Povratak   PC Ekspert Forum > Računala > Mobilno > Tableti
Staro 29.08.2013., 21:47   #61
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
Stigao navodno Pipo M6 u Chipoteku (Vukovarska).
2300. Sad stvarno ne znam kaj da radim...
Čekat tjednima banggood i strepiti za pdv, carinu i garanciju ili ga preplatiti ovdje. Dobro se tu nabija cijena.
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
estugarda je offline   Reply With Quote
Staro 29.08.2013., 23:24   #62
nino_z
nino_z's Avatar
Lokacija: Valpovo/Osijek
Postovi: 267
Ja se lomim već danima oko tog M6, a riješio sam to tako što sam danas za tu lovu uzeo Asus MemoPad FHD 10. Nije 9.7", ali preboljet ću to nekako. Previše mi je za Pipo dati 2300kn, a kakve sam ja sreće sigurno će mi naplatiti sve ako uzmem s bangooda.
http://www.arhiteh.hr/shop/index.php...ducts_id=10274
nino_z je offline   Reply With Quote
Staro 30.08.2013., 09:46   #63
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Cijena je OK.
Odabir logičan.
Meni osobno prilično smeta 16:10 na tabletu. I kakva je to matrica OGS?
Koliko drži baterija? Nije baš divovska.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 30.08.2013., 10:10   #64
sokre10
Postovi: 437
Pozdrav momci,
Već duže pratim temu i nalazim dosta korisnih informacija ovdje. Namjeravam kupiti malo jači tablet i u uži izbor su ušli ovi:
Pipo M9 Pro
http://www.banggood.com/PIPO-M9Pro-R...t-p-79280.html
Fnf ifive X2
http://www.banggood.com/FNF-Ifive-X2...t-p-78498.html
Pipo max M6
http://www.banggood.com/PIPO-MAX-M6-...t-p-74330.html
Cube U30GT2
http://www.banggood.com/Wholesale-CU...t-p-66187.html
Chuwi V99
http://www.banggood.com/Wholesale-CH...t-p-61257.html
Onda V972
http://www.banggood.com/Wholesale-On...t-p-60135.html
Znači, izbor je čisto po nekakvim speckama. Dosta mi je bitan ekran i baterija. 3g mi ne predstavlja ništa. Naravno kvaliteta izrade je bitna. Kakva su Vaša iskustva, predložite nešto pametno. Meni ovako u oko najviše upadaju Cube U30gt2, Pipo Max M6 i onda V972.
Hvala!
sokre10 je online   Reply With Quote
Staro 30.08.2013., 11:22   #65
nino_z
nino_z's Avatar
Postovi: 267
Autor estugarda Pregled postova
Cijena je OK.
Odabir logičan.
Nije divovska, ali kažu da traje 10 sati, unutra je Intel Atom, a matrica je IPS naravno.
Staro 30.08.2013., 12:32   #66
brandon
azriel
brandon's Avatar
Lokacija: kavez
Postovi: 246
Autor nino_z Pregled postova
Samsung Galaxy Tab 3 10.1 ima isti proc, vidi antutu, to je velika razlika sa obzirom na onih ~17000 koje dobije RK3188.
Iskreno, da mogu birati između kineza i Asus, odabrao bih Asus.
Također razlika između 10.1'' 16:10 i 9.7'' 4:3 i nije tako velika, vidi ovdje.
Anandtech je radio detaljnu analizu ARM-ova i ovih novih (aktualnih) atoma i bili su jako blizu po pitanju potrošnje struje.
Autor sokre10 Pregled postova
Pozdrav momci,
Pipo M9 Pro
Fnf ifive X2
Pipo max M6
Cube U30GT2
Chuwi V99
Onda V972
Hvala!
Mislim da bi ti bilo dobro da si prvo izbor filtriraš po nekim fizičkim speckama.
Tu u popisu imaš 4:3, 16:10. Vidim da su ti ostale specke jako slične, quad core, 2GB rama, retina IPS ekran.
Za početak, šta ćeš raditi na tabletu, kakav oblik media konzumacije?
Koliko ćeš držati tablet dnevno u rukama?
Koliko sati baterije očekuješ?
Postoji li nešto što bitno što samo neki model ima (tipa Bluetooth)?
Par mojih opaski:
* 2048x1536 je choppy na kinezima.
* Kloni se
Allwinner A31 proca, idi na RK3188, a pogotovo za te ekrane velike rezolucije.
* Pogledaj testove flash memorije, često ti tableti mogu imati puno rama ali spor flash i ljudima trza i nezadovoljni su.
* Gledaj modele za koje postoji community i custom romovi. Često na kinezima nešto ne valja i moguće da ćeš umrijeti star ako ćeš čekati proizvođača da ti to popravi.
* Izgleda da su stvari sa banggood-a počeli cariniti, ako uzimaš od tamo da ne platiš PDV sačekaj da se situacija oko toga iskristalizira.
Meni se osobno jako dopadaju 2 formata, 4:3 7.9'' i 16:10 8.9''.
Također razmisli i o ovome Cube-u
Chasing shadows, all your life
Zadnje izmijenjeno od: brandon. 30.08.2013. u 12:40.
brandon je offline   Reply With Quote
Staro 30.08.2013., 12:44   #67
sokre10
Postovi: 437
Baterija mi je jako bitna. Primarno ću ga koristiti za posao. Radim videonadzore, alarme i to, pa mi je ekran dosta bitan. 1920x1080 mi je dosta rezolucija. Što se tiće podrške i communitya, radije ću uzeti nešto slabije ali da se ljudi bave s time. Volio bi također da se može pogledati neki film na tvu u 1920*1080.
Staro 30.08.2013., 13:35   #68
antebr
antebr's Avatar
Postovi: 423
Pozdrav momci,
Pipo M9 Pro
Fnf ifive X2
Pipo max M6
Cube U30GT2
Chuwi V99
Onda V972
Hvala!
Moj savjet ti je Onda 972 ili Fnf ifive X2.
Na tebi je da odlučiš šta ti je bitnije, procesor ili grafika (RK3188>A31;SGX544MP2>Mali-400).
Odnosno 2048*1536 ili 1920x1200.
Custom ROM-ova za Rockchip nema, samo obrade stock ROM.
Za Allwiner imaš AOKP,CM 10.1 i PA na 4.2.2 ili CM 10.2 na 4.3.
antebr je offline   Reply With Quote
Staro 30.08.2013., 17:31   #69
sokre10
Postovi: 437
A ovi tableti upogonjeni intel atomom?
Staro 30.08.2013., 18:51   #70
brandon
azriel
brandon's Avatar
Lokacija: kavez
Postovi: 246
Ne shvaćam pitanje. Napisao sam ti nešto o Atom tabletima malo više gore. Koliko se sjećam, app compatibility je praktički 90%+. Nešto više kineskih Atom tableta se tek treba pojaviti.
Staro 31.08.2013., 01:04   #71
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Autor brandon Pregled postova
* Izgleda da su stvari sa banggood-a počeli cariniti...
Može malo detaljnije o ovome?
EDIT: Sad vidim raspravu na kineskim mobitelima. Dakle ipak je u pravu Kinez Tony?
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 31.08.2013. u 01:12.
Staro 31.08.2013., 01:58   #72
rendula
Lokacija: Zagreb, Trešnjevka
Postovi: 5,777
Kako mislis "u pravu je"? Sve je isto od pocetka, salju stvari iz Kine preko Svedske, i ne treba ocekivati da ce biti oslobodjeno pdv-a. Mozda hoce, mozda nece.
Uostalom, nikad se ne narucuje preko interneta s mislju da ce biti oslobodjeno. Ides s planom da ces platiti i pdv, i ako prodje onda je ugodno iznenadjenje Toga se ja oduvijek drzim.
Staro 31.08.2013., 07:32   #73
Postovi: 34,078
Slijedeći četvrtak imate na Pandinom happy houru Pipo M7Pro 3G za 230$
Staro 01.09.2013., 02:08   #74
sokre10
Postovi: 437
Odlučio sam se za pipo max m8pro sa bangooda. Jel se može nekako do onog 10$ kupona? BTW, ta garancija koju oni daju, to vrijedi stvarno ili samo navlakuša. Hvala!
Staro 01.09.2013., 08:36   #75
Postovi: 34,078
Garancija postoji, ali im ga moraš poslati natrag u Kinu.
Staro 01.09.2013., 17:45   #76
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Javi nam prve utiske. A onda i review po mogućnosti.
BTW Jel uzeo tko M6?
Vrlo blizu sam odluke da odem u Chipoteku i uzmem ga. Bez obzira na ekstremno nabijenu cijenu...
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 01.09.2013., 19:49   #77
sokre10
Postovi: 437
Koliko vidim u svijetu medija daju 24mj. garanciju. Za chipoteku ne znam, ne piše nigdje.
Staro 01.09.2013., 20:24   #78
tOta
Lokacija: ...
Postovi: 685
Koji bi tablet izdvojili po kvaliteti ekrana, znači da tražim alternativu za Nexus 10/Sony Xperia Tablet Z i poželjno bi bilo da je 4.2-4.3 u planu ili već dostupan.
tOta je offline   Reply With Quote
Staro 01.09.2013., 21:42   #79
nino_z
nino_z's Avatar
Postovi: 267
Misliš na kinesku alternativu ili općenito?
Za kupovinu kod nas pogledaj Asus Memo Pad FHD 10, oko 2300kn je.
http://tablet-news.com/2013/07/21/as...fhd-10-review/
Staro 02.09.2013., 16:10   #80
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
U Chipoteci je 1.g. garancija na M6 kao i kod Kineza. Malo je čudno da Svijet Medija daje 2 g. Možda je greška?
Uglavnom, imao sam danas u ruci M6. Nažicao sam sumnjičavog prodavača da mi otvori i da probati.
Neloša je to stvarčica. Materijali sami po sebi djeluju malo jeftino na oko i dodir kad se uspoređuje s iPadom, ali cijela stvar djeluje dobro i solidno sklopljena. S druge strane, jedan Asus Transformer TF101 škripi sve u 16 od prvog dana. Na M6 ništa nije u ausvinklu. Ništa ne škripi. Baš sam ga probao fleksati pošteno.
Dolazi sa dva launchera. Čisti JB Android 4.2.2 launcher i neki njihov PipoLauncher. Pretpostavljam da je to onaj koji izgleda kao Win8. Prvo sam probao Android launcher i to radi dobro i prilično fluidno. Nema čak ni puno bloatware-a. Očito ovdje ne isporučuju tablet s kineskim sranjima. Drugi launcher nisam stigao isprobati, a nije mi ni bilo važno pošto ja volim čisti Android. Naročito ako je fluidan.
Bilo mi je važno vidjeti display i rezoluciju u oba moda. Nisam imao s čim usporediti, ali mislim da je bilo dovoljno brightnessa. Već na prvi pogled na par fotki sam vidio da su boje preciznije od Galaxy Note 2 Samoled-a. Nije to baš neka uvjerljiva ocjena displaya jer je preko displaya folija, ali mislim da mi je bilo dovoljno dobro. Za promjenu rezolucije: (HD 2048x1536 i normal 1600x1200) treba svaki put resetirati pa nisam mogao usporediti, ali moram priznati da je razlika minimalna. Da bi se vidjeli piskeli na 1600x1200, baš moraš doslovno nosom dodirnuti display.
To mi je bilo važno zato što sam čuo da u 2048x1536 nije glatko, pa sam mislio ionako to tjerati u 1600x1200. No to je samo djelomično istina. U sučelju nisam primjetio razliku ni u brzini/fluidnosti ni u izgledu, ali sam onda otvorio galeriju i malo brzo listao fotke, scrollao, zoomirao, mijenjao orijentaciju i tu se vidjelo primjetno štekanje, ali zanimljivo, u obje rezolucije skoro podjednako. Možda je mrvicu bilo sporije na HD, ali zanemarivo.Tako da taj lag o kojem se priča, vjeorjatno i nema toliko veze sa samom rezolucijom koliko s firmwareom, ili suživotom komponenti. Vjerojatno je RAM sporiji. Pošto su ostale komponente poznate.
Htio sam još detaljnije isprobati, ali ovi u Chipoteci su postajali sve nervozniji. Kad je prodavač pozvao drugog za asistenciju nadgledanja, postalo mi je jasno da je to bilo to.
Nisam imao optimalne uvjete za pregled, ali mislim da je već sad jasno da Pipo M6 nije igračka. To je ozbiljan tablet. Vrijedi li 2300kn? Vjeorjatno ne, ali za tu lovu nema ništa bolje na 4:3 omjeru kod nas, što je mnogima važno.
Meni se čini da neću čekati i strepiti za pdv i garanciju, nego zažmirit i ispljunut lovu uz garanciju...još ako je stvarno 24.mj...nije to tak loše.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 02.09.2013. u 19:08.
Staro 02.09.2013., 22:24   #81
sokre10
Postovi: 437
Kako se koriste ovi kuponi, malo sam si glup. Ja klikam na ovo što je kolega poslao, međutim, ništa se ne događa?
Regan sam sa adresom na koju mi je slao. (Registracija obavljena prije primanja kupona)
Staro 02.09.2013., 22:28   #82
brandon
azriel
brandon's Avatar
Lokacija: kavez
Postovi: 246
U accountu imas kupon koji kopiras i onda pejstas u cart gdje si dodao artikl, budes vidio input za kupone. Kupon je negdje zatrpan u affiliate il tak nesh.
Staro 02.09.2013., 23:02   #83
sokre10
Postovi: 437
Naručio sam na karaju M9, ali slabiju verziju:
http://www.banggood.com/Wholesale-Pi...t-p-64785.html
Ispalo me 1251kn + eventualna carina. Tada bi trošak bio: 1563kn
Jedino gdje sam ga našao je svijet medija i tamo je 2400kn.
Staro 03.09.2013., 07:04   #84
Postovi: 34,078
Ne zaboravi ih podsjetiti da ti treba EU charger.
Staro 04.09.2013., 16:00   #85
sodom
sodom's Avatar
Postovi: 593
nisam nigdje nasao informaciju (na mobu sam)...ima li asus memopad fhd 10 usb otg?
sodom je offline   Reply With Quote
Staro 04.09.2013., 16:52   #86
nino_z
nino_z's Avatar
Postovi: 267
Kažu da ima, ali ne mogu ti potvrditi jer mi je adapter još na putu iz dalekog ibeja :-)
Staro 04.09.2013., 17:09   #87
Ag008
RESPECT MY AUTHORITAH
Ag008's Avatar
Postovi: 7,500
Jedna od jeftinjava ispod 100$ za 9"
http://www.banggood.com/IPPO-Q9PRO-D...l?utm_design=1
Staro 04.09.2013., 19:15   #88
Postovi: 34,078
Dual core i slaba rezolucija. Nije ni čudo da toliko košta.
Staro 04.09.2013., 22:17   #89
sodom
sodom's Avatar
Postovi: 593
Evo, ja potvrdujem, radit ce ti
Staro 05.09.2013., 03:43   #90
gvozd89
Datum registracije: Aug 2013
Postovi: 7
bok jos jednom... sad imam jednu veliku dilemu, moze se rec i trilemu. narucio bi jedan od ova tri tableta.
pipo s1 pro-najbolji razlog da njega uzmem je taj jer je taj tablet vise manje provjeren i 90 dolara nije puno ako nesto bude lose.
ainol novo hero II-razlog za njega je sjajnih 10,1 inča. jako dobar customer service te dobri reviewovi svih koji su ga kupili. jedino sta mi smeta je GPU. kazu da nije bas dobar kao mali 400. pa ne znam dali bi to predstavljalo toliki problem te cijena koja je skoro duplo veca od s1. (ali cijena nije toliki problem)
cube u30GT-sjajan tablet, malo losjii ekran, sve 5! ali problem kod njega je sto nema toliko informacija od ljudi koji su ga kupili te nisam naiso nigdje za njihov customer review.
mene najvise privlaci ainol hero II. pa sad ako bi mi mogli pomoc sa kojim savjetom bio bih zahvalan. i kada bi ga planiro uzet jel ima neko da daje kupon sa baggood-a?
hvala unaprijed ljudi
gvozd89 je offline   Reply With Quote
