Staro 14.04.2015., 18:12   #2022
iprodano
Datum registracije: Jul 2009
Lokacija: Osijek, Hrvatska
Postovi: 227
Molim vas za pomoć, imam nezgodan problem s bacačem granata.
Znači tijekom pola igre potpuno normalno su prianjali na puške da bi negdje tijekom igre se nešto poremetilo i sada bacači granata jednostavno grafički više ne liježu direktno na pušku nego ima nekoliko centimetara razmaka.
Molim da tko zna o čemu se radi i kako se to može ispraviti.
Da napomenem da igram OWR (Original Weapons Renewal) mod te da prije ili tijekom igre nisam ništa mijenjao ili dirao, pogotovo kad je pola igre sve bilo u redu.
Hvala unaprijed.
iprodano je offline   Reply With Quote
Staro 15.04.2015., 20:06   #2023
Moto001
Moto001's Avatar
Datum registracije: Sep 2014
Lokacija: Slavonija bajnaaaaa
Postovi: 237
Vjerojatno neki "bug" kao po običaju u inim modovima jer se znalo događati da igra super radi i skoro na kraju blokira ili neko njesra i nema kraja jbg. tako je to u serijalu Stalkera nažalost ini broj puta sam odustajo od raznih modova iz tog razloga.
Moto001 je offline   Reply With Quote
Staro 26.04.2015., 15:03   #2024
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Lokacija: 00001
Postovi: 2,529
Autor iprodano Pregled postova
Hvala unaprijed.
Cini mi se da je modu nesto pobrkano PM Bakicu da pokusa rijesit taj fajl pronaci i popravit ga mislim da je on dosta strucan sta se toga tice
Staro 29.09.2015., 21:49   #2025
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Lokacija: 00001
Postovi: 2,529
freeplay /sandbox koji ide na COP ,skidam tek ima tu sve informacije ako koga zanima.
http://www.moddb.com/mods/call-of-chernobyl
Staro 29.09.2015., 22:01   #2026
Konačno izašlo... budemo malo to oprobali u sljedećim danima. Šteta što nije neki story mod nego je freeplay. Al dobro, budemo se ganjali malo sa živinama i banditima.
Staro 01.10.2015., 11:20   #2027
Moto001
Moto001's Avatar
Postovi: 237
Evo instalirao i isprobao igru, igrao nekih 1-2h i bogme igra je dosta teža u odnosu na ostatak serijala na postavkama Stalker, isprobao malo i na najtežim postavkama i bogme sam odustao dok neprođem na manjoj težini igru, a bogme i to će potrajati jer su mape nepregledne i ima ih iz sva 3 serijala u jednom.Ima opcija biranja frakcija s kojim krećete u igru(loner,duty,bandit i dr.) pa koji izaberete tako se i provodite u istoj te sve osim Lonera dodatno stvara više neprijatelja i prilika da zaginete kad se i najmanje nadate jer frakcije su svuda porazbacane.
U ovoj igri nema namještanja postavki težine i osuđeni ste na 50kg barem ako igrate kao Loner pa tako dobivate i odijela tj. oružja i sve ostalo od najslabijeg pa nadalje..... Evo igre za prezimiti i ubiti vrijeme.
Pa nek gejmanje počne
Staro 01.10.2015., 12:59   #2028
kasper_sky
kasper_sky's Avatar
Postovi: 779
zanimljivo
prije nego što počnem skidat pitanjce imali u igri hardcore mod.
kao metak i bok ili moram okvire ispraznit?
Staro 01.10.2015., 14:12   #2029
Napisao je da ima Stalker postavka jel može teže ?
Staro 01.10.2015., 19:22   #2030
Moto001
Moto001's Avatar
Postovi: 237
Ima 4 razine ako se dobro sjećam Rokie,Stalker,Veteran,Master zadnjeg probao i odustao jer je doslovce 1 metak/smrt, a ako te napadne ina gamad zaboravi brzo trčanje i većinom slijedi "smrt" pa savjetujem ipak prvo prelazak na Stalker opciji dok se neupozna teren i sve opcije.Ovo je ako se igra sa opcijom Loner s kojom sam poćeo jer svaka frakcija ima svojih mana i više neprijatelja ali sve piše kod odabira, s kim si prijatelj,neutralan ili neprijatelj te što se dobije po početku igre od opreme, pa navali narode.......
Staro 01.10.2015., 23:15   #2031
Pardon, Master je najjača... eto. Godinu dana nisam igrao i već hlapi
Staro 02.10.2015., 22:45   #2032
Moto001
Moto001's Avatar
Postovi: 237
kad se igra instalira i pokrene pa odabere frakcija s kojom se želi započeti igrati i podese sve opcije glede atmosferskih prilika po volji/želji, onda se na ikonu za pokretanje klikne desnim klikom i ode na properities te u nastavku iza exe. napravi razmak i doda sljedeće -dbg i spreme postavke nanovo pokrene igra i stisne esc te stisne slovo S na tipkovnici dobiju sve ostale opcije podešavanja
Isprobati pod obavezno ima zanimljivih opcija i podešavanja te igra postane zanimljivija i lakša, ali ovo je već bilo i ranije u nekim modovima i nije ništa novo samo se trebalo malo njuškati po netu i forumima.
Evo nakon 5-6h igre i istraživanja i prevođenja po netu ipak se u igri može dosta toga namjestiti tj. može se samostalno odabrati opcije glede oružja,odjela i dr. stvari koje se pojavljuju u igri na sljedeći naćin:
Staro 06.11.2015., 12:49   #2033
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Lokacija: 00001
Postovi: 2,529
Vracam se na Spectrum project/Put u Magli
Pošta ga je naš Bakica ljepo sredio i preveo na naški ja cu vam stavit link a vi cete igrat jeli ko nije jel tako
https://mega.nz/#F!4RECnSyS!05hCFD6pqjWVYJ1EYPpoPA
Znaci ide na CoP 1.6.0.2 verziju ,ima te sve ljepo u tekstu objasnjeno ako negdje zapnete imate i ss .
gamdata te bin folder prebacit gdje je cop instaliran.
https://www.youtube.com/watch?v=gJQikyIkH2M
ovaj je to jel malo gameplay da ne skidate bzvz ako vam ne pase.
edit: fixd link
Zadnje izmijenjeno od: Tajl3r. 16.11.2015. u 19:24.
Staro 14.11.2015., 21:51   #2034
zippo
herr Flick
zippo's Avatar
Postovi: 2,085
ima li koji drugi link na mod ?
Ja na tom dobijem da je mapa prazna
.:S:T:A:L:K:E:R:.. :2 u ocekivanju
nema vise zippacha ......
zippo je offline   Reply With Quote
Staro 08.04.2016., 17:16   #2035
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Lokacija: 00001
Postovi: 2,529
https://www.bundlestars.com/en/bundl...ndle%20stalker
jeli ko vec nije da iskorsti priliku
Staro 08.04.2016., 17:24   #2036
John Creasy
Vocna iglica u mudante
John Creasy's Avatar
Lokacija: Beograd
Postovi: 2,838
nije više dostupan bundle, šteta
Staro 15.05.2016., 13:49   #2037
Mate666
Datum registracije: May 2014
Postovi: 24
Tesko se snalazim sa ovim misery modom. Poginem a pojma nemam ni od cega, jer su mi oni znakovi upozorenja premaleni. Ima li neki guide, potreban je jer je dosta toga ubaceno a o pojacanju tezine i da ne govorim. Hardcore u punom smislu te rijeci.
Mate666 je offline   Reply With Quote
Staro 16.05.2016., 10:35   #2038
kasper_sky
kasper_sky's Avatar
Postovi: 779
rikno si od male radijacije. i gladi i žeđi, znači ako igraš na težoj razini neznam kakv HUD imaš ali na lakšoj ti prikazuje tvoj helth koji brzo pada ako stalno trčkaraš ma i obično gibanje. a hrana i cuga je skupa ko vrag. ako rokneš tablete opet si gladan... i tako u krug.mislim da dok nenabaviš tj. kupiš skupo odijelo koje ti stalno regenerira tvoje zdravlje... ili neki kamen arifekt... do tada buš se krpal.
Staro 16.05.2016., 14:32   #2039
Mate666
Postovi: 24
Nisam od radiacije i hrane sigurno jer sam popio tablete i pojeo nesto. Mozda trovanje, strange phenomenom misija, otrovao se kraj olupine broda. Moram restartat jer sam do tada samo quicksave-o, greska fatalna.
Nema veze, shvatio sam da misery nije sala, sada cu je igrat 100% skoncentriran.
Staro 16.05.2016., 16:28   #2040
Postovi: 10,369
Autor Mate666 Pregled postova
Bit će da si pokvario želudac
