Staro 10.08.2005., 14:38   #1
Nebelwerfer
Nebelwerfer
Nebelwerfer's Avatar
Datum registracije: Apr 2004
Postovi: 270
video fajlovi mi zamrzavaju windowse
skinuh sa neta izvještaj tekme wisla - PAO i kad god želim otvorit folder u kojemu se nalaze 4 video fajla, komp se sav zablokira, pa moram pomoću task managera ugasit proces, moguće je da su fajlovi shebani, ali opet vidim da drugi sa njima nemaju problema...:confused: jeli možda stvar u codecima?
Nebelwerfer je offline   Reply With Quote
Staro 10.08.2005., 14:49   #2
Nebelwerfer
Nebelwerfer
Postovi: 270
zanimljivo, skinuo sam Gspot da vidim jel mi koji codec nedostaje i kaze da imam sve codece....
očito je stvar u tome da zamrzava windoze jer su mi video fajlovi namješteni da kad se otvori folder da ih se prikazuje kao thumbnailove....zašto mi to radi nemam uopće pojma....ima li ko isti takav slučaj?
gdje mogu namjestit da mi sve foldere sa video fajlovima prikazuje kao normalne ikone ili listu na ne kao thumbnailove?
Staro 10.08.2005., 17:06   #3
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
mislim da bi ti ovo moglo pomoci
Well windows seem to have a REALLY big problem when it comes to reading
AVI files. It seems that when you click on an AVI file in explorer,
it'll try to read the entire AVI file to determine the width,height,
etc. of the AVI file (this is displayed in the Properties window). Now
the problem with Windows is that if you have a broken/not fully
downloaded AVI file that doesnt contain this info, Windows will scan the
entire AVI file trying to figure out all these properties which in the
process will probably cause 100% CPU usage and heavy memory usage.
To solve this problem all you have to do is the following:
1. Open up regedit
2. Goto HKEY_CLASSES_ROOT\SystemFileAssociations\.avi\shellex
\PropertyHandler
3. Delete the "Default" value which should be "{87D62D94-71B3-4b9a-9489-
5FE6850DC73E}"
Voila! Please not that this will no longer provide you with the windows
properties displaying the AVI file information such as width, height,
bitrate etc. But its a small price to pay for saving you resources
.i.
Razer Blade 15
Staro 10.08.2005., 17:11   #4
Nebelwerfer
Nebelwerfer
Postovi: 270
je, to je to, puno hvala!:clap:
Staro 10.08.2005., 22:27   #5
Ivan_1
Lokacija: Duga Resa
Postovi: 823
Da ne otvaram novu temu...
meni se pak zna dogoditi da kad samo označim jednim klikom na neku video datoteku s MPEG ekstenzijom dogodi se: "explorer.exe has encountered an error and needs to close" i nakon par sekundi opet se pokrene. da li se to može riješiti na takav način samo sa za mpeg fajlove ili je problem u video datoteci?
Ivan_1 je offline   Reply With Quote
