Staro 29.03.2014., 17:21   #1
Traitorous_8
Traitorous_8's Avatar
Lokacija: Vž
Postovi: 81
Windows 7 ultimate 64bit+WLM 2012 problem
Pozdrav svima,
Tek sto sam presao na Win 7 vec problemi.
Kako pisem odgovor (reply) na mail tako mi text nestaje, u cemu je problem?
Hvala!
The complexity for minimum component costs has increased at a rate of roughly a factor of two per year ... Certainly over the short term this rate can be expected to continue, if not to increase. Over the longer term, the rate of increase is a bit more uncertain, although there is no reason to believe it will not remain nearly constant for at least 10 years. That means by 1975, the number of components per integrated circuit for minimum cost will be 65,000. I believe that such a large circuit can be built on a single wafer. - Gordon Moore
Traitorous_8 je offline   Reply With Quote
Staro 29.03.2014., 17:39   #2
ThePornstar
ThePornstar's Avatar
Postovi: 4,399
Probaj isključit spell check, imao sam i ja sličnih problema prije.
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
Battery: 57 Wh internal
ROM: Android 9
Staro 30.03.2014., 11:00   #3
Traitorous_8
Lokacija: Vž
Postovi: 81
Znas u cem je problem? Totalno cudno al ako pocistim u browserima history tada sve stima!
