Postovi: 227
The disk is write protected
Radi se o sticku Kingston DataTraveler 100 G3 32gb. Nemogu ga formatirati, javlja poruku iz naslova. Probao sam sve sa ovoga linka: http://ccm.net/forum/affich-687538-h...usb-flash-disk Pregledao sam ga sa malwarebyte-om,nod-om 32... Probao kroz disk managment, cmd, reg edit, format kroz windowse i ništa ne pomaže.............. Help ![]() |
Xulos :)
Postovi: 7,561
cmd kao admin i onda diskpart list disk select disk x (where x is the number of your USB flash drive – use the capacity to work out which one it is) attributes disk clear readonly clean create partition primary format fs=fat32 (you can swap fat32 for ntfs if you only need to use the drive with Windows computers) exit http://www.factsnfakes.in/how-to-ena...ve-in-windows/
White Rabbit
Postovi: 4,987
Postovi: 227
A izgleda..... ![]() ![]() Kad mu izlistam preko cmd-a attribute disk read only mu je u NO,ali svejedno nemogu ništa s njime..... Probao i kroz regedit (StorageDevicePolicies) ali opet ništa....... |
