Staro 23.11.2015., 13:30   #18151
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,741
Estetski nedostojno Bugatti-a. Idu u smjeru Lamborghini-a očito.
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
estugarda je offline   Reply With Quote
Staro 23.11.2015., 13:55   #18152
syss
syss's Avatar
Postovi: 10,805
jedan od rijetkih koncepata za kojeg ne bi htio da zaživi... ovo je odvratno iz svakog kuta.
Staro 23.11.2015., 14:17   #18153
lowrider
lowrider's Avatar
Lokacija: KR
Postovi: 1,153
Autor afterburner Pregled postova
Ekipa mislim se u neko dogledno vrime uzet auto oko 4500-5000€. Odma priznajem da o autima neman pojma(zato i pitam)... uglavnom ne treba mi nikakva jurilica ni veliki auto. Bitno mi je da ima klimu, servo i 5 vrata. Auto tipa VW polo mi se cini taman(sto se tice velicine).
Pa sad ako moze preporuka par modela/marki oko te cifre na koje da bacim oko, a koje da izbjegavam.
E i napomena da ce bit 99% gradska voznja i da ne planiram puno km radit.
Znači definitivno benzinac, i ne ove švapse 3cilindraše, gledaj nešto s 4 cilindra, Za tu lovu imaš Grandea, Corsi, Cliača i sl. koliko hoćeš.
Pa nešto većih Astri, Hyundai 130, Kie itd
Gledaj 1. vlasnika, čim novije. To su auti 2005+ i trebalO bi biti do 150 000km
Staro 23.11.2015., 14:24   #18154
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
Ja bih čak rekao do 100 000 km za male benzince. A ima ih. Samo pazi, i 3x provjeri sve, a naročito kilometražu. Prvo u stanici za tehnički, a onda kod pouzdanog majstora.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 23.11.2015., 14:26   #18155
lowrider
lowrider's Avatar
Lokacija: KR
Postovi: 1,153
Evo odlične prilike ak nije bio razbijena jako:
http://www.njuskalo.hr/auti/skoda-fa...oglas-16892201
Staro 23.11.2015., 14:28   #18156
lowrider
lowrider's Avatar
Lokacija: KR
Postovi: 1,153
Zadnje izmijenjeno od: lowrider. 23.11.2015. u 14:42.
Staro 23.11.2015., 15:34   #18157
jed2i
jed2i's Avatar
Datum registracije: Jul 2004
Postovi: 1,771
Staro 23.11.2015., 16:18   #18158
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,343
Koji je gušt vozit zimulje, tak je mekan auto
I još sam namazao gumene okvire sa glicerinom, promjenio zadnji brisač i to je to, snijeg kreni
žmnpp
Staro 23.11.2015., 16:22   #18159
syss
syss's Avatar
Postovi: 10,805
mene naručilo u petak za zamjenu, pa ima još malo uživat dok ne dođe caba c3
Staro 23.11.2015., 16:24   #18160
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Koja je muka prijeci sa 245/40R18 na 225/50R17. Prvo okrenem volan, a 10 sec kasnije skrene i auto. O ležećima da ni ne pričam, više ih ne osjetim. Muka.
Megy je do srijede na ljetnima.
Staro 23.11.2015., 16:26   #18161
syss
syss's Avatar
Postovi: 10,805
meni je muka osim profila i sama guma... ENO MI DUPLO MUKA!!!
Staro 23.11.2015., 16:31   #18162
MAGARAC
MAGARAC's Avatar
Postovi: 5,984
Je, dignut će ih. Pogotovo ako su sinovi kakvih dužnosnika ili lokalnih političara/šerifa.
No, fotkat takve i prijavljivat na onu MUP aplikaciju. Navodno da reagiraju na to.
Dignut ce ih ak im netko pozove pauka. Bil je par puta i susjedima odpeljal aute sa sredine jer ovi koji ni ne zive u zgradi su uzeli sva mjesta pa nisu mogli van. Parking je od zgrade, pauk bez poziva nemre nis dizat.. Prevelik je ulaz u parking, ince bi vec imali rampu, ovak je tesko izvedivo.
Bio u Slo danas po Save. Sutra idu na auto.. U HR je Sava rasprodana. Svima pise da ih imaju a nema ih nitko. Nude neke srpske koje su navodno ok..
Vozim se kod Harmice pored izbjeglickog kampa i kak su busevi parkani u mojoj traci moral sam ih obilazit. Bilo je 5,6 i krenem i dodem skoro do kraja i neka muslimanka uleti i ravno na mene, ko da ju je bunilo neko uhvatilo i ne vidi nista. Zaustavila se pol metra od branika, sestra i ja se usrali od straha. Prvo sam mislio jbt Slovenci bezobrazni dok nisam vidio zenu pokrivenu velom..
Zadnje izmijenjeno od: MAGARAC. 23.11.2015. u 16:48.
MAGARAC je online   Reply With Quote
Staro 23.11.2015., 16:51   #18163
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Strava Eskimo.
Staro 23.11.2015., 16:52   #18164
MAGARAC
MAGARAC's Avatar
Postovi: 5,984
Bit ce strava kad pol metra snijega padne.. Za drugo mi ni ne trebaju.. Ove su HP iliti high perf. tak da nema zajebancije..
U jednom trenu sam svasta mislio kaj se tice te zene u Senicu..
Staro 23.11.2015., 17:00   #18165
MuroF
MuroF's Avatar
Lokacija: VŽ-okolica
Postovi: 118
to su baš zimske?
bugatti izgleda kao da će pojest sve laferrarije,pošree,mclarene i ostale..a vjerujem da i hoće.
MuroF je offline   Reply With Quote
Staro 23.11.2015., 17:03   #18166
MAGARAC
MAGARAC's Avatar
Postovi: 5,984
http://www.sava-tires.com/sava/emea/...ger/eskimo-hp/
Nisam ni znal kaj sam kupil dok nisam sliku malo bolje pogledal.. Ne vozim se puno u SXu i po zimi ga vozim na poslu samo ak padne puno snijega i za moje potrebe po gradu. Megane ima dva god. stare UG8 i dosta su bucne al ostalo je ok. Danas sam napravio oko 250km na njima.. SX je 4,5 godina bio na UG7...
Staro 23.11.2015., 17:12   #18167
lowrider
lowrider's Avatar
Lokacija: KR
Postovi: 1,153
Još jednom, Sava je odlična za zimske uvjete za 99% ljudi, osim za onaj 1% koji svakodnevno vozi utrke na posao i slične destincije
Staro 23.11.2015., 17:17   #18168
MuroF
MuroF's Avatar
Postovi: 118
po šari mi više vukla na cjelogodišnju..
dunlop winter sport 5 je navodno rasturio u više kategorija,danas čitao neki test al sad se ne sjecam di..a i UG9 se bori za vrh.
Staro 23.11.2015., 17:20   #18169
MAGARAC
MAGARAC's Avatar
Postovi: 5,984
Ima u zadnjem AUto klubu test cjelogodinjih i ni jedna nije na nivou na snijegu i mokrom. Nisu ni na visokom temp. dobre na morkom ni na suhom. Ubacili su Alpin A4 i Conti ljetne u usporedbu.
Zanimljve brojke u svakom sl..
Zadnje izmijenjeno od: MAGARAC. 23.11.2015. u 17:36.
Staro 23.11.2015., 17:27   #18170
MuroF
MuroF's Avatar
Postovi: 118
ma to je eventualno guma za nekog iz Dalmacije il tako nešto,nit dobra ljeti nit zimi,a opet prosječna u svemu..2 seta i amen,nema bolje opcije.
Staro 23.11.2015., 17:29   #18171
chief_wolfinjo
imao sam te gume, jako su dobre. sam imaju nekakav čudan zvuk.
Staro 23.11.2015., 17:32   #18172
Dottore
Dottore's Avatar
Postovi: 7,614
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 23.11.2015., 18:05   #18173
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Zezam se. Imaju stvarno čudnu šaru za zimske gume.
Dunlop Winter Sport 5 su mi zasad vrhunske, puno bolje nego na mojem autu TS850... Po ovoj hladnoj kiši su odlično odradile posao.
@Dottore - puno manje mu bježi zadnji kraj kod izlaska iz zavoja sa Trofeo R. Zanima me usporedba Trofeo R i Sport Cup 2.
Nove Michelin Pilot Sport 4!!! Me likey! Idu nakon zime na auto! http://www.michelin.co.uk/tyres/michelin-pilot-sport-4
Staro 23.11.2015., 18:11   #18174
Dottore
Dottore's Avatar
Postovi: 7,614
Čepo si Danlop pet?
Bilo je i vrijeme da izađe nasljednik PS3 , ali ježi ga jer nema 16"
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 23.11.2015., 18:26   #18175
syss
syss's Avatar
Postovi: 10,805
Autor IcyTexx Pregled postova
pa šara je ko na mojim pe2, samo vjerujem da je ovo dostupno u osjetno većoj dimenziji.
Staro 23.11.2015., 21:56   #18176
Milentije
Adrenaline junkie
Milentije's Avatar
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Icy koji je motor u tvom meganu?
Staro 24.11.2015., 02:02   #18177
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Autor Milentije Pregled postova
1.5dCi, 60kW.
Winter Sport 5 su na drugom autu. Mojim TS850 je tek druga sezona.
Staro 24.11.2015., 08:41   #18178
zgmmax
zgmmax's Avatar
Postovi: 1,656
Dal su i dalje guzve u MUPu u Heinzelovoj?
Nisam bil dugo pa ne znam kaj ocekivat
Staro 24.11.2015., 09:48   #18179
syss
syss's Avatar
Postovi: 10,805
nije strašno... otišao sam ranije s posla i bio tamo oko 16h,ja sam bio ticket ~550, now serving 390.
oko 20:30h došao doma, a živim maltene prek puta hajnclove.
Staro 24.11.2015., 10:02   #18180
lowrider
lowrider's Avatar
Lokacija: KR
Postovi: 1,153
Autor syss Pregled postova
Pa ti bi mogao vidjeti te ekrane s brojevima sa svog prozora
Trebali su neki live feed tog reda čekanja za mobitele napraviti, ova 4 sata je jako puno vremena.
Evo ideje za biznis
