#2402 |
Postovi: 2,067
#2403 | |
Dino Saur
Datum registracije: Jan 2012
Postovi: 941
New 20130611 Nightly is up on basketbuild Download Link Includes HALO |
#2404 |
Je suis Schumi
Postovi: 1,524
Ima li tko problema sa Google Chromeom? U zadnje vrijeme mi jako sporo ucitava stranice. Preko obicnog Android preglednika sve leti, ali Chromeu treba dosta da pocne loadat, cak kad je i na wifi spojen :/ Izbrisao sam update i vratio ga na tvornicku verziju, ali opet ista stvar :/ |
#2405 |
Pink Floyd fan
Lokacija: Santa Clara, CA
Postovi: 5,559
Probaj Chrome Beta, puno je bolji.
#2407 |
Lokacija: Rijeka / Grobnik
Postovi: 4,464
pozdrav. dali se je moguce, koristeci real VNC, android VNC ili neki sl program, spojiti sa PC-a na mob remotely (preko neta (3G))? ili barem sa moba na mob (SII na SII)? trebalo bi mi to, ako se starome treba sta postelat na mobu (sII) da se mogu spojit remotely kao sto radimo na kompovima. hvala.
"We all must hang together, or surly we will hang separately." AMD Ryzen7 7800x3D+Noctua NH-D14 | MSI Tomahawk WIFI AMD B650 | 2x16GB Corsair Vengeance DDR5-6000 CL30 1,39v | SAPPHIRE Pulse RX 9070xt UV/OC | 1tb NVMe sammy 970 evo plus, 2TB Samsung 990 EVO Plus, Crucial MX500 500GB, Kingston 480gb | Riotoro ENIGMA G2 850W 80 Gold | Corsair Carbide 300R modded | Win10 ENT LTSC IoT (work) + Win11 ENT LTSC IoT (gejming) | logitech g403 | ROCCAT Horde | AOC CQ27C4 + AOC C24G1 + 50" Hisense H50A6140 AMD Ryzen5 2600+Xilence Cryon M806D.B | Asus x370 Prime Pro rev1.03 (bios 6203) | GSkill Aegis 32GB (2x16) DDR4@3,2GHz | 2x Intel 545s 128GB, 1x Crucial MX500 500GB | Gigabyte GTX960 | sisa 620w | Fractal Design Focus G | Win7 x64 + Win10 ENT LTSC IoT | logitech g403 | ROCCAT SuoraFX intel i5 2500k@4,5ghz (1,28v)+FSP Windale 4 | ASRock Z68 Ext4 Gen3 (bios 1.20) | 2x8gb DDR3 HyperX Savage, 1866mhz, 10-10-11-27,1,5V | Samsung SSD 64gb, 2x256gb SSD | iGPU | corsair vx450w | CoolerMaster Centurion 534 modded | Win7 x64 |
#2408 | |
Je suis Schumi
Postovi: 1,524
#2410 |
Postovi: 5,798
Trazim mesenger aplikaciju, do sad sam koristio IMO, ali nedavno su dodali onaj broadcasting, izbacili podrsku za skype, uglavnom sjebali su aplikaciju. Jel ima neka jednostavna, brza, stabilna koja podržava vecinu messenger protokola? Isprobao par random sa marketa, nista ne valja ![]() |
#2411 | |
Fresh Juice
Postovi: 4,582
#2412 |
PRO
Postovi: 4,889
Zna li netko koji je ovo widget na ekranu? http://www.bug.hr/_cache/841ffc7a60d...rand=836789904 Je li concept ili?
#2413 |
Fresh Juice
Postovi: 4,582
UCCW vjerojatno |
#2414 |
PRO
Postovi: 4,889
hvala jopisu: https://play.google.com/store/apps/d...lime.ics.theme
#2415 | |
gadget freak
Lokacija: Jasenovac
Postovi: 2,224
#2417 |
PRO
Postovi: 4,889
Proba sam, na kraju ipak nije to to. Ovo sadržava theme pack, sa ikonama i wallpaperima, no nema widgeta. Ima još netko koju ideju? u međuvremenu idem pogledati UCCW
#2419 | |
gadget freak
Lokacija: Jasenovac
Postovi: 2,224
Nemam još rootan mob pa mi se ne da s tim zaj..... ![]()
#2420 |
Fresh Juice
Postovi: 4,582
UCCW je to, samo je skin custom. Pitaj na xda na temi za uccw skinove. |
#2421 |
Postovi: 34,079
CPU-Z stigao na Android https://play.google.com/store/apps/d...om.cpuid.cpu_z
#2422 |
Postovi: 52
Pozdrav. Imam problem, usnimio sam Whatsapp i sad su mi se pobrkali kontakti u samom imeniku mobitela, a i oni u samoj aplikaciji (pod jednim imenom vise brojeva, kontakt se vise puta pojavljuje i slicno) Uglavnom, pi.... neznam kaj da napravim. OS je Android 4.0.4 |
#2423 |
Postovi: 34,079
Ako se kontakt pojavljuje više puta, moraš izabrati otkuda će ih uzmiati - SIM, telefon ili Google. Samsung: Imenik - Menu tipka - Kontakti za prikaz (moraš skrolati dole jer ne prikaže sve stavke)
#2424 |
Postovi: 4,398
Postoji li negdje lista programa koji se međusobno kolju? Tako nešto se događa na PC-u pa je logično da se događa i na Androidu. Razmišljao sam malo i vidim da se ljudi sa dual core CPU-ovima, 512 MB i više RAM-a žale na štekanje itd pa sam pretpostavio da se neke aplikacije kolju. Npr. novi LG L3 koji je hardverski prilično sličan Samsung galaxy mini 5570i radi neusporedivo brže. Ne znam je li to do toga jer je mob novi ili nešto drugo. Zauzeće RAM-a na oba mobitela je slično, a razlika u brzini drastična... |
#2425 |
Nemaš klanja. Jedino što može usporavati rad je ako imaš "tonu" aplikacija koje rade istu stvar i to rade paralelno. A na PC-u isto se skoro pa nikad ništa "ne kolje". |
#2429 |
Omicron Alpha resident
Lokacija: Bistra
Postovi: 5,117
Google je opcenito maknuo te adblock aplikacije tako da moras skinuti negdje izvan G. Playa. Ak zelis mogu ti poslati verziju koju sam ja skinuo i koja radi ![]()
#2430 | |
MIUI HR Translator
Lokacija: Krapina
Postovi: 632
http://lucky-patcher.netbew.com/
MIUI HR Translator |
