Zaključane teme
Staro 11.02.2014., 17:50   #3571
Xenon
Postovi: 1,542
nema,
Zakaj još nema update za 620?? Treba bi Glance 2,0!!!
Xenon je offline
Staro 11.02.2014., 17:52   #3572
Don Kihoty
Datum registracije: Apr 2011
Lokacija: Sisak
Postovi: 1,373
Mozda i nedobija black ovaj mjesec...
Don Kihoty je offline
Staro 11.02.2014., 18:18   #3573
gin.tonic
gin.tonic's Avatar
Postovi: 2,446
Debela lista novosti s WP 8.1:
http://www.wpcentral.com/developers-...s-phone-81-sdk
-NEW Audio/video transcoding, Hardware accelerated
-NEW Media editing: audio and video; Audio effects, video effects; Slow motion video
-NEW Apps can capture audio/video from themselves
-NEW Stereoscopic 3d support
-NEW Wi-Fi Direct, a Wi-Fi standard allowing direct peer-to-peer connections over Wi-Fi without an access point
-NEW Windows Phone 8.1 apps won't run on 8.0 devices until they upgrade
-NEW Documentation confirms ALL current Windows Phone 8 hardware to get 8.1
-NEW Dev tools: SemanticZoom, DatePicker, TimePicker
-NEW PlayTo support
-NEW Single sign-in for apps (like on Windows 8) with Microsoft Account; sign in will persist across devices + apps with permissions prompt
-NEW YouTube Player (see lede image) including HTML5 video support (video playback doesn't have to be full screen) And you get custom UI, so YouTube Closed Captions are in
-NEW File picker (see above image)
-NEW Geofencing API for location-based reminders
-NEW Background tasks: Bluetooth signal strength, Chat message notification, -Device connection change, Device use trigger, Gatt characteristic notification, Location, Push notification, Rfcomm connection, System event, Timer
-NEW Slide down to close apps
-NEW Navigation bar color selection
-NEW USB choices
-NEW Updated camera layout, similar to Windows 8.1 (see lede photo above)
-VPN (Virtual Private Network)
-OneDrive (previously SkyDrive) with integrated file browser (just like Windows 8.1)
-Filter through installed apps by usage/install date
-Select multiple tiles when customising the Start screen
-More efficient multitasking
-Ability to install apps on inserted SD Cards
-Internet Explorer 11 improved with WebGL and Normal mapping support
-Separate volume controls for ringer, media, etc.
-Bing smart search (similar search system as Windows 8.1)
-Xbox Music and Xbox Video as standalone apps instead of the Music + Video -Hub (allowing more updates to be pushed)
-Redesigned Xbox Game Hub
-Twitter integrated more deeply into the contacts Hub
-Facebook account option REMOVED (updated)
-Quick settings access (Wi-Fi, Bluetooth) by doing a quick swipe from the top of the screen
-Action Center accessed by doing a full swipe from up to the bottom (separate from the Notification Center)
-Silent notifications which go directly to the Action center
-Possibility to mark a Live Tile as read by swiping from the left of said tile
-'Cortana' smart agent performs the same tasks as Siri and Google Now and even more, including data from Foursquare (MS INVEST)
-Auto-updates for apps (just like Windows 8.1)
-Better backup functionality
-Improved keyboard
-Bluetooth 4.0 LE (to non-Lumia Windows Phones)
-Feature to mirror Windows Phone screens to TVs and/or monitors
-A final interesting note is how Windows Phone is referred to as WinPRT.
Zadnje izmijenjeno od: gin.tonic. 11.02.2014. u 21:17.
gin.tonic je offline
Staro 11.02.2014., 18:37   #3574
trouble
našikan pravim haos
Lokacija: u zabrani
Postovi: 2,707
Autor gin.tonic Pregled postova
Jel vam sad jasno da ste kakili one smeđe kobaje cijelo vrijeme dok ste mi govorili kako je usluga pusha pouzdana. Pouzdana je bila ko poklopac torpedo cijevi na podmornici Kursk. Ovo nije trollanje,flejm nego činjenično stanje. Nisam često na ovom topicu(a i sam koristim HTC 8X ko službeni) jer su tu obično ljudi pametniji i od samog MS....a bojim se iako je i MS sam priznao da im je sistem pusha u banani,ne sumnjam da će se nać neki genijalac iz Babine Grede koji će me pokušat uvjeriti da Microsoft to ne misli onako kako prikazuje u changelogu...
trouble je offline
Staro 11.02.2014., 18:50   #3575
gin.tonic
gin.tonic's Avatar
Postovi: 2,446
Ne znam, meni notifikacije na Whatsupp normalno dolaze, imam WP8 skoro godinu dana, da ne radi kako treba već bi prodao mobitel jer ga koristim svaki dan.
Nekad zna kasniti ali jako rijetko, isto kako i curi na Androidu zna kasniti.
Staro 11.02.2014., 18:53   #3576
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,139
Istina, Viber i Facebook su kasnili ali sa updejtovima je to riješeno. A koliko ja znam update aplikacije ne dira sistem tako da sam siguran da je do aplikacija, ne do OS-a.
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Mario92 je offline
Staro 11.02.2014., 19:00   #3577
trouble
našikan pravim haos
Lokacija: u zabrani
Postovi: 2,707
Meni je bilo momenata kad su dolazile kako spada....a nekad sam moram u samu app ući i tek onda je pisalo delivered na frendovom telefonu. MIslim,WP central forum je bio prepun takvih žalbi. Naravno da sam sve isprobao i šanse su bile 50-50. A da nije do OSa...nebi ispravljali osim ako im je baš jako dosadno pa iz dosade izbacuju novi push deamon spec. za Viber i Whatsapp(po mob.hr forumu).
trouble je offline
Staro 11.02.2014., 21:33   #3578
akoj
lijevo smetalo
akoj's Avatar
Datum registracije: Jan 2014
Postovi: 1,120
Bit će podržana i 384x640 rezolucija.
Nvisen Y-GX01 // BMAX Y11
akoj je offline
Staro 11.02.2014., 22:17   #3579
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,139
Autor akoj Pregled postova
Molim se da ta rezolucija ne bude završila na mobitelu.
Ipak, mogla bi završiti u rukama... točnije, na ruci
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Mario92 je offline
Staro 11.02.2014., 23:02   #3580
Postovi: 8,259
Autor 1v@n Pregled postova
Ne.
Da pogodim, još jedan veliki manjak WP platforme
Naravno da nije veliki manjak, al hebiga, lako se navići na nešto ako je tu, pa makar to koristio samo jednom u životu il godišnje.
Mislim, da se razumijemo, i dalje nebi mijenjao WP phone za nešto drugo, al možemo vajnat
Pupo je offline
Staro 11.02.2014., 23:05   #3581
gin.tonic
gin.tonic's Avatar
Postovi: 2,446
Autor Pupo Pregled postova
To je bit, biti član foruma danas očito
Staro 11.02.2014., 23:10   #3582
Don Kihoty
Lokacija: Sisak
Postovi: 1,373
Oh damn You dostava - nema moje 1020 još neko vrijeme.
Nadam se da će stići prije nego Black update za 620.
Staro 11.02.2014., 23:17   #3583
Mar
Suit up!
Mar's Avatar
Postovi: 5,987
Kad bi moga 8.1 dev preview?
- Barney Stinson
Mar je offline
Staro 11.02.2014., 23:23   #3584
Tvrdi
Sremium
Datum registracije: Oct 2013
Postovi: 2,854
ovaj popis za win8.1 je fenomenalan... kad to izadje w phone je definitivno way to go. Već je i sad ali eto..dolaze stvari koje su još falile...
Tvrdi je offline
Staro 11.02.2014., 23:28   #3585
nathan.fake
Lokacija: n/a
Postovi: 1,258
kom se daju pratit WP8.1 leak-ovi.. https://twitter.com/AngelWZR leak-a screenshot-ove, doslovce, svekih par minuta
nathan.fake je offline
Staro 11.02.2014., 23:31   #3586
Xenon
Postovi: 1,542
popis je jako zanimljiv ima dosta novina koje nisu očekivane al mi se sviđaju
Xenon je offline
Staro 11.02.2014., 23:33   #3587
akoj
lijevo smetalo
akoj's Avatar
Postovi: 1,120
Autor Mar Pregled postova
Travanj.
akoj je offline
Staro 11.02.2014., 23:59   #3588
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,139
2. travanj, tijekom BUILD konferencije.
Mada, čitam po netu da bi WP8.1 image mogao leakati prije
EDIT:
Multi-tasking model works exactly as on Windows 8.1 now. All apps resume immediately.
Oh my god, ovo je možda i najveća prednost 8.1 za mene
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Zadnje izmijenjeno od: Mario92. 12.02.2014. u 00:31.
Mario92 je offline
Staro 12.02.2014., 01:46   #3589
Metlina
Metlina's Avatar
Postovi: 94
iskreno mogu reci da nisam niti upola ocekiva
jedva cekam sad
jos 50 dana
Metlina je offline
Staro 12.02.2014., 03:13   #3590
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,139
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Mario92 je offline
Staro 12.02.2014., 10:47   #3591
zvonac
zvonac's Avatar
Lokacija: Sv.Nedelja
Postovi: 5,839
Posto 925 i 1020 imaju isti kapacitet baterija, potonja ima veci napon, al kolko sam videl na
gsm areni bogme ima i duze trajanje od 925..
Nije neka ogromna razlika, al po testovima je vidljiva..
zvonac je offline
Staro 12.02.2014., 12:58   #3592
Xenon
Postovi: 1,542
Autor Don Kihoty Pregled postova
zašto? Još je ostala 620 a već 2-3 dana ništa se ne mijenja na onoj listu ... dostupnosti ...
Xenon je offline
Staro 12.02.2014., 20:29   #3593
akoj
lijevo smetalo
akoj's Avatar
Postovi: 1,120
Review Nokie Icon.
akoj je offline
Staro 12.02.2014., 20:51   #3594
gin.tonic
gin.tonic's Avatar
Postovi: 2,446
Review Nokie Icon.
To je to, fali glance i microsd, za ostatak nemam riječi
Idealno za mene...
Staro 12.02.2014., 21:55   #3595
Metlina
Metlina's Avatar
Postovi: 94
Icon je predobar mobitel
Taman velicine i zvijer je kao 1520
Metlina je offline
Staro 12.02.2014., 23:31   #3596
Don Kihoty
Lokacija: Sisak
Postovi: 1,373
Dizajn je super. Glance bi se "ugurao" preko proxy-ja, ali to ne smiju u review-u,
jer je "ilegala".
Baš me zanima dali bi otključana radila na našem podneblju.
Staro 12.02.2014., 23:42   #3597
akoj
lijevo smetalo
akoj's Avatar
Postovi: 1,120
Proxy više ne fercera.
Radila bi, ali na 2G.
akoj je offline
Staro 12.02.2014., 23:45   #3598
Don Kihoty
Lokacija: Sisak
Postovi: 1,373
Meni još uvijek radi na L620 - možda zato što još nije Black
Staro 13.02.2014., 00:35   #3599
Metlina
Metlina's Avatar
Postovi: 94
cekajmo MWC da dobijemo nove lumie, garant cemo dobiti nesto dobro
nokia je danas poslala jos jedan teaser koji je malo cudan a nextleak govori o puno uredaja na MWC-u
http://mynokiablog.com/2014/02/12/no...-treasure-tag/
https://twitter.com/NextLeaks/status/433584859051618305
Metlina je offline
Staro 13.02.2014., 01:02   #3600
tux-scooby
tux-scooby's Avatar
Lokacija: Donji Miholjac-Osijek
Postovi: 290
Review Nokie Icon.
Kako ovo dobro izgleda! Nadam se da ce biti dostupna i kod nas jer bi mi to lagano mogao biti sljedeci mobitel
tux-scooby je offline
Zaključane teme
