Zaključane teme
Staro 16.06.2013., 17:58   #1
Gustavo
Lokacija: Sisak
Postovi: 358
(riješeno) Bad sektori na novom hardu
Seagate baracuda 500 gb star 2 mjeseca već zeza, našao sam i s HD regeneratorom popravio 32 bad sektora na tri lokacije, ne znam jel taj hard već sada za reklamaciju, evo smart test nakon popravka.
Serial: W2AMR3KR
LBA: 976773168
Report By: HDDScan for Windows version 3.3
Report Date: 16.6.2013. 16:54:20
Num Attribute Name Value Worst Raw(hex) Threshold
001Raw Read Error Rate 1090940000000140-8D10006
003Spin Up Time 1001000000000000-0000000
004Start/Stop Count 0990990000000000-0510020
005Reallocation Sector Count 1001000000000000-0000036
007Seek Error Rate 075060000000023E-7321030
009Power-On Hours Count 1001000000000000-0319000
010Spin Retry Count 1001000000000000-0000097
012Device Power Cycle Count 1001000000000000-00A2020
183SATA Downshift Error Count1001000000000000-0000000
184End To End Error Count 1001000000000000-0000099
187Reported Uncorrectable Error 0600600000000000-0028000
188Reported Command Timeouts 1000990000000000-0004000
189High Fly Writes 1001000000000000-0000000
190Airflow Temperature 06606534 C 045
190Airflow Temperature Minimum06606533 C045
190Airflow Temperature Maximum06606534 C045
194HDA Temperature 03404034 C 000
194HDA Temperature Minimum03404017 C000
194HDA Temperature Maximum03404060 C000
195Error Rate0540390000000140-8D10000
197Current Pending Errors Count 1001000000000000-0000000
198Uncorrectable Errors Count 1001000000000000-0000000
199UltraDMA CRC Errors 2002000000000000-0000000
240Heads Flying Hours 100253174C690000-02F8000
241Total Host Writes 100253000000831F-5B69000
242Total Host Reads 100253000000B84B-2375000
Gustavo je offline
Staro 16.06.2013., 18:29   #2
OuttaControl
OuttaControl's Avatar
Lokacija: Dalmacija
Postovi: 5,908
Ma nema tu price sta prije odneses to bolje
OuttaControl je online
Staro 16.06.2013., 18:36   #3
iNoob
Game Collector
iNoob's Avatar
Datum registracije: Jun 2010
Lokacija: Viškovo (Rijeka)
Postovi: 366
Nosi to odma na reklamaciju.
Trust me - I know what I'm doing!
iNoob je offline
Staro 16.06.2013., 18:56   #4
Gustavo
Lokacija: Sisak
Postovi: 358
A jel će proći reklamacija obzirom na scan gore?
Gustavo je offline
Staro 16.06.2013., 19:25   #5
OuttaControl
Lokacija: Dalmacija
Postovi: 5,908
E to sam uredio al nije spremilo, na mobu sam, ja ove hex podatke ja neznam citat, ali ako se nevaram, taj repair samo oznaci sektore kao neiskoristive, nadalje ako mozes napravi low level format pa onda ponovo skeniraj
Staro 16.06.2013., 19:40   #6
Gustavo
Lokacija: Sisak
Postovi: 358
Low level cijelog diska neću raditi, imam na D i E particiji dosta prebačenih slika pa ću probat napravit wipe particije C i poslije format pa da vidimo, imam još 22 mjeseca garanciju pa stignem to riješiti.
Gustavo je offline
Staro 16.06.2013., 20:01   #7
Forace
Lokacija: Petrinja
Postovi: 1,604
Problem ti je što bad sektori ne biraju particiju, ako ti se zadrže na logičkoj c imaš sreće. Moj savjet ti je da si napraviš full backup diska i odskeniraš sa hirenom disk tj. sa wd.ovim alatom te po potrebi naraviš low level.
Forace je offline
Staro 16.06.2013., 20:04   #8
Gustavo
Lokacija: Sisak
Postovi: 358
Autor Forace Pregled postova
Našao sam ih sve na C particiji kad sam provjeravao s hiren boot cd-om i čistio HD regeneratorom, u svakom slučaju kažem imam još skoro dvije godine garanciju pa stignem to riješiti.
Zadnje izmijenjeno od: Gustavo. 16.06.2013. u 23:47.
Gustavo je offline
Staro 19.06.2013., 20:10   #9
Gustavo
Lokacija: Sisak
Postovi: 358
Ovo je stanje nakon wipe i format C, čini se nema nekih promjena?
ST500DM002-1BD142-W2AMR3KR-SMART.mht
HDDScan S.M.A.R.T. Report
Model: ST500DM002-1BD142
Firmware: KC45
Serial: W2AMR3KR
LBA: 976773168
Report Date: 19.6.2013. 19:06:56
001Raw Read Error Rate 10709400000000DB-C168006
004Start/Stop Count 0990990000000000-05F1020
007Seek Error Rate 0750600000000269-4567030
009Power-On Hours Count 1001000000000000-034C000
012Device Power Cycle Count 1001000000000000-00AA020
187Reported Uncorrectable Error 0560560000000000-002C000
190Airflow Temperature 06406236 C 045
190Airflow Temperature Minimum06406234 C045
190Airflow Temperature Maximum06406236 C045
194HDA Temperature 03604036 C 000
194HDA Temperature Minimum03604017 C000
194HDA Temperature Maximum03604060 C000
195Error Rate05403500000000DB-C168000
240Heads Flying Hours 1002533648DE0000-0324000
241Total Host Writes 1002530000009AAF-C15F000
242Total Host Reads 1002530000004F54-9328000
Gustavo je offline
Staro 19.06.2013., 20:20   #10
Rade0n
Datum registracije: Jun 2012
Postovi: 820
Ne znam samo čemu ti kopi/pejstovi nekih ljevih alata iz kojih se ništa ne vidi.
Na hirens cd-u nađi segateovu dijagnostiku i testiraj, ako ne prođe testove znači da ne valja i nosiš na reklamaciju.
Rade0n je offline
Staro 20.06.2013., 00:35   #11
Gustavo
Lokacija: Sisak
Postovi: 358
Autor Rade0n Pregled postova
Ok
Ne mogu vjerovat, nestali bad sektori, testove prolazi i radi ko nov.
Zadnje izmijenjeno od: nino. 27.08.2013. u 02:41.
Gustavo je offline
Zaključane teme
