Staro 13.01.2016., 23:14   #871
dur
dur's Avatar
Datum registracije: Feb 2015
Lokacija: Zgb
Postovi: 75
A s koje mreže pokušavaš poslat?
dur je offline   Reply With Quote
Staro 13.01.2016., 23:21   #872
memory
Datum registracije: Apr 2015
Postovi: 5
http://wakeonlan.me/
Forvardirao sam UDP port 9 na routeru ali ništa.
Jel ovo čudo podržava uopće broadcast adresu?
memory je offline   Reply With Quote
Staro 14.01.2016., 00:38   #873
dur
dur's Avatar
Lokacija: Zgb
Postovi: 75
Koliko je meni poznato port forward ne radi s broadcast adresom.
Staro 14.01.2016., 00:51   #874
_saiko
system kaiser
Postovi: 194
Tzv directed broadcast koji tebi treba se u principu ne rutira vec vecina rutera to dropa.
Ono sto mozes napraviti je "helper" adresu ako mozes u svom ruteru stavljati static ARP entry.
Odredi jednu slobodnu adresu iz mreze npr 192.168.1.244 i ARP ff:ff:ff:ff:ff:ff.
Jos samo trebas NAPT na tu IP adresu.
<FLEET>
MBO: Gigabyte GA-X58A-UD7 (rev. 2.0)
CPU: Intel Core i7-950 @ 3.2 GHz
Chipset: Intel X58
RAM: 6 x 4 GB DDR3-1600 (PC3-12800)
VGA: HD4850
HDD(OS): OCZ Vertex3 120GB
HDD(local storage): WD WD2002FAEX 2TB, 2x Seagate 500GB (RAID0@IRST/ICH10R)
ODD: Optiarc (?)
PSU: Silverstone SST-ST60F-P Corsair VX450
Display: Samsung Syncmaster 930BF @ 1280 x 1024
Display2: Panasonic TC-P55VT60 @ 1920x1080
Other: eSata dock
OS: Windows 7 Ultimate x64
Input:
Logitech MX1000 + Logitech UltraX cordless
Model: HP Z420
CPU: Intel Xeon E5-1650 6x core @ 3.2 GHz
Chipset: Intel Sandy Bridge-E
RAM: 4 x 16 GB DDR3-1600 (PC3-12800)
VGA: Nvidia
HDD(OS): Seagate ST500DM002 500GB
HDD(local storage): 2x WD WD5000AAKX (RAID1@C600 SAS/SATA ctrl)
Display: 2x HP LA2205wg 22" @ 1680 x 1050
OS: Windows 7 Enterprise x64
Model: HP Elitebook 8570
CPU: Intel i5 3360M
Chipset: Intel Ivy Bridge
RAM: 2 x 8 GB DDR3-800 (PC3-12800)
VGA: Intel HD4000
HDD: Samsung SSD 850Pro 512GB
ODD: DVD+/-RW
Display: 15.4" (1366 x 768)
Other: Fingerprint reader
Input:
Logitech V500 cordless
MBO: GA-P35-DS3P (rev. 2.0)
CPU: Intel C2Q Q6600 @ 2.4 GHz
RAM: 4 x 2 GB DDR2-800 @ 533 MHz
VGA: ATI Rage 3D @ PCI
HDD(OS): Seagate ST380815AS 80GB / Seagate ST3500418AS 500GB
HDD(storage01): 2x WD RE WD4000FYYZ 4TB (RAID10,f2@mdadm)
HDD(storage02): WDC WD20EARX-00P 2TB
HDD(storage_cctv): Seagate ST3250824AS 250GB
ODD: NEC DVD-RW ND-4551A
PSU: Corsair GS800
Display: -
LAN: Intel 82571EB @2x1Gbps LACP
Controllers: RS232 Oxford Semiconductor Ltd OXuPCI952
OS: Linux x64 (Ubuntu 14.04 LTS)
MBO: HP ProLiant DL120 G7
CPU: Intel Xeon E3-1220 @ 4x 3.10GHz
Chipset: Intel i875P-ICH5
RAM: 4 x 4096 MB DDR3-667 (PC3-10600)
HDD1: 2x MB2000EBUCF HUA723020ALA640 2TB 7200RPM (RAID1@P410)
Display: -
LAN: 82574L @ 1000Mbps FD
OS: Linux x86_64 (Ubuntu 14.04 LTS)
MBO: ASRock 4Core1333-FullHD
CPU: Intel Core 2 Duo E84000 @ 3.0 GHz
Chipset: ATI RS600+SB600
RAM: 1 x 512 MB DDR2-800
VGA: -
HDD: Seagate 500GB
ODD: DVD-RW
PSU: Corsair VX450(?)
Display: Panasonic TH-50PY800
LAN: @1Gbps FD
OS: Windows 8.1 Pro x64
Input:
Logitech Cordless DiNovo Edge
MBO: Intel D201GLY2 (ITX)
CPU: Intel Celeron 220 @ 1.2GHz
Chipset: SiS662
RAM: 1 x 512 MB DDR2-533
VGA: Intel
HDD: Sandisk 1GB CF @ CF2IDE
ODD: -
PSU: miniITX type(?)
Display: -
LAN1-Uplink: @1000Mbps FD
LAN2: @100Mbps FD
OS: Mikrotik OS 6.28
Model: Mikrotik RB2011UAS-2HnD
</FLEET>
cat.7 - where crosstalk is not an issue anymore.
_saiko je offline   Reply With Quote
Staro 14.01.2016., 21:50   #875
memory
Postovi: 5
Mogu postaviti static ARP ali ne sa MAC ff:ff:ff:ff:ff:ff. Javlja mi da je MAC error.
Logiran sam kao administrator.
Staro 14.01.2016., 22:06   #876
back2quick
Datum registracije: Jan 2012
Lokacija: righthere
Postovi: 441
a poslat WOL paket drito s rutera?
back2quick je offline   Reply With Quote
Staro 14.01.2016., 22:21   #877
memory
Postovi: 5
Sa LAN-a sve šljaka. Nikako upogoniti sa WAN-a. A to mi treba.
Staro 21.01.2016., 18:49   #878
tantrum
direktor
tantrum's Avatar
Datum registracije: Feb 2013
Lokacija: Blyatovitica
Postovi: 30
Autor athmo Pregled postova
USPIO SAM!
Preface:
Probao sam No-IP, DuckDNS... svašta i ništa. I evo tek nekako jedva jedvice.
Znači.. uh. Ovako:
1. Registrirati se na DtDNS s korisničkim imenom koje želite da vam zapravo bude domena:
- Npr, ako želite hostname: ztesucks.dtdns.net onda morate napraviti account s imenom "ztesucks".
- Vrlo važno: NE koristiti nestandardne znakove u zaporci. Mora se sastojati samo od engleskih slova u ASCII rasponu i brojeva.
- Zašto? Zato jer passa argumente skripti preko STDIN-a i naravno ne escapea stvari tipa "&, |, #...", a ne čita iz config datoteke stvari.
- Kako znaš? Administration, logging, staviti na Debug i Submit. Zatim pozorno pratiti.
- Vidjet ćete nešto ovako:
Code:
2015-03-15T13:36:57 [Informational] strCmd is: dtdns -u USERNAME -p PASSWORD -i 11.22.33.44
2015-03-15T13:36:57 [Debug] cmd is dtdns -u USERNAME -p PASSWORD -i 11.22.33.44
2015-03-15T13:36:57 [Informational] start program successful!dtdns
2015-03-15T13:37:13 [Notice] sendprogstop: dtdns[1195]  died  exit_code = 0 exit_status = 1
Još ne znam što znači mu ovo sendprogstop zato jer se pojavljuje kod svih cmd programčića. Pretpostavljam da je to nekakav njegov kvazi sigterm nakon što utility obavi svoju dužnost (u ovom slučaju ažuriranje IP adrese)
2. Napraviti hostname s ISTIM imenom kao i accountom (objašnjeno gore). Nakon što napravite sve to postavite IP adresu tog hosta na nešto tipa 12.34.56.78, bilo što što se razlikuje od vaše prave IP adrese tako da možete odmah prepoznati je li se updatealo ili ne iz routera (logično). Sad bi bilo pametno pričekati par sati da se valjda account skroz aktivira u bazi pošto meni ovo nije radilo odmah. No, možda samo nisan ima sriće, pa vi nastavite...
3. U routeru otvorit DDNS dio i postaviti providera na "dipc". Maknuti kvačicu "Enable".
4. Vratiti providera na DtDNS. Sad bi trebalo samo u Server pisati "www.dtdns.net"
5. Upisati podatke pažljivo i postaviti WAN Connection na vezu koju želite (u mom slučaju Internet_VDSL)
6. Stavit kvačicu na Enable i Submit. Pričekati oko 30 sekundi.
7. Provjeriti je li se adresa ažurirala (možete na stranici, a možete i koristit dig iz netutilsa ako ste na nixu). Ako se nije ažuriralo, biti uporan i ponovno ponavljati sve dok se ne ažurira. Ja sam ovo radio nekih... 5-6 sati i sad napokon više radi kako triba. Probajte s rebootom routera, korištenjem drugih providera, svega al kažen van uspit ćete kad tad.
Setup Duckdns na ZTE zxdsl 931viii modemu
Na modemu pod Application / DDNS
Service type: dyndns
Server: www.duckdns.org/update/tvoj duckdns username/tvoj duckdns token broj
Username: NA
Password: NA
Wan connection: Internet_VDSL
Hostname: tvoj duckdns username
Pošto nema loopback, dostupnost dnsa provjeravao sam putem testnih stranica dva puta uspješno, za svako testiranje resetirao sam modem (ujedno i IP).
Za svaki slučaj testirati ću dostupnost idućih nekoliko dana na trećim računalima.
tantrum je offline   Reply With Quote
Staro 24.01.2016., 14:31   #879
Gavroo
Datum registracije: Aug 2011
Postovi: 39
Pozdrav ekipa, imam par pitanja pa se nadam da cete mi moci pomoci.
-Imam 50/10 konekciju i laptop koji je spojen preko wifi-a naravno, medjutim kad skidam nesto preko laptopa non stop puca veza. Pojavi mi se usklicnik na vezi pa moram troubleshoot da popravi. Ugl gotovo je nemoguce nesto dl-at na lap od vecih fajlova. Ima li ko ideju u cemu je stvar i da li ima pomoci?
-Dalje, da li se moze nastimati na routeru automatski restart routera, da svaki dan bude u identicno vrijeme, moje zeljeno vrijeme?
-I na kraju moram generalno pitati za same postavke WLAN-a. Jucer sam zvao Tcom podrsku da mi provjere liniju jer mi se svaki dan uzasno usporavao internet u razdoblju od 15-17h i jedino bi rijesenje bilo restart routera. Oni su mi restartirali routeri njegove postavke, tako da sam morao ponovno nastimavati WLAN ali mi se ne cini bas da radi kako spada, cudne su opcije na routeru i neke koje stvarno nemam blage za sta sluze, pa ako tko ima default profile neki bilo bi lijepo.
Hvala LP
Gavroo je offline   Reply With Quote
Staro 25.01.2016., 15:24   #880
Tihomir111
ZeNgE_Tiho_Cro
Tihomir111's Avatar
Lokacija: Virovitica
Postovi: 466
Kolege, da li netko može poslati screenshot Qos, ili neke druge funkcije, da limitiram wifi na 15 Mbit... žena mi ubije sav promet sa youtube-om... Ili da stavljam netlimiter kod nje na lap? Ty
Tihomir111 je offline   Reply With Quote
Staro 25.01.2016., 15:43   #881
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Autor Tihomir111 Pregled postova
Naoruzaj se i kreni u infiltraciju sa instalacijom softvera na zenin lap, jer koliko je meni ovdje u temi receno ranije (imao sam slican problem ranije), QoS ne radi ili nesto slicno tome.
All you have is your fire and the place you need to reach.
Don't you ever tame your demons, always keep them on a leash.
Alph4Dawg je offline   Reply With Quote
Staro 26.01.2016., 21:42   #882
Doktor-X
Doktor-X NetWork
Doktor-X's Avatar
Lokacija: .
Postovi: 290
gdje se na ovom čudu može promjeniti dns serveri da se ne koriste tht-ovi znam da mogu na samom pc-u ali ja želim na jednom mjestu promjeniti za cijelu mrežu
Doktor-X je offline   Reply With Quote
Staro 27.01.2016., 00:04   #883
Prezime
Datum registracije: Aug 2013
Postovi: 4,364
To cudo te tolko prestrasilo da se nisi usudio pogledat LAN opcije? Slobodno ih pogledas (Network-LAN-DHCP Server) nista te nece tamo ugrist
Staro 27.01.2016., 20:38   #884
Doktor-X
Doktor-X NetWork
Doktor-X's Avatar
Lokacija: .
Postovi: 290
to:
DNS Server1 IP Address 192.168.1.1
pa odakle onda on vuće 195.29.149.196/195.29.166.116
kako piše pod
Path:Status-Network Interface-DSL WAN Connection
a i dhcp server imam ugašen
Staro 27.01.2016., 23:46   #885
Prezime
Postovi: 4,364
Prvo, "DNS Server1 IP Address 192.168.1.1": tu adresu ne upisuj u router pod DNS, jer to je samo adresa IP adresa routera koju upisujes u properties Lan kartice pod "Default Gateway", da ona zna kako ce joj router na toj IP adresi dodjeljivat DNS-e.
Drugo, 195.29.149.196/195.29.166.116 router vuce sa T-Com servera, jer to su njihove DNS adrese. Bez njih ti internet ne moze radit. Na tom mjestu mozes iskljucit kvacicu sa "Assign IspDNS" i upisivat svoje DNS adrese po zelji; medjutim najcece internet najbolje radi s njihovim DNS-ima koje imas nabrojane u zaljepljenoj temi (iznad ostalih tema) pod "DNS by ISP".
Ako kojim slucajem u routeru nemas ukljucenu kvacicu na Assign IspDNS, onda pogledaj/provjeri koje DNS server adrese imas navedene u naprednim opcijama za TCP/IPv4 (pod DNS tabom) na LAN kartici kompa.
Staro 28.01.2016., 15:23   #886
Doktor-X
Doktor-X NetWork
Doktor-X's Avatar
Lokacija: .
Postovi: 290
pod Network-LAN-DHCP Server mi je po default-u pisalo pod DNS Server1 IP Address 192.168.1.1 i kvačica na Assign IspDNS nije bila stavljena sada sam ja pod Server1 i Server2 stavi svoje adrese
Staro 28.01.2016., 15:40   #887
Prezime
Postovi: 4,364
Nisam siguran i mislim da je onda router povlacio T-com DNS adrese, jer sa upisanom 192.168.1.1 nije mogao radit, tj "proglasio" ju neispravnom...
Staro 30.01.2016., 16:02   #888
Mad Hatter
Mad Hatter's Avatar
Datum registracije: Jan 2016
Postovi: 7
Gigabitni portovi
Pozdrav svima, jedno pitanje iako je prije bilo nešto o tome. Imam optiku i aktivirali su mi 200/100 a speed test kaže da sam na 100Mbit - down. Da li ovaj router podržava veće brzine od 100, rekli su mi na 08009000 da podržava. Kartica je Gigabitna na ploči i spojen sam naravno žicom cat5. Da li netko koristi ovu ili veću brzinu sa ovim routerom?
Mad Hatter je offline   Reply With Quote
Staro 30.01.2016., 18:13   #889
_saiko
system kaiser
Postovi: 194
1Gbps je samo WAN/uplink port, ostalo su 100Mbps.
Uostalom pogledaj u status interfacea na PCu.
Moraju ti donjeti novi router...
<FLEET>
Chipset: Intel X58
VGA: HD4850
ODD: Optiarc (?)
Other: eSata dock
Input:
Model: HP Z420
VGA: Nvidia
CPU: Intel i5 3360M
VGA: Intel HD4000
ODD: DVD+/-RW
Input:
PSU: Corsair GS800
Display: -
Display: -
VGA: -
HDD: Seagate 500GB
ODD: DVD-RW
LAN: @1Gbps FD
Input:
Chipset: SiS662
VGA: Intel
ODD: -
Display: -
LAN2: @100Mbps FD
</FLEET>
Staro 05.02.2016., 14:22   #890
Dcos
Lokacija: Koprivnica
Postovi: 2
Pozdrav,
Trebam pomoć oko ovog rutera. Već lagano gubim živce i volju ga složiti da radi kako treba. Imam optiku i ovaj ruter i nikako ne mogu dobiti da mi internet radi stabilno i brzo.
Uređaji koji se spajaju su dva android mobitela (Galaxy S5 i Nexus 5), Chromecast i laptopi. Svi se spajaju preko WIFI.
Trenutačno sam složio pod wifi settings da koristi "N only", morao sam staviti QoS type SSID iz razloga jer ako toga nema neće mi se spojiti niti Chromecast ni Nexus 5.
Trenutno mi je najveći problem da mi se čini da je response time užasno loš. Naprimjer ako otvorim youtube video, prvo dobrih 30 sec se ne događa ništa, i onda dok krene je sve ok. I tako je sa svakim linkom i sa svim.
Uz to, Nexus 5 ne može zadržati konekciju sa WIFI-em dok ode u sleep (scren off nakon par minuta). To se nije događalo prije.
Ako stavim na bilo što drugo osim "N only" još je gore, onda mi na laptopu stalno puca veza odnosno užasno se uspori net.
Ima li netko ideju što još mogu probati prije nego se odlučim kupiti novi router i baciti ZTE u smeće?
Dcos je offline   Reply With Quote
Staro 05.02.2016., 15:36   #891
Postovi: 23,678
Uzmi lap i prvo provjeri kako se sve skupa ponaša kada je žicom (Lan) spojen na router.
Lako je moguće da je konkretni primjerak ZTE - a neispravan, možda da prijaviš kvar / tražiš zamjenu ?
Staro 05.02.2016., 16:10   #892
jp_rv
Datum registracije: May 2014
Lokacija: istra
Postovi: 3,583
Autor Dcos Pregled postova
Pozdrav,
kao prvo, nije mi nikad bilo jasno koji će vam drek full brzina na mobitelima i sličnim uređajima. imaš optiku, šta će bit 80 mbita vjerojatno. ŠTA ĆE TI 80mbita na fakin mobitelu?
drugo, nemoš ga mijenjat (barem ne na jednostavan način) jer je nužan da bi ti radila telefonija. ono šta možeš napravit jer prebacit mu net u bridge, i kupit svoj vlastiti bolji jači brži skuplji router koji će imat snage progurat 100mbita kroz wan port, i ima 300mbita wifi N.
ovisno o karakteristikama kuće/zgrade i broju susjednih wifi mreža, možda ti 2.4ghz neće radit bolje nego sada. kod mojih staraca ne ide, zato imam 2 routera sa 2 wifi mreže koji pokrivaju različite dijelove stana. a nije da imaju veliki stan. kad izlistam wifi mreže, u svakoj prostoriji mi ih nađe 30tak. da ga ubiješ neće wifi radit stabilno. sve šta je tehnički moguće spojit kabelom, je već spojeno kabelom.
instaliraj inssider na laptop i skeniraj. podesi kanal na routeru na onaj koji je najmanje zastupljen i koji ima najniži signal u tvom stanu.
jp_rv je online   Reply With Quote
Staro 05.02.2016., 16:31   #893
Dcos
Postovi: 2
Autor Nikky Pregled postova
Preko kabla radi odlično.
Autor jp_rv Pregled postova
Probati ću ti pojasniti Mobitel i Chromecast su mi primarni uređaji za konzumaciju internet sadržaja.
Netflix. Popcorntime i Showbox (castanje na chromecast), Muzika isto chromecast.
Laptop palim samo kada imam nekog ozbiljnijeg posla.
Plus ne radi se od 80Mbps nego 50Mbps
Telefonija mi je apsolutno nebitna, telefon ne koristim (ni ne posjedujem) tako da ću vjerojatno (ako ne uspijem složiti ZTE da radi kako treba) uzeti neki bolji dual band AC router (Razmišljam o TP link Archer C2 ili C5).
Idealno bi bilo da ga mogu spojiti direktno u ONT, i ZTE potpuno maknuti iz priče. Ne znam je li to moguće?
Skeniranje mreže je bilo prvo što sam probao. Dosta je veliko zagušenje na 2.4GHz (cca 10 mreža ništa na 5GHz) no ne prestrašno. ZTE je postavljen na najbolji kanal i svaki put kada ga pratim je najjači signal.
Staro 05.02.2016., 16:51   #894
Postovi: 23,678
Neki drugi router je moguće spojiti direktno u ONT, potraži info na forumu,
mora podržavati / imati opciju podešavanja Vlan - ova (Vlan=100 na optici za Internet), ...
U vezi wifi situacija će biti sve gora kako vrijeme prolazi zbog zagušenja, pogotovo na 2.4GHz bandu,
čak i da staviš neki pošteni ili bijesni AP / Router pitanje je šta ćeš dobiti jer je svaka lokacija priča za sebe.
Prije kupovine bilo čega, idealno bi bilo kad bi mogao negdje posuditi neki AP / Router sa N i 300 Mbps i boljim vanjskim antenama, pa na njega prebaciti wifi funkciju.
Zadnje izmijenjeno od: Nikky. 05.02.2016. u 16:59.
Staro 05.02.2016., 17:02   #895
jp_rv
Lokacija: istra
Postovi: 3,583
Ako ti uređaji podržavaju 5.8ghz, uzmi neki abgn router, ne treba ti ac jer je šansa da podržavaju ac dosta mala, ipak je to nov standard. ili kako ćeš. za moje potrebe je i stari b standard više nego dosta, za malo skajpanja na tabletu.
imaš onu veliku temu o fiberlandu gdje su govorili kako stavit svoj router na ont.
Staro 06.02.2016., 01:46   #896
rokodbk
rokodbk's Avatar
Postovi: 8
Ljudi molim za pomoć, već pomalo postajem očajan.
Uglavnom, pročitao sam cijeli topic u nadi da cu naci rijesenje za moj problem, ali na zalost nisam nasao rijesenje mog problema iako sam vidio 2-3 posta od korisnika koji imaju slicaj problem kao i ja, ali ni njima nitko nije pomogao.
O cemu se radi: spajam se na ZTE ZXDSL 931VII preko wifi-ja sa raznim uređajima, 3 laptopa, iphone, 2 android moba, i na svim navedenim uređajima wifi konekcija radi normalno, normalo se uređaji spoje i pristupaju internetu.
Jedini problem imam sa novim Andoid TV boxom kojeg sam kupio prije par dana. Uređaj uredno pronađe mrežu, upišem password, spojim se, android tv box dobije ip adresu, sve uredno, uglavnom spojim se na mrezu s tim uređajem. Ali, kad zelim surfat ili koristit youtube ugl bilo sto radit preko interneta na tom uređaju, veza je toliko losa da otvara obicnu web stranicu 20 sekundi ili ju uopce ne otvori. Također u tim trenucima kada preko android tv boxa zelim surfat ili opcenito korsitit net, internet veze na svim drugim uređajima postanu katastrofa spore.
Ugl kada koristim internet preko android tv boxa, internet na svim uređajima bude brutalno spor.
Ljudi molim vas za pomoc, da ne bude da sam taj android box kupio samo da mi skuplja prasinu i bacio novce u vjetar. Onom korisniku koji mi nađe riješenje ovog problema poklanjam TP-Link TL-WA850RE WiFi Range Extender, koristen 3 puta i star tjedan dana, sa garancijom. Ili neku drugu stvar po zelji u toj vrijednosti (200kn)
rokodbk je offline   Reply With Quote
Staro 06.02.2016., 01:52   #897
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,064
Evo ja sam imao slican problem sa android boxom ( mk 809 III ) i meni je pomoglo kao prvo otvaranje boxa i drugacije pozicioniranje wifi antene,a na kraju mi je problem lose konekcije rijesio custom firmware i hvata bolje nego mobitel u sobi,ne znam koliko ti moze pomoci,ali eto probaj,no oko ovoga drugog problema sa sporom vezom na svim ostalim uredajima dok koristis android box ne mogu pomoci.
O kojem se android tv boxu radi ?
Staro 06.02.2016., 02:05   #898
rokodbk
rokodbk's Avatar
Postovi: 8
Uređaj je Tronsmart Orion R68 Meta.
Na uređaju inace wifi radi dobro, jer sam ga odnio kod prijatelja da ga spojim na njegov wifi da provjerim da li je problem u android tv box-u ili problem u ovom ZTE routeru.
Tako da sam skoro siguran da je problem u routeru jer sam vidio kod par drugih korisnika foruma koji su ovdje postali da imaju slican probem (spoje android tablet na wifi pa veza bude uzasno spora na svim drugim uređajima, i sl)
Također sam koristio i TP-Link TL-WA850RE WiFi Range Extender da pojacam signal, nije pomoglo. Onda sam android tv box spojio Lan kabelom na Range Extender jer on ima i jedan Lan ulaz, opet nije pomoglo.
Zadnje izmijenjeno od: rokodbk. 06.02.2016. u 02:08. Razlog: Dopuna
Staro 06.02.2016., 05:54   #899
back2quick
Lokacija: righthere
Postovi: 441
jel šteka net:
1. ako spojiš lan kabelom laptop na extender
2. ako spojiš box lan kabelom na zte
Staro 06.02.2016., 08:18   #900
RAUL
Lokacija: Worldwide
Postovi: 2,553
Probaj promjeniti WiFi kanal na ZTE -u
