M.U.P.
Datum registracije: Sep 2004
Postovi: 2,277
Catalyst 5.10
Evo novosti: "The following section provides a summary of the issues that have been resolved in the latest version of Catalyst™. These include: 3Dmark03: Setting the display resolution to 1024x768 32bbp and having Anti-Aliasing set to 6x no longer results in Windows crashing when running 3Dmark03 Mother Nature test Dungeon Siege 2: The cursor image is now displayed properly when playing the game under Windows XP with an ATI Radeon® X800 series installed Graphedit: Watching and listening to audio/video using the composite input found on the ATI Radeon® X300/X600 no longer results in the left and right audio being swapped Max Payne 2: Erratic mouse pointer behavior is no longer noticed within the game's menu after a short time period of game play Pacific Fighters: Setting the display device to 1024x768 32bpp and enabling Anti-Aliasing to 6x no longer results in display corruption being noticed within the game Prince of Persia: Sands of Time: Attempting to launch the game under Windows with an ATI Radeon® X800 XL installed no longer results in an error message being displayed Silent Hunter 3: Enabling all video options within the game and setting the particle density to 100, along with setting Anti-Aliasing to 6X and Anisotropic Filtering to 16x, no longer results in display corruption on the left portion of the display Stronghold 2: Attempting to launch the game under Windows XP Professional x64 edition no longer results in the game failing to load and the operating system rebooting itself The German language control panel text no longer appears truncated when using 96 DPI Overlay Theater Mode no longer fails to be applied on the secondary display device when using extended desktop mode Catalyst™ Control Center: Entering the Adjustments page and deselecting the option to Let the Application Decide no longer results in the Hue value not changing when moving the slider bar Connecting two display devices to the ATI Radeon® X300/X600 no longer results in the Overlay Theater Mode failing to be applied to the primary display device Attempting to toggle between the CRT and TV using ALT+F5 shortcut no longer fails The red/blue components are no longer intermittently swapped when rendering images with OpenGL based Java 2D pipeline IBM DFP BN68-30012B-06: Connecting the display device to an ATI Radeon® X300/X600 no longer results in display corruption being noticed after the installation of the ATI display driver The ATI Radeon® X850 Pro is now properly identified in the Display Properties Attempting to enabling clone mode under Windows XP MCE while watching TV in a windowed mode no longer results in the operating system crashing Using a PAL version of the Microsoft operating system (XP, or XP MCE) no longer results in the region being switched from PAL to NTSC when clicking the video list found in the tuner tab of the TV function of the ATI MMC The FM seek function found in the ATI MMC no longer operates the same as the tune function when using an ATI All-in-Wonder X800 (PAL) under the Windows XP MCE operating system" Sad sam skinuo pa ću javit rezultate Download |
Postovi: 18,843
A šta je sa Far Cryem i Battlefieldom 2?
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
ATI Catalyst 5.10 Performance Analysis
Caught Somewhere In Time
Datum registracije: Oct 2002
Lokacija: zg-vrbani, vž u srcu
Postovi: 1,860
a kaj je s X1000 serijom??? ovi driveri je ne podržavaju?? kaj ako kupim X1800XL a nemam službene drivere? |
#5 | |
Super Moderators
Postovi: 17,485
#6 | |
Postovi: 1,860
to su zasrali opako |
#7 | |
Super Moderators
Postovi: 17,485
Mislim-jaka muda na netu doći do drivera ![]() |
