Staro 21.09.2005., 21:05   #1
Mailman
Mailman's Avatar
Postovi: 1,606
Catalyst 5.9
Issues Resolved in Catalyst™ Software Suite 5.9
The following section provides a summary of the issues that have been resolved in the latest version of Catalyst™. These include:
* Battlefield 2: The game no longer exits to the Windows desktop after the game logo is displayed
* Endorphin: Running the application under Windows XP no longer results in hesitation being noticed during simulation or playback
* Max Payne 2: Erratic mouse pointer behavior is no longer noticed within the game's menu after a short time period of game play
* MU: Opening a chat window and playing the on-line game no longer results in Hesitation being noticed when pressing the Enter key
* Silent Hunter 3: Enabling all video options within the game and setting the particle density to 100, along with setting Anti-Aliasing to 6X and Anisotropic Filtering to 16x, no longer results in display corruption on the left portion of the display
* Star Wars Knights of the Old Republic 2: Running the Dantoonie level of the game no longer results in hesitation being noticed
* Terminator 3: The game no longer fails to respond and a VPU Recover message no longer occur after loading the game character
* The Catalyst Control Center no longer displays blank pages when quickly exiting and re-launching the Catalyst Control Center while hot-plugging or hot-unplugging a CRT display device
* Installing an All-in-Wonder into a system containing an ATI Radeon Xpress 200 series and an ATI Theater 550 Pro no longer results in loss of signal error message when setting the country region to Sweden
* HDTV support may still be displayed within the control panel with ATI products that do not support HDTV
* Connecting two display devices using the DVI and CRT connectors on a system containing an ATI Xpress 200 results in the system failing to resume when entering standby state
* Catalyst Control Center: The Overdrive Automated Clock Configuration Utility may continue running even after the user selects apply or cancel in the utility's confirmation window
* Connecting two display devices using the DVI and CRT connectors on a system containing an ATI Xpress 200 no longer results in the system failing to resume when entering standby state. Further details can be found in topic number 737-19538
* Catalyst Control Center: Connecting a TV as the only display device to an ATI Radeon X300/X600 series no longer results in the Signal Format found in the Adjustment page of the TV Properties being labeled as Unknown
* Three of the four ATI entries found in the Add or Remove Programs for Windows XP Japanese version, are no longer displayed in English
* The Catalyst Control Center shortcut is now removed when selecting to uninstall the ATI software driver
* Catalyst Control Center: The Overscan slider bar now displays a Minimum, Medium and Maximum setting for All-in-Wonder SCART boards
* WDM version numbers are no longer documented in the Information Center of the Catalyst Control Center for ATI products that do not support WDM drivers
* An intermittent error message is no longer experienced when selecting all of the aspects within the Catalyst Control Center quickly
* The limited account user no longer has the ability to add a short cut for the profile manager in the system tray
* Overdrive settings no longer revert back to the default setting when connecting a secondary display device and enabling extended desktop mode
* Moving the slide bar found in the Adjustments aspect of the Catalyst Control Center are now restored to their pervious levels when clicking the discard button
* A horizontal shifting issue when using the capture application is now resolved
* Changes to the audio settings are now retained after a system reboot when using the ATI Theater 550 Pro
* Resuming from suspend mode no longer results in the audio level returning to its default value
* Poor quality of static texture and scrolling text when watching live TV on system containing an ATI All-in-Wonder X800 series product is no longer noticeable
* Catalyst Control Center: The hot-key list is now dynamically populated to reflect the enable/disable status
* The Use Manual Detection Only translation for traditional Chinese is now correct
* The Overscan/Underscan option found in the Catalyst Control Center has now been translated properly for the Russian language
* The ability to navigate within the Catalyst Control Center while a confirmation dialog box for the Catalyst Control Center is displayed is no longer possible
* The Apply button is now available when making a change to 3D aspect page in the Catalyst Control Center
* Intermittent launch failures of the Catalyst Control Center is now resolved
* Connecting two display devices to the Radeon X700 using the DVI and CRT connectors no longer results in display corruption being noticed when booting Windows XP
* Connecting an HDTV and a CRT display device followed by disabling the CRT and rebooting the system no longer results in the HDTV failing to display an image and the CRT becoming active again
* HDTV support no longer fails to be detected properly after connecting a CRT and TV to the ATI Radeon Xpress 200 series
* Display corruption is no longer noticed on the secondary display device when disabling extended desktop mode
* Setting Anti-Aliasing to 4x in the Catalyst Control Center no longer results in a blank window or an error message being displayed when launching Java plug in
* Hesitation is no longer noticed during the opening cinematic of Madagascar when rotating the display device by 180 degrees
* Display corruption is no longer noticed when running the Codecreatures benchmark when the FrameBuffer is set to 64MB on system containing an ATI Radeon Xpress 200 series
* An extraordinarily long delay is no longer noticed when resuming from an S3 state
* Overlay corruption is no longer noticed when turning off the primary display device in systems containing an ATI Radeon Xpress 200 series
* The display resolution options of 800x600 and 640x480 mode are no longer available within the Display Manager aspect after rotating a desktop that is rotated by 90 or 270 degree
* Running 3D billboard under XP and having the application window display on the left side of the primary display, no longer results in the 3D screen image staying on the left side when dragging the application to the right side of the display device
* A black screen image is no longer displayed when entering a full screen DOS prompt when using an ATI Radeon 9800 XT under Windows XP
* The Windows XP Professional x64 Edition operating system no longer prompts the user for confirmation of the un-install of ATI Parental Control when running the ATI un-attended un-install
* Entering standby mode under the Windows XP operating system no longer results in display corruption being noticed or the operating system failing to respond
* Display corruption when using the TV-Out composite setting has now been resolved for the ATI Radeon Xpress 200 series
* Video corruption is no longer noticed when playing a DVD under Windows XP MCE
* Live TV no longer appears choppy when using and ATI Radeon X300 and two ATI Theater 550 Pro tuner cards and outputting to PiP in PowerCinema
* Video jitter is no longer noticed when playing back video using overlay with DXVA
* The German language control panel text no longer appears truncated when using 96 DPI
www.ati.com
Mailman je offline   Reply With Quote
Staro 21.09.2005., 21:07   #2
Mailman
Mailman's Avatar
Postovi: 1,606
Known Issues for Catalyst™ Software Suite 5.9
The following section provides a summary of open issues in the latest version of Catalyst™. These include
* City of Heroes: Playing the game under Windows XP Media Center Edition may results in display corruption being notice when attempting to task-switch between the game and the desktop. Further details can be found in topic number 737-19792
* Prince of Persia: Sands of Time: Attempting to launch the game under Windows with an ATI Radeon X800 XL installed results in an error message being displayed. Further details can be found in topic number 737-19787
* The Apply button in the Custom settings of the Advanced mode found under the Catalyst™ Control Center Video standard settings is grayed out when playing a media file. Further details can be found in topic number 737-497
* Connecting an HDTV to an ATI Radeon X700 series may result in the HDTV being detected as a CRT or TV under the Windows XP operating system. Further details can be found in topic number 737-20575
* Attempting to install the integrated WDM driver under Windows XP may result in an error message being displayed indicating that the hardware is not installed because the install Wizard cannot find the necessary software. Further details can be found in topic number 737-20576.
* Connecting a CRT and a TV may result in the TV not being automatically detected under Windows XP MCE when using an ATI Radeon 9550/9600/9650 series. Further details can be found in topic number 737-20577
* Using the Custom option when installing the software driver results in the Theater 550 software driver not being present. Further details can be found in topic number 737-20579
ATI Desktop product family support
The Catalyst™ software suite is designed to support the following ATI desktop products:
* Radeon® X850 series
* Radeon® X800 series
* Radeon® X700 series
* Radeon® X600 series
* Radeon® X550 series
* Radeon® X300 series
* Radeon® 9X00 series
* Radeon® 8500 series
* Radeon® 7X00 series
zanimljivo, nema najave R520.....
možda u .ini-jima...
Staro 21.09.2005., 22:46   #3
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Eto ti ga na vraže, zaigrao se sa SS2-odem na net kad već novi driveri
Ajd, tko je probao nek podijeli iskustva
Staro 22.09.2005., 10:33   #4
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 6,994
Poveći broj riješenih bugova
Staro 22.09.2005., 12:13   #5
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,962
Up and piči
Staro 22.09.2005., 18:37   #6
damir1
Ancient
damir1's Avatar
Lokacija: Đakovo
Postovi: 893
čekam omege
valjda će ga proći taj WOW već jednom
damir1 je offline   Reply With Quote
Staro 22.09.2005., 18:50   #7
Mailman
Mailman's Avatar
Postovi: 1,606
čekam W1zzarda....
Staro 22.09.2005., 21:16   #8
Jelc
Super Moderators
Postovi: 17,485
Originally posted by damir1
čekam omege
Teško
Osim toga-tek su prije deset dana izašli Omega 5.8
Staro 22.09.2005., 21:37   #9
Gemmy
smeghead
Gemmy's Avatar
Postovi: 3,154
Ja ih mislim probat sutra
Nego kojim programom izbrišem skroz stare drivere(nakon rem. u control panelu)
Staro 22.09.2005., 21:51   #10
Jelc
Super Moderators
Postovi: 17,485
Po jubilarni 101 put
http://www.drivercleaner.net/
Staro 22.09.2005., 22:20   #11
Gemmy
smeghead
Gemmy's Avatar
Postovi: 3,154
TNX Jelc
Ja ću ih prventveno isprobat zbog ovog
Nadam se da nakon toga neće više izbacivat
Staro 23.09.2005., 19:54   #12
Mailman
Mailman's Avatar
Postovi: 1,606
Originally posted by Mailman
čekam W1zzarda....
http://www.techpowerup.com/softmod/downloads.php
Staro 23.09.2005., 20:26   #13
Mailman
Mailman's Avatar
Postovi: 1,606
hahahah.....maknuli su onaj beskorisni truform slider iz opcija...
Staro 23.09.2005., 20:54   #14
Jelc
Super Moderators
Postovi: 17,485
Ma, je li to uopće poslužilo u kojij igri???
RTCW?
Staro 23.09.2005., 21:12   #15
illusion
illusion's Avatar
Postovi: 562
TNX Jelc
meni radilo i sa 5.6, 5.7 i 5.8 ali mi je izbacilo van pa ponovno pokrene, dok kod frenda ni igru nije pokretao dok nisam skinuo 5.9 i inst glavno je da je meni radilo
TNX jelc
illusion je offline   Reply With Quote
