Staro 01.07.2014., 23:19   #1
Traitorous_8
Traitorous_8's Avatar
Lokacija: Vž
Postovi: 81
Winamp has stopped working
Pozdrav,
Pri pokusaju reprodukcije jednog za sada jedinog albuma winamp mi javlja gresku iz naziva. Probao sam reinstalirati no nista, cak sam ponovo skinuo taj isti album no problem ostaje i dalje.
Kakve ideje?
Hvala!
The complexity for minimum component costs has increased at a rate of roughly a factor of two per year ... Certainly over the short term this rate can be expected to continue, if not to increase. Over the longer term, the rate of increase is a bit more uncertain, although there is no reason to believe it will not remain nearly constant for at least 10 years. That means by 1975, the number of components per integrated circuit for minimum cost will be 65,000. I believe that such a large circuit can be built on a single wafer. - Gordon Moore
Traitorous_8 je offline   Reply With Quote
Staro 01.07.2014., 23:30   #2
MMI
MMI's Avatar
Postovi: 913
ne bi znao al probaj AIMP3, od kad sam ga "otkrio" winamp sam zaboravio
MMI je offline   Reply With Quote
Staro 02.07.2014., 00:59   #3
Traitorous_8
Lokacija: Vž
Postovi: 81
Autor MMI Pregled postova
Radi sa AIM kao sto radi i sa svim ostalim multimedijalnim programima koje imam osim sa winamp. Cudno. Btw hvala na linku, dobar je AIMP3!
Staro 02.07.2014., 03:29   #4
HumWeed
HumWeed's Avatar
Lokacija: Lava Reef
Postovi: 1,140
winamp ima nekad problema sa odredjenim "kodekima"
meni recimo svira pcm wave dok ostale vrste ne samo se zablokira
Why would you invite a mushroom to a Christmas party? He's a fun guy to be with.
Why do mummies like Christmas so much? Because of all the wrapping.
Why does Santa have three gardens? So he can "ho ho ho".
HumWeed je offline   Reply With Quote
