Staro 07.12.2015., 20:10   #6721
Sokios
Sokios's Avatar
Datum registracije: Mar 2008
Postovi: 94
Koja bi mi bila najjača grafa za i3 4160 a da ne bude usko grlo proc? Planiram igrati najviše Battelfield 4, COH 2 i sl.
Sokios je offline   Reply With Quote
Staro 07.12.2015., 20:30   #6722
syss
syss's Avatar
Postovi: 10,805
ma bjež od gainwarda.
Staro 07.12.2015., 21:44   #6723
emilblomsky
emilblomsky's Avatar
Lokacija: karlovac
Postovi: 2,109
Autor syss Pregled postova
Inace bi,ali kupim je ovdje u Klc ,pa i ako rikne,nosim ju u trgovinu i dobim drugu.Tako da...
Phil of the future!
Staro 07.12.2015., 21:54   #6724
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,281
presao sam na gtx750ti STRIX
jucer ju stavio, mocna je to grafa
MojSkuter
Eladio je online   Reply With Quote
Staro 07.12.2015., 22:34   #6725
Dottore
Dottore's Avatar
Postovi: 7,726
Kupi ako si sto posto siguran.
Budeš na kraju vidio veselje sa reklamacijom Gainwarda. Više nisu dobri kao nekada.
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 07.12.2015., 23:45   #6726
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,589
Je samo sto su 260x i 750ti preko soma kuna.Ova je 850kn!Onda mi je bolje potegnuti do 370!Ima jedna u hg spotu 900kn,ali vidim samo u Vinkovcima.
http://www.protis.hr/products/detail...5dc22gd5/90563 Mega deal, zgrabi dok ima (mislio da je rasprodana)
Dakle 370 je samo rebrand dotične, jača od 750Ti, gtx 660, a slabija od 270/270X i gtx 950
Staro 08.12.2015., 00:43   #6727
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,281
netko ce krivo pomisliti gledajuci ovaj niz od 5 zelenih u niti par mjeseci da sam za zeleni tabor a stvarno nisam )
sve je ostalo u postavkama isto osim sto sam za gtx 750Ti smanjio AF sa 16 na 4 samplea, cisto preventivno..
kad je gtx760 u pitanju ne sjecam se najbolje ali rekao bi da je avg frame rate nesto iznad 45 fps , mozda grijesim, ali svakako ono sto zelim reci igrivost super..
pa sa gtx 770 drzao 60FPS i rijetko kad je pao na 45fps , mogu komotno reci da je avg 59FPS i igrivost naravno odlicna..
i sada na gtx 750 ti frame rate je izmedju 35 i 55 ..rekao bih avg 40fps (podsjecam smanjen je AF na 4 sempla)
ponavljam nisam radio mjerenja nego pricam po osjecaju, ali
poanta: i dalje je igrivost odlicna.. rekao bih kvaliteta efekata i igivost je ostala ista..
treba isljuciti frapse, i mjerace i ovo i ono i gustati u igri a ne se baviti testiranjima i patiti sto netko drugi ima 200 frejmova
bas me interesira sta jos ovo "slabo" cudo od kartice moze.. i zbog cega vlada tolika "pomama" za visokim frejmrejtima kad je sve to isti gnjurac bar meni koji igram fallout4
mislim , nisam sad izmislio nista pametno ovim gore recenim , ali super me je odusevila ova mala tiha hladna graficka za koju "skoro" da ni ne trebas napajanje i koja izgleda kao u biti pola "normalne" graficke ...glavno da radi , a ova definitivno ima zubice i neda se i moze se itekako igrati ocito i s njome i to u kvalitetnim detaljima..
ma i taj gejming treba demistificirati..
krenuti redom sta se igra, i s kojom grafom i kojim preferencama... (1080p mi je monitor i na to se osvrcem ovdje)
nisam nesto gejmao zadnje vrijeme i isprepadan testovima i komentarima itd sam shvatio da s obzirom na moj monitor treba ici u smjeru r9 280x.. to je kao ono super.. bolje ne treba..
e sad.. igram fallout4.. pa cu se na temelju njega i osvrnuti na ovo sto govorim, jer mozda ima jos onih koji bi htjeli nesto skupo pa pate jer imaju samo nesto slabije..
dakle presao sam sa gtx 760 na gtx770 (kao neki "zeleni" ajmo to tako reci r9 280x) i sada sam zavrsio na gtx750Ti ..zamjena je u biti kad se pogleda snaga poprilicna, da ne kazem dupla.. (ne tako davno prije sam imao gtx 660 , i gtx 560 , --> netko ce krivo pomisliti gledajuci ovaj niz od 5 zelenih u niti par mjeseci da sam za zeleni tabor a stvarno nisam )
MojSkuter
Zadnje izmijenjeno od: Eladio. 08.12.2015. u 01:22.
Staro 08.12.2015., 00:50   #6728
Sphere
Datum registracije: Mar 2015
Postovi: 1,254
Zasto si mjenjao gtx 770?
Sta se tice igri, na nekima se skroz normalno igra i u 35 fpsa, a na nekima mi je i 45 fpsa malo
Sphere je offline   Reply With Quote
Staro 08.12.2015., 01:00   #6729
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,281
Autor Sphere Pregled postova
zato jer me srce boli imati tako nesto "vrijedno" a sto znam da ce izgubiti na cijeni a ja ni priblizno ne vrtim sve te igre , koliko smatram da bi trebao, da se to "isplati".. a i obveze i godine cine svoje.. zena, djete, kredit, u kuci bolje da kupim neke stvari koje mi trebaju nego sto se tu "igram"
..uletila je kombinacija i zamjena i ja zadovoljan i dobivenim i doplatom..
a kad malo razmislim brijem da bi mi se sad jedino "isplatio" nintendo wii
da se vratim na temu..
racunalo mi treba i zbog posla.. ali graficka? graficka definitivno ne.. cak se razmisljam prodat i ovu strixicu kad predjem fallout 4, ali svidjela mi se pa sad nisam siguran
MojSkuter
Staro 08.12.2015., 01:45   #6730
emilblomsky
Lokacija: karlovac
Postovi: 2,109
Autor Eladio Pregled postova
Sad si me zapalio za tu 750 ti!
Uzet cu je,trebala bi lomiti na 1280x1024,a i na 1920x1080 bude solidna.
Gtx 950 mi je prevelika razlika u novcu.
Phil of the future!
Staro 08.12.2015., 02:19   #6731
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,281
ovo sto ti je M.C. preporucio R7 265 je jos i bolja grafa od 750Ti (bar po frejmovima na stocku, nisam upucen u detaljnije analize)
u principu jako puno igri koliko vidim gtx750Ti vrti na high ili ultra detaljima u igrivom frejmrejtu.. ove ostale koliko sad gledam isto vrti ali tu se smanjuju detalji, sto i dalje moze izgledati jako dobro.. vidjet cemo
PS
jbt napajanje mi je skoro duze od graficke...
MojSkuter
Zadnje izmijenjeno od: Eladio. 08.12.2015. u 02:28.
Staro 08.12.2015., 02:26   #6732
Manuel Calavera
Postovi: 14,589
Zašto pored one što sam ti linkao gore? Još i dobar cooler + 3 god. garancije.
To je ipak jača gpu od 750ti za iste novce. Prema techspotu 370 (265) je došla na 5% od gtx 950 i to negdje 2-3 drivera prije crimsona:
Other more affordable choices are the $150 R7 370 and $160 GTX 950. The R7 370 was on average 5% slower and is about 5% cheaper, so this one's a draw. When we reviewed the GTX 950 at launch it was 10% faster than the R7 370, but with a few driver updates AMD has been able to close that gap.
The R7 370 does have the advantage of being the more efficient GPU. If your priority is frame rate performance over power consumption then the GTX 950 is the best choice, but if you prefer a more efficient graphics card then the R7 370 is your best bet. We acknowledge that there isn't a clear cut winner here, so for most gamers it will come down to which GPU maker they prefer.
Ona gore je nekih 25% jeftinija od najjeftinijih (single fan) gtx 950
Staro 08.12.2015., 02:34   #6733
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,281
M.C. mislim da je njemu uvjet da kupi u karlovcu na rate.. inace slazem se s tobom da vrijedi ju razmotriti ..ali kao da mi se cini da je gtx950 vise jaca nego tih5%
MojSkuter
Staro 08.12.2015., 02:35   #6734
Manuel Calavera
Postovi: 14,589
Dobro to sam smetnio. Doduše ako se ne varam spominjao je nekakvo putovanje u zg ako treba
Staro 08.12.2015., 08:28   #6735
emilblomsky
Lokacija: karlovac
Postovi: 2,109
Ma kupujem ovdje u Comelu. Znam ,Manuel ,da je ova bolji izbor,budem vidio jel se moze kako povuci iz Zg.Ali ako da,bude sigurno druga cijena.Iz Linksa lakse povucu ,za vise manje istu lovu.
Ne pitaj kako,ne znam ni ja. Valjda ovisi o dobavljacu.
Phil of the future!
Staro 08.12.2015., 14:39   #6736
ivo1950
ivo1950's Avatar
Postovi: 172
Pozdrav,
Crkla je stara hd4850. Komp je (q9550, može oc jer ima bolji hladnjak, 6gb rama). Koja grafička kartica bi bila max da je cpu ne ogranicava. Gledao sam r7 265. Treba za battlefield 4 i slične igre. Rezolucija je 1920x1080. Hvala
ivo1950 je offline   Reply With Quote
Staro 08.12.2015., 17:37   #6737
2XO
Lokacija: Osijek-Zagreb
Postovi: 325
Max R9 270 koja ti je mrvicu jača od R7 265 (ocana R7 265 sustiže 270 po perfomansama), cpu će ti bottleneckati sve jače od toga.
2XO je offline   Reply With Quote
Staro 08.12.2015., 18:01   #6738
Manuel Calavera
Postovi: 14,589
Možeš isto onu iz protisa
Staro 10.12.2015., 10:13   #6739
ivo1950
ivo1950's Avatar
Postovi: 172
Jučer su mi javili da su nestale one asus r7 265. Neznan koliko ima smisla rastezat se do r9 270 s obzirom na procesor, a druga opcija je r7 360. Imate li kakvih prijedloga da uzmen nešto da podržava battlefield 4 na 1920x1080. Hoće li biti kakvih akcija tijekom 12. miseca?
Staro 10.12.2015., 10:58   #6740
Dottore
Dottore's Avatar
Postovi: 7,726
Teško da gura toliko na toj rezoluciji i uz toliko žrtovanje na low kvaliteti.
Akcije neće biti, jedino čekaj da padne dolar i pada cijena grafičke.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 10.12.2015., 17:18   #6741
emilblomsky
Lokacija: karlovac
Postovi: 2,109
Evo ,naručio danas Msi r7 370 gaming! Cijena je ok ovdje u Klc,tako da sam zadovoljan!Trebala bi biti u utorak ovdje pa javim dojmove.Vidim da ima zero frozr,nešto kao Asus Strix,paljenje ventova samo kod opterečenja!
Phil of the future!
Staro 10.12.2015., 17:56   #6742
Manuel Calavera
Postovi: 14,589
Autor ivo1950 Pregled postova
Možeš i 360-tku, međutim pazi da nije neki glasan model (npr. giga iz recenzije ovog portala).
Akcije u hardveru nisu ni blizu recimo popusta na odjeću, obuću i sl. tako da neke osjetne popuste ne očekuj.
Što se tiče same grafe, može ona poprilično dobro gurati BF4 https://www.youtube.com/watch?v=HPDhtvLtwks (Alta = high, activado/deactivado - uključeno/isključeno)
Zadnje izmijenjeno od: Manuel Calavera. 10.12.2015. u 18:02.
Staro 10.12.2015., 19:11   #6743
ivo1950
ivo1950's Avatar
Postovi: 172
Mogla bi onda biti ova
https://www.links.hr/hr/graficka-kar...i-i-0518061038
Staro 10.12.2015., 19:49   #6744
Sphere
Postovi: 1,254
Nebi ja te XFX sa jednim ventom razmatrao
Staro 11.12.2015., 22:49   #6745
Drvoje
Split resist itself!
Drvoje's Avatar
Postovi: 4,037
Pogotovo ne od XFX klošara - za njih je i Gainward mila majka (bez obzira koliko moroni krivo okretali ventove u Phantom izvedbi, puše suprotno od smjera grafe!?).
Npr. na XFX R9 280X (DD model) stave yebenu plastiku ispod alu heatsinka da "hladi" komponente, a o njihovim šugavim jamstvenim naljepnicama i manjoj gari od nekih da ne pričam.
Ako se ide na ATI onda one s 3god. gare (ASUS, Gigabyte, MSI.. - tim redom) ili pak Sapphire s 2 god. od ovih ostalih vendora (Sapphire je mislim i dalje najveći ATI partner).
BTW ne znam koliko ta 360-tka troši, ali ove s dva venta definitivno osiguravaju mriniji san (imaju i veću površinu heatsinka = niže temp. cile kartice, time i manju buku).
Ako imaš provjetreni kejs ili klimu u sobi za lito, onda tek možda neki drek s jednim ventom.
Pomelo mi sig -.-
Staro 16.12.2015., 00:13   #6746
BoTiA
Lokacija: doma
Postovi: 254
Pozdrav, trebala bi mi pomoć, trenutno imam ovu konfiguraciju:
Procesor AMD Phenom x3 720
Matična: GA-MA785G-UD3H
Grafička: integrirana na ploči, *ATI Radeon HD 4200
Monitor je dell 23" u2311h
E sad.... Sin bi mi želi igrati Counter-Strike: Condition Zero, da li mi je moguć upgrade, ako da koju karticu preporucate za neko "normalno" igranje? Ne trebaju biti neke ultra postavke....
Takodjer, procesoru je otkljucana 4-ta jezgra ako to što znači....i soba u kojoj se nalazi kompjuter se jako grije ljeti pa bih iz toga razloga želio izbjeći nešto što će mi raditi dodatne probleme. Na procesoru je hladnjak SCYTHE*Katana 3.
BoTiA je offline   Reply With Quote
Staro 16.12.2015., 00:17   #6747
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,063
Mislim da bi za taj procesor vrhunac bila HD 7850/R7 265/R7 370,ili mozda ipak nova GTX 750Ti jer Nvidia se puno bolje ponasa sa sporijim procesorima.
Evo kanal di covjek testira sve igre sa slicnim setupom pa vidi
https://www.youtube.com/user/ObscureAngelPT/videos
Zadnje izmijenjeno od: blava. 16.12.2015. u 02:23.
Staro 16.12.2015., 02:07   #6748
Manuel Calavera
Postovi: 14,589
Autor BoTiA Pregled postova
Koje točno napajanje? Ako nije sad neki hard core šroteks
http://www.supernet.hr/graficke-kart...dia_7#M0901870
Staro 16.12.2015., 08:21   #6749
BoTiA
Lokacija: doma
Postovi: 254
Napajanje je CORSAIR 550W VX
Staro 16.12.2015., 10:21   #6750
Sphere
Postovi: 1,254
Sa tim napajanjem si miran
