		#245 |
			 Gamer
			Datum registracije: Apr 2014
				Lokacija: Dusseldorf
					Postovi: 43
		#248 |
					Postovi: 1,625
		 Jedno brzinsko pitanje: stavio sam si ove crimsone. E sad, gdje mi je nestalo ono podešavanje ekrana ? Tipa da mogu desni klik na telku i disable itd. I staviti telku lijevo umjesto desno od monitora itd. To je prije bilo pod my digital flat panels. Sad je tamo nešto drugačije :O
		#250 | |
			 Zmaj od Bosne
			Datum registracije: Dec 2011
					Postovi: 218
 Ideš u Crimson-u Display > Additional Settings(gore u desnom kutu) i onda ti se otvori My digital Flat-Panels i još opcija.
	 RIP Šaban (21.6.2016)
		#254 |
			 Zmaj od Bosne
					Postovi: 218
		 Nije dugo prošlo i evo nam novi 16.3.2 driver. AMD RSCE 16.3.2 Link za Windows 10 64-bit Radeon Software Crimson Edition 16.3.2 Highlights Support for: Oculus Rift™ SDK v1.3 HTC Vive™ AMD Radeon™ Pro Duo Updated Crossfire Profiles available for: Everybody's Gone to the Rapture™ Hitman™ in DirectX®11 Resolved Issues Counter-Strike™: Global Offensive fails to stretch on non-native display aspect ratios. As part of the new Display Scaling per game feature, users can set "GPU Scaling" to "On" and "Scaling Mode" to "Full Panel" in the Display options tab in Radeon™ Settings as well as setting "Display Scaling" to "Full Panel" in their CSGO gaming profile under the "Gaming, Profile Options" tabs for this to take effect. AMD Radeon™ Fury Series may experience corruption on desktop when system is idle for an extended period of time. FFXIV can experience black screen or experience an application hang. XCOM2™ may experience minor stutter while the camera is panning around a scene. Radeon™ Settings check for software update may not display the latest available driver. Known Issues A few game titles may fail to launch or crash if the AMD Gaming Evolved overlay is enabled. A temporary workaround is to disable the AMD Gaming Evolved "In Game Overlay" Need For Speed™ may experience poor scaling or flickering in AMD Crossfire™ mode. As a work around users can disable the profile through the Radeon™ Settings game manager. The Division™ may experience flickering in AMD Crossfire™ mode. Power efficiency toggle in Radeon™ Settings is showing up for some unsupported products. DOTA2™ may experience game menu flickering when entering full screen mode with AMD Crossfire™ enabled. League of Legends® may experience some graphical corruption on characters death animation in AMD Crossfire™ mode. XCOM2™ users may experience an application crash when using AMD Crossfire™ mode. As a work around please disable AMD Crossfire™ for the games profile in the Radeon™ Settings Gaming tab. Hitman™ may experience flickering when played in DirectX™ 11 mode. As a work around users are recommended to either set the game to DirectX™ 12 mode in the games settings launcher or simply set “Shadow Resolution” to “Low” in the game settings. Lijep pozdrav Ekspertima ![]()
		#256 | |
				Lokacija: スラボニア
					Postovi: 3,061
 ![]() Ja sam mislio da ti imas HD 7990. Vidim imaju dvije verzije,beta nekakva,nadam se da nece sprziti graficku ko prijasnje bete ![]()  |
		#257 | |
			 Gamer
					Postovi: 43
 brate iskreno ja neam pojma sta ja imam buni me stalno 7990 i 8990 negdje pokazuje ovako negdje onako kupio sam polovan komp na brzaka toliko je sve to bilo brzo da nisam nimalo pazio platio 800 eura sve zajedno sto stoji pod moj komp... danas imam slobodan dan driveri staviti u 9:00am i dosad nije bio niti jedna tekstura izoblicena dok na svim prijasnim driverima je bilo katastrofa ![]()  |
		#258 |
			 Džabe si krečio!
					Postovi: 5,190
		 Ali ti imaš dvije takve    Daj slikaj kako to izgleda u kućištu ako ti se da ![]() Multi GPU sustavi su pain in the ass kad se radi o driverima, sutteringu, texture glitchevima, etc... A ti imas 4 GPU-a ![]() Probaj naći nekakvu formulu gdje je sve stabilno, pa nemoj više dirati previše. Jesi probao disable-ati ULPS? I naravno, uvijek imaj u pozadini otvoren GPU-Z kako bi mogao imati monitoring i pratiti što se događa sa svim ti silnim GPU-ovima ![]()  |
		#261 |
			 Gamer
					Postovi: 43
		#266 |
			Datum registracije: Aug 2013
					Postovi: 268
		 A ne citam bas Internetove tako detaljno, ja samo znam da je sve radilo prije nego li sam stavio novi Crimson, dakle on je kriv  ![]() Ni Sherlock Holmes ne bi drugacije deducirao ![]() Thnx na tipu, sad sam nabrzinu progulao i instalirao alternativni flash player za youtube, za sad raci, nemam volje ni vremena dublje ulaziti u to.  |
		#267 |
			 Zmaj od Bosne
					Postovi: 218
		 AMD RSCE 16.4.1 Radeon Software Crimson Edition 16.4.1 Highlights Support for: Quantum Break™ Upto 35% faster performance using Quantum Break™ on Radeon™ R9 Fury X than with Radeon™ Software Crimson Edition 16.3.2(1). Oculus Rift™ HTC Vive™ Resolved Issues Frame rate capping issues experienced in some DirectX®12 applications is resolved. Hitman™ may experience flickering when played in DirectX® 11 mode using high game shadow settings. Known Issues A few game titles may fail to launch or crash if the AMD Gaming Evolved overlay is enabled. A temporary workaround is to disable the AMD Gaming Evolved "In Game Overlay" Need For Speed™ may experience poor scaling or flickering in AMD Crossfire™ mode. As a work around users can disable the profile through the Radeon™ Settings game manager. The Division™ may experience flickering in AMD Crossfire™ mode. Power efficiency toggle in Radeon™ Settings is showing up for some unsupported products. XCOM2™ users may experience an application crash when using AMD Crossfire™ mode. As a work around please disable AMD Crossfire™ for the games profile in the Radeon™ Settings Gaming tab. Some DX9 applications cannot disable AMD Crossfire™ mode through Radeon™ Settings. A small subset of AMD Radeon™ R9 380 users may be experiencing slower than expected fan speeds. A work around is to raise your fan speeds through AMD Overdrive in Radeon™ Settings manually to a desired amount. HDMI Scaling options may not be available in Radeon™ Settings on some system configurations. ![]()
		#269 | |
			 Gamer
					Postovi: 43
 nije to samo kod hitmana kod dosta igri se to desava,zalosno al istinito wow,league of legends,nfs,gw2 i da nenabrajam... realno support crossfirex 70 % pokriven vise stete donosi nego koristi a sad na posao ![]() ![]()  |
		#270 |
		 Zadnje izmijenjeno od: trpi. 10.04.2016. u 23:12.  |
