Staro 13.09.2014., 18:31   #7231
Thoroughbred B
Thoroughbred B's Avatar
Datum registracije: Apr 2003
Lokacija: RI
Postovi: 4,918
Evo Ace nakon 5 borbi s m48 pattonom
http://wotreplays.com/site/1162968#f...enspirit-m48a1
BTW završio po fame bodovima na 4068 mjestu...za upucat se...
Staro 14.09.2014., 12:44   #7232
m4dm4n
Does youer dewg byte?
m4dm4n's Avatar
Postovi: 1,967
Ima tko kakav invite code sa điđama miđama da mi ponudi na PM ?
Staro 14.09.2014., 17:24   #7233
Thoroughbred B
Lokacija: RI
Postovi: 4,918
Staro 14.09.2014., 23:05   #7234
Dottore
Dottore's Avatar
Postovi: 7,736
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 15.09.2014., 15:02   #7235
m4dm4n
m4dm4n's Avatar
Postovi: 1,967
Staro 15.09.2014., 15:04   #7236
m4dm4n
m4dm4n's Avatar
Postovi: 1,967
Autor Dottore Pregled postova
Mijenjaj crew skills pod hitno.
Staro 15.09.2014., 18:24   #7237
Dottore
Dottore's Avatar
Postovi: 7,736
Kako? Moram baš sve? Znači ispočetka
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 15.09.2014., 18:37   #7238
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
Napraviš drop perkova i platiš po članu posade mislmi 20k silvera i onda ti se zadnji skill spusti za cca 10%, i sve ih možeš nanovo izabrat.
Dakle commander prvi i glavni ti je 6 sense, drugi možeš recon ili repair a treći ako već želiš stavi BIA.
Na gunnera obavezno stavi ovaj prvi koji imaš (ubi me nemrem mu se sjetit imena), drugi obavezno repair, treći možeš bia, kod drivera prvi cluch braking, druga dva kao gore, loader safe stowage, ostale kao gore.
Tako bi ja napravio ako želiš imat biu (iako je nećeš još imat ali će bit prvi sljedeći gotovi skill).
S tim da ne brzaj sa zamjenom da ne bi morao 2 put radit drop skillova a to je onda muka za vratit, čekaj da ti još ljudi kažu kaj da staviš.
žmnpp
Staro 15.09.2014., 19:23   #7239
m4dm4n
m4dm4n's Avatar
Postovi: 1,967
Autor buljo Pregled postova
Ovaj skill je Dead Eye. Nije nešto posebno, no ja ga volim uvijek imat, nikad nije loše povećati šansu za uništenje modula.
Napravio bih skillove točno kak si rekao.
Staro 15.09.2014., 20:14   #7240
Dottore
Dottore's Avatar
Postovi: 7,736
Commander: 6th sense, then repair
Gunner: Repair, then snap shot
Driver: Repair, then Off Road
Loader: Safe Stowage, then repair
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 16.09.2014., 00:42   #7241
Dottore
Dottore's Avatar
Postovi: 7,736
Evo konačno ispravio i poslije toga ide BIA
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 16.09.2014., 01:08   #7242
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
Super, još i bolje nego da si biu stavio za treći skill, nije tolika razlika na tom tenku da bi opravdao jedan slot na skillu.
Inače lampica ti se pali sa zadrškom od 2-3 sekunde, tako da ako snipaš i upali se lampica nemoj čekat sekundu da opališ šut nego odma bježi jer vrlo vjerojatno te već ciljaju.
I ta lampica je barem meni definitivno prvi i najbolji skill na svakom tenku. Kad je nema hendikepiran sam
žmnpp
Staro 16.09.2014., 01:21   #7243
Thoroughbred B
Lokacija: RI
Postovi: 4,918
Šta radi cammo skill na loaderu ?
Staro 16.09.2014., 01:27   #7244
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
Kamuflira ga
Ajde ajde nije uopce lose slozio
žmnpp
Staro 16.09.2014., 01:40   #7245
Dottore
Dottore's Avatar
Postovi: 7,736
Repair --> Recon/Mentor)
Gunner: Snap Shot, (BIA --> Repair --> Designated Target )
Driver: Smooth Ride, ( BiA --> Repair --> Clutch Braking )
Loader: Safe Stowage, ( BiA --> Repair --> Adrenaline Rush )
Nisam imao uopće pojma da je koristan Six Sense.
IS-8 trenutno ( uskoro tim redosljedom )
Commander: Sixth Sense, (BIA --> Repair --> Recon/Mentor)
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Zadnje izmijenjeno od: Dottore. 16.09.2014. u 01:54.
Staro 16.09.2014., 01:54   #7246
m4dm4n
m4dm4n's Avatar
Postovi: 1,967
Autor Dottore
Nisam ni ja dok ga nisam stavio, i još kad sam skužio da radi sa zadrškom od par sekundi, nema veće sreČe.
Staro 16.09.2014., 09:18   #7247
Thoroughbred B
Lokacija: RI
Postovi: 4,918
Ja bi odmah stavio repair,pa tek onda BIA...bia ne daje puno,a težak je grind...lakše ju je grindat s repair skillom,to se ipak osjeti drastično...i to odmah
Staro 17.09.2014., 10:44   #7248
Thoroughbred B
Lokacija: RI
Postovi: 4,918
Pitanje,frend ima problema s WOT-om,ulogira se...klikne battle i izbaci ga na desktop...isto tako ja mu mogu poslat ingame chat,primi,ali ne može mi poslat ništa...isto tako ga izbaci kad klikne gore "istraži"...meni se čini firewall,ali kaže da je to provjerio...any ideas?
7.2k dmg m48,šteta što sam dao turret tomato IS3,taman mi ga sj...mogao sam napravit 8k bez beda.
http://wotreplays.com/site/1174106#f...enspirit-m48a1
Zadnje izmijenjeno od: Thoroughbred B. 17.09.2014. u 19:40.
Staro 17.09.2014., 22:32   #7249
rodney
only fool, not a horse
rodney's Avatar
Datum registracije: Apr 2008
Lokacija: near zgb
Postovi: 1,281
Skine ti 10% ukupnog iskustva, a ne samo zadnji skill.
"I intend to live forever. So far, so good."
job security - example
rodney je offline   Reply With Quote
Staro 18.09.2014., 09:46   #7250
KillerLoop2807
motion graphics freak
KillerLoop2807's Avatar
Datum registracije: Jun 2010
Lokacija: Kutina
Postovi: 177
Pogledajte zadnjih par minuta ovog replaya, kada IS počne cap. Gluplju ososbu u životu nisam vidio, kako je taj došao do T7 zbilja mi nije jasno... Ignore the chat BTW. :P
http://wotreplays.com/site/1175071
A evo i jedan Ace tanker od sinoć, zadnja partija
http://wotreplays.com/site/1175072
KillerLoop2807 je offline   Reply With Quote
Staro 19.09.2014., 12:22   #7251
Thoroughbred B
Lokacija: RI
Postovi: 4,918
Igra li netko na 27" 1440p?
Staro 19.09.2014., 13:01   #7252
Dottore
Dottore's Avatar
Postovi: 7,736
Autor Thoroughbred B Pregled postova
Za to bi trebala jača grafička. Ako misliš gurati na full detalju.
Evo, dva mjeseca igram na integrušu. Gotovo sam zaboravio kako igrati sa GF 560Ti
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 19.09.2014., 13:12   #7253
Thoroughbred B
Lokacija: RI
Postovi: 4,918
Poslužit će 660ti...ne mora baš sve na full
Mislio sam vidjet koliko to pojede perf...
Staro 19.09.2014., 13:42   #7254
Dottore
Dottore's Avatar
Postovi: 7,736
Neće puno, ali veća rezolucija minimalno 2Gb. Možeš i tjerati na full.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 19.09.2014., 16:46   #7255
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
Prekjučer sam igrao sa frendom u platunu i imali smo tako loše partije da se nisam mogao načudit, tier 9 i 10, nakon 40 partija sam imao 38 % wr i 1100 WN8, nikad od kad igram ovu igru nisam imao tako loš dan, jednostavno šta god sam napravio bilo je krivo.
Jučer sa drugim frendom igramo fv arty 6, i tier 7 i 8, nakon 25-30 partija wr je bio 68% a wn8 3100.
Bio bi 3500 da me zadnjih par partija nije bacalo u desetke sa is3. Još frend komentira na moje: Ah opet ace tanker,
da se više uopće ne veselim tom aceu kao prije, velim ma veselim se ali samo na tenkovima di to nemam
žmnpp
Staro 19.09.2014., 20:35   #7256
skoda90
skoda90's Avatar
Datum registracije: Mar 2010
Postovi: 384
Ja sam danas gotov sa fv 6icom,stvarno odlican arty,istrazio sedmicu u 130 bitki...ovaj sljedeci mi nekak nema logike naprijed ide 14 u rikverc 40-50 :S
skoda90 je offline   Reply With Quote
Staro 20.09.2014., 22:18   #7257
skoda90
skoda90's Avatar
Postovi: 384
Napokon sjela jedna fina partija sa t30 i dobrim igracima,inace dobijem sve noobove poput sebe
http://wotreplays.com/site/1182271#k...skoda_ivan-t30
Staro 21.09.2014., 14:00   #7258
Thoroughbred B
Lokacija: RI
Postovi: 4,918
Sreo kolegu iz klana u randomu i paf Ace...konačno
Mogao sam i puno više da nije bilo Lorr camper cunta koji me riješio iz baze,ali mogao sam i ja biti malo oprezniji.
http://wotreplays.com/site/1184050#s...spirit-type_61
Otprilike ovako nešto je potrebno da se dobije 40% chance to win borba
http://wotreplays.com/site/1184515#e...enspirit-m48a1
Zadnje izmijenjeno od: Thoroughbred B. 21.09.2014. u 17:12.
Staro 22.09.2014., 16:13   #7259
Pepermint
Pepermint's Avatar
Postovi: 587
mijenjajte pass, 300 golda daju opet
http://worldoftanks.eu/en/news/pc-br...assword-event/
P: Guild Wars 2 account, ponude na PM
Pepermint je offline   Reply With Quote
Staro 22.09.2014., 17:41   #7260
pinkskin
pinkskin's Avatar
Lokacija: Daruvar
Postovi: 1,747
http://ftr.wot-news.com/2014/09/22/w...ally-november/
do kraja 10. mjeseca i M48 patton bi se trebao naći u mojoj garaži
