Staro 20.08.2013., 14:23   #1
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,535
Nvidia GeForce v326.80 Beta Driver
Staro 20.08.2013., 15:00   #2
Mrakky
Mrakky's Avatar
Datum registracije: Oct 2012
Lokacija: Velika Gorica
Postovi: 115
ako ko proba, a imao je prije problem sa rušenjem drajvera, molio bi ga da napiše doživljaje, dal se kaj promjenilo, tnx!
edit: vrag mi neda mira, pobao sam ih, i vidio u event viveru iste greške, tak da mi se nije dalo isprobavat nikaj više, vratio na stare drajvere.
Zadnje izmijenjeno od: Mrakky. 20.08.2013. u 17:35.
Mrakky je offline   Reply With Quote
Staro 21.08.2013., 00:40   #3
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,535
evo ih i tu http://www.geforce.co.uk/drivers/results/65095
Release Summary
This Game Ready driver offers the best gaming experience for Splinter Cell: Blacklist and is also a recommended driver update for the Windows 8.1 Preview. GeForce R326 drivers also provide performance increases for a variety of different games.
New in GeForce R326 Drivers
Performance Boost – Increases performance by up to 19% for GeForce 400/500/600/700 series GPUs in several PC games vs. GeForce 320.49 WHQL-certified drivers. Results will vary depending on your GPU and system configuration. Here is one example of measured gains:
GeForce GTX 770:
Up to 15% in Dirt: Showdown Up to 6% in Tomb Raider
GeForce GTX 770 SLI:
Up to 19% in Dirt: Showdown Up to 11% in F1 2012
SLI Technology
Added SLI profile for Spinter Cell: Blacklist Added SLI profile for Batman: Arkham Origins
SHIELD
Enables GeForce to SHIELD streaming. Learn more here.
4K Displays
Adds support for additional tiled 4K displays Extended support for tiled 4K features
Additional Details
Installs PhysX System Software 9.13.0725. Installs HD Audio v1.3.26.4 Includes support for applications built using CUDA 5.5 or earlier version of the CUDA Toolkit. More information at http://developer.nvidia.com/cuda-toolkit Supports OpenGL 4.3 for GeForce 400-series and later GPUs. Supports DisplayPort 1.2 for GeForce GTX 600 series GPUs. Supports multiple languages and APIs for GPU computing: CUDA C, CUDA C++, CUDA Fortran, OpenCL, DirectCompute, and Microsoft C++ AMP. Supports single GPU and NVIDIA SLI technology on DirectX 9, DirectX 10, DirectX 11, and OpenGL, including 3-way SLI, Quad SLI, and SLI support on SLI-certified Intel and AMD motherboards.
Staro 21.08.2013., 17:29   #4
Mrakky
Mrakky's Avatar
Postovi: 115
pa da ne povjeruješ, opet pun nvidia forum istih prigovora, ovo mi več postaje smiješno, aj bar rade kak treba 314.22
Staro 21.08.2013., 21:50   #5
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,580
Izdrkavanje po faci al sto ces... Pun mi je k i nvidie i 7 serije, ozbiljno razmisljam o prelasku na ati ili prodat ovo cudo i uzet 680ku
Staro 21.08.2013., 22:00   #6
syss
syss's Avatar
Postovi: 10,805
6xx ftw
Staro 21.08.2013., 23:17   #7
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,535
Meni na 660ti sve super vec godinu dana na svim driverima, dobra serija ocito
Staro 22.08.2013., 01:24   #8
MAGARAC
MAGARAC's Avatar
Postovi: 5,997
Autor xulos Pregled postova
Ja je imam vec neko vrijeme i nist. Isto ko i sa 670, stavim driver i zaboravim da postoji dok ne vidim da je netko stavio ovdje.
Staro 22.08.2013., 08:54   #9
Također. Bilo je malih trzavica sa onim prvim 320 driverom. Sve kasnije radi OK.
Staro 22.08.2013., 10:17   #10
Mrakky
Mrakky's Avatar
Postovi: 115
meni je isto bilo tako ispočetka, sam odjednom počelo kršenje u igrama, na prijašnjoj beti, čak sam probal i ovu betu al kad sam videl iste errore u event vieweru sam probao zaigrat tsw i shvatio da zapinje, pa mi se nije dalo više experimentirat i jednostavno vratio sliku na 314.22 di i sa boljim postavkama mogu igrat.
ima ko objašnjenje kaj se desilo sa karticama, nikaj nije bilo drmano po njima nisu vađenje ne pregrijavaju se dobar protok zraka i nimalo prašine na njima imam dobre filtere na usisnim ventovima, e kad bi neko znao odgovor na tu misteriju bilo bi super.
jedino kaj mi u biosu naritano na gen 3, a u drajverima očitava gen 2, al to je radi proca SB nema gen 3, mislim da nije do toga jer je tak i prije bilo dok je sve šljakalo, ko da mi komp dobil duhove.
još jedno pitanje, jel zna ko kaj o onom fixu kaj omogučuje SB cpu da fura gen 3 ili je to samo isključivo za Sandy Bridge-E procove?
tnx
Staro 22.08.2013., 10:35   #11
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,580
Ma nema tu filozofije, nakon 310.90 svi driveri su sjebani i tko god ostavi komp dulje od 36h dobit ce tdr. Treba drivere iz 0 napisati i to je to.
Staro 22.08.2013., 11:03   #12
Mrakky
Mrakky's Avatar
Postovi: 115
slažem se, al kolko sam shvalitl sljedeči i budu bili takvi nekakvi, svebude bilu u jednom prozoru i drajver setings i expirianbeve, nemogu nč taj podatak, al se iskreno nadam da bude bude tak i bilo i naravno da se iskupe svaka serija od 2x0 do 7x0 ima boots bar 40%, al to su samo moje želje i vjerujem želje mnogih, a sad kolko bu to bila istina bumo vidli, da napokon vrate slavu u pisanju drajvera za kartice koje su podosta slabije od atijevih, al ih pojedu. (baš zbog dobrih drajvera)
iskreno se nadam tak nečemu, ak nebu tak bilo vrlo vjerojatno bum prodal ove dve jer i za te pare kupim top amd grafu kojima su sad drajveri kak treba.
ugl. jako sramotno za nvidiu, nisam fan boj ni atija ni nvidije, u zadnje vrijeme mi se jako sviđa apu cpu kod amd-a i još kad bi se dao uparat sa nekom pipa 7850/70 7980/70 to bi bio pun pogodat, čak razmišlam da mi sljedeča konfa bude amd apu, ali naravno da de da uparit top grafa, živi bili pa videli, al mi to sve tak kreče tim pravcem.
sretno nvidia i amd-u u poboljšanju svojih proizvoda jer je to jedini način za privuč kupce.
edit: to xulos, daj mi reci ti drajveri 310.90 su još bolji od 314.22, ti voziš na njima? tnx!
Zadnje izmijenjeno od: Mrakky. 22.08.2013. u 11:12.
Staro 22.08.2013., 11:44   #13
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,535
Ali to ne vrijedi za sve, ima nas vise na forumu kojima rade nego ne rade..meni komp ima uptime po mjesec dana i sve 5
Staro 22.08.2013., 11:52   #14
zvonac
zvonac's Avatar
Lokacija: Sv.Nedelja
Postovi: 5,831
A baš bi si nabavil gtx 760, i sad čitam o tim lošim drajverima..
Jel bar ima drivera kaj su grafe stabilne s njima (serija 7)?
Staro 22.08.2013., 11:56   #15
Gilbert5
Agent 0
Gilbert5's Avatar
Lokacija: Kutina - ZG
Postovi: 4,312
Imao sam referentnu GTX760 od gainwarda, uredno je radila sa zadnjim driverima. Pretjeruju decki malo imho.
Staro 22.08.2013., 11:56   #16
Mrakky
Mrakky's Avatar
Postovi: 115
Autor zvonac Pregled postova
kao što je kolega mamutarka reko nije pravilo, držim fige da sve radi kak treba.
Staro 22.08.2013., 11:59   #17
Mrakky
Mrakky's Avatar
Postovi: 115
Autor Gilbert5 Pregled postova
Imao sam referentnu GTX od gainwarda, uredno je radila sa zadnjim driverima. Pretjeruju decki malo imho.
pa nije pretjerivanje, vjerujem da ima više onih kojima sve uredno radi, al ima i onik kao što sam ja, tak me pogodilo, nema tu nikakve filozofije, jedino sam razmišljal da zadnje instaliram bez jedne grafe i da ju nakon instalacije piknem i enejblam sli, je probo to ko?
Staro 23.08.2013., 17:27   #18
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,580
Imao si, vise nemas. Radi uredno, ali ostavi pc da radi dan i pol i dobit ces tdr, uostalom imas event viewer pa pogledaj
ti sa svojom grafom nemas problema, ali ekipa sa serijom 7 svi imaju problema i tko kaze da nema laze jer se u event vieweru sve vidi Ima vas vise kojima rade ali sa 320 verzijom, sve verzije drivera na svim grafama imaju problem sa TDR, sto opet ponavljam je vidljivo u event vieweru.
Moja je stabilna, sve igre rade ali se kernel skreša nakon 36 sati svima i to nije fiksano, dakle svakih 24 h reset pca i ok. Iako to nije nek iveliki problem nervira jer ti se to moze dogodit u sred igranja
Staro 23.08.2013., 17:37   #19
zvonac
zvonac's Avatar
Postovi: 5,831
Zasad radi ok, odigral većinu poznatih naslova, i ne vidim nekih anomalija, al bum komp ostavil upaljen pa bumo sutra vidli kakva bu situacija...
Staro 23.08.2013., 18:41   #20
Mrakky
Mrakky's Avatar
Postovi: 115
nema gore stvari nego kad ti se skrši usred igre, pogotovo još ak se konpletno ufuraš, a još bolje kad nemaš preveč vremena za igranje pa uloviš koji sat i onda kršenje, za znoret, niš drugo....
Staro 24.08.2013., 10:40   #21
zvonac
zvonac's Avatar
Postovi: 5,831
Jučer igram Metro LL, Splinter Cell i sve ok..
Evo sad malo prije dobim crni ekran tj monitor se ugasi, napravim restart, opet isto...
Staro 24.08.2013., 10:51   #22
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,580
No, rekoh ti.
Staro 24.08.2013., 11:28   #23
zvonac
zvonac's Avatar
Postovi: 5,831
Furam generičke drivere..
Bum probal 326.41
Staro 24.08.2013., 12:29   #24
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,580
326.19 su meni bili ok u igrama.
Staro 24.08.2013., 14:01   #25
Meni je jučer Metro LL šiknuo BSOD. Ali čini mi se da je kriv procesor a ne driver.
Staro 24.08.2013., 14:02   #26
zvonac
zvonac's Avatar
Postovi: 5,831
326.19 i 326.80 mi se monitor gasi, i ovo s restartom ne pomaže, dva put napravim restart i odmah nakon podizanja winsa, ugasi se monitor.
Sad sam stavil 326.41 i bumo vidli, .
Uglavnom, koma..
Staro 24.08.2013., 14:22   #27
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,580
welcome to the club
Staro 24.08.2013., 16:12   #28
Mrakky
Mrakky's Avatar
Postovi: 115
ista stvar ko i samnom sam kaj ja imam seroju 6x0 pa mogu vratit na stare 314.22 koji delaju savršeno ponekat imam osječaj da se budu ventovi razleteli, al sve prolazi bez štekanja.
ste vi sa serijom 7x0 probali te starije drajvere ili neide nikako?
negdije sam pročital da bi možda i išli kad bi se editirao činimise inf fajl tak nekaj, pa probajte progooglat malo.
Staro 24.08.2013., 16:23   #29
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,464
...ste vi sa serijom 7x0 probali te starije drajvere ili neide nikako?
pisalo se o tome vec.
mogu se stavit samo treba malo izmjenit inf.
"We all must hang together, or surly we will hang separately."
AMD Ryzen7 7800x3D+Noctua NH-D14 | MSI Tomahawk WIFI AMD B650 | 2x16GB Corsair Vengeance DDR5-6000 CL30 1,39v | SAPPHIRE Pulse RX 9070xt UV/OC | 1tb NVMe sammy 970 evo plus, 2TB Samsung 990 EVO Plus, Crucial MX500 500GB, Kingston 480gb | Riotoro ENIGMA G2 850W 80 Gold | Corsair Carbide 300R modded | Win10 ENT LTSC IoT (work) + Win11 ENT LTSC IoT (gejming) | logitech g403 | ROCCAT Horde | AOC CQ27C4 + AOC C24G1 + 50" Hisense H50A6140
AMD Ryzen5 2600+Xilence Cryon M806D.B | Asus x370 Prime Pro rev1.03 (bios 6203) | GSkill Aegis 32GB (2x16) DDR4@3,2GHz | 2x Intel 545s 128GB, 1x Crucial MX500 500GB | Gigabyte GTX960 | sisa 620w | Fractal Design Focus G | Win7 x64 + Win10 ENT LTSC IoT | logitech g403 | ROCCAT SuoraFX
intel i5 2500k@4,5ghz (1,28v)+FSP Windale 4 | ASRock Z68 Ext4 Gen3 (bios 1.20) | 2x8gb DDR3 HyperX Savage, 1866mhz, 10-10-11-27,1,5V | Samsung SSD 64gb, 2x256gb SSD | iGPU | corsair vx450w | CoolerMaster Centurion 534 modded | Win7 x64
Staro 24.08.2013., 16:42   #30
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,580
je evo dao sam 3k kuna za grafu koja je izasla prije mj dana da bi editirao inf fajl od drivera koji su stari 8 mj posto driveri samo za 7 seriju ne rade na istim tim grafama ? I od onda je izaslo jos 10 igara za koje ti driveri nemaju " support" ? Nisam izgorio po glavi, to je ko kad neko kupi nexus od 3k kuna i onda ga roota jer mu ne rade notifikacije, evo sve sam potrcao...
