Staro 05.01.2003., 17:11   #1
Deathclaw
Deathclaw's Avatar
Lokacija: Županja
Postovi: 17
Question Problem sa grafičkom
Moja konfa je: P4 1.4 Ghz socket 423 (Willamette)
Abit TH7 - Raid matična ploča
256 Mb RDRAM 400 MHz Rambus
IBM 40 GB HDD 7200 okr / min, 2 Mb cache
Hercules 3D Prophet 4500 64 Mb SDRAM (Kyro 2)
Sony 52 x CD - rom
Napajanje: AC 230 V; 250 W
Windows XP Professional + service pack 1
U Bios - u mi je AGP podešen na 4 x
Imam veliki problem sa igrama - nijedna igra (osim 2D igara, one rade) ne radi. Instalirao sam najnovije drivere za Win XP (mislim v 16.055) i opet ništa ne radi. Kada pokrenem igru prvih par sekundi se sve normalno pokrene i onda grafika jednostavno "poludi" - kursora je oko 10 - ak na ekranu i konstantno se slika trza u jednoj te istoj sceni iz igre. Naravno, igra zablokira. . Ne znam što da radim - na Win 98 nije bilo problema. To je sve bilo sa Direct X - om 8.1 onda sam pokušao i instalirao DX 9.0 i opet isto. Pokrenuo sam dxdiag i dobio ove rezultate:
System Information
Time of this report: 12/22/2002, 11:44:22
Machine name: DARIO
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 1 (2600.xpsp1.020828-1920)
Language: English (Regional Setting: Croatian)
System Manufacturer: ABIT
System Model: 6A69SA19
BIOS: BIOS Rev:0.1
Processor: Intel(R) Pentium(R) 4 CPU 1400MHz
Memory: 256MB RAM
Page File: 110MB used, 423MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0 (4.09.0000.0900)
DX Setup Parameters: Not found
DxDiag Version: 5.03.0000.0900 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: The file pmxdisp.dll is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer. DirectDraw test results: All tests were successful. Direct3D 7 test results: Failure at step 32 (User verification of Direct3D rendering): HRESULT = 0x00000000 (error code) Direct3D 8 test results: Failure at step 32 (User verification of Direct3D rendering): HRESULT = 0x00000000 (error code) Direct3D 9 test results: Failure at step 32 (User verification of Direct3D rendering): HRESULT = 0x00000000 (error code)
Sound Tab 1: The file als4000.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer. DirectSound test results: All tests were successful.
Music Tab: DirectMusic test results: All tests were successful.
Input Tab: No problems found.
Network Tab: No problems found. DirectPlay test results: The tests were cancelled before completing.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: 3D Prophet 4500
Manufacturer: Hercules
Chip type: PowerVR KYRO
DAC type: PowerVR
Device Key: Enum\PCI\VEN_104A&DEV_0010&SUBSYS_00101681&REV_07
Display Memory: 64.0 MB
Current Mode: 1024 x 768 (32 bit) (100Hz)
Monitor: SyncMaster 755DF(X)/705DF(X),MagicSyncMaster CDP17BDF(U)(UP)
Monitor Max Res: 1792,1344
Driver Name: pmxdisp.dll
Driver Version: 6.13.0010.6270 (English)
DDI Version: 8
Driver Attributes: Beta Retail
Driver Date/Size: 9/27/2002 16:34:52, 49376 bytes
WHQL Logo'd: No
WHQL Date Stamp: None
VDD: n/a
Mini VDD: powervr.sys
Mini VDD Date: 9/27/2002 16:34:46, 566496 bytes
Device Identifier: {D7B71EAA-4350-11CF-4F6D-1A20A5C2CB35}
Vendor ID: 0x104A
Device ID: 0x0010
SubSys ID: 0x00101681
Revision ID: 0x0007
Revision ID: 0x0007
Video Accel: ModeH263_A ModeMPEG1_A ModeMPEG2_A ModeMPEG2_C
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: All tests were successful.
D3D7 Test Result: Failure at step 32 (User verification of Direct3D rendering): HRESULT = 0x00000000 (error code)
D3D8 Test Result: Failure at step 32 (User verification of Direct3D rendering): HRESULT = 0x00000000 (error code)
D3D9 Test Result: Failure at step 32 (User verification of Direct3D rendering): HRESULT = 0x00000000 (error code)
Ne znam što nije uredu. :confused:
Molim za pomoć!
Deathclaw je offline   Reply With Quote
Staro 05.01.2003., 18:19   #2
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Mislim da ti je stvar u driverima. Odakle si ih skinuo? kod mene su verzija 6.13.10.6270(english)
Skini nove drivere sa Herculesovog site-a.
Staro 05.01.2003., 18:23   #3
MadBoY
MadModerator
MadBoY's Avatar
Lokacija: N/A
Postovi: 5,195
Točnije skini ove drivere. Oni su za XP i Hercules 3d Prophet 4500 (bez TV-outa)
http://europe.hercules.com/supportf....t=DRIVER&os=23
DDI Version: 8
Ovaj dio mi nije jasan. Beta?
Staro 05.01.2003., 18:36   #4
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
Da baš uočih..
Koliko mi se čini nešto je prtljo s driverima. Imao sam tu grafulju i svašta mi se dešavalo ali ovako nešto nije a nema što nisam radio s njom. Igrao sam na njoj neku beta verziju UT 2003, nakon prtljanja po registriju pa mi nije ovakva iznenađenja priredila. Jesi možda radio nešto s BIOSOM od grafičke? Da je nisi možda OC-ao? Promijeni ti drivere koji ti je dao ludi boy pa vidi onda. Ona beta tamo mi je čudna.
Staro 05.01.2003., 19:18   #5
Deathclaw
Deathclaw's Avatar
Lokacija: Županja
Postovi: 17
Ma, imao sam grafičku overclockiranu neko vrijeme na 185 / 185, ali sam ju vratio na staro. Drivere za nju sam uvijek skidao sa Herculesovog site - a, pa tako i ove. Bios grafičke nisam dirao.
Ali OK skinit ću te drivere pa ću vam javiti kako je prošlo!
Staro 05.01.2003., 21:23   #6
Deathclaw
Deathclaw's Avatar
Lokacija: Županja
Postovi: 17
Isto kao i prije...
Skinuo sam drivere s onog linka koji mi je MadBoy dao instalirao ih i shvatio da su to isti driveri koje ja imam. Također piše Beta retail i isto je ova verzija drivera - 6.13.0010.6270 (English). I opet isti problem... . Napominjem driveri za chipset su instalirani i sve odlično radi dok ne pokrenem igre...
Staro 05.01.2003., 22:42   #7
MadBoY
MadModerator
MadBoY's Avatar
Lokacija: N/A
Postovi: 5,195
E pa možda je ovo problem. Kartica nemože raditi u 4x modu. Stavi na 2X pa javi ima li ikakvih problema.
Staro 06.01.2003., 10:46   #8
Deathclaw
Deathclaw's Avatar
Lokacija: Županja
Postovi: 17
AGP 2 x
Promijenio sam AGP Data Transfer rate na 2 x, ali je sve opet isto!
Staro 06.01.2003., 12:20   #9
MadBoY
MadModerator
MadBoY's Avatar
Lokacija: N/A
Postovi: 5,195
Re: AGP 2 x
Onda reinstaliraj Windowse. Najprije instaliraj Windowse pa onda Service pack, pa onda drivere za matičnu, pa onda drivere za grafiču i nakon toga ostale.
Ako ti ovo ne pomogne imaš ispriku za novu grafičku
Koliko ti je grafička radila na 185/185? To ti nije bilo baš pametno ako nisi imao neko dodatno hlađenje i otvoreno kućište.
Staro 06.01.2003., 12:36   #10
matijas
matijas's Avatar
Lokacija: Republic Of Maximir
Postovi: 354
probaj resetirati BIOS na fail-safe opcije, ne znam kako to ide na win XP, ali potrazi jel imas kakve opcije za popravljanje windowsa, ostavi si reinstalaciju za kraj, tek ako ti nista vise ne pada na pamet...
Imao super komp koji sam poklonio curi, sad radim na sasvim prosjecnom laptopu i bas mi je OK
matijas je offline   Reply With Quote
Staro 06.01.2003., 14:24   #11
Deathclaw
Deathclaw's Avatar
Lokacija: Županja
Postovi: 17
Kada u Biosu ucitam fail-safe i restartiram komp ne mogu se Windowsi podići. Prvo mi kaže da nešto nije u redu s procesorom ili da sam ga promijenio, a onda pritisnem F1 za nastavak i onda bi se trebali ucitati Windowsi, ali nema nista, samo crni ekran smrti... . Onda odem u BIOS i vidim da mi je "megarhecažu" procesora smanjio sa 1400 na 800 Mhz! Ništa bez nove grafulje, ja bih rekao... Ali stvarno ne znam što nije u redu s mojom. :confused: Sve radi odlično, samo kad pokrenem neku 3D aplikaciju - bye, bye!
Imam jos jedno pitanje. Je li uredu sto mi se temperatura procesora vrti oko 50 - ak stupnjeva?
Staro 06.01.2003., 15:22   #12
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
Ma normalno je naravno. Mene samo zanima kako si jebeno došao do 185/185!?? Ja je nikad nisam uspio pomjeriti iznad 180/180. Sve mi se čini da si je malo spalia
Staro 06.01.2003., 16:42   #13
Deathclaw
Deathclaw's Avatar
Lokacija: Županja
Postovi: 17
Ma, 185 / 185 nije ništa.. Natjerao sam ja nju i 190 / 190, ali nakon nekog vremena igranja počeo se pojavljivati poneki artefakt, ali bilo je igrivo.. :clap:
Staro 06.01.2003., 17:07   #14
MadBoY
MadModerator
MadBoY's Avatar
Lokacija: N/A
Postovi: 5,195
190/190!!!!! meni sve puca na 183/183 tad se u nekim igrama pojavljuju čudne stvari. Nebi bilo čudno da ti je grafička malo pregorila . Jesi li imao kakvo dodatno hlađenje za grafičku? Ako nisi bilo je sehr vruće
Staro 06.01.2003., 18:31   #15
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
Ajmo ofako. Ako imaš mogučnost isprobaj grafulju kod nekog drugog na compu pa čemo znati u čemu je fora. Mislim, ako iste stvari radi na drugom compu jebiga barem je jasno o čemu se radi...
A ako ne; reinstal windoza i polako slaži nadalje programe, igrice dok ne vidiš što te točno jebe.
Staro 06.01.2003., 18:53   #16
Deathclaw
Deathclaw's Avatar
Lokacija: Županja
Postovi: 17
Ma nisam imao nikakvo dodatno hlađenje... Ali to ništa nije u usporedbi sa mojom starom TNT 2 M64. To je bila overclockerska zvijer! :clap: U Power Stripu sam je natjerivao do 200 / 200 Mhz!!! Al' je bilo vruće!
Staro 06.01.2003., 19:31   #17
greg SE
greg SE's Avatar
Datum registracije: Oct 2001
Lokacija: Vinkovci
Postovi: 5,231
ali nek onda i taj drugi komp bude na XP jer je rekao da mu je na 98ici radilo kako treba
Staro 07.01.2003., 00:36   #18
z3D
z3D's Avatar
Datum registracije: Aug 2002
Lokacija: Zagreb, Croatia
Postovi: 1,332
e sorry prijatelju ali STVARNO NEMA SANSE da je engine rive 2 isao na 200 Mhz! to je vec lagano pecanje... :burn:
z3D je offline   Reply With Quote
Staro 07.01.2003., 00:55   #19
CatKiller
al se nekad dobro jelo...
CatKiller's Avatar
Postovi: 3,312
Je , moguće je , mislim da je Guilemontov TNT2 Ultra radio na 175/183 po defaultu (Maxi Gamer Xentor 32 TNT2 Ultra , e to je drobiloooo.)
Staro 07.01.2003., 00:58   #20
MadBoY
MadModerator
MadBoY's Avatar
Lokacija: N/A
Postovi: 5,195
Neznam sad za TNT al negdje sam vidio da su za 196/196 na Kyro II trebali raditi volt mod da bi radilo.
Staro 08.01.2003., 17:59   #21
z3D
z3D's Avatar
Postovi: 1,332
i na mojoj rivi memorija ide preko 200, ali engine...nema sanse! cak ni sa jebackim hladenjem se javljaju artefakti
Staro 08.01.2003., 21:46   #22
Veky
Veky's Avatar
Datum registracije: Nov 2002
Postovi: 1,950
Ja ti imam tu istu graficku al sa strane, ceka da ju netko kupi.
Inace skoro sve je radilo na njoj, same su me zezali GTA3 i UT2003.
Veky je offline   Reply With Quote
Staro 08.01.2003., 23:28   #23
CatKiller
CatKiller's Avatar
Postovi: 3,312
Radi , ali nije igrivo , ali dobro dođe za interaktivni screensaver
